This new function can be used to get the physical address of a
clockdomain. Required for mapping the clkctrl clocks under hwmod
without modification to DT data.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
The previous implementation was racy in many locations, where the current
status of the clockdomain was read out, some operations were executed,
and the previous status info was used afterwards to decide next state
for the clockdomain. Instead, fix the implementation of the allow_idle /
deny_idle APIs to properly have usecounting support. This allows clean
handling internally within the clockdomain core, and simplifies the
usage also within hwmod.
spinlock-protected shorts/ints
The atomic usecounts seem to be confusing, and are no longer needed
since the operations that they are attached to really should take
place under lock. Replace the atomic counters with simple integers,
protected by the enclosing powerdomain spinlock.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Split the clkdm_(add|del)_(wk|sleep)dep() functions into lockless and
locking versions -- this will be needed in a subsequent patch. Also,
while here, remove the leading underscore, since these are not
currently static functions. And for functions that have
kerneldoc-style comment blocks, but which are missing the initial
'/**' tag, fix the tag to indicate that they are kerneldoc.
Add a per-powerdomain spinlock. Use that instead of the clockdomain
spinlock. Add pwrdm_lock()/pwrdm_unlock() functions to allow other
code to acquire or release the powerdomain spinlock without reaching
directly into the struct powerdomain.
Cc: Jean Pihet <jean.pihet@newoldbits.com>
In clkdm_sleep(), the powerdomain should be eligible to switch power
states right after the call to the low-level clockdomain sleep
function. We should have been tracking that with the
pwrdm_state_switch() code, but we weren't, for whatever reason. Fix that.
This resolves the "pwrdm state mismatch(cam_pwrdm) 3 != 0" that appears
during the OMAP4460 Pandaboard-ES PM test, e.g. here:
http://www.pwsan.com/omap/testlogs/test_v3.8-rc5/20130126003323/pm/4460pandaes/4460pandaes_log.txt
Cc: Tero Kristo <t-kristo@ti.com>
Commit d043d87 (ARM: OMAP2+: clockdomain: bypass clockdomain handling
when disabling unused clks) skips the decrementing of a clock-domains
use count if the clocks use count is zero. However, for OMAP4 devices
this is causing the EMU clock-domain to be stuck ON as the use count is
not getting decremented correctly.
The scenario that leads to this problem is described below ...
omap_hwmod_setup_all
--> _setup
--> clkdm_hwmod_enable
--> EMU clock domain usecount = 1
--> _enable_clocks
--> clk_enable
--> trace_clk_div_div usecount = 1
--> EMU clock domain usecount = 2
--> _idle
--> _disable_clocks
--> clk_disable
--> trace_clk_div_div usecount = 0
--> clkdm_hwmod_disable
--> skips decrement of EMU clock domain usecount
because trace_clk_div_div is 0!
Hence, due to the order that a clocks use count is decremented and the
clock domain is disabled, it is possible that the clock domain can have
a non-zero use count when the actual clock has a use count of 0.
Therefore, we should only bypass the clock-domain handling when both the
clock-domain and clock in the clock-domain have a use count of 0 and
warn when the clock-domain has a zero use count and the clock has a
non-zero use count.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
[paul@pwsan.com: fixed checkpatch warning]
Clean all #ifdef's added to common clock code. This code is no longer
needed due to migration to the common clock framework.
Signed-off-by: Mike Turquette <mturquette@ti.com>
[paul@pwsan.com: clean up new ifdefs added in clockdomain.c]
The OMAP port to the common clk framework[1] resulted in spurious WARNs
while disable unused clocks. This is due to _clkdm_clk_hwmod_disable
catching clkdm->usecount's with a value of zero. Even less desirable it
would not allow the clkdm_clk_disable function pointer to get called due
to an early return of -ERANGE.
This patch adds a check for such a corner case by skipping the WARN and
early return in the event that clkdm->usecount and clk->enable_usecount
are both zero. Presumably this could only happen during the check for
unused clocks at boot-time.
