The mux settings for keypad are done for omap4430sdp in
board file.
Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com>
[tony@atomide.com: improved formatting a bit]
Don't PTR_ERR() a non-error pointer:
initcall omap4_l3_init+0x0/0xdc returned -544980480 after 0 usecs
initcall omap4_l3_init+0x0/0xdc returned with error code -544980480
Signed-off-by: Rabin Vincent <rabin@rab.in>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6:
hwspinlock: depend on OMAP4
ARM: OMAP2+: Fix warnings for GPMC interrupt
OMAP4: PandaBoard: remove unused power regulators
arm: mach-omap2: omap_l3_smx: fix irq handler setup
arm: mach-omap2: devices: fix omap3_l3_init() return value
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (442 commits)
[media] videobuf2-dma-contig: make cookie() return a pointer to dma_addr_t
[media] sh_mobile_ceu_camera: Do not call vb2's mem_ops directly
[media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTURE
[media] v4l: soc-camera: Store negotiated buffer settings
[media] rc: interim support for 32-bit NEC-ish scancodes
[media] mceusb: topseed 0x0011 needs gen3 init for tx to work
[media] lirc_zilog: error out if buffer read bytes != chunk size
[media] lirc: silence some compile warnings
[media] hdpvr: use same polling interval as other OS
[media] ir-kbd-i2c: pass device code w/key in hauppauge case
[media] rc/keymaps: Remove the obsolete rc-rc5-tv keymap
[media] remove the old RC_MAP_HAUPPAUGE_NEW RC map
[media] rc/keymaps: Rename Hauppauge table as rc-hauppauge
[media] rc-rc5-hauppauge-new: Fix Hauppauge Grey mapping
[media] rc-rc5-hauppauge-new: Add support for the old Black RC
[media] rc-rc5-hauppauge-new: Add the old control to the table
[media] rc-winfast: Fix the keycode tables
[media] a800: Fix a few wrong IR key assignments
[media] opera1: Use multimedia keys instead of an app-specific mapping
[media] dw2102: Use multimedia keys instead of an app-specific mapping
Fix up trivial conflicts (remove/modify and some real conflicts) in:
arch/arm/mach-omap2/devices.c
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/dabusb/dabusb.c
drivers/staging/dabusb/dabusb.h
drivers/staging/easycap/easycap_ioctl.c
drivers/staging/usbvideo/usbvideo.c
drivers/staging/usbvideo/vicam.c
Make sure the kernel can be compiled with both OMAP2 and OMAP3 camera
support linked in, and give public symbols proper omap2/omap3 prefixes.
Signed-off-by: Sergio Aguirre <saaguirre@ti.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
The omap3isp platform device requires platform data. Instead of
registering the device in omap2_init_devices(), export an
omap3_init_camera() function to fill the device structure with the
platform data pointer and register the device.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
The ISP CBUFF module isn't use, its resource isn't needed.
Add new/changed base address definitions and resources for
OMAP3630 ISP.
The OMAP3430 CSI2PHY block is same as the OMAP3630 CSIPHY2
block. But the later name is chosen as it gives more symmetry
to the names.
Signed-off-by: Tuukka Toivonen <tuukkat76@gmail.com>
Signed-off-by: Vimarsh Zutshi <vimarsh.zutshi@gmail.com>
Fix the return value for the successful case.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
The l3 interconnect device is build with all the data required
to handle the error logging. The data is extracted from the
hwmod data base.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: sricharan <r.sricharan@ti.com>
Acked-by: Benoit Cousson <b-cousson@ti.com>
hwmod database.
'devel-hsmmc' into omap-for-linus
arch/arm/mach-omap2/omap_hwmod_44xx_data.c
OMAP2420 platform consists of mmc block as in omap1 and not the
hsmmc block as present in omap2430, omap3, omap4 platforms.
Removing all base address macro defines except keeping one for OMAP2420 and
adapting only hsmmc device registration and driver to hwmod framework.
Changes involves:
1) Remove controller reset in devices.c which is taken care of
by hwmod framework.
2) Using omap-device layer to register device and utilizing data from
hwmod data file for base address, dma channel number, Irq_number,
device attribute.
3) Update the driver to use dev_attr to find whether controller
supports dual volt cards
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com>
Reviewed-by: Balaji T K <balajitk@ti.com>
Cc: Benoit Cousson <b-cousson@ti.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Tony Lindgren <tony@atomide.com>
Moving the definition of mux setting API from devices.c to hsmmc.c
and renaming it from "omap2_mmc_mux" to "omap_hsmmc_mux".
