'omap4_clock_fixes_3.1rc', 'missing_2430_musb_adds_terminator_fix_3.1rc' and 'pwrdm_clkdm_fixes_3.1rc' into prcm-fixes-a-3.1rc
Fix the following compile warning:
arch/arm/mach-omap2/clock44xx_data.c: In function 'omap4xxx_clk_init':
arch/arm/mach-omap2/clock44xx_data.c:3371:6: warning: 'cpu_clkflg' may be used uninitialized in this function
The approach taken here is intended to work if omap4xxx_clk_init() is
converted into an initcall.
Thanks to Bjarne Steinsbo <bsteinsbo@gmail.com> for proposing another
approach.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Bjarne Steinsbo <bsteinsbo@gmail.com>
After commit 665d001338b494d6d62810aa99b4c0fa1a0884b9 ("OMAP2+: hwmod:
Follow the recommended PRCM module enable sequence"), device drivers
for OMAP IP blocks that do not use runtime PM can cause oopses or
kernel instability[1][2].
This is because those non-runtime PM drivers do not use the hwmod
code, which implements the correct IP block enable and disable
sequence.
Several options for dealing with this problem have been proposed:
1. Add a new field to the OMAP struct clk to mark clocks that are
currently used by non-runtime PM drivers. Modify the clock code to
use the old clockdomain sequence for these marked clocks. As
drivers are converted to use runtime PM, remove the annotation from
the clocks.
2. Similar to #1, but associate the flag with the struct omap_clk
instead.
3. Add IDLEST wait support to the OMAP4 clock code, similar to the way
it is implemented for OMAP2/3, and enable it in each struct clk
currently used by non-runtime PM drivers. As drivers are converted
to use runtime PM, remove the annotation from the clocks.
4. Do nothing; leave the problem to those responsible for the
unconverted drivers.
5. Re-enable clock-based clockdomain control in the OMAP4 clock code.
This would revert back to the behavior of Linux 3.0, simply with a
slightly longer module enable/disable latency.
Unfortunately, no approach seemed particularly good. Options 1
through 3 seemed unwise due to the following reasons:
A. The OMAP struct clks are intended primarily to describe hardware
clock nodes, and the intention is that no driver-specific data
should be stored there (applies to #1)
B. The resulting patch would have been quite large for the -rc series
(applies to #1, #2, #3)
C. The patch would have been a new, yet temporary hack; and similar fixes
have drawn negative comments in the recent past (see for example [3])
Option 4 is undesirable because commit
665d001338b494d6d62810aa99b4c0fa1a0884b9 ("OMAP2+: hwmod: Follow the
recommended PRCM module enable sequence") has resulted in a less
stable kernel; and kernel stability is more important than OMAP4 power
management.
Option 5 is the approach taken in this patch. This seemed to be the
least intrusive approach for 3.1-rc.
The approach in this patch was originally proposed by Ohad Ben-Cohen
<ohad@wizery.com>. I'm simply writing the commit message and passing
it along.
Thanks to Luciano Coelho <coelho@ti.com> for reporting the problem.
Thanks to Ohad Ben-Cohen <ohad@wizery.com> for tracking the problem
down, generating a temporary workaround, and proposing a patch to deal
with the problem. Thanks to Rajendra Nayak <rnayak@ti.com> for
proposing another patch to deal with the problem. Thanks to Felipe
Balbi <balbi@ti.com> for comments.
1. Coelho, Luciano <coelho@ti.com>. _Re: Oops on ehci_hcd when
booting 3.0.0-rc2 on panda_. Tue, 09 Aug 2011 14:26:08 +0300.
