[ Upstream commit 33e9572483031a79ad0a4468064675144d9269ec ]
smp_processor_id() checks preemption if CONFIG_DEBUG_PREEMPT is enabled,
causing a warning dump during boot:
[ 5.042377] BUG: using smp_processor_id() in preemptible [00000000] code: swapper/0/1
[ 5.050281] caller is pwrdm_set_next_pwrst+0x48/0x88
[ 5.055330] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.14.24-g57341df0b4 #1
Use the raw_smp_processor_id() for the trace instead, this value does
not need to be perfectly correct. The alternative of disabling preempt
is too heavy weight operation to be applied in PM hot path for just
tracing purposes.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Pull ARM SoC platform updates from Olof Johansson:
"Improved and new platform support for various SoCs:
New SoC support:
- Broadcom BCM23550
- Freescale i.MX7Solo
- Qualcomm MDM9615
- Renesas r8a7792
Improvements:
- convert clps711x to multiplatform
- debug uart improvements for Atmel platforms
- Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram
- OMAP tweaks and improvements to hwmod
- OMAP support for kexec on SMP"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: davinci: fix build break because of undeclared dm365_evm_snd_data
ARM: s3c64xx: smartq: Avoid sparse warnings
ARM: sti: Implement dummy L2 cache's write_sec
ARM: STi: Update machine _namestr to be more generic.
arm: meson: explicitly select clk drivers
ARM: tango: add Suspend-to-RAM support
ARM: hisi: consolidate the hisilicon machine entries
ARM: tango: fix CONFIG_HOTPLUG_CPU=n build
MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry
MAINTAINERS: Update BCM63XX entry
MAINTAINERS: Add NS2 entry
MAINTAINERS: Fix nsp false-positives
MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries
ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs
ARM: clps711x: Switch to MULTIPLATFORM
ARM: clps711x: Remove boards support
ARM: clps711x: Add basic DT support
ARM: clps711x: Reduce static map size
ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu
ARM: oxnas: Change OX810SE default driver config
The previous implementation was racy in many locations, where the current
status of the clockdomain was read out, some operations were executed,
and the previous status info was used afterwards to decide next state
for the clockdomain. Instead, fix the implementation of the allow_idle /
deny_idle APIs to properly have usecounting support. This allows clean
handling internally within the clockdomain core, and simplifies the
usage also within hwmod.
Testing on ARM encountered the following pair of lockdep-RCU splats:
[ INFO: suspicious RCU usage. ]
4.6.0-rc4-next-20160422 #1 Not tainted
include/trace/events/power.h:328 suspicious rcu_dereference_check() usage!
RCU used illegally from idle CPU!
rcu_scheduler_active = 1, debug_locks = 0
RCU used illegally from extended quiescent state!
no locks held by swapper/0/0.
stack backtrace:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.6.0-rc4-next-20160422 #1
Hardware name: Generic OMAP3-GP (Flattened Device Tree)
[<c010f55c>] (unwind_backtrace) from [<c010b64c>] (show_stack+0x10/0x14)
[<c010b64c>] (show_stack) from [<c047acbc>] (dump_stack+0xa8/0xe0)
[<c047acbc>] (dump_stack) from [<c012bc10>] (pwrdm_set_next_pwrst+0xf8/0x1cc)
[<c012bc10>] (pwrdm_set_next_pwrst) from [<c01269fc>] (omap3_enter_idle_bm+0x1b8/0x1e8)
[<c01269fc>] (omap3_enter_idle_bm) from [<c05fa0b8>] (cpuidle_enter_state+0x84/0x408)
[<c05fa0b8>] (cpuidle_enter_state) from [<c0182c1c>] (cpu_startup_entry+0x1c8/0x3f0)
[<c0182c1c>] (cpu_startup_entry) from [<c0b00c20>] (start_kernel+0x354/0x3cc)
[<c010b64c>] (show_stack) from [<c047ac3c>] (dump_stack+0xa8/0xe0)
[<c047ac3c>] (dump_stack) from [<c012c340>] (_pwrdm_state_switch+0x188/0x32c)
