To reduce kernel source file data duplication, share struct
omap_hwmod_class and omap_hwmod_class_sysconfig arrays across OMAP2xxx
and 3xxx hwmod data files.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
omap_hwmod_dma_info arrays across OMAP2xxx and 3xxx hwmod data files.
omap_hwmod_mpu_irqs arrays across OMAP2xxx and 3xxx hwmod data files.
omap_hwmod_addr_space arrays across OMAP2xxx and 3xxx hwmod data
files.
Add a new hwmod class for IVA devices. To be used when hwmods
are created for IVA2 on OMAP3.
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Benoît Cousson <b-cousson@ti.com>
Add support for categorizing and iterating over hardware IP blocks by
the "class" of the IP block. The class is the type of the IP block:
e.g., "timer", "timer1ms", etc. Move the OCP_SYSCONFIG/SYSSTATUS data
from the struct omap_hwmod into the struct omap_hwmod_class, since
it's expected to stay consistent for each class. While here, fix some
comments.
The hwmod_class structures in this patch were designed and proposed by
Benoît Cousson <b-cousson@ti.com> and were refined in a discussion
between Thara Gopinath <thara@ti.com>, Kevin Hilman
<khilman@deeprootsystems.com>, and myself.
This patch uses WARN() lines that are longer than 80 characters, as
Kevin noted a broader lkml consensus to increase greppability by
keeping the messages all on one line.
Signed-off-by: Benoît Cousson <b-cousson@ti.com>
Cc: Thara Gopinath <thara@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
