These files use the consumer API, so include clk.h explicitly.
Acked-by: Tero Kristo <t-kristo@ti.com>
Cc: Tony Lindgren <tony@atomide.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
OMAP2/3 now use generic API for the prm_clear_mod_irqs, the SoC specific
implementation details are provided through prm_ll_data.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
This helps to isolate the PRM into its own driver.
osc_ck can be simply defined as a multiplexer clock, and the sys_ck
can be a simple divider.
In omap2_common_pm_late_init suspend_set_ops was called to set common
suspend handling functions for all omap platforms. This created two
problems. First, these suspend ops were being set for all platforms,
regardless of whether or not suspend support has been integrated so in
the case of AM33XX, suspend to mem was presented as available but
failed every time. Second, some platforms will need to define a
completely separate set of suspend ops, such as AM33XX, due to
differences from previous omap platforms so there is no need to
always set the common omap ops.
This patch moves the suspend_set_ops call from omap2_common_pm_late_init
into a separate function that then gets called in the omap*_pm_init
functions for each platform.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Users of the CM funtionality should not access the CM registers directly
by themselves. Thus, added new CM driver APIs for the OMAP2 specific
functionalities which support the existing direct register accesses, and
changed the platform code to use these. This is done in preparation
for moving the CM code into its own individual driver.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
On OMAP platform, FIQ is reserved for secure environment only. If at all
the FIQ needs to be disabled, it involves going through security
API call. Hence the local_fiq_[enable/disable]() in the OMAP code is bogus.
On GP devices too, the fiq is disabled for non-secure software.
So just get rid of it.
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into omap-for-v3.9/pm-wfi-take2
On OMAP2+ devices, standardize and clean up WFI entry and WFI blocking.
Basic test logs are available here:
http://www.pwsan.com/omap/testlogs/wfi_devel_a_3.9/20130208085027/
arch/arm/mach-omap2/pm24xx.c
Use the HWMOD_BLOCK_WFI flag in the hwmod data to prevent the MPU from
entering WFI when the I2C devices are active. No idea why this is needed;
this could certainly bear further investigation if anyone is interested.
The objective here is to remove some custom code from the OMAP24xx PM
code.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
There shouldn't be any need to jump to SRAM code if the OMAP CORE
clockdomain (and consequently the SDRAM controller and CORE PLL) stays
active during MPU WFI. The SRAM code should only be needed when the RAM
enters self-refresh. So in the case where CORE stays active, just call
WFI directly from the mach-omap2/pm24xx.c code. This removes some
unnecessary SRAM code.
This second version replaces the inline WFI with the corresponding
coprocessor register call, using tlbflush.h as an example. This is
because the assembler doesn't recognize WFI as a valid ARMv6
instruction.
Cc: Richard Woodruff <r-woodruff2@ti.com>
Several OMAP2+ power management fixes, optimizations, and cleanup.
This series is a prerequisite for the functional powerdomain
conversion series.
Basic test logs for this branch are here:
http://www.pwsan.com/omap/testlogs/pm_cleanup_fixes_3.9/20130129150017/
Don't attempt to put clockdomains to sleep; this should be handled by the
clock framework. It should be enough to program the next-power-state,
and then let the code in omap_pm_clkdms_setup() deal with the rest.
Start out by programming the MPU and CORE powerdomains to stay ON.
Then control the MPU and CORE powerdomain states directly in
omap2_enter_full_retention() and omap2_enter_mpu_retention(). Not the
most optimal way to do it, but certainly is the most conservative until
OMAP2xxx PM is working again.
Get rid of the open-coded PM_PWSTCTRL_MPU writes in
omap2_enter_mpu_retention(); use the powerdomain code instead.
code.
Based on earlier discussions[1] we attempted to find a suitable
location for the omap DMA header in commit 2b6c4e73 (ARM: OMAP:
DMA: Move plat/dma.h to plat-omap/dma-omap.h) until the conversion
to dmaengine is complete.
Unfortunately that was before I was able to try to test compile
of the ARM multiplatform builds for omap2+, and the end result
was not very good.
So I'm creating yet another all over the place patch to cut the
last dependency for building omap2+ for ARM multiplatform. After
this, we have finally removed the driver dependencies to the
arch/arm code, except for few drivers that are being worked on.
The other option was to make the <plat-omap/dma-omap.h> path
to work, but we'd have to add some new header directory to for
multiplatform builds.
