The Kconfig-Option OMAP4_ERRATA_I688 is never visible due to a
contradiction in it's dependencies.
The option requires ARCH_MULTIPLATFORM to be 'disabled'. However, an
enclosing menu requires either ARCH_MULTI_V6 or ARCH_MULTI_V7 to be
enabled. These options inherit a dependency from an enclosing menu,
that requires ARCH_MULTIPLATFORM to be 'enabled'.
This is a contradiction and made this option also unavailable for
non-multiplatform configurations.
Since there are no selects on OMAP4_ERRATA_I688, which would ignore
dependencies, the code related to that option is dead and can be
removed.
This (logical) defect has been found with the undertaker tool.
(https://undertaker.cs.fau.de)
Signed-off-by: Stefan Hengelein <stefan.hengelein@fau.de>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Pull ARM SoC non-critical fixes from Olof Johansson:
"Here's a small collection of fixes accrued during the last release
that weren't considered severe enough to merge during the -rc series.
A few of these are around resurrecting TI81xx support that's been
broken for quite a while, the rest are smaller fixes -- most for PXA
but a few across the board.
There are also some updates to MAINTAINERS here, in particular for
Broadcom platforms"
* tag 'fixes-non-critical-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
MAINTAINERS: fix git repositories for Broadcom SoCs
ARM: pxa: fix broken isa interrupts for zeus and viper
ARM: DRA7: hwmod: Fix boot crash with DEBUG_LL enabled on UART3
ARM: OMAP: DRA7: hwmod: Make gpmc software supervised as the smart idle is broken
ARM: AM43xx: hwmod: set DSS submodule parent hwmods
ARM: OMAP2+: hwmod: print error if wait_target_ready() failed
MAINTAINERS: add maintainer for OMAP hwmod data
ARM: OMAP2+: Disable omap3 PM init for ti81xx
ARM: OMAP2+: Fix reboot for 81xx
ARM: OMAP2+: Fix dm814 and dm816 for clocks and timer init
ARM: OMAP2+: Fix ti81xx class type
ARM: OMAP2+: Fix ti81xx devtype
ARM: OMAP2+: Fix error handling for omap2_clk_enable_init_clocks
MAINTAINERS: add a git entry for BMIPS-based BCM7xxx SoCs
MAINTAINERS: add a git entry for BCM7xxx ARM-based SoCs
MAINTAINERS: update Broadcom Cygnus SoC git tree
MAINTAINERS: move BCM63xx ARM-based SoCs git tree
hx4700: regulator: declare full constraints
ARM: pxa: add regulator_has_full_constraints to spitz board file
ARM: pxa: add regulator_has_full_constraints to poodle board file
Pull ARM updates from Russell King:
- clang assembly fixes from Ard
- optimisations and cleanups for Aurora L2 cache support
- efficient L2 cache support for secure monitor API on Exynos SoCs
- debug menu cleanup from Daniel Thompson to allow better behaviour for
multiplatform kernels
- StrongARM SA11x0 conversion to irq domains, and pxa_timer
- kprobes updates for older ARM CPUs
- move probes support out of arch/arm/kernel to arch/arm/probes
- add inline asm support for the rbit (reverse bits) instruction
- provide an ARM mode secondary CPU entry point (for Qualcomm CPUs)
- remove the unused ARMv3 user access code
- add driver_override support to AMBA Primecell bus
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (55 commits)
ARM: 8256/1: driver coamba: add device binding path 'driver_override'
ARM: 8301/1: qcom: Use secondary_startup_arm()
ARM: 8302/1: Add a secondary_startup that assumes ARM mode
ARM: 8300/1: teach __asmeq that r11 == fp and r12 == ip
ARM: kprobes: Fix compilation error caused by superfluous '*'
ARM: 8297/1: cache-l2x0: optimize aurora range operations
ARM: 8296/1: cache-l2x0: clean up aurora cache handling
ARM: 8284/1: sa1100: clear RCSR_SMR on resume
ARM: 8283/1: sa1100: collie: clear PWER register on machine init
ARM: 8282/1: sa1100: use handle_domain_irq
ARM: 8281/1: sa1100: move GPIO-related IRQ code to gpio driver
ARM: 8280/1: sa1100: switch to irq_domain_add_simple()
ARM: 8279/1: sa1100: merge both GPIO irqdomains
ARM: 8278/1: sa1100: split irq handling for low GPIOs
ARM: 8291/1: replace magic number with PAGE_SHIFT macro in fixup_pv code
ARM: 8290/1: decompressor: fix a wrong comment
ARM: 8286/1: mm: Fix dma_contiguous_reserve comment
ARM: 8248/1: pm: remove outdated comment
ARM: 8274/1: Fix DEBUG_LL for multi-platform kernels (without PL01X)
ARM: 8273/1: Seperate DEBUG_UART_PHYS from DEBUG_LL on EP93XX
Commit 9a1091ef0017 ("irqchip: gic: Support hierarchy irq domain")
changed the GIC driver to use a non-legacy IRQ domain on DT
platforms. This patch assumes that DT-driven systems are getting
all of their interrupts from device tree.
