path: root/arch/arm/mach-omap2/cm81xx.h
2015-01-26ARM: OMAP2+: Add clock domain support for dm816xAida Mynzhasova
This patch adds required definitions and structures for clockdomain initialization, so omap3xxx_clockdomains_init() was substituted by new ti81xx_clockdomains_init() while early initialization of TI81XX platform. Note that we now need to have 81xx in a separate CONFIG_SOC_TI81XX block instead inside the ifdef block for omap3 to avoid make randconfig build errors. This code is based on the TI81XX-LINUX-PSP-04.04.00.02 patches published at: http://downloads.ti.com/dsps/dsps_public_sw/psp/LinuxPSP/TI81XX_04_04/04_04_00_02/index_FDS.html Cc: Brian Hutchinson <b.hutchman@gmail.com> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Aida Mynzhasova <aida.mynzhasova@skitlab.ru> [tony@atomide.com: updated to apply, renamed to clockdomains81xx.c, fixed to use am33xx_clkdm_operations, various fixes suggested by Paul Walmsley] Reviewed-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