[1] http://article.gmane.org/gmane.linux.ports.arm.omap/88824
[paul@pwsan.com: split the hwmod and clock disable cases; modified the
code to skip the clockdomain handling during the disable-unused-clocks phase;
added COMMON_CLK ifdef; removed include of clk-private.h at Mike's request]
omap-for-v3.8/cleanup-headers-serial-take2
This is the first set of omap cleanup patches for v3.8 merge
window to remove most of the remaining plat includes to get us
closer to ARM common zImage support.
To avoid a huge amount of trivial merge conflicts with includes,
this branch is based on several small topic branches coordinated
with the driver subsystem maintainers. These branches are based on
v3.7-rc1 and can also be merged into the related driver subsystem
branches as needed:
omap-for-v3.8/cleanup-headers-prepare few trivial driver changes
omap-for-v3.8/cleanup-headers-dma move of the DMA header
omap-for-v3.8/cleanup-headers-gpmc GPMC and MTD changes
omap-for-v3.8/cleanup-headers-mmc MMC related changes
omap-for-v3.8/cleanup-headers-dss DSS related changes
omap-for-v3.8/cleanup-headers-asoc ASoC related changes
Note that for the dma-omap.h, it was decided that it should be
is completed. For the related discussion, please see:
https://patchwork.kernel.org/patch/1519591/#
After these patches we still have a few plat headers remaining
that will be handled in later pull requests.
We want to remove plat/cpu.h. To do this, let's first split
it to private soc.h to mach-omap1 and mach-omap2. We have to
keep plat/cpu.h around until the remaining drivers are fixed,
so let's include the local soc.h in plat/cpu.h and for drivers
still including plat/cpu.h.
Once the drivers are fixed not to include plat/cpu.h, we
can remove the file.
This is needed for the ARM common zImage support.
[tony@atomide.com: updated to not print a warning]
Remove arch/arm/plat-omap/include/plat/clock.h by merging it into
arch/arm/mach-omap1/clock.h and arch/arm/mach-omap2/clock.h.
The goal here is to facilitate ARM single image kernels by removing
includes via the "plat/" symlink.
[tony@atomide.com: fixed to remove duplicate clock.h includes]
Previously the code only acquired spinlock after increasing / decreasing
the usecount value, which is wrong. This leaves a small window where
a task switch may occur between the check of the usecount and the actual
wakeup / sleep of the domain. Fixed by moving the spinlock locking before
the usecount access. Left the usecount as atomic_t if someone wants an
easy access to the parameter through atomic_read.
Acked-by: Paul Walmsley <paul@pwsan.com>
The idle status of the IP blocks and clocks inside the EMU clockdomain
isn't taken into account by the PRCM hardware when deciding whether
the clockdomain is idle. Add a workaround flag in the clockdomain
code, CLKDM_MISSING_IDLE_REPORTING, to deal with this problem, and add
the code necessary to support it.
If CLKDM_MISSING_IDLE_REPORTING is set on a clockdomain, the
clockdomain will be forced active whenever an IP block inside that
clockdomain is in use, even if the clockdomain supports
hardware-supervised idle. When the kernel indicates that the last
active IP block inside the clockdomain is no longer used, the
clockdomain will be forced idle, or, if that mode is not supported in
the hardware, it will be placed into hardware-supervised idle.
This patch is an equal collaboration with Jon Hunter
<jon-hunter@ti.com>. Ming Lei <ming.lei@canonical.com>, Will Deacon
<will.deacon@arm.com>, Madhav Vij <mvij@ti.com>, Kevin Hilman
<khilman@ti.com>, Benoît Cousson <b-cousson@ti.com>, and Santosh
Shilimkar <santosh.shilimkar@ti.com> all made essential contributions
to the understanding of EMU clockdomain power management on OMAP.
Cc: Jon Hunter <jon-hunter@ti.com>
Cc: Ming Lei <ming.lei@canonical.com>
Cc: Madhav Vij <mvij@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: Benoît Cousson <b-cousson@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Jon Hunter <jon-hunter@ti.com>
Find and unwrap wrapped strings in the style:
pr_debug("clockdomain: hardware cannot set/clear wake up of "
"%s when %s wakes up\n", clkdm1->name, clkdm2->name);
Keeping these strings contiguous seems to be the current Linux kernel
policy.