Or we would have to manually include arch/arm/plat-omap/include
again from arch/arm/Makefile for omap2+.
Neither of these alternatives sound appealing as they will
likely lead addition of various other headers exposed to the
drivers, which we want to avoid for the multiplatform kernels.
Since we already have a minimal include/linux/omap-dma.h,
let's just use that instead and add a note to it to not
use the custom omap DMA functions any longer where possible.
Note that converting omap DMA to dmaengine depends on
dmaengine supporting automatically incrementing the FIFO
address at the device end, and converting all the remaining
legacy drivers. So it's going to be few more merge windows.
[1] https://patchwork.kernel.org/patch/1519591/#
cc: Russell King <linux@arm.linux.org.uk>
cc: Kevin Hilman <khilman@ti.com>
cc: "Benoît Cousson" <b-cousson@ti.com>
cc: Herbert Xu <herbert@gondor.apana.org.au>
cc: "David S. Miller" <davem@davemloft.net>
cc: Vinod Koul <vinod.koul@intel.com>
cc: Dan Williams <djbw@fb.com>
cc: Mauro Carvalho Chehab <mchehab@infradead.org>
cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
cc: David Woodhouse <dwmw2@infradead.org>
cc: Kyungmin Park <kyungmin.park@samsung.com>
cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
cc: Hans Verkuil <hans.verkuil@cisco.com>
cc: Vaibhav Hiremath <hvaibhav@ti.com>
cc: Lokesh Vutla <lokeshvutla@ti.com>
cc: Rusty Russell <rusty@rustcorp.com.au>
cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
cc: Afzal Mohammed <afzal@ti.com>
cc: linux-crypto@vger.kernel.org
cc: linux-media@vger.kernel.org
cc: linux-mtd@lists.infradead.org
cc: linux-usb@vger.kernel.org
cc: linux-fbdev@vger.kernel.org
Acked-by: Felipe Balbi <balbi@ti.com>
omap-for-v3.8/cleanup-headers-prepare-multiplatform-v3
omap prcm changes via Paul Walmsley <paul@pwsan.com>:
Some miscellaneous OMAP hwmod changes for 3.8, along with a PRM
change needed for one of the hwmod patches to function.
Basic test logs for this branch on top of Tony's
omap-for-v3.8/clock branch at commit
558a0780b0a04862a678f7823215424b4e5501f9 are here:
http://www.pwsan.com/omap/testlogs/hwmod_devel_a_3.8/20121121161522/
However, omap-for-v3.8/clock at 558a0780 does not include some fixes
that are needed for a successful test. With several reverts,
fixes, and workarounds applied, the following test logs were
obtained:
http://www.pwsan.com/omap/testlogs/TEST_hwmod_devel_a_3.8/20121121162719/
which indicate that the series tests cleanly.
arch/arm/mach-omap2/cm33xx.c
arch/arm/mach-omap2/io.c
arch/arm/mach-omap2/prm_common.c
Clean all #ifdef's added to OMAP2 clock code to make it COMMON clk
ready, not that CONFIG_COMMON_CLK is enabled.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
[paul@pwsan.com: also drop CONFIG_COMMON_CLK tests around APLL recalc_rate
functions]
Signed-off-by: Mike Turquette <mturquette@ti.com>
[paul@pwsan.com: remove some ifdefs in mach-omap2/io.c]
Convert all OMAP2 specific platform files to use COMMON clk
and keep all the changes under the CONFIG_COMMON_CLK macro check
so it does not break any existing code. At a later point switch
to COMMON clk and get rid of all old/legacy code.
[paul@pwsan.com: updated to apply]
Most of the defines are specific to omap1 and omap2+,
and should be in the local headers. Only minimal function
prototypes need to be shared.
As discussed on linux-arm-kernel, we want to avoid
relative includes for the arch/arm/*omap* shared code:
http://www.spinics.net/lists/linux-omap/msg80520.html
So this patch re-adds a minimal plat/sram.h.
The new plat/sram.h must not be included from drivers,
that will break build for omap2+ CONFIG_MULTIPLATFORM.
Note that this patch temporarily adds two more
relative includes; Those will be removed in the
following patch.
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into omap-for-v3.8/cleanup-prcm
The first set of OMAP PRM/CM-related cleanup patches for 3.8.
Prepares for the future move of the PRM/CM code to drivers/. Also
includes some prcm.[ch] cleanup patches from the WDTIMER cleanup
series that don't need external acks.