Turns out that OMAP has quite a few hidden gems, and still uses
hardcoded interrupts despite having fairly complete DTs.
This patch attempts to work around these by offering a translation
method that can be called directly from the hwmod code, if present.
The same hack is sprinkled over PRCM and TWL.
It isn't pretty, but it seems to do the job without having to add
more hacks to the interrupt controller code.
Tested on OMAP4 (Panda-ES) and OMAP5 (UEVM5432).
Acked-by: Nishanth Menon <nm@ti.com>
[tony@atomide.com: updated to fix make randconfig issue]
This patch implements generic DT L2C initialisation (the one from
init_IRQ in arch/arm/kernel/irq.c) for Omap4 and AM43 platforms and
kills the SoC specific stuff in arch/arm/mach-omap2/omap4-common.c.
Tested-by: Nishanth Menon <nm@ti.com>
We are missing proper hooks for 81xx for reboot to work.
Cc: Brian Hutchinson <b.hutchman@gmail.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Otherwise it will return true for cpu_is_omap34xx() which we don't
want for the clocks and hwmod. It's closer to am33xx for the clocks
and hwmod than to the omap34xx. We also want to be able to detect
814x and 816x separately as at least the clocks are different with
814x using a apll and 816x using a fapll for the source clocks.
Note that we can also remove omap3xxx_clk_init() call as it's wrong
and ti81xx are booting in device tree only mode.
If the boot loader enables HYP mode on the boot CPU, the secondary CPU
also needs to call into the ROM to switch to HYP mode before booting.
The firmwares on the omap5 and dra7xx unfortunately do not take care
of this, so it has to be handled by the kernel.
This patch is based on "[PATCH 2/2] ARM: OMAP5: Add HYP mode entry support
for secondary CPUs" by Santosh Shilimkar <santosh.shilimkar@ti.com>,
except this version does not require a compile time CONFIG to control
if it should enable HYP mode or not, it simply does it based on the mode
of the boot CPU, so it works whether the CPU boots in SVC or HYP mode,
and should even work as a guest kernel inside kvm if qemu decides to
support emulating the omap5 or dra7xx.
Cc: stable@vger.kernel.org #v3.16+
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
OMAP INTC irqchip driver will be moved under
drivers/irqchip/ soon but we still have a dependency
with mach-omap2 when it comes to idle functions.
In order to make it easy to share those function
prototypes with OMAP PM code, we introduce this new
header.
To avoid modifying several board-files and some of
the PM-related code, we just include the new header
from common.h which was already included by all
users of IRQ-related PM code.
Signed-off-by: Felipe Balbi <balbi@ti.com>
that was just a no-op wrapper around omap_intc_handle_irq
anyway.
now that we're calling set_handle_irq() from
init_irq(), we can safely drop all callers to
omap3_intc_handle_irq() and its definition.
now we can safely drop those fields from our machine_desc.