The offending lines were found with the following command:
pcregrep -rnM '"\s*$\s*"' arch/arm/*omap*
While here, some messages have been clarified, some pr_warning(
... calls have been converted to pr_warn( ..., and some printk(KERN_*
... have been converted to pr_*.
With patch 'ARM: OMAP2+: powerdomain: Wait for powerdomain transition
in pwrdm_state_switch()', the pwrdm_clkdm_state_switch() API becomes
duplicate of pwrdm_state_switch().
Get rid off duplicate pwrdm_clkdm_state_switch() and update the
users of it with pwrdm_state_switch()
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
To fix things like this:
arch/arm/mach-omap2/usb-tusb6010.c:58: error: implicit declaration of function 'memset'
arch/arm/kernel/leds.c:40: error: implicit declaration of function 'strcspn'
arch/arm/kernel/leds.c:40: warning: incompatible implicit declaration of built-in function 'strcspn'
arch/arm/kernel/leds.c:45: error: implicit declaration of function 'strncmp'
arch/arm/kernel/leds.c:55: error: implicit declaration of function 'strlen'
arch/arm/kernel/leds.c:55: warning: incompatible implicit declaration of built-in function 'strlen'
arch/arm/mach-omap2/clockdomain.c:52: error: implicit declaration of function 'strcmp'
At Tony's request, remove the omap_chip bitmasks from the clockdomain
and clockdomain dependency definitions. Instead, initialize
clockdomains based on one or more lists that are applicable to a
particular SoC family, variant, and silicon revision.
Tony Lindgren <tony@atomide.com> found a bug in a previous version of this
patch - thanks Tony.
Cc: Tony Lindgren <tony@atomide.com>
In preparation for OMAP_CHIP() removal, split clkdm_init() into four
functions. This allows some of them to be called multiple times: for
example, clkdm_register_clkdms() can be called once to register
clockdomains that are common to a group of SoCs, and once to register
clockdomains that are specific to a single SoC.
The appropriate order to call these functions - which is enforced
by the code - is:
1. clkdm_register_platform_funcs()
2. clkdm_register_clkdms() (can be called multiple times)
3. clkdm_register_autodeps() (optional; deprecated)
4. clkdm_complete_init()
Convert the OMAP2, 3, and 4 clockdomain init code to use these new
functions.
While here, improve documentation, and increase CodingStyle
conformance by shortening some local variable names.
force wakeup
While using clockdomain force wakeup method, not waiting for powerdomain
to be effectively ON may end up locking the clockdomain FSM until a
next wakeup event occurs.
One such issue was seen on OMAP4430, where L4_PER was periodically
getting stuck in in-transition state when transitioning from from OSWR to ON.
This issue was reported and investigated by Patrick Titiano <p-titiano@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Reported-by: Patrick Titiano <p-titiano@ti.com>
Cc: Benoit Cousson <b-cousson@ti.com>
[paul@pwsan.com: updated to apply; added transition wait on clkdm_deny_idle();
remove two superfluous pwrdm_wait_transition() calls]
Since the clkdm state programming is now done from within the hwmod
framework (which uses a per-hwmod lock) instead of the being done
from the clock framework (which used a global lock), there is now a
need to have per-clkdm locking to prevent races between different
hwmods/modules belonging to the same clock domain concurrently
programming the clkdm state.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Add a new function, clkdm_in_hwsup(), that returns true if a clockdomain
is configured for hardware-supervised idle. It does not actually read the
hardware; rather, it checks an internal flag in the struct clockdomain, which
is changed when the clockdomain is switched in and out of hardware-supervised
idle. This should be safe, since all changes to the idle mode should
pass through the clockdomain code.
Based on a set of patches by Rajendra Nayak <rnayak@ti.com> which do
the same thing by checking the hardware bits. This approach should be
faster and more compact.
Cc: Todd Poynor <toddpoynor@google.com>
Duplicate the existing API for clockdomain enable from clock to enable
a clock domain from hwmod framework.
This will be needed when the hwmod framework will move from the current
clock centric approach to the module based approach.
These APIs are returning 0 for the moment for OMAP2 and OMAP3 until
their hwmods are updated with the clksm attribute.
