allocation in two functions
Omit an extra message for a memory allocation failure in these functions.
This issue was detected by using the Coccinelle software.
Link: http://events.linuxfoundation.org/sites/events/files/slides/LCJ16-Refactor_Strings-WSang_0.pdf
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
* A multiplication for the size determination of a memory allocation
indicated that an array data structure should be processed.
Thus use the corresponding function "kcalloc".
* Replace the specification of a data structure by a pointer dereference
to make the corresponding size determination a bit safer according to
the Linux coding style convention.
as the parameter for the operator "sizeof" to make the corresponding size
determination a bit safer according to the Linux coding style convention.
Use the more common pr_warn.
Other miscellanea:
o Realign arguments
All OMAP IP blocks expect LE data, but CPU may operate in BE mode.
Need to use endian neutral functions to read/write h/w registers.
I.e instead of __raw_read[lw] and __raw_write[lw] functions code
need to use read[lw]_relaxed and write[lw]_relaxed functions.
If the first simply reads/writes register, the second will byteswap
it if host operates in BE mode.
Changes are trivial sed like replacement of __raw_xxx functions
with xxx_relaxed variant.
Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org>
Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Commit c1d1cd597fc77af3086470f8627d77f52f7f8b6c ("ARM: OMAP2+:
omap_device: remove obsolete pm_lats and early_device code") missed a
few omap_device_build() calls that aren't included as part of the default
OMAP2+ Kconfig, omap2plus_defconfig.
Ideally, all devices that are present on the SoC should be created by
default, and only the corresponding device driver should be configured
or deconfigured in Kconfig. This allows drivers to be built as
modules and loaded later, even if they weren't part of the original
kernel build. Unfortunately, we're not quite there yet.
Thanks to Tony Lindgren for reporting this, found during his
randconfig tests.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Remove now-obsolete code from arch/arm/mach-omap2/omap_device.c. This
mostly consists of removing the first attempt at device PM latency
handling. This was never really used, has been replaced by the common
dev_pm_qos code, and needs to go away as part of the DT conversion.
Also, the early platform_device creation code has been removed, as it
appears to be unused.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
We want to remove plat/cpu.h. To do this, let's first split
it to private soc.h to mach-omap1 and mach-omap2. We have to
keep plat/cpu.h around until the remaining drivers are fixed,
so let's include the local soc.h in plat/cpu.h and for drivers
still including plat/cpu.h.
Once the drivers are fixed not to include plat/cpu.h, we
can remove the file.
This is needed for the ARM common zImage support.
[tony@atomide.com: updated to not print a warning]
Let's make omap_device local to mach-omap2 for
Remove the device dependent code (ex. cpu_is_xxx()) and settings
from the driver code and instead pass them via the platform
data. This allows a clean separation of the driver code and the platform
code, as required by the move of the platform header files to
include/linux/platform_data.
Note about the smartreflex functional clocks: the smartreflex fclks
are derived from sys_clk and have the same name as the main_clk from
the hwmod entry, in order for the SmartReflex driver to request the
fclk (using clk_get(dev, "fck")).
Signed-off-by: Jean Pihet <j-pihet@ti.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-for-v3.7-rc1/fixes-pm
OMAP PM related fixes for v3.7-rc
In case of error, the function voltdm_lookup() returns NULL
not ERR_PTR(). The IS_ERR() test in the return value check
should be replaced with NULL test.
dpatch engine is used to auto generate this patch.
(https://github.com/weiyj/dpatch)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Acked-by: Jean Pihet <j-pihet@ti.com>
Find and unwrap wrapped strings in the style:
pr_debug("clockdomain: hardware cannot set/clear wake up of "
"%s when %s wakes up\n", clkdm1->name, clkdm2->name);
Keeping these strings contiguous seems to be the current Linux kernel
policy.
The offending lines were found with the following command:
pcregrep -rnM '"\s*$\s*"' arch/arm/*omap*
While here, some messages have been clarified, some pr_warning(
... calls have been converted to pr_warn( ..., and some printk(KERN_*
... have been converted to pr_*.
Pull trivial tree from Jiri Kosina:
"Trivial updates all over the place as usual."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits)
Fix typo in include/linux/clk.h .
pci: hotplug: Fix typo in pci
iommu: Fix typo in iommu
video: Fix typo in drivers/video
Documentation: Add newline at end-of-file to files lacking one
arm,unicore32: Remove obsolete "select MISC_DEVICES"
module.c: spelling s/postition/position/g
cpufreq: Fix typo in cpufreq driver
trivial: typo in comment in mksysmap
mach-omap2: Fix typo in debug message and comment
scsi: aha152x: Fix sparse warning and make printing pointer address more portable.
Change email address for Steve Glendinning
Btrfs: fix typo in convert_extent_bit
via: Remove bogus if check
netprio_cgroup.c: fix comment typo
backlight: fix memory leak on obscure error path
Documentation: asus-laptop.txt references an obsolete Kconfig item
Documentation: ManagementStyle: fixed typo
mm/vmscan: cleanup comment error in balance_pgdat
mm: cleanup on the comments of zone_reclaim_stat
Correcting spelling typo in mach-omap2
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
The SmartReflex driver incorrectly treats some per-OPP data as data
common to all OPPs (e.g., ERRMINLIMIT). Move this data into a per-OPP
data structure.