Also calling "omap_hsmmc_mux" from omap2_hsmmc_init.
Cc: Chris Ball <cjb@laptop.org
The MMC controller on the OMAP2420 is different from those
on the OMAP2430, OMAP3 and OMAP4 families - all of the latter
are identical. The one on the OMAP2420 is closer to that
on OMAP1 chips.
Currently, the n8x0 is the only OMAP2420 platform supported
in mainline which registers the MMC controller. Upcoming
changes to register the controllers using hwmod data are
potentially invasive. To reduce the risk, separate out the
2420 controller registration from the common init function
and update its only user. Also seperating out mux settings
for OMAP2420.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Cc: Madhusudhan Chikkature <madhu.cr@ti.com>
Cc: Chris Ball <cjb@laptop.org>
Remove static platform_device and resource data within
omap mailbox driver; use the one defined in the hwmod
database along with omap_device framework for device
build and registration.
Add device latency functions to be used, so clock can be
enabled and sysconfig is configured.
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com>
Signed-off-by: Omar Ramirez Luna <omar.ramirez@ti.com>
'devel-nand' into omap-for-linus
-Add the platform changes for the keypad driver
-Register keyboard device with hwmod framework.
Signed-off-by: Syed Rafiuddin <rafiuddin.syed@ti.com>
Signed-off-by: Abraham Arce <x0066660@ti.com>
Cleans up all base address definitions for omap_mcspi
and adapts the device registration and driver to hwmod framework.
Changes involves:
1) Removing all base address macro defines.
device attribute(number of chipselect).
3) Appending base address with pdata reg_offset for omap4 boards.
For omap4 all regs used in driver deviate with reg_offset_macros
defined with an value of 0x100. So pass this offset through pdata
and append the same to base address retrieved from hwmod data file
and we are not mapping *_HL_* regs which are not used in driver.
Signed-off-by: Charulatha V <charu@ti.com>
Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
Reviewed-by: Partha Basak <p-basak2@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
We want to have just CONFIG_ARCH_OMAP2, 3 and 4. The rest
are nowadays just subcategories of these.
Search and replace the following:
ARCH_OMAP2420 SOC_OMAP2420
ARCH_OMAP2430 SOC_OMAP2430
ARCH_OMAP3430 SOC_OMAP3430
No functional changes.
Signed-off-by: Thomas Weber <weber@corscience.de>
Acked-by: Sourav Poddar <sourav.poddar@ti.com>
omap2_wd_timer_disable is declared in wdtimer.h and used by hwmod
function pointers for usage, the header inclusion is necessary
to ensure that the prototype and function remains consistent.
omap_wdt_latency is passed as a pointer and does not need global scope
Fixes sparse warnings:
arch/arm/mach-omap2/devices.c:981:31: warning: symbol 'omap_wdt_latency' was not declared. Should it be static?
arch/arm/mach-omap2/wd_timer.c:27:5: warning: symbol 'omap2_wd_timer_disable' was not declared. Should it be static?
Signed-off-by: Nishanth Menon <nm@ti.com>
The OMAP watchdog timer IP blocks require a specific set of register
writes to occur before they will be disabled[1], even if the device
clocks appear to be disabled in the CM_*CLKEN registers. In the MPU
watchdog case, failure to execute this reset sequence will eventually
cause the watchdog to reset the OMAP unexpectedly.
Previously, the code to disable this watchdog was manually called from
mach-omap2/devices.c during device initialization. This causes the
watchdog to be unconditionally disabled for a portion of kernel
initialization. This should be controllable by the board-*.c files,
since some system integrators will want full watchdog coverage of
kernel initialization. Also, the watchdog disable code was not
connected to the hwmod shutdown code. This means that calling
omap_hwmod_shutdown() will not, in fact, disable the watchdog, and the
goal of omap_hwmod_shutdown() is to be able to shutdown any on-chip
OMAP device.
To resolve the latter problem, populate the pre_shutdown pointer in
the watchdog timer hwmod classes with a function that executes the
watchdog shutdown sequence. This allows the hwmod code to fully
disable the watchdog.
Then, to allow some board files to support watchdog coverage
throughout kernel initialization, add common code to mach-omap2/io.c
to cause the MPU watchdog to be disabled on boot unless a board file
specifically requests it to remain enabled. Board files can do this
by changing the watchdog timer hwmod's postsetup state between the
omap2_init_common_infrastructure() and omap2_init_common_devices()
function calls.
