path: root/arch/arm/mach-omap2/cm2_7xx.h
2014-10-27ARM: OMAP4+: CM: remove omap4_cm1/cm2_* functionsTero Kristo
These are not used for anything, so remove both the implementations and header file references. Signed-off-by: Tero Kristo <t-kristo@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-22arm: dra7xx: Add hwmod data for pcie1 phy and pcie2 phyKishon Vijay Abraham I
Added hwmod data for pcie1 and pcie2 phy present in DRA7xx SOC. Also added the missing CLKCTRL OFFSET macro and CONTEXT OFFSET macro for pcie1 phy and pcie2 phy. Cc: Tony Lindgren <tony@atomide.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Tested-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-08-23ARM: OMAP: DRA7: CM: Add DRA7XX register definesAmbresh K
Add the new defines for DRA7XX CM registers. Signed-off-by: Ambresh K <ambresh@ti.com> Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> [paul@pwsan.com: added generation notation in comments] Signed-off-by: Paul Walmsley <paul@pwsan.com>