[<c012c340>] (_pwrdm_state_switch) from [<c012c4f0>] (_pwrdm_post_transition_cb+0xc/0x14)
[<c012c4f0>] (_pwrdm_post_transition_cb) from [<c012ba74>] (pwrdm_for_each+0x30/0x5c)
[<c012ba74>] (pwrdm_for_each) from [<c012c72c>] (pwrdm_post_transition+0x24/0x30)
[<c012c72c>] (pwrdm_post_transition) from [<c012548c>] (omap_sram_idle+0xfc/0x240)
[<c012548c>] (omap_sram_idle) from [<c0126934>] (omap3_enter_idle_bm+0xf0/0x1e8)
[<c0126934>] (omap3_enter_idle_bm) from [<c05fa038>] (cpuidle_enter_state+0x84/0x408)
[<c05fa038>] (cpuidle_enter_state) from [<c0182b90>] (cpu_startup_entry+0x1c8/0x3f0)
[<c0182b90>] (cpu_startup_entry) from [<c0b00c20>] (start_kernel+0x354/0x3cc)
These are caused by event tracing from the idle loop, and they were
exposed by commit 293e2421fe25 ("rcu: Remove superfluous versions of
rcu_read_lock_sched_held()"), which suppressed some false negatives.
The current commit therefore adds the _rcuidle suffix to make RCU aware
of this implicit use of RCU by event tracing, thus preventing both splats.
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Tony Lindgren <tony@atomide.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: <linux-omap@vger.kernel.org>
Cc: <linux-arm-kernel@lists.infradead.org>
Removes some functions that are not used anywhere:
omap_change_voltscale_method() voltdm_add_pwrdm()
voltdm_for_each() voltdm_for_each_pwrdm()
And remove define VOLTSCALE_VPFORCEUPDATE and VOLTSCALE_VCBYPASS
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
pwrdm_get_voltdm() pwrdm_for_each_clkdm() pwrdm_del_clkdm()
Acked-by: Nishanth Menon <nm@ti.com>
powerdomain configuration in OMAP is done using PWRSTCTRL register for
each power domain. However, PRCM lets us write any value we'd like to
the logic and power domain target states, however the SoC integration
tends to actually function only at a few discrete states. These valid
states are already in our powerdomains_xxx_data.c file.
So, provide a function to easily query valid low power state that the
power domain is allowed to go to.
Based on work originally done by Jean Pihet <j-pihet@ti.com>
https://patchwork.kernel.org/patch/1325091/ . There is no attempt to
create a new powerdomain solution here, except fixing issues seen
attempting invalid programming attempts. Future consolidation to the
generic powerdomain framework should consider this requirement as
well.
Similar solutions have been done in product kernels in the past such
as:
https://android.googlesource.com/kernel/omap.git/+blame/android-omap-panda-3.0/arch/arm/mach-omap2/pm44xx.c
Signed-off-by: Nishanth Menon <nm@ti.com>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
No need to invoke callback when the clkdm pointer is NULL.
Some of the includes are totally unnecessary, remove some others in
preparation to make the PRCM its own driver.
[paul@pwsan.com: updated to apply; fixed build error on OMAP2xxx-only configs]
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Commit 'cd8abed' "ARM: OMAP2+: Powerdomain: Remove the need to
always have a voltdm associated to a pwrdm" leads to the following
Smatch complaint:
arch/arm/mach-omap2/powerdomain.c:131 _pwrdm_register()
error: we previously assumed 'arch_pwrdm' could be null (see line 105)
So, fix the unchecked dereference of arch_pwrdm.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
to a pwrdm
The powerdomain framework currently expects all powerdomains to be associated with
a corresponding voltagedomain. For some SoCs' (like the already existing AM33xx
family, or for the upcoming AM437x and DRA7 SoCs') which
do not have a Voltage controller/Voltage Processor (neither the SR I2C
bus to communicate with the PMIC) there is no need for a Powerdomain to have
a voltage domain association since there is no auto-scaling of voltages possible
using the voltage FSM.