While at that, also drop the now unused omap_intc_of_init()
definition.
nobody uses that function outside of this file,
so we don't need to expose it.
of_device_ids (i.e. compatible strings and the respective data) are not
supposed to change at runtime. All functions working with of_device_ids
provided by <linux/of.h> work with const of_device_ids. So mark the
non-const function parameters and structs for OMAP2+ as const, too.
With consolidated code, now we can add the required hooks for
DRA7 to enable power management.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
[nm@ti.com: minor modifications]
Signed-off-by: Nishanth Menon <nm@ti.com>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Kevin Hilman <khilman@linaro.org>
OMAP5 to enable power management.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
[nm@ti.com: minor rebase updates]
omap44xx_restart is defined as a static void inline when DRA7/AM437X is
defined alone, which implies that the restart function is no longer
functional even though it is built in. So, fix the definition of the
same.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Merge OMAP fixes from Tony Lindgren:
Fixes for omaps for issues discovered during the merge window and
enabling of a few features that had to wait for the driver
dependencies to clear.
The fixes included are:
- Fix am43xx hard reset flags
- Fix SoC detection for DRA722
- Fix CPU OPP table for omap5
- Fix legacy mux parser bug if requested muxname is a prefix of
multiple mux entries
- Fix qspi interrupt binding that relies on the irq crossbar
that has not yet been enabled
- Add missing phy_sel for am43x-epos-evm
- Drop unused gic_init_irq() that is no longer needed
And the enabling of features that had driver dependencies are:
- Change dra7 to use Audio Tracking Logic clock instead of a fixed
clock now that the clock driver for it has been merged
- Enable off idle configuration for selected omaps as all the kernel
dependencies for device tree based booting are finally merged as
this is needed to get the automated PM tests working finally with
- Add hwmod entry for ocp2scp3 for omap5 to get sata working as
all the driver dependencies are now in the kernel and this patch
fell through the cracks during the merge window
* tag 'omap-for-v3.16/fixes-against-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: dts: dra7-evm: remove interrupt binding
ARM: OMAP2+: Fix parser-bug in platform muxing code
ARM: DTS: dra7/dra7xx-clocks: ATL related changes
ARM: OMAP2+: drop unused function
ARM: dts: am43x-epos-evm: Add Missing cpsw-phy-sel for am43x-epos-evm
ARM: dts: omap5: Update CPU OPP table as per final production Manual
ARM: DRA722: add detection of SoC information
ARM: dts: Enable twl4030 off-idle configuration for selected omaps
ARM: OMAP5: hwmod: Add ocp2scp3 and sata hwmods
ARM: OMAP2+: hwmod: Change hardreset soc_ops for AM43XX
Commit d941f86fad41b ("ARM: l2c: AM43x: add L2 cache support") enabled
the L2 cache support for the am43xx SoC, but caused a build regression
when the driver for that cache controller is disabled:
arch/arm/mach-omap2/built-in.o: In function `am43xx_init_early':
:(.init.text+0xb20): undefined reference to `omap_l2_cache_init'
This did not happen for OMAP4, which has the same call, but enables
the l2x0 driver unconditionally. We could do the same thing for
am43xx, but it seems better to allow turning it off and make the
code work in either case.
This adds an inline wrapper for omap_l2_cache_init for the disabled
case, and removes the 'select' from OMAP4 so it becomes a user
visible option.
Cc: linux-omap@vger.kernel.org
gic_init_irq() is no longer used as of:
commit b42b918194c4791510ac049e3d507169a7de8544
Author: Tony Lindgren <tony@atomide.com>
Date: Thu May 30 12:53:05 2013 -0700
ARM: OMAP2+: Remove board-omap4panda.c
Drop it.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Cc: Tony Lindgren <tony@atomide.com>
Get rid of init call to initialize L2 cache. Instead use the init_early
machine hook. This helps in using the initialization routine across
SoCs without the need of ugly cpu_is_*() checks.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
As there is no common panel framework in the kernel, we have OMAP
specific panel drivers. However, the DT data should be generic. This
brings the issue that some other platform could use the same panels, and
would need to create a driver with the same 'compatible' string as the
OMAP driver.
