path: root/arch/arm/mach-omap2/sr_device.c
2011-03-07OMAP: voltage: move plat/voltage.h to mach-omap2/voltage.hPaul Walmsley
At this point in time, there's no reason for this header file to be in plat-omap/include/plat/voltage.h. It should not be included by device drivers, and the code that uses it is currently all under mach-omap2/. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2011-03-07OMAP: smartreflex: move plat/smartreflex.h to mach-omap2/smartreflex.hPaul Walmsley
There's no reason for this header file to be in plat-omap/include/plat/smartreflex.h. The hardware devices are in OMAP2+ SoCs only. Leaving this header file in plat-omap causes problems due to cross-dependencies with other header files that should live in mach-omap2/. Thanks to Benoît Cousson <b-cousson@ti.com> for suggesting the removal of the smartreflex.h include from the OMAP3xxx hwmod data. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Benoît Cousson <b-cousson@ti.com>
2011-01-07OMAP3+: sr_device: include pm headerNishanth Menon
omap_enable_smartreflex_on_init is meant to be used by boards which would like to have SR enabled by default on the platform, while omap_devinit_smartreflex is used by pm code, the protos are defined in pm.h. This header should be included to ensure that sr_device function definitions match the prototypes. including pm.h fixes the sparse warnings (with CONFIG_OMAP_SMARTREFLEX=y): arch/arm/mach-omap2/sr_device.c:138:13: warning: symbol 'omap_enable_smartreflex_on_init' was not declared. Should it be static? arch/arm/mach-omap2/sr_device.c:143:12: warning: symbol 'omap_devinit_smartreflex' was not declared. Should it be static? Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2010-12-22OMAP4: Smartreflex framework extensionsThara Gopinath
This patch extends the smartreflex framework to support OMAP4. The changes are minor like compiling smartreflex Kconfig option for OMAP4 also, and a couple of OMAP4 checks in the smartreflex framework. The change in sr_device.c where new logic has to be introduced for reading the efuse registers is due to the fact that in OMAP4 the efuse registers are 24 bit aligned. A __raw_readl will fail for non-32 bit aligned address and hence the 8-bit read and shift. Signed-off-by: Thara Gopinath <thara@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-12-22OMAP3: PM: Adding smartreflex device file.Thara Gopinath
This patch adds support for device registration of various smartreflex module present in the system. This patch introduces the platform data for smartreflex devices which include the efused n-target vaules, a parameter to indicate whether smartreflex autocompensation needs to be enabled on init or not. An API omap_enable_smartreflex_on_init is provided for the board files to enable smartreflex autocompensation during system boot up. Signed-off-by: Thara Gopinath <thara@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