Basic test logs for this branch on top of v3.7-rc2 are here:
http://www.pwsan.com/omap/testlogs/prcm_cleanup_a_3.8/20121021123719/
But due to the number of unrelated regressions present in v3.7-rc[12],
it's not particularly usable as a testing base. With reverts, fixes,
and workarounds applied as documented in:
http://www.pwsan.com/omap/testlogs/test_v3.7-rc2/20121020134755/README.txt
the following test logs were obtained:
http://www.pwsan.com/omap/testlogs/prcm_cleanup_a_3.8/20121020231757/
arch/arm/mach-omap2/Makefile
arch/arm/mach-omap2/clockdomain2xxx_3xxx.c
Move OMAP3xxx-specific CM functions & macros into cm3xxx.[ch] and
OMAP2xxx-specific macros into cm2xxx.[ch]. Move basic CM register
access functions into static inline functions in cm2xxx_3xxx.h,
leaving only OMAP2/3 hardreset functions in cm2xxx_3xxx.c.
As part of this, split the CM and hwmod code that waits for devices to
become ready into SoC-specific functions.
This is in preparation for the upcoming move of this code to drivers/.
Reviewed-by: Russ Dill <Russ.Dill@ti.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Move OMAP3xxx-specific PRM functions & macros into prm3xxx.[ch] and
OMAP2xxx-specific macros into prm2xxx.h. (prm2xxx.c will be created
by a subsequent patch when it's needed.) Move basic PRM register
access functions into static inline functions in prm2xxx_3xxx.h, leaving
only OMAP2/3 hardreset functions in prm2xxx_3xxx.c.
Also clarify the initcall function naming to reinforce that this code
is specifically for the PRM IP block.
This is in preparation for the upcoming powerdomain series and the
We want to remove plat/cpu.h. To do this, let's first split
it to private soc.h to mach-omap1 and mach-omap2. We have to
keep plat/cpu.h around until the remaining drivers are fixed,
so let's include the local soc.h in plat/cpu.h and for drivers
still including plat/cpu.h.
Once the drivers are fixed not to include plat/cpu.h, we
can remove the file.
This is needed for the ARM common zImage support.
[tony@atomide.com: updated to not print a warning]
Remove arch/arm/plat-omap/include/plat/clock.h by merging it into
arch/arm/mach-omap1/clock.h and arch/arm/mach-omap2/clock.h.
The goal here is to facilitate ARM single image kernels by removing
includes via the "plat/" symlink.
[tony@atomide.com: fixed to remove duplicate clock.h includes]
We can move this from plat to be local to plat-omap
for common ARM zImage support.
Move plat/dma.h to plat-omap/dma-omap.h as part of single
zImage work
As the interrupts should only be defined in the platform_data, and
eventually coming from device tree, there's no need to define them
in header files.
Let's remove the hardcoded references to irqs.h and fix up the includes
so we don't rely on headers included in irqs.h. Note that we're
defining OMAP_INTC_START as 0 to the interrupts. This will be needed
when we enable SPARSE_IRQ. For some drivers we need to add
#include <plat/cpu.h> for now until these drivers are fixed to
remove cpu_is_omapxxxx() usage.
While at it, sort som of the includes the standard way, and add
the trailing commas where they are missing in the related data
structures.
Note that for drivers/staging/tidspbridge we just define things
locally.
Cc: Paul Walmsley <paul@pwsan.com>
This way we can remove includes of plat/gpio.h which won't work
with the single zImage support.
Note that we also remove the cpu_class_is_omap2() check
in gpio-omap.c as the drivers should not call it as we need to
make it local to arch/arm/mach-omap2 for single zImage support.
While at it, arrange the related includes in the standard way.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: linux-mtd@lists.infradead.org
Cc: alsa-devel@alsa-project.org
plat/board.h file is now empty - remove it.
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: linux-mmc@vger.kernel.org
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Chris Ball <cjb@laptop.org>
The sti console workaround uses the OMAP custom tags.
Those tags are not used in upstream kernel and therefore the workaround
never fires on upstream kernels.
Remove the sti console workaround tags part.
This leaves the workaround functional part intact so can be reused if
needed.
Pull sweeping late_initcall cleanup for arm-soc from Olof Johansson:
"This is a patch series from Shawn Guo that moves from individual
late_initcalls() to using a member in the machine structure to invoke
a platform's late initcalls.
This cleanup is a step in the move towards multiplatform kernels since
it would reduce the need to check for compatible platforms in each and
every initcall."
