Add missed callback needed for supporting suspend-to-disk (hibernation) mode.
Signed-off-by: Grygorii Strashko <Grygorii.Strashko@linaro.org>
Acked-by: Kevin Hilman <khilman@linaro.org>
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so #ifdef blocks
depending on CONFIG_PM_RUNTIME may now be changed to depend on
CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere in the code under
arch/arm/ (the defconfig files will be modified later).
Acked-by: Nishanth Menon <nm@ti.com>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
We're moving omaps to use device tree based booting and already have
omap2, omap4, omap5, am335x and am437x booting in device tree only
mode.
Only omap3 still has legacy booting still around and we really want
to make that device tree only. So let's add a warning about deprecated
legacy booting so we get people to upgrade their boards to use device
tree based booting and find out about any remaining issues.
Note that for most boards we already have the .dts file and those can
be booted with without changing the bootloader using the appended
DTB mode.
Acked-By: Sebastian Reichel <sre@kernel.org>
Reviewed-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
When an alias for a clock already exists the warning is printed. For
every module with a main_clk defined, a clk alias for fck is added.
There are some components that have the same main_clk defined, so this
is a really normal situation.
For example the am33xx edma device has 4 components using the same main
clock. So there are three warnings in the boot log for this already
existing clock alias:
platform 49000000.edma: alias fck already exists
As this is only interesting for developers, this patch changes the
message to a debug message.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Need a newer base version to get a regulator fix for Samsung platforms that
they enable building in a defconfig.
Linux 3.13-rc5
Due to the cross dependencies between hwmod for automanaged device
information for OMAP and dts node definitions, we can run into scenarios
where the dts node is defined, however it's hwmod entry is yet to be
added. In these cases:
a) omap_device does not register a pm_domain (since it cannot find
hwmod entry).
b) driver does not know about (a), does a pm_runtime_get_sync which
never fails
c) It then tries to do some operation on the device (such as read the
revision register (as part of probe) without clock or adequate OMAP
generic PM operation performed for enabling the module.
This causes a crash such as that reported in:
https://bugzilla.kernel.org/show_bug.cgi?id=66441
When 'ti,hwmod' is provided in dt node, it is expected that the device
will not function without the OMAP's power automanagement. Hence, when
we hit a fail condition (due to hwmod entries not present or other
similar scenario), fail at pm_domain level due to lack of data, provide
enough information for it to be fixed, however, it allows for the driver
to take appropriate measures to prevent crash.
Reported-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
As we currently need to support a mix of legacy platform data and
device tree intialized data, let's make sure things keep working
for the TWL GPIOs.
Mostly the issue is caused by the fact that DSS does not yet have
device tree bindings, so we need to rely on the TWL GPIO callback
for setting up things like LCD backlight for some boards.
As of_platform_populate() for the TWL GPIO is called by twl-core
after the I2C bus has been initialized, we cannot pass the auxdata
table from the board init code to twl-core like we used to with
just legacy platform data.
So let's use the omap_device bus hook to patch in the platform
data for TWL GPIO until we have sorted out the issues with the
TWL GPIOs and device tree bindings.
The other option was be to initialize twl core using legacy
platform data, which seems like a step backwards as we're moving
to device tree only initialization. And we really don't want to
add custom configuration functions to the TWL GPIO driver either
for this.
OMAP device hooks around suspend|resume_noirq ensures that hwmod
devices are forced to idle using omap_device_idle/enable as part of
the last stage of suspend activity.
For a device such as i2c who uses autosuspend, it is possible to enter
the suspend path with dev->power.runtime_status = RPM_ACTIVE.
As part of the suspend flow, the generic runtime logic would increment
it's dev->power.disable_depth to 1. This should prevent further
pm_runtime_get_sync from succeeding once the runtime_status has been
set to RPM_SUSPENDED.
Now, as part of the suspend_noirq handler in omap_device, we force the
following: if the device status is !suspended, we force the device
to idle using omap_device_idle (clocks are cut etc..). This ensures
that from a hardware perspective, the device is "suspended". However,
runtime_status is left to be active.
