path: root/arch/arm/mach-omap2/irq.c
2007-09-20ARM: OMAP: Optimize INTC register accesses and enable autoidlingJuha Yrjola
Use virtual addresses directly instead of physical addresses to avoid having to recalculate the virtual address with every register access. Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-25ARM: OMAP: Remove IVA IRQ bankKomal Shah
ARM11 can't access the IVA interrupt controller from IVA slave port. From Richard Woodruff: "The 0x40000000 is an IVA-ARM7 local bus address. The IVA-INTC is NOT accessible through the IVA-L3-Slave Port. The current TRM does say this directly and indirectly in a few spots and in figures." Signed-off-by: Komal Shah <komal_shah802003@yahoo.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-08-01[ARM] 3739/1: genirq updates: irq_chip, add and use irq_chip.nameDavid Brownell
Patch from David Brownell ARM genirq cleanups/updates: - Start switching platforms to newer APIs * use "irq_chip" name, not "irqchip" * providing irq_chip.name - Show irq_chip.name in /proc/interrupts, like on x86. This update a bit more than half of the ARM code. The irq_chip.name values were chosen to match docs (if I have them) or be otherwise obvious ("FPGA", "CPLD", or matching the code). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3145/1: OMAP 3a/5: Add support for omap24xxTony Lindgren
Patch from Tony Lindgren This patch adds support for omap24xx series of processors. The files live in arch/arm/mach-omap2, and share common files with omap15xx and omap16xx processors in arch/arm/plat-omap. Omap24xx support was originally added for 2.6.9 by TI. This code was then improved and integrated to share common code with omap15xx and omap16xx processors by various omap developers, such as Paul Mundt, Juha Yrjola, Imre Deak, Tony Lindgren, Richard Woodruff, Nishant Menon, Komal Shah et al. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
