path: root/arch/arm/mach-omap2/sdram-nokia.c
2012-02-24ARM: OMAP2+: Move most of plat/io.h into local iomap.hTony Lindgren
There's no need to have these defines in plat/io.h. Note that we now need to ifdef omap_read/write calls as they will be available for omap1 only. While at it, clean up the includes to group them like they typically are grouped. Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-12-13ARM: OMAP3: sdram-nokia: add 200 MHz memory timings infoIgor Dmitriev
Add memory timing info regarding the 200 MHz memory in sdram-nokia. Note that 100 MHz mode uses these same timings too. Signed-off-by: Igor Dmitriev <ext-dmitriev.igor@nokia.com> Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com> Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> [tony@atomide.com: updated comments for 100 MHz timings] Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-11-17ARM: 7159/1: OMAP: Introduce local common.h filesTony Lindgren
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>, there's no need to keep local prototypes in non-local headers. Add mach-omap1/common.h and mach-omap2/common.h and move the local prototypes there from plat/common.h and mach/omap4-common.h. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-17arm: omap: sdram-nokia: add 97.6/195.2 MHz timing dataAaro Koskinen
Introduce 97.6/195.2 MHz memory timing data. Based on patches by Eduardo Valentin, Igor Dmitriev and Juha Keski-Saari. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Cc: Eduardo Valentin <eduardo.valentin@nokia.com> Cc: Igor Dmitriev <ext-dmitriev.igor@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-17arm: omap: sdram-nokia: delete redundant timing dataAaro Koskinen
41.5 MHz SDRAM clock is not usable. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-17arm: omap: sdram-nokia: improve error handlingAaro Koskinen
Actually check for errors: print an error log and return NULL. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-17arm: omap: sdram-nokia: use array to list timingsAaro Koskinen
Use an array to make it easier to add new values. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-17arm: omap: sdram-nokia: prepare for new memory timingsAaro Koskinen
Rename the current timings to indicate they're for 166 MHz. Based on patches by Eduardo Valentin and Juha Keski-Saari. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Cc: Eduardo Valentin <eduardo.valentin@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-17arm: omap: add sdram-nokia.hAaro Koskinen
Add a header file for Nokia SDRAM functions. Based on patches by Juha Keski-Saari. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-12-17arm: omap: rename board-rx51-sdram.c to sdram-nokia.cAaro Koskinen
Rename the file and functions so that it can be reused by future Nokia boards. Based on patches by Juha Keski-Saari. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