*if* an operation is attempted after this point to
pm_runtime_get_sync, runtime framework depends on runtime_status to
indicate accurately the device status, and since it sees it to be
ACTIVE, it assumes the module is functional and returns a non-error
value. As a result the user will see pm_runtime_get succeed, however a
register access will crash due to the lack of clocks.
To prevent this from happening, we should ensure that runtime_status
exactly indicates the device status. As a result of this change
any further calls to pm_runtime_get* would return -EACCES (since
disable_depth is 1). On resume, we restore the clocks and runtime
status exactly as we suspended with. These operations are not expected
to fail as we update the states after the core runtime framework has
suspended itself and restore before the core runtime framework has
resumed.
Cc: stable@vger.kernel.org # v3.4+
Reported-by: J Keerthy <j-keerthy@ti.com>
Acked-by: Rajendra Nayak <rnayak@ti.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
In case of error, the function omap_device_alloc() returns ERR_PTR()
and never returns NULL. The NULL test in the return value check
should be replaced with IS_ERR().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Some hwmods which are marked with HWMOD_INIT_NO_IDLE are left in enabled
state post setup(). When a omap_device gets created for such hwmods
make sure the omap_device and pm_runtime states are also in sync for such
hwmods by doing a omap_device_enable() and pm_runtime_set_active() for the
device.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Tested-by: Mark Jackson <mpfj-list@newflow.co.uk>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Memory controllers in OMAP (like GPMC and EMIF) have the hwmods marked with
HWMOD_INIT_NO_IDLE and are left in enabled state post initial setup.
Even if they have drivers missing, avoid idling them as part of
omap_device_late_idle()
Pull power management and ACPI updates from Rafael Wysocki:
"This time the total number of ACPI commits is slightly greater than
the number of cpufreq commits, but Viresh Kumar (who works on cpufreq)
remains the most active patch submitter.
To me, the most significant change is the addition of offline/online
device operations to the driver core (with the Greg's blessing) and
the related modifications of the ACPI core hotplug code. Next are the
freezer updates from Colin Cross that should make the freezing of
tasks a bit less heavy weight.
We also have a couple of regression fixes, a number of fixes for
issues that have not been identified as regressions, two new drivers
and a bunch of cleanups all over.
Highlights:
- Hotplug changes to support graceful hot-removal failures.
It sometimes is necessary to fail device hot-removal operations
gracefully if they cannot be carried out completely. For example,
if memory from a memory module being hot-removed has been allocated
for the kernel's own use and cannot be moved elsewhere, it's
desirable to fail the hot-removal operation in a graceful way
rather than to crash the kernel, but currenty a success or a kernel
crash are the only possible outcomes of an attempted memory
hot-removal. Needless to say, that is not a very attractive
alternative and it had to be addressed.
However, in order to make it work for memory, I first had to make
it work for CPUs and for this purpose I needed to modify the ACPI
processor driver. It's been split into two parts, a resident one
handling the low-level initialization/cleanup and a modular one
playing the actual driver's role (but it binds to the CPU system
device objects rather than to the ACPI device objects representing
processors). That's been sort of like a live brain surgery on a
patient who's riding a bike.
So this is a little scary, but since we found and fixed a couple of
regressions it caused to happen during the early linux-next testing
(a month ago), nobody has complained.
As a bonus we remove some duplicated ACPI hotplug code, because the
ACPI-based CPU hotplug is now going to use the common ACPI hotplug
code.
- Lighter weight freezing of tasks.
These changes from Colin Cross and Mandeep Singh Baines are
targeted at making the freezing of tasks a bit less heavy weight
operation. They reduce the number of tasks woken up every time
during the freezing, by using the observation that the freezer
simply doesn't need to wake up some of them and wait for them all
to call refrigerator(). The time needed for the freezer to decide
to report a failure is reduced too.
Also reintroduced is the check causing a lockdep warining to
trigger when try_to_freeze() is called with locks held (which is
generally unsafe and shouldn't happen).
- cpufreq updates
First off, a commit from Srivatsa S Bhat fixes a resume regression
introduced during the 3.10 cycle causing some cpufreq sysfs
attributes to return wrong values to user space after resume. The
fix is kind of fresh, but also it's pretty obvious once Srivatsa
has identified the root cause.