In the long run, we have to get a common panel framework. For the time
being, this patch solves the issue:
At early boot time, we go through the DT nodes looking for the panels
the kernel supports for OMAP. For each found node, the 'compatible'
string is prepended with "omapdss,", i.e. "sony,acx565akm" becomes
"omapdss,sony,acx565akm". The OMAP display drivers all have "omapdss,"
at the beginning of their compatible field.
This allows us to have generic DT data, but OMAP specific display
drivers.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Reviewed-by: Archit Taneja <archit@ti.com>
The OMAP display architecture requires a bunch of platform devices which
are not created via .dts (for now). We also need to pass a few function
pointers and the DSS hardware version from the arch code to omapdss
driver.
This patch adds omapdss_init_of() function, called from board-generic at
init time, which handles those tasks.
Move all OMAP4 PM errata initializations to centralized location in
omap4_pm_init_early. This allows for users to utilize the erratas
in various submodules as needed.
Reported-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The same workaround as ff999b8a0983ee15668394ed49e38d3568fc6859
"ARM: OMAP4460: Workaround for ROM bug because of CA9 r2pX GIC ..."
need to be applied not only when system is booting, but when MPUSS hits
OSWR state through CPUIdle too. Without this WA the same issue is
reproduced now on boards PandaES and Tablet/Blaze with SOM OMAP4460
when CONFIG_CPU_IDLE is enabled.
After MPUSS has enterred OSWR and waken up:
- GIC distributor became disabled forever
- scheduling is not performed any more
Cc: Kevin Hilman <khilman@linaro.org>
Reported-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
git://git.linaro.org/people/mike.turquette/linux
Pull more clock framework changes from Mike Turquette:
"The second half of the clock framework pull requeust for 3.14 is
dominated by platform support for Qualcomm's MSM SoCs, DT binding
updates for TI's OMAP-ish processors and additional support for
Samsung chips.
Additionally there are other smaller clock driver changes and several
last minute fixes. This pull request also includes the HiSilicon
support that depends on the already-merged arm-soc pull request"
[ Fix up stupid compile error in the source tree with evil merge - Grumpy Linus ]
* tag 'clk-for-linus-3.14-part2' of git://git.linaro.org/people/mike.turquette/linux: (49 commits)
clk: sort Makefile
clk: sunxi: fix overflow when setting up divided factors
clk: Export more clk-provider functions
dt-bindings: qcom: Fix warning with duplicate dt define
clk: si5351: remove variant from platform_data
clk: samsung: Remove unneeded semicolon
clk: qcom: Fix modular build
ARM: OMAP3: use DT clock init if DT data is available
ARM: AM33xx: remove old clock data and link in new clock init code
ARM: AM43xx: Enable clock init
ARM: OMAP: DRA7: Enable clock init
ARM: OMAP4: remove old clock data and link in new clock init code
ARM: OMAP2+: io: use new clock init API
ARM: OMAP2+: PRM: add support for initializing PRCM clock modules from DT
ARM: OMAP3: hwmod: initialize clkdm from clkdm_name
ARM: OMAP: hwmod: fix an incorrect clk type cast with _get_clkdm
ARM: OMAP2+: clock: use driver API instead of direct memory read/write
ARM: OMAP2+: clock: add support for indexed memmaps
ARM: dts: am43xx clock data
ARM: dts: AM35xx: use DT clock data
clk_init is now separated to a common function which gets called for all
SoC:s, which initializes the DT clocks and calls the SoC specific clock init.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
As we currently need to support a mix of legacy platform data and
device tree intialized data, let's make sure things keep working
for the TWL GPIOs.
Mostly the issue is caused by the fact that DSS does not yet have
device tree bindings, so we need to rely on the TWL GPIO callback
for setting up things like LCD backlight for some boards.
As of_platform_populate() for the TWL GPIO is called by twl-core
after the I2C bus has been initialized, we cannot pass the auxdata
table from the board init code to twl-core like we used to with
just legacy platform data.