The call to pwrdm_wait_transition() in clkdm_clk_enable()
is redundant since the function pwrdm_clkdm_state_switch()
which is called next also does the same thing.
Signed-off-by: Vaibhav Bedia <vaibhav.bedia@ti.com>
'remotes/origin/pwrdm_add_can_lose_context_fns_2.6.39', 'remotes/origin/omap_device_a_2.6.39', 'remotes/origin/mmc_a_2.6.39', 'remotes/origin/hwmod_b_2.6.39', 'remotes/origin/dmtimer_a_2.6.39', 'remotes/origin/pwrdm_clkdm_a_2.6.39', 'remotes/origin/clkdm_statdep_omap4_2.6.39', 'remotes/origin/clk_a_2.6.39', 'remotes/origin/clk_autoidle_a_2.6.39', 'remotes/origin/clk_autoidle_b_2.6.39', 'remotes/origin/clk_b_2.6.39', 'remotes/origin/clk_clkdm_a_2.6.39', 'remotes/origin/misc_a_2.6.39', 'remotes/origin/for_2.6.39/omap3_hwmod_data' and 'remotes/origin/wdtimer_a_2.6.39' into tmp-integration-2.6.39-20110310-024
a clockdomain
Add a new clockdomain flag, CLKDM_NO_AUTODEPS, which, when marked on a
clockdomain, will prevent "autodeps" from being associated with the
clockdomain. ("Autodeps" are sleep dependencies and wakeup
dependencies from/to processor modules that are automatically added to
a clockdomain when it is in hardware-supervised idle mode. They are
deprecated -- a relic from the old CDP trees -- but are still in use
for OMAP3.)
Also, prevent the hwmod code from adding or removing initiator
dependencies for clockdomains with this flag set.
This patch should allow others to test which clockdomains actually
still need autodeps.
Thanks to Kevin Hilman <khilman@ti.com> for noting that the original
version should also modify the hwmod code.
Now that wkup and sleep dependencies are supported (in the
form of static deps) for OMAP4, remove all instances of
pr_errs' stating dependencies are still unsupported
on OMAP4.
Define the following architecture specific funtions for omap2/3/4
.clkdm_clk_enable
.clkdm_clk_disable
Convert the platform-independent framework to call these functions.
Also rename the api's by removing the omap2_ preamble.
Hence call omap2_clkdm_k_enable as clkdm_clk_enable and
omap2_clkdm_clk_disable as clkdm_clk_disable.a
Remove unused functions (_enable/_disable_hwsup) and unsed
headers from clockdomain.c file.
.clkdm_allow_idle
.clkdm_deny_idle
Hence call omap2_clkdm_allow_idle as clkdm_allow_idle and
omap2_clkdm_deny_idle as clkdm_deny_idle.
Make the _clkdm_add_autodeps and _clkdm_del_autodeps as non-static
so they can be accessed from OMAP2/3 platform specific code.
.clkdm_sleep
.clkdm_wakeup
Hence call omap2_clkdm_wakeup as clkdm_wakeup and
omap2_clkdm_sleep as clkdm_sleep.
[paul@pwsan.com: fixed omap3_clkdm_clear_all_sleepdeps() and
omap2_clkdm_clear_all_wkdeps() to test against the correct
loop termination condition; thanks to Kevin Hilman for finding and
helping fix]
.clkdm_add_wkdep
.clkdm_del_wkdep
.clkdm_read_wkdep
.clkdm_clear_all_wkdeps
.clkdm_add_sleepdep
.clkdm_del_sleepdep
.clkdm_read_sleepdep
.clkdm_clear_all_sleepdeps
With this also move the clkdm lookups for all wkdep_srcs and
sleepdep_srcs at clkdm_init.
[paul@pwsan.com: fixed loop termination conditions in omap*_clkdm_clear_all_*();
thanks to Kevin Hilman for finding and helping fix those bugs; also
avoid re-resolving clockdomains during init; abstracted out clkdm_dep walk]
Put infrastructure in place, so arch specific func pointers
can be hooked up to the platform-independent part of the
framework.