Posted to the <linux-omap@vger.kernel.org> mailing list. Available
from (among others)
http://www.spinics.net/linux/lists/linux-omap/msg55213.html
2. Munegowda, Keshava <keshava_mgowda@ti.com>. _Re: Oops on ehci_hcd
when booting 3.0.0-rc2 on panda_. Thu, 11 Aug 2011 13:51:05 +0530.
from (among others)
http://www.spinics.net/linux/lists/linux-omap/msg55371.html
3. King, Russell <linux@arm.linux.org.uk>. _Re: [PATCH 5/8] OMAP4:
PM: TEMP: Prevent l3init from idling/force sleep_. Thu, 23 Jun
2011 16:22:49 +0100. Posted to the <linux-omap@vger.kernel.org>
mailing list. Available from (among others)
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg51392.html
Cc: Luciano Coelho <coelho@ti.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Cc: Benoît Cousson <b-cousson@ti.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (47 commits)
OMAP: Add debugfs node to show the summary of all clocks
OMAP2+: hwmod: Follow the recommended PRCM module enable sequence
OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code
OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming
OMAP2+: PM: idle clkdms only if already in idle
OMAP2+: clockdomain: add clkdm_in_hwsup()
OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework
OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition()
OMAP4: hwmod: Introduce the module control in hwmod control
OMAP4: cm: Add two new APIs for modulemode control
OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure
OMAP4: hwmod data: Add PRM context register offset
OMAP4: prm: Remove deprecated functions
OMAP4: prm: Replace warm reset API with the offset based version
OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros
OMAP: hwmod: Wait the idle status to be disabled
OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros
OMAP2+: hwmod: Init clkdm field at boot time
OMAP4: hwmod data: Add clock domain attribute
OMAP4: clock data: Add missing divider selection for auxclks
* 'next/fixes2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (24 commits)
ASoC: omap: McBSP: fix build breakage on OMAP1
OMAP: hwmod: fix the i2c-reset timeout during bootup
I2C: OMAP2+: add correct functionality flags to all omap2plus i2c dev_attr
I2C: OMAP2+: Tag all OMAP2+ hwmod defintions with I2C IP revision
I2C: OMAP1/OMAP2+: create omap I2C functionality flags for each cpu_... test
I2C: OMAP2+: Introduce I2C IP versioning constants
I2C: OMAP2+: increase omap_i2c_dev_attr flags from u8 to u32
I2C: OMAP2+: Set hwmod flags to only allow 16-bit accesses to i2c
OMAP4: hwmod data: Change DSS main_clk scheme
OMAP4: powerdomain data: Remove unsupported MPU powerdomain state
OMAP4: clock data: Keep GPMC clocks always enabled and hardware managed
OMAP4: powerdomain data: Fix core mem states and missing cefuse flag
OMAP2+: PM: Initialise sleep_switch to a non-valid value
OMAP4: hwmod data: Modify DSS opt clocks
OMAP4: iommu: fix clock name
omap: iovmm: s/sg_dma_len(sg)/sg->length/
omap: iommu: fix pte programming
arm: omap3: cm-t35: fix slow path warning
arm: omap3: cm-t35: minor comments fixes
omap: ZOOM: QUART: Request reset GPIO
* 'next/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
MAINTAINERS: add maintainer of CSR SiRFprimaII machine
ARM: CSR: initializing L2 cache
ARM: CSR: mapping early DEBUG_LL uart
ARM: CSR: Adding CSR SiRFprimaII board support
OMAP4: clocks: Update the clock tree with 4460 clock nodes
OMAP4: PRCM: OMAP4460 specific PRM and CM register bitshifts
OMAP4: ID: add omap_has_feature for max freq supported
OMAP: ID: introduce chip detection for OMAP4460
ARM: Xilinx: merge board file into main platform code
ARM: Xilinx: Adding Xilinx board support
Fix up conflicts in arch/arm/mach-omap2/cm-regbits-44xx.h
'omap4_clock_auxclk_3.1' and 'omap_device_a_3.1' into prcm-devel-3.1
On OMAP4, the PRCM recommended sequence for enabling
a module after power-on-reset is:
-1- Force clkdm to SW_WKUP
-2- Enabling the clocks
-3- Configure desired module mode to "enable" or "auto"
-4- Wait for the desired module idle status to be FUNC
-5- Program clkdm in HW_AUTO(if supported)
This sequence applies to all older OMAPs' as well,
however since they use autodeps, it makes sure that
no clkdm is in IDLE, and hence not requiring a force
SW_WKUP when a module is being enabled.
