path: root/arch/arm/mach-omap2/common-board-devices.h
2011-07-04OMAP: New twl-common for common TWL configurationPeter Ujfalusi
Introduce a new file, which will be used to configure common pmic (TWL) devices, regulators, and TWL audio. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2011-06-01arm: omap2plus: move NAND_BLOCK_SIZE out of boardsIgor Grinberg
Several boards defining mtd partitions also defined NAND_BLOCK_SIZE as SZ_128K. Move the define to common-board-devices.h This removes multiple defines of NAND_BLOCK_SIZE. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> [tony@atomide.com: updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-03omap: move detection of NAND CS to common-board-devicesMike Rapoport
and reduce amount of copy/paste Signed-off-by: Mike Rapoport <mike@compulab.co.il> CC: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-03omap: use common initialization for PMIC i2c busMike Rapoport
Introduce omap_pmic_init that registers i2c bus and PMIC device on that bus and add omap2/3/4 wrappers for common cases. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-03omap: consolidate touch screen initialization among different boardsMike Rapoport
Add common-board-devices.c that will contain the code for peripheral devices initializatoin shared between multiple boards. Start small with touchscreen initialization. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
