path: root/arch/arm/mach-omap2/mux34xx.c
2011-01-06omap3|4: mux: make local structures staticNishanth Menon
Mux data is passed by pointers to mux.c from the SoC specific mux file, these variables dont really need to be global scope. This fixes the following sparse warnings: arch/arm/mach-omap2/mux44xx.c:547:29: warning: symbol 'omap4_core_cbl_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux44xx.c:1265:29: warning: symbol 'omap4_core_cbs_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux44xx.c:1549:29: warning: symbol 'omap4_wkup_cbl_cbs_ball' was not declared. Should it be static? Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-11-17OMAP: mux: Add __func__ macro to pr_xxx macrosDan Murphy
Removed mux: and added the __func__ macro to make debugging easier. Signed-off-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Tony Lindgren <tony@atomide.com>
2010-11-17OMAP: mux: Add support for control module split in several partitionsBenoit Cousson
Starting on OMAP4, the pin mux configuration is located in two different partitions of the control module (CODE_PAD and WKUP_PAD). The first one is inside the core power domain whereas the second one is inside the wakeup. - Add the capability to add any number of partition during board init time depending of Soc partitioning. - Add some init flags as well in order to avoid explicit Soc version check inside the mux core code. - Add a comment with mux0 mode on top of omap_mux/board/<partition> if the current mux mode is not the default one. Thanks to Tony Lindgren <tony@atomide.com> for the following improvements: - Add omap_mux_get for getting the partition data so platform level device code can use it. - Fix the rx51 board code to use the new API. - Do not store the partition for each mux entry. Look up the partition for debugfs instead. Thanks to Dan Murphy <dmurphy@ti.com> for testing on OMAP4 and reporting a couple of bugs. Thanks to Anand Gadiyar <gadiyar@ti.com> for testing on OMAP3 zoom and bug report. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Murphy Dan <dmurphy@ti.com> Cc: Paul Walmsley <paul@pwsan.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Anand Gadiyar <gadiyar@ti.com>
2010-10-08OMAP: mach-omap2: Fix static declaration warningsManjunath Kondaiah G
This patch fixes sparse warnings due to non declaration of static structures and variables. Sparse warning logs fixed: arch/arm/mach-omap2/control.c:88:6: warning: symbol 'omap3_secure_ram_storage' was not declared. Should it be static? n arch/arm/mach-omap2/timer-gp.c:50:22: warning: symbol 'gptimer_wakeup' was not declared. Should it be static? arch/arm/mach-omap2/timer-gp.c:240:18: warning: symbol 'omap_timer' was not declared. Should it be static? arch/arm/mach-omap2/prcm.c:121:24: warning: symbol 'prcm_context' was not declared. Should it be static? arch/arm/mach-omap2/mux2420.c:510:29: warning: symbol 'omap2420_pop_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux2430.c:589:29: warning: symbol 'omap2430_pop_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:934:28: warning: symbol 'omap3_cus_subset' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1080:29: warning: symbol 'omap3_cus_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1272:28: warning: symbol 'omap3_cbb_subset' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1393:29: warning: symbol 'omap3_cbb_ball' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1603:28: warning: symbol 'omap36xx_cbp_subset' was not declared. Should it be static? arch/arm/mach-omap2/mux34xx.c:1821:29: warning: symbol 'omap36xx_cbp_ball' was not declared. Should it be static? arch/arm/mach-omap2/pm-debug.c:165:15: warning: symbol 'pm_dbg_dir' was not declared. Should it be static? arch/arm/mach-omap2/board-omap3evm.c:587:30: warning: symbol 'ads7846_config' was not declared. Should it be static? arch/arm/mach-omap2/board-omap3evm.c:606:23: warning: symbol 'omap3evm_spi_board_info' was not declared. Should it be static? arch/arm/mach-omap2/board-rx51-sdram.c:46:25: warning: symbol 'rx51_sdrc_params' was not declared. Should it be static? arch/arm/mach-omap2/board-rx51-sdram.c:211:25: warning: symbol 'rx51_get_sdram_timings' was not declared. Should it be static? arch/arm/mach-omap2/board-omap3touchbook.c:64:15: warning: symbol 'touchbook_revision' was not declared. Should it be static? arch/arm/mach-omap2/board-am3517evm.c:350:24: warning: symbol 'am3517_evm_dss_device' was not declared. Should it be static? arch/arm/mach-omap2/board-omap3stalker.c:567:23: warning: symbol 'omap3stalker_spi_board_info' was not declared. Should it be static? Signed-off-by: Manjunath Kondaiah G <manjugk@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-07-05omap: mux: Remove unncessary parens from mux34xx.cTony Lindgren
Remove unncessary parens from mux34xx.c Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-05-04omap3: Remove non-muxable ball entries for 3630Tony Lindgren
These are currently non-muxable, so let's save some memory and remove them. Otherwise we get the following warnings: mux: Unknown ball offset 0x5e mux: Unknown ball offset 0x60 mux: Unknown ball offset 0x62 ... Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-03omap: Fix 3630 mux errorsTony Lindgren
3630 has more mux signals than 34xx. The additional pins exist in omap36xx_cbp_subset, but are not initialized as the superset is missing these offsets. This causes the following errors during the boot: mux: Unknown entry offset 0x236 mux: Unknown entry offset 0x22e mux: Unknown entry offset 0x1ec mux: Unknown entry offset 0x1ee mux: Unknown entry offset 0x1f4 mux: Unknown entry offset 0x1f6 mux: Unknown entry offset 0x1f8 mux: Unknown entry offset 0x1fa mux: Unknown entry offset 0x1fc mux: Unknown entry offset 0x22a mux: Unknown entry offset 0x226 mux: Unknown entry offset 0x230 mux: Unknown entry offset 0x22c mux: Unknown entry offset 0x228 Fix this by adding the missing offsets to omap3 superset. Note that additionally the uninitialized pins need to be skipped on 34xx. Based on an earlier patch by Allen Pais <allen.pais@ti.com>. Reported-by: Allen Pais <allen.pais@ti.com> Signed-off-by: Allen Pais <allen.pais@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: mux: Add 36xx CBP package supportTony Lindgren
Add 36xx CBP package support Cc: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-11omap: mux: Add new style pin multiplexing data for 34xxTony Lindgren
Add new style mux data for 34xx. This should also work with 3630 easily by adding the processor subset and ball data. Note that this data is __initdata, and gets optimized out except for the GPIO pins if CONFIG_OMAP_MUX is not set. Also note that this data uses omap3630 naming for the SDMMC registers instead of 34xx naming with just MMC. Cc: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
