path: root/arch/arm/mach-omap2/mux2420.c
2010-11-17OMAP: mux: Add __func__ macro to pr_xxx macrosDan Murphy
Removed mux: and added the __func__ macro to make debugging easier. Signed-off-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Tony Lindgren <tony@atomide.com>
2010-11-17OMAP: mux: Add support for control module split in several partitionsBenoit Cousson
Starting on OMAP4, the pin mux configuration is located in two different partitions of the control module (CODE_PAD and WKUP_PAD). The first one is inside the core power domain whereas the second one is inside the wakeup. - Add the capability to add any number of partition during board init time depending of Soc partitioning. - Add some init flags as well in order to avoid explicit Soc version check inside the mux core code. - Add a comment with mux0 mode on top of omap_mux/board/<partition> if the current mux mode is not the default one. Thanks to Tony Lindgren <tony@atomide.com> for the following improvements: - Add omap_mux_get for getting the partition data so platform level device code can use it. - Fix the rx51 board code to use the new API. - Do not store the partition for each mux entry. Look up the partition for debugfs instead. Thanks to Dan Murphy <dmurphy@ti.com> for testing on OMAP4 and reporting a couple of bugs. Thanks to Anand Gadiyar <gadiyar@ti.com> for testing on OMAP3 zoom and bug report. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Murphy Dan <dmurphy@ti.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Anand Gadiyar <gadiyar@ti.com>
2010-10-08OMAP: mach-omap2: Fix static declaration warningsManjunath Kondaiah G
This patch fixes sparse warnings due to non declaration of static structures and variables. Sparse warning logs fixed: arch/arm/mach-omap2/control.c:88:6: warning: symbol 'omap3_secure_ram_storage' was not declared. Should it be static? n arch/arm/mach-omap2/timer-gp.c:50:22: warning: symbol 'gptimer_wakeup' was not declared. Should it be static? arch/arm/mach-omap2/timer-gp.c:240:18: warning: symbol 'omap_timer' was not declared. Should it be static? arch/arm/mach-omap2/prcm.c:121:24: warning: symbol 'prcm_context' was not declared. Should it be static? arch/arm/mach-omap2/mux2420.c:510:29: warning: symbol 'omap2420_pop_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux2430.c:589:29: warning: symbol 'omap2430_pop_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:934:28: warning: symbol 'omap3_cus_subset' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1080:29: warning: symbol 'omap3_cus_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1272:28: warning: symbol 'omap3_cbb_subset' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1393:29: warning: symbol 'omap3_cbb_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1603:28: warning: symbol 'omap36xx_cbp_subset' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1821:29: warning: symbol 'omap36xx_cbp_ball' was not declared. Should it be static? arch/arm/mach-omap2/pm-debug.c:165:15: warning: symbol 'pm_dbg_dir' was not declared. Should it be static? arch/arm/mach-omap2/board-omap3evm.c:587:30: warning: symbol 'ads7846_config' was not declared. Should it be static? arch/arm/mach-omap2/board-omap3evm.c:606:23: warning: symbol 'omap3evm_spi_board_info' was not declared. Should it be static? arch/arm/mach-omap2/board-rx51-sdram.c:46:25: warning: symbol 'rx51_sdrc_params' was not declared. Should it be static? arch/arm/mach-omap2/board-rx51-sdram.c:211:25: warning: symbol 'rx51_get_sdram_timings' was not declared. Should it be static? arch/arm/mach-omap2/board-omap3touchbook.c:64:15: warning: symbol 'touchbook_revision' was not declared. Should it be static? arch/arm/mach-omap2/board-am3517evm.c:350:24: warning: symbol 'am3517_evm_dss_device' was not declared. Should it be static? arch/arm/mach-omap2/board-omap3stalker.c:567:23: warning: symbol 'omap3stalker_spi_board_info' was not declared. Should it be static? Signed-off-by: Manjunath Kondaiah G <manjugk@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: mux: Add data for 2420Tony Lindgren
Add data for 2420. Big thanks to Paul Walmsley <paul@pwsan.com> for generating usable mux data out of TRMs. Cc: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