OMAP4 does not need to support autodeps, because
of the dyanamic dependency feature, wherein
the HW takes care of waking up a clockdomain from
idle and hence the module, whenever an interconnect
access happens to the given module.
Implementing the sequence for OMAP4 requires
the clockdomain handling that is currently done in
clock framework to be done as part of hwmod framework
since the step -4- above to "Wait for the desired
module idle status to be FUNC" is done as part of
hwmod framework.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
[b-cousson@ti.com: Adapt it to the new clkdm hwmod attribute and API]
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
[paul@pwsan.com: dropped mach-omap2/clock.c changes; modified to only
call the clockdomain code if oh->clkdm is set; disable clock->clockdomain
interaction on OMAP4]
On OMAP4 the auxclk nodes (part of SCRM) support both
divider as well as parent selection.
Supporting this requires splitting the existing nodes
(which support only parent selection) into two nodes,
one for parent and another for divider selection.
The nodes for parent selection are named auxclk*_src_ck
and the ones for divider selection as auxclk*_ck.
[b-cousson@ti.com: Rebase on top of clock cleanup
and autogen alignement]
Extend the existing function to create clkdev for every optional
clocks to add a well one "fck" alias for the main_clk of the
omap_hwmod.
It will allow to remove these static clkdev entries from the
clockXXX_data.c file.
Cc: Kevin Hilman <khilman@ti.com>
Cc: Todd Poynor <toddpoynor@google.com>
[paul@pwsan.com: remove all of the "fck" role clkdev aliases from the
clock data files; fixed error message]
'hwmod_dss_fix_3.1' and 'i2c_fixes_3.1' into prcm-fixes-3.1
On OMAP4, CPU accesses on unmapped addresses are redirected to GPMC by
L3 interconnect. Because of CPU speculative nature, such accesses are
possible which can lead to indirect access to GPMC and if it's clock is
not running, it can result in hang/abort on the platform.
Above makes access to GPMC unpredictable during the execution, so it's
module mode needs to be kept under hardware control instead of software
control.
Since the auto gating is supported for GPMC, there isn't any power impact
because of this change.
The issue was un-covered with security middleware running along with HLOS.
In this case GPMC had a valid MMU descriptor on secure side where as HLOS
didn't map the GMPC because it isn't being used.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
[b-cousson@ti.com: Update subject and fix typos in the changelog]
Add missing DSS optional clocks to HWMOD data for OMAP4xxx.
Add HWMOD_CONTROL_OPT_CLKS_IN_RESET flag for dispc to fix dispc reset.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
[b-cousson@ti.com: Remove a comment and update the subject]
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
[paul@pwsan.com: removed DSS "fck" role and some clkdev aliases at Tomi's
request]
UNIPRO was removed from OMAP4 devices from ES2.0 onwards.
Since this IP was anyway non-functional and not supported,
it is best to remove it completely.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
[b-cousson@ti.com: Update the changelog]
[paul@pwsan.com: split PRCM header file changes into a separate patch]
McASP2, 3 and MMC6 modules are not present in the OMAP4 family.
Remove the fclk and the clksel related to these nodes.
Rename the references that were potentially re-used in order nodes.
Remove related macros in prcm header files.
Update TI copyright date.
[b-cousson@ti.com: Update the patch according to autogen output]
[paul@pwsan.com: split PRCM data changes into a separate patch]
The DPLL USB can generate higher speed (x2) than the regular ones.
The max multiplication value is then twice the previous value.
Fix both max_mult and max_div with that correct values.
Change the max_div variable type to u16 to allow storing up to 256.
Replace as well the define with the value to avoid
unneeded indirection and provide a better readability.