So let's use the omap_device bus hook to patch in the platform
data for TWL GPIO until we have sorted out the issues with the
TWL GPIOs and device tree bindings.
The other option was be to initialize twl core using legacy
platform data, which seems like a step backwards as we're moving
to device tree only initialization. And we really don't want to
add custom configuration functions to the TWL GPIO driver either
for this.
This is no longer used, omap4 is device tree based now.
AM335x, AM43xx, OMAP5 and DRA7 have missing late init hook. Introduce
SoC specific hook with a call to OMAP2+ generic lateinit hook. This
allows the generic late initializations such as cpufreq hooks to be
active.
Based on out-of-tree patches that need to be introduced in
mainline, this introduction allows us to provide the foundation for
further SoC specific features as they are developed.
Cc: Benoit Cousson <bcousson@baylibre.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Paul Walmsley <paul@pwsan.com>
For few things we're still going to be needing platform
data for device tree based drivers. Let's set up auxdata
handling and do it in pdata-quirks.c so we have all the
legacy calls in one place.
We want to drop the board-*.c files but keep things working.
Let's make it a bit easier to support legacy platform data
init with quirks. This also keeps board-generic.c clean from
board specific hacks.
For now, the quirks table is empty, that is populated
in the later patches.
The IO descriptor tables for DRA7 are a complete reuse from OMAP5.
A new dra7xx_init_early() does the base address inits.
Signed-off-by: R Sricharan <r.sricharan@ti.com>
Preparing to move the parsing of reboot= to generic kernel code forces
the change in reboot_mode handling to use the enum.
[akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c]
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/soc
From Tony Lindgren:
Omap SoC changes. Mostly improves am33xx support, and adds
minimal support for am43x SoCs.
* tag 'omap-for-v3.11/soc-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2+: AM43x: SRAM base and size
ARM: OMAP2+: AM43x: GP or HS ?
ARM: OMAP2+: AM43x: early init
ARM: OMAP2+: AM43x: static mapping
ARM: OMAP2+: AM437x: SoC revision detection
ARM: OMAP2+: AM43x: soc_is support
ARM: OMAP2+: AM43x: kbuild
ARM: OMAP2+: AM43x: Kconfig
ARM: OMAP2+: separate out OMAP4 restart
ARM: AM33XX: clk: Add clock node for EHRPWM TBCLK
ARM: OMAP3: clock data: get rid of unused USB host clock aliases and dummies
ARM: OMAP2+: AM33xx: Add missing reset status info to GFX hwmod
+ Linux 3.10-rc5
Minimal early init - PRCM initialization not yet taken care.
Control module is similar (base address, feature register etc.) as
that of AM335x, while PRCM base address is different. Instead of
adding a new header file for AM43x, PRCM base address is added in
AM335x header file as it is similar to it to a large extent.
Signed-off-by: Afzal Mohammed <afzal@ti.com>
[tony@atomide.com: updated to drop am33xx_check_features()]
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-v3.11/pm
OMAP PM cleanups for v3.10
Pull ARM SoC driver changes from Olof Johansson:
"This is a rather large set of patches for device drivers that for one
reason or another the subsystem maintainer preferred to get merged
through the arm-soc tree. There are both new drivers as well as
existing drivers that are getting converted from platform-specific
code into standalone drivers using the appropriate subsystem specific
interfaces.
In particular, we can now have pinctrl, clk, clksource and irqchip
drivers in one file per driver, without the need to call into platform
specific interface, or to get called from platform specific code, as
long as all information about the hardware is provided through a
device tree.
Most of the drivers we touch this time are for clocksource. Since now
most of them are part of drivers/clocksource, I expect that we won't
have to touch these again from arm-soc and can let the clocksource
maintainers take care of these in the future.
Another larger part of this series is specific to the exynos platform,
which is seeing some significant effort in upstreaming and
modernization of its device drivers this time around, which
unfortunately is also the cause for the churn and a lot of the merge
conflicts.