1. OMAP34xx Multimedia Device Silicon Revision 3.1.x Rev. ZH
[SWPU222H], Section 16.4.3.6, "Start/Stop Sequence for WDTs (Using
WDTi.WSPR Register)"
Cc: Benoît Cousson <b-cousson@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Charulatha Varadarajan <charu@ti.com>
Split the wd_timer disable code out into its own file,
mach-omap2/wd_timer.c; it belongs in its own file rather than
cluttering up devices.c.
clk_get() return value should be checked with IS_ERR(). Furthermore,
clocks should be put and disabled properly.
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (163 commits)
omap: complete removal of machine_desc.io_pg_offst and .phys_io
omap: UART: fix wakeup registers for OMAP24xx UART2
omap: Fix spotty MMC voltages
ASoC: OMAP4: MCPDM: Remove unnecessary include of plat/control.h
serial: omap-serial: fix signess error
OMAP3: DMA: Errata i541: sDMA FIFO draining does not finish
omap: dma: Fix buffering disable bit setting for omap24xx
omap: serial: Fix the boot-up crash/reboot without CONFIG_PM
OMAP3: PM: fix scratchpad memory accesses for off-mode
omap4: pandaboard: enable the ehci port on pandaboard
omap4: pandaboard: Fix the init if CONFIG_MMC_OMAP_HS is not set
omap4: pandaboard: remove unused hsmmc definition
OMAP: McBSP: Remove null omap44xx ops comment
OMAP: McBSP: Swap CLKS source definition
OMAP: McBSP: Fix CLKR and FSR signal muxing
OMAP2+: clock: reduce the amount of standard debugging while disabling unused clocks
OMAP: control: move plat-omap/control.h to mach-omap2/control.h
OMAP: split plat-omap/common.c
OMAP: McBSP: implement functional clock switching via clock framework
OMAP: McBSP: implement McBSP CLKR and FSR signal muxing via mach-omap2/mcbsp.c
Fixed up trivial conflicts in arch/arm/mach-omap2/
{board-zoom-peripherals.c,devices.c} as per Tony
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits)
ALSA: hda - Disable sticky PCM stream assignment for AD codecs
ALSA: usb - Creative USB X-Fi volume knob support
ALSA: ca0106: Use card specific dac id for mute controls.
ALSA: ca0106: Allow different sound cards to use different SPI channel mappings.
ALSA: ca0106: Create a nice spot for mapping channels to dacs.
ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence.
ALSA: ca0106: Pull out dac powering routine into separate function.
ALSA: ca0106 - add Sound Blaster 5.1vx info.
ASoC: tlv320dac33: Use usleep_range for delays
ALSA: usb-audio: add Novation Launchpad support
ALSA: hda - Add workarounds for CT-IBG controllers
ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs
ASoC: tpa6130a2: Error handling for broken chip
ASoC: max98088: Staticise m98088_eq_band
ASoC: soc-core: Fix codec->name memory leak
ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066
ALSA: hda - Add some workarounds for Creative IBG
ALSA: hda - Fix wrong SPDIF NID assignment for CA0110
ALSA: hda - Fix codec rename rules for ALC662-compatible codecs
ALSA: hda - Add alc_init_jacks() call to other codecs
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: Makefile - replace the use of <module>-objs with <module>-y
crypto: hifn_795x - use cancel_delayed_work_sync()
crypto: talitos - sparse check endian fixes
crypto: talitos - fix checkpatch warning
crypto: talitos - fix warning: 'alg' may be used uninitialized in this function
crypto: cryptd - Adding the AEAD interface type support to cryptd
crypto: n2_crypto - Niagara2 driver needs to depend upon CRYPTO_DES
crypto: Kconfig - update broken web addresses
crypto: omap-sham - Adjust DMA parameters
crypto: fips - FIPS requires algorithm self-tests
crypto: omap-aes - OMAP2/3 AES hw accelerator driver
crypto: updates to enable omap aes
padata: add missing __percpu markup in include/linux/padata.h
MAINTAINERS: Add maintainer entries for padata/pcrypt
Only OMAP2+ platforms have the System Control Module (SCM) IP block.
In the past, we've kept the SCM header file in plat-omap. This has
led to abuse - device drivers including it; includes being added that
create implicit dependencies on OMAP2+ builds; etc.
In response, move the SCM headers into mach-omap2/.
As part of this, remove the direct SCM access from the OMAP UDC
driver. It was clearly broken. The UDC code needs an indepth review for
use on OMAP2+ chips.