Remove the defines that become useless.
A couple of fieds were edited manually and thus do not stick
to the template used by the generator and by other structures.
Move them to the correct location.
[paul@pwsan.com: dropped the UNIPRO changes since those will be removed
in a later patch]
usb_host_fs_fck does have a clkdev mapping with "usbhs-omap.0"
and "fs_fck" alias used by the driver.
The entry with NULL dev is thus not needed anymore.
Cc: Felipe Balbi <balbi@ti.com>
The USB DPLL is a J-Type DPLL with the sddiv extra parameter. Add it
in USB DPLL.
[paul@pwsan.com: dropped UNIPRO change since it is removed in a later patch]
Add the new clock nodes (bandgap_ts_fclk, div_ts_ck) for omap4460.
Handle these nodes using the clock flags (CK_*).
Signed-off-by: Nishanth Menon <nm@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
Acked-by: Paul Walmsley <paul@pwsan.com>
DSS driver has used fck and ick clocks on OMAP2/3 to get DSS HW up and
running, and also to get the pixel clock's source clock rate from the
fck.
On OMAP4 the clock data is set up in a different way, as there's no ick,
dss_fck points to a fake clock which just affects DSS's MODULEMODE, and
dss_dss_clk if the DSS_FCK.
>From DSS driver's point of view the dss_fck sounds like an ick, and
dss_dss_clk is the fck. While this is not entirely correct from HW point
of view, especially for the ick, configuring the clock aliases that way
makes DSS "just work" with OMAP4's clock setup.
In the (hopefully near) future DSS driver will be reworked to use
pm_runtime support which should clean up the clock code.
arch/arm/mach-omap2/board-overo.c
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits)
omap: zoom: host should not pull up wl1271's irq line
arm: plat-omap: iommu: fix request_mem_region() error path
OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430
omap4: mux: Remove duplicate mux modes
omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag
omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set
omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected
omap4: board-omap4panda: Initialise the serial pads
omap3: board-3430sdp: Initialise the serial pads
omap4: board-4430sdp: Initialise the serial pads
omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init
omap2+: mux: Remove the use of IDLE flag
omap2+: Add separate list for dynamic pads to mux
perf: add OMAP support for the new power events
OMAP4: Add IVA OPP enteries.
OMAP4: Update Voltage Rail Values for MPU, IVA and CORE
OMAP4: Enable 800 MHz and 1 GHz MPU-OPP
OMAP3+: OPP: Replace voltage values with Macros
OMAP3: wdtimer: Fix CORE idle transition
Watchdog: omap_wdt: add fine grain runtime-pm
Fix up various conflicts in
- arch/arm/mach-omap2/board-omap3evm.c
- arch/arm/mach-omap2/clock3xxx_data.c
- arch/arm/mach-omap2/usb-musb.c
- arch/arm/plat-omap/include/plat/usb.h
- drivers/usb/musb/musb_core.h
DSS code uses ick as one of the clocks in clk_get/clk_put. OMAP4 clock database
doesn't have ick for DSS, so adding ick as dummy clock.
This is needed for backward compatibility with OMAP2/3.
Once pm_runtime* APIs get introduced in DSS, this will be revisited.
Signed-off-by: Sumit Semwal <sumit.semwal@ti.com>
Currently, clock database has <dev, clock-name> tuples for DSS2. Because of
this, the clock names are different across different OMAP platforms.
This patch aligns the DSS2 clock names and roles across OMAP 2420, 2430, 3xxx,
44xx platforms in the clock databases, hwmod databases for opt-clocks, and DSS
clock handling.
This ensures that clk_get/put/enable/disable APIs in DSS can use uniform role
names.