There is one new subsystem that gets merged as part of this series:
the reset controller interface, which is a very simple interface for
taking devices on the SoC out of reset or back into reset. Patches to
use this interface on i.MX follow later in this merge window, and we
are going to have other platforms (at least tegra and sirf) get
converted in 3.11. This will let us get rid of platform specific
callbacks in a number of platform independent device drivers."
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits)
irqchip: s3c24xx: add missing __init annotations
ARM: dts: Disable the RTC by default on exynos5
clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3}
ARM: exynos: restore mach/regs-clock.h for exynos5
clocksource: exynos_mct: fix build error on non-DT
pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register()
irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure
reset: NULL deref on allocation failure
reset: Add reset controller API
dt: describe base reset signal binding
ARM: EXYNOS: Add arm-pmu DT binding for exynos421x
ARM: EXYNOS: Add arm-pmu DT binding for exynos5250
ARM: EXYNOS: Enable PMUs for exynos4
irqchip: exynos-combiner: Correct combined IRQs for exynos4
irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq
ARM: EXYNOS: fix compilation error introduced due to common clock migration
clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3}
clk: exynos4: export clocks required for fimc-is
clk: samsung: Fix compilation error
clk: tegra: fix enum tegra114_clk to match binding
Pull ARM SoC platform updates from Olof Johansson:
"This branch contains part 1 of the platform updates for 3.10. Among
the highlights:
- Support for the new Atmel Cortex-A5 based platforms (SAMA5D3)
- New support for CSR SiRFatlas6 SoCs
- A handful of updates for NVidia T114 (a.k.a. Tegra 4)
- A bunch of updates for the shmobile platforms
- A handful of updates for davinci
- A few updates for Qualcomm MSM
- Plus a handful of other patches, defconfig updates, etc."
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (135 commits)
ARM: tegra: pm: fix build error w/o PM_SLEEP
ARM: davinci: ensure global variables are declared
ARM: davinci: sram.c: fix incorrect type in assignment
ARM: davinci: da8xx dt: make file local symbols static
ARM: davinci: da8xx: add remoteproc support
ARM: socfpga: Upgrade clk driver for socfpga to make use of dts clock entries
ARM: socfpga: Add clock entries into device tree
ARM: socfpga: Enable soft reset
ARM: EXYNOS: replace cpumask by the corresponding macro
ARM: EXYNOS: handle properly the return values
ARM: EXYNOS: factor out the idle states
ARM: OMAP4: Enable fix for Cortex-A9 erratas
ARM: OMAP2+: Export SoC information to userspace
ARM: OMAP2+: SoC name and revision unification
ARM: OMAP2+: Move common part of late init into common function
ARM: tegra: pm: remove duplicated include from pm.c
ARM: davinci: da850: override mmc DT node device name
ARM: davinci: da850: add mmc DT entries
mmc: davinci_mmc: add DT support
ARM: SAMSUNG: check processor type before cache restoration in resume
Current code has rather inconsistent function names for 'secondary_startup'
routines. Update it to make it more consistent.
Suggested by Kevin Hilman as part of OMAP5 PM patch review.
Current OMAP4 CPUIdle driver is using omap4_mpuss_read_prev_context_state()
to check whether the MPU cluster lost context or not before calling
cpu_cluster_pm_exit(). This was initially done an optimization for
corner cases, where if the cluster low power entry fails for some
reason, the cluster context restore gets skipped. However, since
reading the previous context is expensive (involving slow accesses to
the PRCM), it's better to avoid it and simply check the target cluster
state instead.
Moving forward, OMAP CPUidle drivers needs to be moved to drivers/idle/*
once the PRM/CM code gets moved to drivers. This patch also reduces one
dependency with platform code for idle driver movement.
[khilman@linaro.org: minor changelog edits]
In some situations it is useful for userspace to
know some SoC-specific information. For example,
this may be used for deciding what kernel module to
use or how to better configure some settings etc.
This patch exports OMAP SoC information to userspace
using existing in Linux kernel SoC infrastructure.