Extend the arch operations to add an api which the powerdomain core can
then use to identify if a voltdm lookup and association for a powerdomain
is really needed.
Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
Tested-by: Afzal Mohammed <afzal@ti.com> # am335x evm
Signed-off-by: Kevin Hilman <khilman@linaro.org>
Pull ARM updates from Russell King:
"The major items included in here are:
- MCPM, multi-cluster power management, part of the infrastructure
required for ARMs big.LITTLE support.
- A rework of the ARM KVM code to allow re-use by ARM64.
- Error handling cleanups of the IS_ERR_OR_NULL() madness and fixes
of that stuff for arch/arm
- Preparatory patches for Cortex-M3 support from Uwe Kleine-König.
There is also a set of three patches in here from Hugh/Catalin to
address freeing of inappropriate page tables on LPAE. You already
have these from akpm, but they were already part of my tree at the
time he sent them, so unfortunately they'll end up with duplicate
commits"
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (77 commits)
ARM: EXYNOS: remove unnecessary use of IS_ERR_VALUE()
ARM: IMX: remove unnecessary use of IS_ERR_VALUE()
ARM: OMAP: use consistent error checking
ARM: cleanup: OMAP hwmod error checking
ARM: 7709/1: mcpm: Add explicit AFLAGS to support v6/v7 multiplatform kernels
ARM: 7700/2: Make cpu_init() notrace
ARM: 7702/1: Set the page table freeing ceiling to TASK_SIZE
ARM: 7701/1: mm: Allow arch code to control the user page table ceiling
ARM: 7703/1: Disable preemption in broadcast_tlb*_a15_erratum()
ARM: mcpm: provide an interface to set the SMP ops at run time
ARM: mcpm: generic SMP secondary bringup and hotplug support
ARM: mcpm_head.S: vlock-based first man election
ARM: mcpm: Add baremetal voting mutexes
ARM: mcpm: introduce helpers for platform coherency exit/setup
ARM: mcpm: introduce the CPU/cluster power API
ARM: multi-cluster PM: secondary kernel entry code
ARM: cacheflush: add synchronization helpers for mixed cache state accesses
ARM: cpu hotplug: remove majority of cache flushing from platforms
ARM: smp: flush L1 cache in cpu_die()
ARM: tegra: remove tegra specific cpu_disable()
arch/arm/plat-omap/dmtimer.c
_pwrdm_save_clkdm_state_and_activate() tried to test one of its
unsigned arguments to determine whether it was less than zero. Fix by
moving the error test to the caller.
Reported-by: Chen Gang <gang.chen@asianux.com>
pwrdm_can_ever_lose_context() is only ever called from the OMAP GPIO
code, and only with a pointer returned from omap_hwmod_get_pwrdm().
omap_hwmod_get_pwrdm() only ever returns NULL on error, so using
IS_ERR_OR_NULL() to validate the passed pointer is silly. Use a
simpler !ptr check instead.
Add a per-powerdomain spinlock. Use that instead of the clockdomain
spinlock. Add pwrdm_lock()/pwrdm_unlock() functions to allow other
code to acquire or release the powerdomain spinlock without reaching
directly into the struct powerdomain.
Cc: Jean Pihet <jean.pihet@newoldbits.com>
Move omap_set_pwrdm_state() from the PM code to the powerdomain code,
and refactor it to split it up into several functions. A subsequent patch
will rename it to conform with the existing powerdomain function names.
This version includes some additional documentation, based on a
suggestion from Jean Pihet. It also modifies omap_set_pwrdm_state()
to not bail out early unless both the powerdomain current power state
and the next power state are equal. (Previously it would terminate
early if the next power state was equal to the target power state,
which was insufficiently rigorous.)
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Tero Kristo <t-kristo@ti.com>
Drop an unnecessary pwrdm_wait_transition() from mach-omap2/pm.c -
it's called by the subsequent pwrdm_state_switch().
