path: root/arch/arm/mach-omap2/smartreflex-class3.c
2014-09-18arm: mach-omap2: Convert pr_warning to pr_warnJoe Perches
Use the more common pr_warn. Other miscellanea: o Realign arguments Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-06-10PM / AVS: SmartReflex: use omap_sr * for enable/disable interfaceAndrii Tseglytskyi
SmartReflex driver interface is natively divided to two parts: - external SmartReflex interface - interface between SmartReflex driver and SmartReflex Class Functions which belong to AVS class interface can use struct omap_sr* instead of struct voltatedomain*, to provide a direct connection between SR driver and SR class. This allows us to optimize and not do additional lookups where none is required. sr_enable() and sr_disable() are interface functions between SR driver and SR class. They are typically used by Class driver to enable/disable SmartReflex hardware module. Now they take struct omap_sr* as input parameter. Signed-off-by: Andrii Tseglytskyi <andrii.tseglytskyi@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-06-10PM / AVS: SmartReflex: use omap_sr * for errgen interfacesAndrii Tseglytskyi
SmartReflex driver interface is natively divided to two parts: - external SmartReflex interface - interface between SmartReflex driver and SmartReflex Class Functions which belong to AVS class interface can use struct omap_sr* instead of struct voltatedomain*, to provide a direct connection between SR driver and SR class. This allows us to optimize and not do additional lookups where none is required. sr_disable_errgen() and sr_configure_errgen() are interface functions between SR driver and SR class. They are typically used by Class driver to configure error generator module during SmartReflex enable/disable sequence. Now they take struct omap_sr* as input parameter. Signed-off-by: Andrii Tseglytskyi <andrii.tseglytskyi@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-02-09ARM: OMAP2+: Make sure files with omap initcalls include soc.hTony Lindgren
Looks like there are few more places that I missed that can cause compiler warnings. After grepping for omap initcall, all files needing soc.h should now have it. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-11ARM: OMAP2+: Use omap initcallsTony Lindgren
This way the initcalls don't run on other SoCs on multiplatform kernels. Otherwise we'll get something like this when booting on vexpress: omap_hwmod: _ensure_mpu_hwmod_is_setup: MPU initiator hwmod mpu not yet registered ... WARNING: at arch/arm/mach-omap2/pm.c:82 _init_omap_device+0x74/0x94() _init_omap_device: could not find omap_hwmod for mpu ... omap-dma-engine omap-dma-engine: OMAP DMA engine driver ... Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-05-31ARM: OMAP2+: smartreflex: Use the names from hwmod data instead of voltage ↵Jean Pihet
domains. Associate a name with each SmartReflex instance from the hwmod data, rather than attempting to reuse the name of a voltage domain. The name from hwmod better reflects the smartreflex integration in the system. Also have the name passed to the drivers using pdata, which helps to remove any dependencies on SoC-specific structures. Signed-off-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: J Keerthy <j-keerthy@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-05-31ARM: OMAP3+: SmartReflex: class drivers should use struct omap_sr *Jean Pihet
Convert SmartReflex "class" functions to take a struct omap_sr *, rather than a struct voltagedomain *. SmartReflex code should be driver code and not tightly coupled to OMAP subarchitecture-specific structures. Based on Paul's original code for the SmartReflex driver conversion. Signed-off-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: J Keerthy <j-keerthy@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-05-31ARM: OMAP2+: SmartReflex: move the smartreflex header to include/linux/powerJean Pihet
Move the smartreflex header file (arch/arm/mach-omap2/smartreflex.h) in a new header file include/linux/power/smartreflex.h. This change makes the SmartReflex implementation ready for the move to drivers/. Signed-off-by: Jean Pihet <j-pihet@ti.com> Signed-off-by: J Keerthy <j-keerthy@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2012-03-05ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VPNishanth Menon
SmartReflex AVS Errorgen module supplies signals to Voltage Processor. It is suggested that by disabling Errorgen module before we disable VP, we might be able to ensure lesser chances of race condition to occur in the system. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Jean Pihet <j-pihet@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: voltage: rename omap_voltage_get_nom_volt -> voltdm_get_voltageKevin Hilman
Use preferred voltdm_ naming for getting current nominal voltage. No functional changes. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: voltage: rename scale and reset functions using voltdm_ prefixKevin Hilman
Rename voltage scaling related functions to use voltdm_ prefix intead of omap_voltage_, and cleanup kerneldoc comments in the process. s/omap_voltage_scale_vdd/voltdm_scale/ s/omap_voltage_reset/voltdm_reset/ Also, in voltdm_reset() s/target_uvdc/target_volt/ to be consistent with naming throughout the file. No functional changes. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-03-07OMAP: smartreflex: move plat/smartreflex.h to mach-omap2/smartreflex.hPaul Walmsley
There's no reason for this header file to be in plat-omap/include/plat/smartreflex.h. The hardware devices are in OMAP2+ SoCs only. Leaving this header file in plat-omap causes problems due to cross-dependencies with other header files that should live in mach-omap2/. Thanks to Benoît Cousson <b-cousson@ti.com> for suggesting the removal of the smartreflex.h include from the OMAP3xxx hwmod data. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com>
2010-12-22OMAP3: PM: Adding smartreflex class3 driverThara Gopinath
Smartreflex Class3 implementation continuously monitors silicon performance and instructs the Voltage Processors to increase or decrease the voltage. This patch adds smartreflex class 3 driver. This driver hooks up with the generic smartreflex driver smartreflex.c to abstract out class specific implementations out of the generic driver. Class3 driver is chosen as the default class driver for smartreflex. If any other class driver needs to be implemented, the init of that driver should be called from the board file. That way the new class driver will over-ride the Class3 driver. Signed-off-by: Thara Gopinath <thara@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