This information can be read under
/sys/devices/socX directory
Signed-off-by: Ruslan Bilovol <ruslan.bilovol@ti.com>
[tony@atomide.com: updated for multiplatform changes]
omap-for-v3.10/timer
arch/arm/mach-omap2/timer.c
There is a lot of redundancy in the definitions for the various system
timers for OMAP2+ devices. For example, the omap3_am33xx_gptimer_timer_init()
function is the same as the omap3_gp_gptimer_timer_init() function and the
function omap4_sync32k_timer_init() can be re-used for OMAP5 devices.
Therefore, consolidate the definitions to simplify the code.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
clk inits on OMAP happen quite early, even before slab is available.
The dependency comes from the fact that the timer init code starts to
use clocks and hwmod and we need clocks to be initialized by then.
There are various problems doing clk inits this early, one is,
not being able to do dynamic clk registrations and hence the
dependency on clk-private.h. The other is, inability to debug
early kernel crashes without enabling DEBUG_LL and earlyprintk.
Doing early clk init also exposed another instance of a kernel
panic due to a BUG() when CONFIG_DEBUG_SLAB is enabled.
[ 0.000000] Kernel BUG at c01174f8 [verbose debug info unavailable]
[ 0.000000] Internal error: Oops - BUG: 0 [#1] SMP ARM
[ 0.000000] Modules linked in:
[ 0.000000] CPU: 0 Not tainted (3.9.0-rc1-12179-g72d48f9 #6)
[ 0.000000] PC is at __kmalloc+0x1d4/0x248
[ 0.000000] LR is at __clk_init+0x2e0/0x364
[ 0.000000] pc : [<c01174f8>] lr : [<c0441f54>] psr: 600001d3
[ 0.000000] sp : c076ff28 ip : c065cefc fp : c0441f54
[ 0.000000] r10: 0000001c r9 : 000080d0 r8 : c076ffd4
[ 0.000000] r7 : c074b578 r6 : c0794d88 r5 : 00000040 r4 : 00000000
[ 0.000000] r3 : 00000000 r2 : c07cac70 r1 : 000080d0 r0 : 0000001c
[ 0.000000] Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
[ 0.000000] Control: 10c53c7d Table: 8000404a DAC: 00000017
[ 0.000000] Process swapper (pid: 0, stack limit = 0xc076e240)
[ 0.000000] Stack: (0xc076ff28 to 0xc0770000)
[ 0.000000] ff20: 22222222 c0794ec8 c06546e8 00000000 00000040 c0794d88
[ 0.000000] ff40: c074b578 c076ffd4 c07951c8 c076e000 00000000 c0441f54 c074b578 c076ffd4
[ 0.000000] ff60: c0793828 00000040 c0794d88 c074b578 c076ffd4 c0776900 c076e000 c07272ac
[ 0.000000] ff80: 2f800000 c074c968 c07f93d0 c0719780 c076ffa0 c076ff98 00000000 00000000
[ 0.000000] ffa0: 00000000 00000000 00000000 00000001 c074cd6c c077b1ec 8000406a c0715724
[ 0.000000] ffc0: 00000000 00000000 00000000 00000000 00000000 c074c968 10c53c7d c0776974
[ 0.000000] ffe0: c074cd6c c077b1ec 8000406a 411fc092 00000000 80008074 00000000 00000000
[ 0.000000] [<c01174f8>] (__kmalloc+0x1d4/0x248) from [<c0441f54>] (__clk_init+0x2e0/0x364)
[ 0.000000] [<c0441f54>] (__clk_init+0x2e0/0x364) from [<c07272ac>] (omap4xxx_clk_init+0xbc/0x140)
[ 0.000000] [<c07272ac>] (omap4xxx_clk_init+0xbc/0x140) from [<c0719780>] (setup_arch+0x15c/0x284)
[ 0.000000] [<c0719780>] (setup_arch+0x15c/0x284) from [<c0715724>] (start_kernel+0x7c/0x334)
[ 0.000000] [<c0715724>] (start_kernel+0x7c/0x334) from [<80008074>] (0x80008074)
[ 0.000000] Code: e5883004 e1a00006 e28dd00c e8bd8ff0 (e7f001f2)
[ 0.000000] ---[ end trace 1b75b31a2719ed1c ]---
[ 0.000000] Kernel panic - not syncing: Attempted to kill the idle task!