Also get rid of pwrdm_wait_transition() in the powerdomain code - there's
no longer any need to export this function.
Fix the trace in the case a power domain did not hit the desired
state, as reported by Paul Walmsley.
Reported-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Jean Pihet <j-pihet@ti.com>
[paul@pwsan.com: split this fix off from the patch
"ARM: OMAP2+: PM debug: trace the functional power domains states"]
arch/arm/mach-omap2/prcm.c and arch/arm/plat-omap/include/plat/prcm.h
are now completely unused and can be removed.
Tested-by: Vaibhav Hiremath <hvaibhav@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into cleanup-makefile-sparse
smatch and string-wrapping cleanups for the OMAP subarch code.
These changes fix some of the more meaningful warnings that smatch
returns for the OMAP subarch code, and unwraps strings that are
wrapped at the 80-column boundary, to conform with the current
practice.
Basic build, boot, and PM logs are available here:
http://www.pwsan.com/omap/testlogs/warnings_a_cleanup_3.7/20120912025927/
As the plat and mach includes need to disappear for single zImage work,
we need to remove plat/hardware.h.
Do this by splitting plat/hardware.h into omap1 and omap2+ specific files.
The old plat/hardware.h already has omap1 only defines, so it gets moved
to mach/hardware.h for omap1. For omap2+, we use the local soc.h
that for now just includes the related SoC headers to keep this patch more
readable.
Note that the local soc.h still includes plat/cpu.h that can be dealt
with in later patches. Let's also include plat/serial.h from common.h for
all the board-*.c files. This allows making the include files local later
on without patching these files again.
Note that only minimal changes are done in this patch for the
drivers/watchdog/omap_wdt.c driver to keep things compiling. Further
patches are needed to eventually remove cpu_is_omap usage in the drivers.
Also only minimal changes are done to sound/soc/omap/* to remove the
unneeded includes and to define OMAP44XX_MCPDM_L3_BASE locally so there's
no need to include omap44xx.h.
While at it, also sort some of the includes in the standard way.
Cc: linux-watchdog@vger.kernel.org
Cc: alsa-devel@alsa-project.org
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
Cc: Liam Girdwood <lrg@ti.com>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Find and unwrap wrapped strings in the style:
pr_debug("clockdomain: hardware cannot set/clear wake up of "
"%s when %s wakes up\n", clkdm1->name, clkdm2->name);
Keeping these strings contiguous seems to be the current Linux kernel
policy.
The offending lines were found with the following command:
pcregrep -rnM '"\s*$\s*"' arch/arm/*omap*
While here, some messages have been clarified, some pr_warning(
... calls have been converted to pr_warn( ..., and some printk(KERN_*
... have been converted to pr_*.
Pull arm-soc power management changes from Arnd Bergmann:
"These are various power management related changes, mainly concerning
cpuidle on i.MX and OMAP, as well as a the move of the omap
smartreflex driver to live in the power subsystem."
