Since the clkdm state programming is now done from within the hwmod
framework (which uses a per-hwmod lock) instead of the being done
from the clock framework (which used a global lock), there is now a
need to have per-clkdm locking to prevent races between different
hwmods/modules belonging to the same clock domain concurrently
programming the clkdm state.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Define the following architecture specific funtions for omap2/3/4
.clkdm_clk_enable
.clkdm_clk_disable
Convert the platform-independent framework to call these functions.
Also rename the api's by removing the omap2_ preamble.
Hence call omap2_clkdm_k_enable as clkdm_clk_enable and
omap2_clkdm_clk_disable as clkdm_clk_disable.a
Remove unused functions (_enable/_disable_hwsup) and unsed
headers from clockdomain.c file.
.clkdm_allow_idle
.clkdm_deny_idle
Hence call omap2_clkdm_allow_idle as clkdm_allow_idle and
omap2_clkdm_deny_idle as clkdm_deny_idle.
Make the _clkdm_add_autodeps and _clkdm_del_autodeps as non-static
so they can be accessed from OMAP2/3 platform specific code.
.clkdm_sleep
.clkdm_wakeup
Hence call omap2_clkdm_wakeup as clkdm_wakeup and
omap2_clkdm_sleep as clkdm_sleep.
[paul@pwsan.com: fixed omap3_clkdm_clear_all_sleepdeps() and
omap2_clkdm_clear_all_wkdeps() to test against the correct
loop termination condition; thanks to Kevin Hilman for finding and
helping fix]
Cc: Kevin Hilman <khilman@ti.com>
.clkdm_add_wkdep
.clkdm_del_wkdep
.clkdm_read_wkdep
.clkdm_clear_all_wkdeps
.clkdm_add_sleepdep
.clkdm_del_sleepdep
.clkdm_read_sleepdep
.clkdm_clear_all_sleepdeps
With this also move the clkdm lookups for all wkdep_srcs and
sleepdep_srcs at clkdm_init.
[paul@pwsan.com: fixed loop termination conditions in omap*_clkdm_clear_all_*();
thanks to Kevin Hilman for finding and helping fix those bugs; also
avoid re-resolving clockdomains during init; abstracted out clkdm_dep walk]