Cc: Cory Maccarrone <darkstar6262@gmail.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Inorder to avoid any assumptions from bootloader, the watchdog
timer module is reset during init. This enables the watchdog
timer.
Therefore, it is required to disable WDT after it is reset
during init. Otherwise the system would reboot as per the default
watchdog timer registers settings.
Later, when the watchdog driver is loaded, the watchdog timer settings
is adjusted as per the default timer_margin set in the driver and the
driver would supports the normal operations supported by OMAP watchdog
timer.
Reported-by: Kevin Hilman <khilman@deeprootsystems.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-linus
Upcoming ASoC multi-component and OMAP hwmod changes will conflict
in arch/arm/mach-omap2/devices.c. Avoid this by moving a little bit
include statement introduced by ASoC Multi-Component Support patch.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Cc: Paul Walmsley <paul@pwsan.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
In OMAP4, as per new PM programming model, the legacy registers
which were there in OMAP3 are all shifted by 0x100 while new one's
are added from offset 0 to 0x10.
For OMAP4, the register offset appending of 0x100 done in devices.c
currently, is moved to driver file.This change fits in for current
implementation as well as once the driver undergoes hwmod adaptation.
Cc: Adrian Hunter <adrian.hunter@nokia.com>
This patch splits omap_init_wdt() into separate omap_init_wdt()
functions under mach-omap1 and mach-omap2 and set them up with
subsys_initcall.
Also it uses omap_device_build() API instead of
platform_device_register() for watchdog timer device registration
for OMAP2plus chips.
For OMAP2plus chips, the device specific data defined in centralized
hwmod database will be used.
Acked-by: Cousson, Benoit <b-cousson@ti.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
wires variable is renamed, extended and this single variable to be used to
pass the platform capabilities, e.g DDR mode. Also removed the hardcoded
value was using as bus-width.
Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com>
Updates to enable omap aes
Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com>
[tony@atomide.com: updated to use CONFIG_ARCH_OMAP2/3 instead of old 24XX/34XX]
Fairly simple conflicts, the most serious ones are the i.MX ones which I
suspect now need another rename.
arch/arm/mach-mx2/clock_imx27.c
arch/arm/mach-mx2/devices.c
arch/arm/mach-omap2/board-rx51-peripherals.c
arch/arm/mach-omap2/board-zoom2.c
sound/soc/fsl/mpc5200_dma.c
sound/soc/fsl/mpc5200_dma.h
sound/soc/fsl/mpc8610_hpcd.c
sound/soc/pxa/spitz.c
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
git://gitorious.org/~doyu/lk/mainline into omap-for-linus
arch/arm/mach-omap1/devices.c
omap{1,2}-mailbox are modules that provide the 'omap-mailbox' driver.
Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
Will be useful to identify them later.
OMAP_STI doesn't exist in Kconfig, therefore removing all
references for it from the source code.
Signed-off-by: Christoph Egger <siccegge@cs.fau.de>
Convert 2420 platform init code to use new mux code
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits)
random: simplify fips mode
crypto: authenc - Fix cryptlen calculation
crypto: talitos - add support for sha224
crypto: talitos - add hash algorithms
crypto: talitos - second prepare step for adding ahash algorithms
crypto: talitos - prepare for adding ahash algorithms
crypto: n2 - Add Niagara2 crypto driver
crypto: skcipher - Add ablkcipher_walk interfaces
crypto: testmgr - Add testing for async hashing and update/final
crypto: tcrypt - Add speed tests for async hashing
crypto: scatterwalk - Fix scatterwalk_done() test
crypto: hifn_795x - Rename ablkcipher_walk to hifn_cipher_walk
padata: Use get_online_cpus/put_online_cpus in padata_free
padata: Add some code comments
padata: Flush the padata queues actively
padata: Use a timer to handle remaining objects in the reorder queues
crypto: shash - Remove usage of CRYPTO_MINALIGN
crypto: mv_cesa - Use resource_size
crypto: omap - OMAP macros corrected
Fix up conflicts in arch/arm/mach-omap2/devices.c
There is two gpio for mmc use, one is for card detecting, another is
used for checking write protect. Intialize its pinmux in case the bootloader
doesn't set it.
Signed-off-by: Stanley.Miao <stanley.miao@windriver.com>
arch/arm/Kconfig
arch/arm/include/asm/system.h
arch/arm/mm/Kconfig
Add V4L2 DSS driver support in device.c
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