Fix up conflicts in arch/arm/mach-{imx/mach-imx6q.c,omap2/prm2xxx_3xxx.h}
* tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits)
ARM: OMAP2+: PM: fix IRQ_NOAUTOEN removal by mis-merge
ARM: OMAP2+: do not allow SmartReflex to be built as a module
ARM: OMAP2: Use hwmod to initialize mmc for 2420
ARM: OMAP3: PM: cpuidle: optimize the clkdm idle latency in C1 state
ARM: OMAP3: PM: cpuidle: optimize the PER latency in C1 state
ARM: OMAP3: PM: cpuidle: default to C1 in next_valid_state
ARM: OMAP3: PM: cleanup cam_pwrdm leftovers
ARM: OMAP3: PM: call pre/post transition per powerdomain
ARM: OMAP2+: powerdomain: allow pre/post transtion to be per pwrdm
ARM: OMAP3: PM: Remove IO Daisychain control from cpuidle
ARM: OMAP3PLUS: hwmod: reconfigure IO Daisychain during hwmod mux
ARM: OMAP3+: PRM: Enable IO wake up
ARM: OMAP4: PRM: Add IO Daisychain support
ARM: OMAP3: PM: Move IO Daisychain function to omap3 prm file
ARM: OMAP3: PM: correct enable/disable of daisy io chain
ARM: OMAP2+: PRM: fix compile for OMAP4-only build
W1: OMAP HDQ1W: use runtime PM
ARM: OMAP2+: HDQ1W: use omap_device
W1: OMAP HDQ1W: use 32-bit register accesses
W1: OMAP HDQ1W: allow driver to be built on all OMAP2+
The wake-up power domain is an alway-on power domain and so this power domain
does not have a power state status (PM_PWSTST_xxx) register that indicates the
current state. However, during the registering of the wake-up power domain the
state of the domain is queried by calling pwrdm_read_pwrst(). This actually
tries to read a register that does not exist and returns a value of 0 that
indicates that the current state is OFF. The OFF state count of the wake-up
power domain is then set to 1 and the current state to OFF. Both of which are
incorrect.
To fix this, if a power domain only supports the ON state, do not attempt to
read the power state status register and simply return ON as the current power
state.
This is based upon Tony's current linux-omap master branch.
Testing:
- Boot tested on OMAP4460 panda.
- Boot tested on OMAP3430 beagle and validated CORE RET still working (using
Paul's 32k timer patch [1]).
[1] http://marc.info/?l=linux-omap&m=134000053229888&w=2
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
Acked-by: Kevin Hilman <khilman@ti.com>
[paul@pwsan.com: edited commit message slightly]
Iteration over all power domains in the idle path is unnecessary since
only power domains that are transitioning need to be accounted for.
Also PRCM register accesses are known to be expensive, so the
additional latency added to the idle path is signficiant.
In order allow the pre/post transitions to be isolated and called
per-pwrdm, change the API so passing in a specific power domain will
trigger the pre/post transtion accounting for only that specific power
domain. Passing NULL means iterating over all power domains as is
current behavior.
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
Acked-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
With patch 'ARM: OMAP2+: powerdomain: Wait for powerdomain transition
in pwrdm_state_switch()', the pwrdm_clkdm_state_switch() API becomes
duplicate of pwrdm_state_switch().
Get rid off duplicate pwrdm_clkdm_state_switch() and update the
users of it with pwrdm_state_switch()
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
Commit b1cbdb00d ("OMAP: clockdomain: Wait for powerdomain to be ON
when using clockdomain force wakeup") was assuming that
pwrdm_state_switch() does wait for the powerdomain transition which is
not the case. The missing wait for the powerdomain transition
violates the sequence which the hardware expects, which causes power
management failures on some devices.
Fix this API by adding the pwrdm_wait_transition().
[paul@pwsan.com: added some more details in the commit log]
get_context_loss_count functions return context loss count as u32, and
zero means an error. However, zero is also returned when context has
never been lost and could also be returned when the context loss count
has wrapped and goes to zero.
Change the functions to return an int, with negative value meaning an
error.
OMAP HSMMC code uses omap_pm_get_dev_context_loss_count(), but as the
hsmmc code handles the returned value as an int, with negative value
meaning an error, this patch actually fixes hsmmc code also.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
[tony@atomide.com: updated to fix a warning with recent dmtimer changes]
When a powerdomain is registered and it has an associated voltage domain,
add the powerdomain to the voltagedomain using voltdm_add_pwrdm().
Also add voltagedomain iterator helper functions to iterate over all
registered voltagedomains and all powerdomains associated with a
voltagedomain.
Modeled after a similar relationship between clockdomains and powerdomains.
When a powerdomain is registered, lookup the voltage domain by name
and keep a pointer to the containing voltagedomain in the powerdomain
structure.
Modeled after similar method between powerdomain and clockdomain layers.
At Tony's request, remove the omap_chip bitmasks from the powerdomain
definitions. Instead, initialize powerdomains based on one or more
lists that are applicable to a particular SoC family, variant, and
silicon revision.