'remotes/origin/pwrdm_add_can_lose_context_fns_2.6.39', 'remotes/origin/omap_device_a_2.6.39', 'remotes/origin/mmc_a_2.6.39', 'remotes/origin/hwmod_b_2.6.39', 'remotes/origin/dmtimer_a_2.6.39', 'remotes/origin/pwrdm_clkdm_a_2.6.39', 'remotes/origin/clkdm_statdep_omap4_2.6.39', 'remotes/origin/clk_a_2.6.39', 'remotes/origin/clk_autoidle_a_2.6.39', 'remotes/origin/clk_autoidle_b_2.6.39', 'remotes/origin/clk_b_2.6.39', 'remotes/origin/clk_clkdm_a_2.6.39', 'remotes/origin/misc_a_2.6.39', 'remotes/origin/for_2.6.39/omap3_hwmod_data' and 'remotes/origin/wdtimer_a_2.6.39' into tmp-integration-2.6.39-20110310-024
Modifying the device & driver name from "mmci-omap-hs" to
"omap_hsmmc".
Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com>
Acked-by: Benoit Cousson<b-cousson@ti.com>
The devices of clocks are set to usbhs, so that
only usbhs common driver can invoke these clocks.
The dummy per port clocks are added to omap3
clock data base. This helps to invoke common
clock get APIs for omap3 and omap4.
Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Disable autoidle on all clocks during clock framework initialization.
(If CONFIG_PM is set, autoidle is re-enabled for all clocks later in
the boot process.)
The principle behind this patch, and some similar patches, is that the
kernel should start with all power management features disabled.
Later in the boot process, the PM code, if compiled in with CONFIG_PM,
enables or re-enables power management features.
Tested-by: Rajendra Nayak <rnayak@ti.com>
Enable hardware gate control for all dpll MX and X2 postdividers.
This requires the allow_idle/deny_idle functions to be
populated for all clock nodes (mx/x2 post dividers) in
clkops.
All OMAP3/4 dpll's support hardware level autogating.
Populate allow_idle/deny_idle function pointers for all
DPLL's in clkops.
A few headers are included twice, remove them.
Found the following errors using make includecheck:
arch/arm/mach-omap2/clock44xx_data.c: prm44xx.h is
included more than once.
arch/arm/mach-omap2/clockdomains44xx_data.c: cm1_44xx.h
is included more than once.
arch/arm/mach-omap2/clockdomains44xx_data.c: cm2_44xx.h
arch/arm/mach-omap2/powerdomain2xxx_3xxx.c: prm-regbits-34xx.h
Cc: Tony Lindgren <tony@atomide.com>
[paul@pwsan.com: dropped lists from patch cc:s; tweaked subject line]
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (144 commits)
USB: add support for Dream Cheeky DL100B Webmail Notifier (1d34:0004)
USB: serial: ftdi_sio: add support for TIOCSERGETLSR
USB: ehci-mxc: Setup portsc register prior to accessing OTG viewport
USB: atmel_usba_udc: fix freeing irq in usba_udc_remove()
usb: ehci-omap: fix tll channel enable mask
usb: ohci-omap3: fix trivial typo
USB: gadget: ci13xxx: don't assume that PAGE_SIZE is 4096
USB: gadget: ci13xxx: fix complete() callback for no_interrupt rq's
USB: gadget: update ci13xxx to work with g_ether
USB: gadgets: ci13xxx: fix probing of compiled-in gadget drivers
Revert "USB: musb: pm: don't rely fully on clock support"
Revert "USB: musb: blackfin: pm: make it work"
USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path
USB: uas: Ensure we only bind to a UAS interface
USB: uas: Rename sense pipe and sense urb to status pipe and status urb
USB: uas: Use kzalloc instead of kmalloc
USB: uas: Fix up the Sense IU
usb: musb: core: kill unneeded #include's
DA8xx: assign name to MUSB IRQ resource
usb: gadget: g_ncm added
Manually fix up trivial conflicts in USB Kconfig changes in:
arch/arm/mach-omap2/Kconfig
arch/sh/Kconfig
drivers/usb/Kconfig
drivers/usb/host/ehci-hcd.c
and annoying chip clock data conflicts in:
The following OMAP4 clocks have the following fixed divisors that
determine the frequency at which these clocks operate. These
dividers are defined by the PRCM specification and without these
dividers the rates of the below clocks are calculated incorrectly.