Fix up trivial conflicts in arch/arm/mach-{exynos/mach-universal_c210.c,
imx/mach-cpuimx51.c, omap2/board-generic.c} due to changes nearby (and,
in the case of cpuimx51.c the board support being deleted)
* tag 'cleanup-initcall' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: ux500: use machine specific hook for late init
ARM: tegra: use machine specific hook for late init
ARM: shmobile: use machine specific hook for late init
ARM: sa1100: use machine specific hook for late init
ARM: s3c64xx: use machine specific hook for late init
ARM: prima2: use machine specific hook for late init
ARM: pnx4008: use machine specific hook for late init
ARM: omap2: use machine specific hook for late init
ARM: omap1: use machine specific hook for late init
ARM: msm: use machine specific hook for late init
ARM: imx: use machine specific hook for late init
ARM: exynos: use machine specific hook for late init
ARM: ep93xx: use machine specific hook for late init
ARM: davinci: use machine specific hook for late init
ARM: provide a late_initcall hook for platform initialization
Resolve some warnings identified by cppcheck in arch/arm/mach-omap2:
[arch/arm/mach-omap2/usb-tusb6010.c:129]: (style) Checking if unsigned variable 'tmp' is less than zero.
[arch/arm/mach-omap2/prm_common.c:241]: (error) Possible null pointer dereference: irq_setup - otherwise it is redundant to check if irq_setup is null at line 247
[arch/arm/mach-omap2/pm34xx.c:790]: (style) Variable 'per_clkdm' is assigned a value that is never used
[arch/arm/mach-omap2/pm34xx.c:790]: (style) Variable 'core_clkdm' is assigned a value that is never used
[arch/arm/mach-omap2/pm24xx.c:185]: (style) Variable 'only_idle' is assigned a value that is never used
[arch/arm/mach-omap2/mux.c:254]: (error) Possible null pointer dereference: mux
[arch/arm/mach-omap2/mux.c:258]: (error) Possible null pointer dereference: mux
[arch/arm/mach-omap2/gpmc-onenand.c:178]: (style) Variable 'tick_ns' is assigned a value that is never used
[arch/arm/mach-omap2/gpio.c:56]: (error) Possible null pointer dereference: pdata - otherwise it is redundant to check if pdata is null at line 57
[arch/arm/mach-omap2/devices.c:45]: (style) Variable 'l' is assigned a value that is never used
[arch/arm/mach-omap2/board-omap3evm.c:641] -> [arch/arm/mach-omap2/board-omap3evm.c:639]: (style) Found duplicate branches for if and else.
[arch/arm/mach-omap2/am35xx-emac.c:95]: (style) Variable 'regval' is assigned a value that is never used
[arch/arm/mach-omap2/devices.c:74]: (style) Variable 'l' is assigned a value that is never used
[arch/arm/mach-omap2/pm34xx.c:277]: (style) Variable 'per_prev_state' is assigned a value that is never used
[arch/arm/plat-omap/dmtimer.c:352]: (error) Possible null pointer dereference: timer - otherwise it is redundant to check if timer is null at line 354
[arch/arm/plat-omap/omap_device.c:478]: (style) Variable 'c' is assigned a value that is never used
[arch/arm/plat-omap/usb.c:42]: (style) Variable 'status' is assigned a value that is never used
[arch/arm/mach-omap1/clock.c:197]: (style) Variable 'dpll1_rate' is assigned a value that is never used
[arch/arm/mach-omap1/lcd_dma.c:60]: (style) struct or union member 'lcd_dma_info::size' is never used
[arch/arm/mach-omap1/pm.c:572]: (style) Variable 'entry' is assigned a value that is never used
Some of them are pretty good catches, such as gpio.c:56 and
usb-tusb6010.c:129.
Thanks to Jarkko Nikula for some comments on the sscanf() warnings.
It seems that the kernel sscanf() ignores the field width anyway for the
%d format, so those changes have been dropped from this second version.
Thanks to Daniel Marjamäki <daniel.marjamaki@gmail.com> for pointing
out that a variable was unnecessarily marked static in the
board-omap3evm.c change.
