path: root/arch/arm/mach-omap2/i2c.c
2011-07-10OMAP: hwmod: fix the i2c-reset timeout during bootupAvinash.H.M
The sequence of _ocp_softreset doesn't work for i2c. The i2c module has a special sequence to reset the module. The sequence is - Disable the I2C. - Write to SOFTRESET bit. - Enable the I2C. - Poll on the RESETDONE bit. The sequence is implemented as a function and the i2c_class is updated with the correct 'reset' pointer. omap_hwmod_softreset function is implemented which triggers the softreset by writing into sysconfig register. On following this sequence, i2c module resets properly and timeouts are not seen. Cc: Rajendra Nayak <rnayak@ti.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@ti.com> Signed-off-by: Avinash.H.M <avinashhm@ti.com> [paul@pwsan.com: combined this patch with a patch to remove HWMOD_INIT_NO_RESET from the 44xx hwmod flags; change register offset conditional code to use the IP block revision; minor code cleanup] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2010-07-05omap: mux: Convert 2420 platform init code to use new mux codeTony Lindgren
Convert 2420 platform init code to use new mux code Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-25omap: i2c: Fix muxing for command line enabled busJarkko Nikula
The commit b63128e81214cc2db2995d690438055c26d213a5 broke the pin muxing for I2C busses that are enabled from the kernel command line. Fix this by defining the board registration function omap_register_i2c_bus in common platform code as it was before but keep the muxing in architecture dependent files. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: Split i2c platform init for mach-omap1 and mach-omap2Tony Lindgren
Otherwise we cannot limit new mux code to mach-omap2. The same signal names should eventually work for other omaps under mach-omap2. Note that these pins don't need to be OMAP_PIN_INPUT_PULLUP, just OMAP_PIN_INPUT is enough. Cc: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