This is in preparation of splitting the clockdomain framework into
platform-independent part (for all omaps) and platform-specific
parts.
Commit 56a6a19dffda6b75cef8d4183c7c6ff650025cbd ("omap2plus: prm:
Trvial build break fix for undefined reference to
'omap2_prm_read_mod_reg'") generates a lot of warnings on boot since
clockdomain functions that manipulate wake-up dependencies are not
implemented yet on OMAP4 for 2.6.38. This patch bypasses the OMAP2/3
functions on OMAP4, which in turn avoids the warnings when the
functions would attempt to call the underlying OMAP2/3 PRCM functions.
A one-line warning is still logged from the clockdomain code that the
OMAP4 wake-up dependency code is not yet implemented.
A clockdomain wake-up and sleep dependency implementation for OMAP4
from Rajendra should be possible to merge during the 2.6.39 merge
window:
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg41748.html
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg42222.html
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
The OMAP powerdomain code and data is all OMAP2+-specific. This seems
unlikely to change any time soon. Move plat-omap/include/plat/powerdomain.h
to mach-omap2/powerdomain.h. The primary point of doing this is to remove
the temptation for unrelated upper-layer code to access powerdomain code
and data directly.
As part of this process, remove the references to powerdomain data
from the GPIO "driver" and the OMAP PM no-op layer, both in plat-omap.
Change the DSPBridge code to point to the new location for the
powerdomain headers. The DSPBridge code should not be including the
powerdomain headers; these should be removed.
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Greg Kroah-Hartman <greg@kroah.com>
The OMAP clockdomain code and data is all OMAP2+-specific. This seems
unlikely to change any time soon. Move plat-omap/include/plat/clockdomain.h
to mach-omap2/clockdomain.h. The primary point of doing this is to remove
the temptation for unrelated upper-layer code to access clockdomain code
and data directly.
DSPBridge also uses the clockdomain headers for some reason, so,
modify it also. The DSPBridge code should not be including the
clockdomain headers; these should be removed.
Tested-by: Rajendra Nayak <rnayak@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
register accesses
Reverse some of the effects of commit
84c0c39aec31a09571fc08a752a2f4da0fe9fcf2 ("ARM: OMAP4: PM: Make OMAP3
Clock-domain framework compatible for OMAP4"). On OMAP2/3, the
CM_CLKSTCTRL register is at a constant offset from the powerdomain's
CM instance.
Also, remove some of the direct CM register access from the
clockdomain code, moving it to the OMAP2/3 CM code instead. The
intention here is to simplify the clockdomain code. (The long-term
goal is to move all direct CM register access across the OMAP core
code to the appropriate cm*.c file.)
Add PRCM partition, CM instance register address offset, and clockdomain
register address offset to each OMAP4 struct clockdomain record. Add OMAP4
clockdomain code to use this new data to access registers properly.
While here, clean up some nearby clockdomain code to allocate auto variables
in my recollection of Linus's preferred style.
The autogeneration scripts have been updated.
Split _omap2_clkdm_set_hwsup() into _disable_hwsup() and _enable_hwsup().
While here, also document that the autodeps are deprecated and that they
should be removed at the earliest opportunity.
The documentation has been fixed for _{enable,disable}_hwsup(), thanks
to Kevin Hilman <khilman@deeprootsystems.com> for pointing out that those
functions still had placeholder documentation in an earlier patch revision.
Now that OMAP4-specific PRCM functions have been added, distinguish the
existing OMAP2/3-specific PRCM functions by prefixing them with "omap2_".
This patch should not result in any functional change.
Cc: Jarkko Nikula <jhnikula@gmail.com>
Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
In preparation for adding OMAP4-specific PRCM accessor/mutator
functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific
files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been
moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was
OMAP2xxx/3xxx-specific.
This process also requires the #includes in each of these files to be
changed to reference the new file name. As part of doing so, add some
comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use
"sideways includes", to indicate that these users of the PRM/CM includes
should not be doing so.
Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this
patch.
Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com>
Acked-by: Felipe Contreras <felipe.contreras@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
layer starts
When the clockdomain layer initializes, place all clockdomains into
software-supervised mode, and clear all wakeup and sleep dependencies
immediately, rather than waiting for the PM code to do this later.