Gražvydas Ignotas <notasas@gmail.com> found and reported a bug in a
related patch that also applied to this patch - thanks Gražvydas.
Cc: Gražvydas Ignotas <notasas@gmail.com>
In preparation for OMAP_CHIP() removal, split pwrdm_init() into three
functions. This allows some of them to be called multiple times: for
example, pwrdm_register_pwrdms() can be called once to register
powerdomains that are common to a group of SoCs, and once to register
powerdomains that are specific to a single SoC.
The appropriate order to call these functions - which is enforced
by the code - is:
1. pwrdm_register_platform_funcs()
2. pwrdm_register_pwrdms() (can be called multiple times)
3. pwrdm_complete_init()
Convert the OMAP2, 3, and 4 powerdomain init code to use these new
functions.
While here, improve documentation, and increase CodingStyle
conformance by shortening some local variable names.
Program all powerdomain target state as ON; this is to prevent domains
from hitting low power states (if bootloader has target states set to
something other than ON) and potentially even losing context while PM
is not fully initialized, which can cause the system to crash. The PM
late init code can then program the desired target state for all the
power domains.
[paul@pwsan.com: dropped comment typo hunk; fixed comment indent and moved
to kerneldoc; moved code to pwrdm_init(); changed pwrdm_init() argument name
to prevent clash; cleaned up patch description]
The patch adds the new power management trace points for
the OMAP architecture.
The trace points are for:
- default idle handler. Since the cpuidle framework is
instrumented in the generic way there is no need to
add trace points in the OMAP specific cpuidle handler;
- SoC clocks changes (enable, disable, set_rate),
- power domain states: the desired target state and -if different-
the actually hit state.
Because of the generic nature of the changes, OMAP3 and OMAP4 are supported.
Tested on OMAP3 with suspend/resume, cpuidle, basic DVFS.
Some drivers wish to know whether the device that they control can
ever lose context, for example, when the device's enclosing
powerdomain loses power. They can use this information to determine
whether it is necessary to save and restore device context, or whether
it can be skipped. Implement the powerdomain portion of this by
adding the function pwrdm_can_ever_lose_context(). This is not for
use directly from driver code, but instead is intended to be called
from driver-subarch integration code (i.e., arch/arm/*omap* code).
Currently, the result from this function should be passed into the
driver code via struct platform_data, but at some point this should
be part of some common or OMAP-specific device code.
While here, update file copyrights.
Add new powerdomain API
u32 pwrdm_get_context_loss_count(struct powerdomain *pwrdm)
for checking how many times the powerdomain has lost context. The
loss count is the sum of the powerdomain off-mode counter, the
logic off counter and the per-bank memory off counter.
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
[paul@pwsan.com: removed bogus return value on error; improved kerneldoc;
tweaked commit message]
The OMAP powerdomain code and data is all OMAP2+-specific. This seems
unlikely to change any time soon. Move plat-omap/include/plat/powerdomain.h
to mach-omap2/powerdomain.h. The primary point of doing this is to remove
the temptation for unrelated upper-layer code to access powerdomain code
and data directly.
As part of this process, remove the references to powerdomain data
from the GPIO "driver" and the OMAP PM no-op layer, both in plat-omap.
Change the DSPBridge code to point to the new location for the
powerdomain headers. The DSPBridge code should not be including the
powerdomain headers; these should be removed.
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Greg Kroah-Hartman <greg@kroah.com>
The OMAP clockdomain code and data is all OMAP2+-specific. This seems
unlikely to change any time soon. Move plat-omap/include/plat/clockdomain.h
to mach-omap2/clockdomain.h. The primary point of doing this is to remove
the temptation for unrelated upper-layer code to access clockdomain code
and data directly.
DSPBridge also uses the clockdomain headers for some reason, so,
modify it also. The DSPBridge code should not be including the
clockdomain headers; these should be removed.