Second, we have a new freqdomain_cpus sysfs attribute for the
acpi-cpufreq driver to provide information previously available via
related_cpus. From Lan Tianyu.
Finally, we fix a number of issues, mostly related to the
CPUFREQ_POSTCHANGE notifier and cpufreq Kconfig options and clean
up some code. The majority of changes from Viresh Kumar with bits
from Jacob Shin, Heiko Stübner, Xiaoguang Chen, Ezequiel Garcia,
Arnd Bergmann, and Tang Yuantian.
- ACPICA update
A usual bunch of updates from the ACPICA upstream.
During the 3.4 cycle we introduced support for ACPI 5 extended
sleep registers, but they are only supposed to be used if the
HW-reduced mode bit is set in the FADT flags and the code attempted
to use them without checking that bit. That caused suspend/resume
regressions to happen on some systems. Fix from Lv Zheng causes
those registers to be used only if the HW-reduced mode bit is set.
Apart from this some other ACPICA bugs are fixed and code cleanups
are made by Bob Moore, Tomasz Nowicki, Lv Zheng, Chao Guan, and
Zhang Rui.
- cpuidle updates
New driver for Xilinx Zynq processors is added by Michal Simek.
Multidriver support simplification, addition of some missing
kerneldoc comments and Kconfig-related fixes come from Daniel
Lezcano.
- ACPI power management updates
Changes to make suspend/resume work correctly in Xen guests from
Konrad Rzeszutek Wilk, sparse warning fix from Fengguang Wu and
cleanups and fixes of the ACPI device power state selection
routine.
- ACPI documentation updates
Some previously missing pieces of ACPI documentation are added by
Lv Zheng and Aaron Lu (hopefully, that will help people to
uderstand how the ACPI subsystem works) and one outdated doc is
updated by Hanjun Guo.
- Assorted ACPI updates
We finally nailed down the IA-64 issue that was the reason for
reverting commit 9f29ab11ddbf ("ACPI / scan: do not match drivers
against objects having scan handlers"), so we can fix it and move
the ACPI scan handler check added to the ACPI video driver back to
the core.
A mechanism for adding CMOS RTC address space handlers is
introduced by Lan Tianyu to allow some EC-related breakage to be
fixed on some systems.
A spec-compliant implementation of acpi_os_get_timer() is added by
Mika Westerberg.
The evaluation of _STA is added to do_acpi_find_child() to avoid
situations in which a pointer to a disabled device object is
returned instead of an enabled one with the same _ADR value. From
Jeff Wu.
Intel BayTrail PCH (Platform Controller Hub) support is added to
the ACPI driver for Intel Low-Power Subsystems (LPSS) and that
driver is modified to work around a couple of known BIOS issues.
Changes from Mika Westerberg and Heikki Krogerus.
The EC driver is fixed by Vasiliy Kulikov to use get_user() and
put_user() instead of dereferencing user space pointers blindly.
Code cleanups are made by Bjorn Helgaas, Nicholas Mazzuca and Toshi
Kani.
- Assorted power management updates
The "runtime idle" helper routine is changed to take the return
values of the callbacks executed by it into account and to call
rpm_suspend() if they return 0, which allows us to reduce the
overall code bloat a bit (by dropping some code that's not
necessary any more after that modification).
The runtime PM documentation is updated by Alan Stern (to reflect
the "runtime idle" behavior change).
New trace points for PM QoS are added by Sahara
(<keun-o.park@windriver.com>).
PM QoS documentation is updated by Lan Tianyu.
Code cleanups are made and minor issues are addressed by Bernie
Thompson, Bjorn Helgaas, Julius Werner, and Shuah Khan.
- devfreq updates
New driver for the Exynos5-bus device from Abhilash Kesavan.
Minor cleanups, fixes and MAINTAINERS update from MyungJoo Ham,
Abhilash Kesavan, Paul Bolle, Rajagopal Venkat, and Wei Yongjun.
- OMAP power management updates
Adaptive Voltage Scaling (AVS) SmartReflex voltage control driver
updates from Andrii Tseglytskyi and Nishanth Menon."