This may cause internal peripherals using these clocks to operate
at the wrong frequency.
- abe_24m_fclk (freq = divided-by-8)
- ddrphy_ck (freq = parent divided-by-2)
- dll_clk_div_ck (freq = parent divided-by-2)
- per_hs_clk_div_ck (freq = parent divided-by-2)
- usb_hs_clk_div_ck (freq = parent divided-by-3)
- func_12m_fclk (freq = parent divided-by-16)
- func_24m_clk (freq = parent divided-by-4)
- func_24mc_fclk (freq = parent divided-by-8)
- func_48mc_fclk (freq = divided-by-4)
- lp_clk_div_ck (freq = divided-by-16)
- per_abe_24m_fclk (freq = divided-by-4)
Cc: Kevin Hilman <khilman@deeprootsystems.com>
L3INSTR clock domain is read only register and its reset value is
HW_AUTO. The modules withing this clock domain needs to be kept under
hardware control.
MODULEMODE:
- 0x0: Module is disable by software. Any INTRCONN access to module
results in an error, except if resulting from a module wakeup
(asynchronous wakeup).
- 0x1: Module is managed automatically by hardware according to
clock domain transition. A clock domain sleep transition put
module into idle. A wakeup domain transition put it back
into function. If CLKTRCTRL=3, any INTRCONN access to module
is always granted. Module clocks may be gated according to
the clock domain state.
This patch keeps CM_L3INSTR_L3_3_CLKCTRL, CM_L3INSTR_L3_INSTR_CLKCTRL
and CM_L3INSTR_INTRCONN_WP1_CLKCTRL module mode under hardware control
by using ENABLE_ON_INIT flag.
Without this the OMAP4 device OFF mode SAR restore phase aborts during
interconnect register restore phase. This can be also handled by doing
explicit a clock enable and disable in the low power code since there
is no direct module associated with it. But that seems not necessary
since the clock domain is under HW control.
Acked-by: Benoit Cousson <b-cousson@ti.com>
In omap4, there is no explicit configuration register to enable mailbox clocks.
Defining dummy clock for mailbox clock module to keep the mailbox driver
backward compatible with previous omaps.
Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com>
Acked-by: Benoît Cousson <b-cousson@ti.com>
J-Type DPLLs have additional configuration parameters that need to
be programmed when setting the multipler and divider for the DPLL.
These parameters being the sigma delta divider (SD_DIV) for the DPLL
and the digital controlled oscillator (DCO) to be used by the DPLL.
The current code is implemented specifically to configure the
OMAP3630 PER J-Type DPLL. The OMAP4430 USB DPLL is also a J-Type DPLL
and so this code needs to be updated to work for both OMAP3 and OMAP4
devices and any other future devices that have J-TYPE DPLLs.
For the OMAP3630 PER DPLL both the SD_DIV and DCO paramenters are
used but for the OMAP4430 USB DPLL only the SD_DIV field is used.
The current implementation will only program the SD_DIV and DCO
fields if the DPLL has both and hence this does not work for
OMAP4430.
In order to make the code more generic add two new fields to the
dpll_data structure for the SD_DIV field and DCO field bit-masks
and only program these fields if the masks are defined for a specific
DPLL. This simplifies the code and allows us to remove the flag
DPLL_NO_DCO_SEL.
Tested on OMAP36xx Zoom3 and OMAP4 Blaze.
[paul@pwsan.com: removed explicit inlining and added '_' prefix on lookup_*()
functions; added testing info to commit message; added 35xx comments back in]
Fix opt clocks name in clock framework and hwmod.
Add the missing iclk in the ocp_if structure.
Add the HWMOD_CONTROL_OPT_CLKS_IN_RESET flag to ensure
the the GPIO optional clock is enable during reset.
