In some cases the physical address info is needed, so store this
under the existing cm*_base, prm_base and prcm_mpu_base variables.
These are converted now to structs that contain both virtual and
physical address base for the instance.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Currently, TI clock driver uses an encapsulated struct that is cast into
a void pointer to store all register addresses. This can be considered
as rather nasty hackery, and prevents from expanding the register
address field also. Instead, replace all the code to use proper struct
in place for this, which contains all the previously used data.
This patch is rather large as it is touching multiple files, but this
can't be split up as we need to avoid any boot breakage.
Some of the TI clock providers will be converted to use syscon, thus
low-level regmap support is needed for the clock drivers also. This
patch adds this support, which can be enabled for individual drivers
in later patches.
This gets rid of need for some exported driver APIs, and simplifies the
initialization of the CM driver. Done in preparation to make CM a
separate driver. The init data is now also passed to the SoC specific
implementations, allowing future expansion to add feature flags etc.
There is no need to provide the CM base address through a low-level API
from the low-level IO init, as this information is available through DT.
Re-routed the parsing function to be called from the CM drivers also to
simplify the implementation under io.c.
Splits the clock related provider module inits under their own driver files.
Previously this was done for all modules under the common PRM driver.
Adds a generic CM driver API for enabling/disabling modules.
The SoC specific implementations are registered through cm_ll_data.
Tested-by: Nishanth Menon <nm@ti.com>
Adds a generic CM driver API for waiting module to enter idle / standby.
Acked-by: Paul Walmsley <paul@pwsan.com>
This patch consolidates the parameters provided for the SoC specific
cm_*_wait_module_ready calls, adds the missing cm_ll_data function
pointers and uses the now generic call from the mach-omap2 board code.
SoC specific *_wait_module_ready calls are also made static so they
can only be accessed through the generic CM driver API only.
Some of the includes are totally unnecessary, remove some others in
preparation to make the PRCM its own driver.
[paul@pwsan.com: updated to apply; fixed build error on OMAP2xxx-only configs]
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Fixes the following error:
CC arch/arm/mach-omap2/cm_common.o
arch/arm/mach-omap2/cm_common.c: In function ‘cm_register’:
arch/arm/mach-omap2/cm_common.c:42:11: error: ‘EINVAL’ undeclared (first use in this function)
arch/arm/mach-omap2/cm_common.c:42:11: note: each undeclared identifier is reported only once for each function it appears in
arch/arm/mach-omap2/cm_common.c:45:11: error: ‘EEXIST’ undeclared (first use in this function)
arch/arm/mach-omap2/cm_common.c: In function ‘cm_unregister’:
arch/arm/mach-omap2/cm_common.c:66:11: error: ‘EINVAL’ undeclared (first use in this function)
make[1]: *** [arch/arm/mach-omap2/cm_common.o] Error 1
make: *** [arch/arm/mach-omap2] Error 2
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Split omap2_set_globals_prcm() into PRM, CM, and PRCM_MPU variants, since
these are all separate IP blocks. This should make it easier to move the
PRM, CM, PRCM_MPU code into drivers/ in future patchsets.
At this point arch/arm/plat-omap/include/plat/prcm.h is empty; a
subsequent patch will remove it, and remove the #include from all the
files that #include it.
Tested-by: Vaibhav Hiremath <hvaibhav@ti.com>
SoC-independent CM functions
Convert the OMAP clock code's _omap2_module_wait_ready() to use
SoC-independent CM functions that are provided by the CM code, rather
than using a deprecated function from mach-omap2/prcm.c.
This facilitates the future conversion of the CM code to a driver, and
also removes a mach-omap2/prcm.c user. mach-omap2/prcm.c will be removed
by a subsequent patch.
Some modules have IDLEST registers that aren't in the CM module, such
as the AM3517 IDLEST bits. So we also need a fallback function for
these non-CM odd cases. Create a temporary one in mach-omap2/clock.c,
intended to exist until the SCM drivers are ready.
There are several CM operations which behave similarly across OMAP2+
SoCs, but which have slight differences in their underlying
implementations.
This patch creates the support code for this function pointer
registration process. No function pointers are included yet, but a
subsequent patch will create these for the module IDLEST registers.
This patch allows other code to use CM-provided data and operations
without needing to know which SoC is currently in use. A further
description of the concept is provided in the patch entitled
"ARM: OMAP2+: PRM: prepare for use of prm_ll_data function pointers".