* tag 'pm+acpi-3.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (162 commits)
cpufreq: Fix cpufreq regression after suspend/resume
ACPI / PM: Fix possible NULL pointer deref in acpi_pm_device_sleep_state()
PM / Sleep: Warn about system time after resume with pm_trace
cpufreq: don't leave stale policy pointer in cdbs->cur_policy
acpi-cpufreq: Add new sysfs attribute freqdomain_cpus
cpufreq: make sure frequency transitions are serialized
ACPI: implement acpi_os_get_timer() according the spec
ACPI / EC: Add HP Folio 13 to ec_dmi_table in order to skip DSDT scan
ACPI: Add CMOS RTC Operation Region handler support
ACPI / processor: Drop unused variable from processor_perflib.c
cpufreq: tegra: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: s3c64xx: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: omap: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: imx6q: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: exynos: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: dbx500: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: davinci: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: arm-big-little: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: powernow-k8: call CPUFREQ_POSTCHANGE notfier in error cases
cpufreq: pcc: call CPUFREQ_POSTCHANGE notfier in error cases
The "runtime idle" helper routine, rpm_idle(), currently ignores
return values from .runtime_idle() callbacks executed by it.
However, it turns out that many subsystems use
pm_generic_runtime_idle() which checks the return value of the
driver's callback and executes pm_runtime_suspend() for the device
unless that value is not 0. If that logic is moved to rpm_idle()
instead, pm_generic_runtime_idle() can be dropped and its users
will not need any .runtime_idle() callbacks any more.
Moreover, the PCI, SCSI, and SATA subsystems' .runtime_idle()
routines, pci_pm_runtime_idle(), scsi_runtime_idle(), and
ata_port_runtime_idle(), respectively, as well as a few drivers'
ones may be simplified if rpm_idle() calls rpm_suspend() after 0 has
been returned by the .runtime_idle() callback executed by it.
To reduce overall code bloat, make the changes described above.
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Remove "no_idle_on_suspend" check, since respective
driver should be able to prevent idling of an
omap device whenever required.
Driver's can get same behavior by just returning -EBUSY
from their ->runtime_suspend only during suspend.
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Rajendra nayak <rnayak@ti.com>
Cc: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
If DEBUG_LL and earlyprintk are enabled, and omap-serial.c is compiled
as a module, the kernel boot hangs early as the clocks for serial port
are cut while earlyprintk still uses the port.
The problem is a race between the late_initcall for omap_device (which
idles devices that have no drivers) and the late_initcall in
kernel/printk.c which turns off the earlyconsole. Any printks
that happen between this omap_device late initcall and the earlyconsole
late initcall will crash when accessing the UART.
The fix is to ensure the omap_device initcall happens after the
earlyconsole initcall.
Reported-by: Tony Lindgren <tony@atomide.com>
arch/arm/plat-omap/dmtimer.c
Consistently check errors using the usual method used in the kernel
for much of its history. For instance:
int gpmc_cs_set_timings(int cs, const struct gpmc_timings *t)
int div;
div = gpmc_calc_divider(t->sync_clk);
if (div < 0)
return div;
static int gpmc_set_async_mode(int cs, struct gpmc_timings *t)
return gpmc_cs_set_timings(cs, t);
ret = gpmc_set_async_mode(gpmc_onenand_data->cs, &t);
if (IS_ERR_VALUE(ret))
return ret;
So, gpmc_cs_set_timings() thinks any negative return value is an error,
but where we check that in higher levels, only a limited range are
errors...
There is only _one_ use of IS_ERR_VALUE() in arch/arm which is really
appropriate, and that is in arch/arm/include/asm/syscall.h:
static inline long syscall_get_error(struct task_struct *task,
struct pt_regs *regs)
unsigned long error = regs->ARM_r0;
return IS_ERR_VALUE(error) ? error : 0;
because this function really does have to differentiate between error
return values and addresses which look like negative numbers (eg, from
mmap()).
So, here's a patch to remove them from OMAP, except for the above.
omap_hwmod_lookup() only returns NULL on error, never an error pointer.
Checking the returned pointer using IS_ERR_OR_NULL() is needless
overhead. Use a simple !ptr check instead.
