To reduce kernel source file data duplication, share struct
omap_hwmod_dma_info arrays across OMAP2xxx and 3xxx hwmod data files.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Add a new hwmod class for IVA devices. To be used when hwmods
are created for IVA2 on OMAP3.
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Benoît Cousson <b-cousson@ti.com>
Add support for categorizing and iterating over hardware IP blocks by
the "class" of the IP block. The class is the type of the IP block:
e.g., "timer", "timer1ms", etc. Move the OCP_SYSCONFIG/SYSSTATUS data
from the struct omap_hwmod into the struct omap_hwmod_class, since
it's expected to stay consistent for each class. While here, fix some
comments.
The hwmod_class structures in this patch were designed and proposed by
Benoît Cousson <b-cousson@ti.com> and were refined in a discussion
between Thara Gopinath <thara@ti.com>, Kevin Hilman
<khilman@deeprootsystems.com>, and myself.
This patch uses WARN() lines that are longer than 80 characters, as
Kevin noted a broader lkml consensus to increase greppability by
keeping the messages all on one line.
Signed-off-by: Benoît Cousson <b-cousson@ti.com>
Cc: Thara Gopinath <thara@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
register bits.
In OMAP3 Some modules like Smartreflex do not have the regular sysconfig
register.Instead clockactivity bits are part of another register at a
different bit position than the usual bit positions 8 and 9.
In OMAP4, a new scheme is available due to the new protocol
between the PRCM and the IPs. Depending of the scheme, the SYSCONFIG
bitfields position will be different.
The IP_REVISION register should be at offset 0x00.
It should contain a SCHEME field. From this we can determine whether
the IP follows legacy scheme or the new scheme.
31:30 SCHEME Used to distinguish between old scheme and current.
Read 0x0: Legacy protocol.
Read 0x1: New PRCM protocol defined for new OMAP4 IPs
For legacy IP
13:12 MIDLEMODE
11:8 CLOCKACTIVITY
6 EMUSOFT
5 EMUFREE
4:3 SIDLEMODE
2 ENAWAKEUP
1 SOFTRESET
0 AUTOIDLE
For new OMAP4 IP's, the bit position in SYSCONFIG is (for simple target):
5:4 STANDBYMODE (Ex MIDLEMODE)
3:2 IDLEMODE (Ex SIDLEMODE)
1 FREEEMU (Ex EMUFREE)
0 SOFTRESET
Unfortunately In OMAP4 also some IPs will not follow any of these
two schemes. This is the case at least for McASP, SmartReflex
and some security IPs.
This patch introduces a new field sysc_fields in omap_hwmod_sysconfig which
can be used by the hwmod structures to specify the offsets for the
sysconfig register of the IP.Also two static structures
omap_hwmod_sysc_type1 and omap_hwmod_sysc_type2 are defined
which can be used directly to populate the sysc_fields if the IP follows
legacy or new OMAP4 scheme. If the IP follows none of these two schemes
a new omap_hwmod_sysc_fields structure has to be defined and
passed as part of omap_hwmod_sysconfig.
Signed-off-by: Thara Gopinath <thara@ti.com>
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