Tested-by: Rajendra Nayak <rnayak@ti.com>
OMAP4 powerdomain control registers are split between the PRM hardware
module and the PRCM_MPU local PRCM. Add this PRCM partition
information to each OMAP4 powerdomain record, and convert the OMAP4
powerdomain function implementations to use the OMAP4 PRM instance
functions.
Also fixes a potential null pointer dereference of pwrdm->name.
The autogeneration scripts have been updated.
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Benoît Cousson <b-cousson@ti.com>
In preparation for adding OMAP4-specific PRCM accessor/mutator
functions, split the existing OMAP2/3 PRCM code into OMAP2/3-specific
files. Most of what was in mach-omap2/{cm,prm}.{c,h} has now been
moved into mach-omap2/{cm,prm}2xxx_3xxx.{c,h}, since it was
OMAP2xxx/3xxx-specific.
This process also requires the #includes in each of these files to be
changed to reference the new file name. As part of doing so, add some
comments into plat-omap/sram.c and plat-omap/mcbsp.c, which use
"sideways includes", to indicate that these users of the PRM/CM includes
should not be doing so.
Thanks to Felipe Contreras <felipe.contreras@gmail.com> for comments on this
patch.
Cc: Jarkko Nikula <jhnikula@gmail.com>
Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Acked-by: Omar Ramirez Luna <omar.ramirez@ti.com>
Acked-by: Felipe Contreras <felipe.contreras@gmail.com>
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Split the existing cm44xx.h file into cm1_44xx.h and cm2_44xx.h files
so they match their underlying OMAP hardware modules. Add clockdomain
offset information.
Add header files for the MPU local PRCM, prcm_mpu44xx.h, and for the
SCRM, scrm44xx.h. SCRM register offsets still need to be added; TI
should do this.
Move the "_MOD" macros out of the prcm-common.h header file, into the
header file of the hardware module that they belong to. For example,
OMAP4430_PRM_*_MOD macros have been moved into the prm44xx.h header.
Adjust #includes of all files that used the old PRCM header file names
to point to the new filenames.
The autogeneration scripts have been updated accordingly.
Define the following architecture specific funtions for omap2/3/4
.pwrdm_set_mem_onst
.pwrdm_set_mem_retst
.pwrdm_read_mem_pwrst
.pwrdm_read_prev_mem_pwrst
.pwrdm_read_mem_retst
.pwrdm_clear_all_prev_pwrst
.pwrdm_enable_hdwr_sar
.pwrdm_disable_hdwr_sar
.pwrdm_wait_transition
.pwrdm_set_lowpwrstchange
Convert the platform-independent framework to call these functions.
[paul@pwsan.com: rearranged Makefile changes]
Cc: Benoit Cousson <b-cousson@ti.com>
.pwrdm_set_logic_retst
.pwrdm_read_logic_pwrst
.pwrdm_read_prev_logic_pwrst
.pwrdm_read_logic_retst
.pwrdm_set_next_pwrst
.pwrdm_read_next_pwrst
.pwrdm_read_pwrst
.pwrdm_read_prev_pwrst
[paul@pwsan.com: remove remaining static allocations in powerdomains.h file;
remove path in file header comments, rearranged Makefile changes]
Put infrastructure in place, so arch specific func pointers
can be hooked up to the platform-independent part of the
framework.
This is in preparation of splitting the powerdomain framework into
platform-independent part (for all omaps) and platform-specific
parts.
Add a missing break at end of switch statement. At the moment it is a
fall through to WARN_ON(1) and return -EEXIST.
Signed-off-by: Thomas Weber <weber@corscience.de>
Add some missing credits for people who have contributed significant features
or fixes.
Cc: Tero Kristo <tero.kristo@nokia.com>
Cc: Thara Gopinath <thara@ti.com>
Some powerdomains in OMAP4 support a direct transition from one sleep
state to another deeper sleep state without having to wakeup the
powerdomain. This patch adds an api in the powerdomain framework to
set the LOWPOWERSTATECHANGE bit in PWRSTCTRL register.