OMAP devices (oh->od) always have a valid platform device attached (see
omap_device_alloc()) so there's no point validating the platform device
pointer (we will have already oopsed long before if this is not the
case here.)
Lastly, oh->od is only ever NULL or a valid omap device pointer - 'oh'
comes from the statically declared hwmod tables, and the pointer is
only filled in by omap_device_alloc() at a point where the omap device
pointer must be valid.
Pull ARM SoC-specific updates from Arnd Bergmann:
"This is a larger set of new functionality for the existing SoC
families, including:
- vt8500 gains support for new CPU cores, notably the Cortex-A9 based
wm8850
- prima2 gains support for the "marco" SoC family, its SMP based
cousin
- tegra gains support for the new Tegra4 (Tegra114) family
- socfpga now supports a newer version of the hardware including SMP
- i.mx31 and bcm2835 are now using DT probing for their clocks
- lots of updates for sh-mobile
- OMAP updates for clocks, power management and USB
- i.mx6q and tegra now support cpuidle
- kirkwood now supports PCIe hot plugging
- tegra clock support is updated
- tegra USB PHY probing gets implemented diffently"
* tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits)
ARM: prima2: remove duplicate v7_invalidate_l1
ARM: shmobile: r8a7779: Correct TMU clock support again
ARM: prima2: fix __init section for cpu hotplug
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3)
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3)
arm: socfpga: Add SMP support for actual socfpga harware
arm: Add v7_invalidate_l1 to cache-v7.S
arm: socfpga: Add entries to enable make dtbs socfpga
arm: socfpga: Add new device tree source for actual socfpga HW
ARM: tegra: sort Kconfig selects for Tegra114
ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114
ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC
ARM: tegra: Fix build error for gic update
ARM: tegra: remove empty tegra_smp_init_cpus()
ARM: shmobile: Register ARM architected timer
ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move
ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT
ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles
ARM: mxs: use apbx bus clock to drive the timers on timrotv2
Remove now-obsolete code from arch/arm/mach-omap2/omap_device.c. This
mostly consists of removing the first attempt at device PM latency
handling. This was never really used, has been replaced by the common
dev_pm_qos code, and needs to go away as part of the DT conversion.
Also, the early platform_device creation code has been removed, as it
appears to be unused.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
This way the initcalls don't run on other SoCs on multiplatform
kernels. Otherwise we'll get something like this when booting
on vexpress:
omap_hwmod: _ensure_mpu_hwmod_is_setup: MPU initiator hwmod mpu not yet registered
WARNING: at arch/arm/mach-omap2/pm.c:82 _init_omap_device+0x74/0x94()
_init_omap_device: could not find omap_hwmod for mpu
omap-dma-engine omap-dma-engine: OMAP DMA engine driver
Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
When booting with DT the OF core can fill up the resources provided within
the DT blob.
The current way of handling the DT boot prevents us from removing hwmod data
for platforms only suppose to boot with DT (OMAP5 for example) since we need
to keep the whole hwmod database intact in order to have more resources in
hwmod than in DT (to be able to append the DMA resource from hwmod).
To fix this issue we just examine the OF provided resources:
If we do not have resources we use hwmod to fill them.
If we have resources we check if we already able to recive DMA resource, if
no we only append the DMA resurce from hwmod to the OF provided ones.
In this way we can start removing hwmod data for devices which have their
resources correctly configured in DT without regressions.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Benoît Cousson <b-cousson@ti.com>
[paul@pwsan.com: fixed checkpatch problem; updated to apply]
Add flags parameter for omap_hwmod_count_resources() so users can tell which
type of resources they are interested when counting them in hwmod database.
[paul@pwsan.com: updated to apply]
Remove arch/arm/plat-omap/include/plat/clock.h by merging it into
arch/arm/mach-omap1/clock.h and arch/arm/mach-omap2/clock.h.
The goal here is to facilitate ARM single image kernels by removing
includes via the "plat/" symlink.
[tony@atomide.com: fixed to remove duplicate clock.h includes]
Let's make omap_hwmod local to mach-omap2 for
ARM common zImage support.
Let's make omap_device local to mach-omap2 for