Tested-by: Charulatha V <charu@ti.com>
The CORE and PER M3 post dividers are different from the rest of the
DPLL post dividers as in they go to SCRM, and are used
there to export clocks for instance used by external sensor.
There is no automatic HW dependency in PRCM to manage them. Hence these
two clocks (dpll post dividers) should be managed by SW and explicitly
enabled/disabled.
Add control in clock framework to handle that.
Add support for auxiliary clocks nodes which are part of SCRM.
Add register address, mask and link to the clksel structure that
were missing in the IVA DPLL mux clock node.
Signed-off-by: Jonathan Bergsagel <jbergsagel@ti.com>
This patch extends the OMAP4 clock data to include
various x2 clock nodes between DPLL and HS dividers as the
clock framework skips a x2 while calculating the dpll locked
frequency.
The clock database extensions are autogenerated using
the scripts maintained by Benoit Cousson.
Signed-off-by: Thara Gopinath <thara@ti.com>
[paul@pwsan.com: fixed merge conflicts against v2.6.37-rc5; dropped
dpll_mpu_x2_ck on advice from Benoît]
The gating of pad_clks and slimbus_ck is controlled by the PRCM, but
since the clock source is external, this is the SW responsability
to gate / un-gate it when the mcpdm or slimbus module need to be used.
There is no autogating possible with such external clock.
Add SW control to enable / disable this SW gating in the pad_clks_ck
and slimbus_clk clock node.
Signed-off-by: Sebastien Guiriec <s-guiriec@ti.com>
In preparation for adding OMAP4-specific PRCM accessor/mutator
functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific
files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been
moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was
OMAP2xxx/3xxx-specific.
This process also requires the #includes in each of these files to be
changed to reference the new file name. As part of doing so, add some
comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use
"sideways includes", to indicate that these users of the PRM/CM includes
should not be doing so.
Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this
patch.
Cc: Jarkko Nikula <jhnikula@gmail.com>
Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Acked-by: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Split the existing cm44xx.h file into cm1_44xx.h and cm2_44xx.h files
so they match their underlying OMAP hardware modules. Add clockdomain
offset information.
Add header files for the MPU local PRCM, prcm_mpu44xx.h, and for the
SCRM, scrm44xx.h. SCRM register offsets still need to be added; TI
should do this.
Move the "_MOD" macros out of the prcm-common.h header file, into the
header file of the hardware module that they belong to. For example,
OMAP4430_PRM_*_MOD macros have been moved into the prm44xx.h header.
Adjust #includes of all files that used the old PRCM header file names
to point to the new filenames.
The autogeneration scripts have been updated accordingly.
The convention for omap device naming is omap_XXX.
Rename the device and driver name in order to stick
to this naming convention.
Change device name in clock nodes as well.
Cc: Ben Dooks <ben-i2c@fluff.org>
Acked-by: Ben Dooks <ben-linux@fluff.org>
musb core doesn't need to know about platform
specific details. So start moving clock
handling to platform glue layer and make
musb core agnostic about that.
change all ocurrences of musb_hdrc to musb-hdrc.
We will call glue layer drivers musb-<glue layer>,
so in order to keep things somewhat standard, let's
change the underscore into a dash.
Add clkdev aliases for the USBHOST and USBTLL clocks on OMAP3 and
OMAP4, so that the driver can refer to the clocks using a common alias.
This will disappear when the driver is converted to use the hwmod
database, but until then this patch is needed.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Only OMAP2+ platforms have the System Control Module (SCM) IP block.
In the past, we've kept the SCM header file in plat-omap. This has
led to abuse - device drivers including it; includes being added that
create implicit dependencies on OMAP2+ builds; etc.
In response, move the SCM headers into mach-omap2/.
As part of this, remove the direct SCM access from the OMAP UDC
driver. It was clearly broken. The UDC code needs an indepth review for
use on OMAP2+ chips.
Cc: Cory Maccarrone <darkstar6262@gmail.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
