path: root/arch/arm/mach-omap2/gpmc-smc91x.c
2013-04-01ARM: OMAP2+: Convert SMC91x to use gpmc_cs_program_settings()Jon Hunter
Convert the OMAP2+ SMC91x code to use the gpmc_cs_program_settings() function for configuring the various GPMC options instead of directly programming the CONFIG1 register. Move configuration of the GPMC settings outside retime function and this does not need to be done if the timings are changed dynamically at runtime. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
2013-04-01ARM: OMAP2+: Add structure for storing GPMC settingsJon Hunter
The GPMC has various different configuration options such as bus-width, synchronous or asychronous mode selection, burst mode options etc. Currently, there is no central structure for storing all these options when configuring the GPMC for a given device. Some of the options are stored in the GPMC timing structure and some are directly programmed into the GPMC configuration register. Add a new structure to store these options and convert code to use this structure. Adding this structure will allow us to create a common function for configuring these options. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
2012-11-09ARM: OMAP2+: smc91x: generic timing calculationAfzal Mohammed
Generic gpmc timing calculation helper is available now, use it instead of custom timing calculation. Signed-off-by: Afzal Mohammed <afzal@ti.com>
2012-10-15ARM: OMAP2+: gpmc: localize gpmc headerAfzal Mohammed
Requirement of gpmc header outside of mach-omap2 has been cutoff, move gpmc header file in plat-omap folder to local mach-omap2 folder Objective - common zImage participation of omap Signed-off-by: Afzal Mohammed <afzal@ti.com>
2012-09-20ARM: OMAP2+: Make gpmc-smc91x.h localTony Lindgren
This can be local to mach-omap2. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-12ARM: OMAP: Split plat/hardware.h, use local soc.h for omap2+Tony Lindgren
As the plat and mach includes need to disappear for single zImage work, we need to remove plat/hardware.h. Do this by splitting plat/hardware.h into omap1 and omap2+ specific files. The old plat/hardware.h already has omap1 only defines, so it gets moved to mach/hardware.h for omap1. For omap2+, we use the local soc.h that for now just includes the related SoC headers to keep this patch more readable. Note that the local soc.h still includes plat/cpu.h that can be dealt with in later patches. Let's also include plat/serial.h from common.h for all the board-*.c files. This allows making the include files local later on without patching these files again. Note that only minimal changes are done in this patch for the drivers/watchdog/omap_wdt.c driver to keep things compiling. Further patches are needed to eventually remove cpu_is_omap usage in the drivers. Also only minimal changes are done to sound/soc/omap/* to remove the unneeded includes and to define OMAP44XX_MCPDM_L3_BASE locally so there's no need to include omap44xx.h. While at it, also sort some of the includes in the standard way. Cc: linux-watchdog@vger.kernel.org Cc: alsa-devel@alsa-project.org Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-12ARM: OMAP2+: Prepare for irqs.h removalTony Lindgren
As the interrupts should only be defined in the platform_data, and eventually coming from device tree, there's no need to define them in header files. Let's remove the hardcoded references to irqs.h and fix up the includes so we don't rely on headers included in irqs.h. Note that we're defining OMAP_INTC_START as 0 to the interrupts. This will be needed when we enable SPARSE_IRQ. For some drivers we need to add #include <plat/cpu.h> for now until these drivers are fixed to remove cpu_is_omapxxxx() usage. While at it, sort som of the includes the standard way, and add the trailing commas where they are missing in the related data structures. Note that for drivers/staging/tidspbridge we just define things locally. Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-10ARM: OMAP: remove plat/board.h fileIgor Grinberg
plat/board.h file is now empty - remove it. Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Chris Ball <cjb@laptop.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: linux-mmc@vger.kernel.org Cc: linux-mtd@lists.infradead.org Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-12arm: omap2plus: GPIO cleanupIgor Grinberg
use gpio_request_<one|array>() instead of multiple gpiolib calls, remove unneeded variables, etc. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: use smc91x_platdata to setup smc91xLadislav Michl
Use smc91x_platdata to setup smc91x, so we can get rid of OMAP specific stuff in smc91x driver Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-28ARM: OMAP2/3: Add generic smc91x support when connected to GPMCTony Lindgren
Convert the board-rx51 smc91x code to be generic and make the boards to use it. This allows future recalculation of the timings when the source clock gets scaled. Also correct the rx51 interrupt to be IORESOURCE_IRQ_HIGHLEVEL. Thanks to Paul Walmsley <paul@pwsan.com> for better GPMC timing calculations. Signed-off-by: Tony Lindgren <tony@atomide.com>