It was a know issue, that slab allocations would fail when common
clock core tries to cache parent pointers for mux clocks on OMAP,
and hence a patch 'clk: Allow late cache allocation for clk->parents,
commit 7975059d' was added to work this problem around.
A BUG() within kmalloc() with CONFIG_DEBUG_SLAB enabled was completely
overlooked causing this regression.
More details on the issue reported can be found here,
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg85932.html
With all these issues around clk inits happening way too early, it
makes sense to at least move them to a point where dynamic memory
allocations are possible. So move them to a point just before the
timer code starts using clocks and hwmod.
This should at least pave way for clk inits on OMAP moving to dynamic
clock registrations instead of using the static macros defined in
clk-private.h.
The issue with kernel panic while CONFIG_DEBUG_SLAB is enabled
was reported by Piotr Haber and Tony Lindgren and this patch
fixes the reported issue as well.
Reported-by: Piotr Haber <phaber@broadcom.com>
Reviewed-by: Mike Turquette <mturquette@linaro.org>
Acked-by: Paul Walmsley <paul@pwsan.com>
Cc: stable@vger.kernel.org # v3.8
Commit bbd707ac {ARM: omap2: use machine specific hook for late init}
accidentally added two declarations for omap4430_init_late().
Remove the duplicate declaration.
Cc: Shawn Guo <shawn.guo@linaro.org>
Pull ARM SoC late OMAP changes from Olof Johansson:
"This branch contains changes for OMAP that came in late during the
release staging, close to when the merge window opened.
It contains, among other things:
- OMAP PM fixes and some patches for audio device integration
- OMAP clock fixes related to common clock conversion
- A set of patches cleaning up WFI entry and blocking.
- A set of fixes and IP block support for PM on TI AM33xx SoCs
(Beaglebone, etc)
- A set of smaller fixes and cleanups around AM33xx restart and
revision detection, as well as removal of some dead code
(CONFIG_32K_TIMER_HZ)"
* tag 'late-omap' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (34 commits)
ARM: omap2: include linux/errno.h in hwmod_reset
ARM: OMAP2+: fix some omap_device_build() calls that aren't compiled by default
ARM: OMAP4: hwmod data: Enable AESS hwmod device
ARM: OMAP4: hwmod data: Update AESS data with memory bank area
ARM: OMAP4+: AESS: enable internal auto-gating during initial setup
ASoC: TI AESS: add autogating-enable function, callable from architecture code
ARM: OMAP2+: hwmod: add enable_preprogram hook
ARM: OMAP4: clock data: Add missing clkdm association for dpll_usb
ARM: OMAP2+: PM: Fix the dt return condition in pm_late_init()
ARM: OMAP2: am33xx-hwmod: Fix "register offset NULL check" bug
ARM: OMAP2+: AM33xx: hwmod: add missing HWMOD_NO_IDLEST flags
ARM: OMAP: AM33xx hwmod: Add parent-child relationship for PWM subsystem
ARM: OMAP: AM33xx hwmod: Corrects PWM subsystem HWMOD entries
ARM: DTS: AM33XX: Add nodes for OCMC RAM and WKUP-M3
ARM: OMAP2+: AM33XX: Update the hardreset API
ARM: OMAP2+: AM33XX: hwmod: Update the WKUP-M3 hwmod with reset status bit
ARM: OMAP2+: AM33XX: hwmod: Fixup cpgmac0 hwmod entry
ARM: OMAP2+: AM33XX: hwmod: Update TPTC0 hwmod with the right flags
ARM: OMAP2+: AM33XX: hwmod: Register OCMC RAM hwmod
ARM: OMAP2+: AM33XX: CM/PRM: Use __ASSEMBLER__ macros in header files
Add restart hook so that DTS based AM33xx builds can restart
the platform.
Signed-off-by: Jean-Sebastien A. Beaudry <jsabeaudry@handyem.com>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