This fixes a major bug where critical sleep dependencies added by the
hwmod code are cleared during late PM init.
As a side benefit, the _init_{wk,sleep}dep_usecount() functions are no
longer needed, so remove them.
Kevin Hilman <khilman@deeprootsystems.com> did all the really hard work on
this, identifying the problem and finding the bug.
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Fix all of the remaining OMAP2 PRCM register shift/bitmask macros that
did not use the _SHIFT/_MASK suffixes to use them. This makes the use
of these macros consistent. It is intended to reduce error, as code
can be inspected visually by reviewers to ensure that bitshifts and
bitmasks are used in the appropriate places.
This patch fixes usage of bitwise OR in if conditions, and instead
uses logical OR.
Cc: Abhijit Pagare <abhijitpagare@ti.com>
Simplify the code in the omap2_clk_disable() and omap2_clk_enable()
functions, reducing levels of indentation. This makes the code easier
to read. Add some additional debugging pr_debug()s here also to help
others understand what is going on.
Revise the omap2_clk_disable() logic so that it now attempts to
disable the clock's clockdomain before recursing up the clock tree.
Simultaneously, ensure that omap2_clk_enable() is called on parent
clocks first, before enabling the clockdomain. This ensures that a
parent clock's clockdomain is enabled before the child clock's
clockdomain. These sequences should be the inverse of each other.
Revise the omap2_clk_enable() logic so that it now cleans up after
itself upon encountering an error. Previously, an error enabling a
parent clock could have resulted in inconsistent usecounts on the
enclosing clockdomain.
Remove the trivial _omap2_clk_disable() and _omap2_clk_enable() static
functions, and replace it with the clkops calls that they were
executing.
For all this to work, the clockdomain omap2_clkdm_clk_enable() and
omap2_clkdm_clk_disable() code must not return an error on clockdomains
without CLKSTCTRL registers; so modify those functions to simply return 0
in that case.
While here, add some basic kerneldoc documentation on both functions,
and get rid of some old non-CodingStyle-compliant comments that have
existed since the dawn of time (at least, the OMAP clock framework's
time).
Cc: Richard Woodruff <r-woodruff2@ti.com>
_clkdm_add_autodeps() and _clkdm_del_autodeps() will attempt to dereference
a NULL pointer if no autodeps were supplied to clkdm_init().
Based on a patch from Roel Kluin <roel.kluin@gmail.com> - thanks Roel.
Cc: Roel Kluin <roel.kluin@gmail.com>
A check is added for avoiding the sleep/wakeup dependency updates
for OMAP4 as the structures for the dependencies are currently absent.
Signed-off-by: Abhijit Pagare <abhijitpagare@ti.com>
[paul@pwsan.com: added warnings, explanatory comment, copyright update]
This patch only affects documentation; no functional changes are
included.
Clean up comments in the current clockdomain, powerdomain code and
header files. This mostly involves conversion to kerneldoc format,
although some clarifications are also included.
Add usecounting for wakeup and sleep dependencies. In the current
situation, if several functions add dependencies on the same
clockdomains, when the first dependency removal function is called,
the dependency will be incorrectly removed from the hardware.
Add clkdm_clear_all_wkdeps() and clkdm_clear_all_sleepdeps(), which
provide a fast and usecounting-consistent way to clear all hardware
clockdomain dependencies, since accesses to these registers can be
quite slow. pm{2,3}4xx.c has been updated to use these new functions.
The original version of this patch did not touch these files, which
previously wrote directly to the wkdep registers, and thus confused
the usecounting code. This problem was found by Kevin Hilman
<khilman@deeprootsystems.com>.
N.B.: This patch introduces one significant functional difference over
the previous pm34xx.c code: sleepdeps are now cleared during
clockdomain initialization, whereas previously they were left
untouched. This has been tested by Kevin and confirmed to work.
The original version of this patch also did not take into
consideration that some clockdomains do not have sleep or wakeup
dependency sources, which caused NULL pointer dereferences. This
problem was debugged and fixed by Kevin Hilman
Cc: Jouni Högander <jouni.hogander@nokia.com>