Cc: Felipe Balbi <balbi@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
Cc: Charulatha Varadarajan <charu@ti.com>
Cc: Daniel Marjamäki <daniel.marjamaki@gmail.com>
Cc: Tarun Kanti DebBarma <tarun.kanti@ti.com>
Reviewed-by: Charulatha Varadarajan <charu@ti.com> # for gpio.c
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Disintegrate asm/system.h for ARM.
cc: linux-arm-kernel@lists.infradead.org
The platform_suspend_ops can be shared across OMAP2, 3, and 4, along
with all of the functions referenced in that structure. This patch
shares them. It also removes the suspend_state file-scoped variable
in the OMAP2 and 3 PM code; it does not appear to be actually needed
by anything.
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
[khilman@ti.com: minor rework needed due to rebase/merge with conflicting changes]
Signed-off-by: Kevin Hilman <khilman@ti.com>
clkdms_setup() is identical across OMAP2, 3, and 4, so share it.
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Kevin Hilman <khilman@ti.com>
This is needed to minimize io.h so the SoC specific io.h
for ARMs can removed.
Note that minimal driver changes for DSS and RNG are needed to
include cpu.h for SoC detection macros.
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
There's no need to have these defines in plat/io.h.
Note that we now need to ifdef omap_read/write calls
as they will be available for omap1 only.
While at it, clean up the includes to group them like
they typically are grouped.
Remove omap_{read,write}l() from the 24xx PM code. The clocksource
code should now handle what this was supposed to do.
Tested on N800 -- but it's hard to say whether this fixes anything.
OMAP24xx static suspend path is currently broken, and this patch
doesn't change that.
Cc: Rob Herring <robherring2@gmail.com>
Acked-by: Kevin Hilman <khilman@ti.com>
On OMAP2420-based systems, the PM code ignores the state of the UART
functional clocks when determining what idle state to enter. This
breaks the serial port now that the UART driver's clock behavior can
be controlled via the PM autosuspend timeout.
To fix, remove the special-case idle handling for the UARTs in the
OMAP2420/2430 PM idle code added by commit
4af4016c53f52b26461b8030211f8427a58fa5ed ("OMAP3: PM: UART: disable
clocks when idle and off-mode support").
Tested on Nokia N800. This patch is a collaboration between Tony
Lindgren <tony@atomide.com> and Paul Walmsley <paul@pwsan.com>.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Omap_uart_can_sleep function blocks system wide low power state until
uart is active remove this func and add qos requests to prevent
MPU from transitioning.
Keep qos request to default value which will allow MPU to transition
and while uart baud rate is available calculate the latency value
from the baudrate and use the same to hold constraint while uart clocks
are enabled, and if uart is auto-idled the constraint is updated with
default constraint value allowing MPU to transition.
Qos requests are blocking notifier calls so put these requests to
work queue, also the driver uses irq_safe version of runtime API's
and callbacks can be called in interrupt disabled context.
So to avoid warn on slow path warning while using qos update
API's from runtime callbacks use the qos_work_queue.
During bootup the runtime_resume call backs might not be called and runtime
callback gets called only after uart is idled by setting the autosuspend
timeout. So qos_request from runtime resume callback might not activated during
boot if uart baudrate is calculated during bootup for console uart, so schedule
the qos_work queue once we calc_latency while configuring the uart port.
Flush and complete any pending qos jobs in work queue while suspending.
Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> (for drivers/tty changes)
In preparation to UART runtime conversion remove uart specific calls
from pm24xx/34xx files and their definition from serial.c
These func calls will no more be used with upcoming uart runtime design.
1.) omap_uart_prepare_suspend :- can be taken care with driver suspend hooks.
2.) omap_uart_enable_irqs :- Used to enable/disable uart irq's in suspend
path from PM code, this is removed as same is handled by
uart_suspend_port/uart_resume_port in omap-serial driver which will
do an port_shutdown on suspend freeing irq and port_startup on resume
enabling back irq.
3.) Remove prepare_idle/resume_idle calls used to gate uart clocks.
UART clocks can be gated within driver using runtime funcs
and be woken up using irq_chaining from omap_prm driver.
4.) Remove console_locking from idle path as clock gating is done withing
driver itself with runtime API. Remove is_suspending check used to acquire
console_lock.
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>,
there's no need to keep local prototypes in non-local headers.
Add mach-omap1/common.h and mach-omap2/common.h and move the
local prototypes there from plat/common.h and mach/omap4-common.h.
commit 20d5d5514981f9a68832bffb27a698545ecba77a (OMAP2: PM debug:
remove register dumping) left some code lying around which doesn't
do anything. Clean it up.
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
git://git.pwsan.com/linux-integration into omap-for-linus