Furthermore, in order to make the SmartReflex implementation ready for
the move to drivers/, remove the dependency from the SR driver code
to the voltage layer by querying the data tables only from the SR device
init code.
Based on Paul's original code for the SmartReflex driver conversion.
Signed-off-by: J Keerthy <j-keerthy@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
domains.
Associate a name with each SmartReflex instance from the hwmod data,
rather than attempting to reuse the name of a voltage domain. The name
from hwmod better reflects the smartreflex integration in the system.
Also have the name passed to the drivers using pdata, which helps to remove
any dependencies on SoC-specific structures.
Move the smartreflex header file
(arch/arm/mach-omap2/smartreflex.h) in a new header file
include/linux/power/smartreflex.h.
This change makes the SmartReflex implementation ready for the move
to drivers/.
arch/arm/mach-lpc32xx/clock.c
arch/arm/mach-pxa/pxa25x.c
arch/arm/mach-pxa/pxa27x.c
The conflicts with pxa are non-obvious, we have multiple branches
adding and removing the same clock settings. According to
Haojian Zhuang, removing the sa1100 rtc dummy clock is the correct
fix here.
To set sr ntarget values for all volt_domain,
volt_table is retrieved by doing a look_up of 'vdd_name'
field from omap_hwmod but voltage domain pointer does not
belong to omap_hwmod and is not used anywhere else.
As a part of voltage layer and SR Layer clean up volt
pointer is removed from omap_hwmod and added in dev
attributes of SR. The value of the field must match
the voltage domain names for the binding to be effective.
Tested on OMAP3630 SDP, OMAP3530 Beagleboard and
OMAP4430 SDP Board.
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Shweta Gulati <shweta.gulati@ti.com>
Acked by: Nishanth Menon <nm@ti.com>
Cc: Benoit Cousson <b-cousson@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
Building omap_devices should only be done at init time, and since
omap_device_build() is using early_platform calls which are also
__init, this ensures that omap_device isn't trying to use functions
that disappear.
Remove all these duplicated structures since a default one is now
available.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
All of the device init and device driver interaction with omap_device
is done using platform_device pointers. To make this more explicit,
have omap_device return a platform_device pointer instead of an
omap_device pointer.
All current users of the omap_device pointer were only using it to get
at the platform_device pointer or struct device pointer, so fixing all
of the users was trivial.
This also makes it more difficult for device init code to directly
access members of struct omap_device, and allows for easier changing
of omap_device internals.
Start cleaning up the voltage layer to have a voltage domain layer
that resembles the structure of the existing clock and power domain
layers. To that end:
- move the 'struct voltagedomain' out of 'struct omap_vdd_info' to
become the primary data structure.
- convert any functions taking a pointer to struct omap_vdd_info into
functions taking a struct voltagedomain pointer.
- convert the register & initialize of voltage domains to look like
that of powerdomains
- convert omap_voltage_domain_lookup() to voltdm_lookup(), modeled
after the current powerdomain and clockdomain lookup functions.
- omap_voltage_late_init(): only configure VDD info when
the vdd_info struct is non-NULL
At this point in time, there's no reason for this header file to be in
plat-omap/include/plat/voltage.h. It should not be included by device
drivers, and the code that uses it is currently all under mach-omap2/.
There's no reason for this header file to be in
plat-omap/include/plat/smartreflex.h. The hardware devices are in
OMAP2+ SoCs only. Leaving this header file in plat-omap causes
problems due to cross-dependencies with other header files that should
live in mach-omap2/.
Thanks to Benoît Cousson <b-cousson@ti.com> for suggesting the removal
of the smartreflex.h include from the OMAP3xxx hwmod data.
Cc: Benoît Cousson <b-cousson@ti.com>
omap_enable_smartreflex_on_init is meant to be used by boards
which would like to have SR enabled by default on the platform, while
omap_devinit_smartreflex is used by pm code, the protos are defined
in pm.h. This header should be included to ensure that sr_device
function definitions match the prototypes.
including pm.h fixes the sparse warnings (with CONFIG_OMAP_SMARTREFLEX=y):
arch/arm/mach-omap2/sr_device.c:138:13: warning: symbol 'omap_enable_smartreflex_on_init' was not declared. Should it be static?
arch/arm/mach-omap2/sr_device.c:143:12: warning: symbol 'omap_devinit_smartreflex' was not declared. Should it be static?
This patch extends the smartreflex framework to support
OMAP4. The changes are minor like compiling smartreflex Kconfig
option for OMAP4 also, and a couple of OMAP4 checks in
the smartreflex framework.
The change in sr_device.c where new logic has to be introduced
for reading the efuse registers is due to the fact that in OMAP4
the efuse registers are 24 bit aligned. A __raw_readl will
fail for non-32 bit aligned address and hence the 8-bit read
and shift.
Signed-off-by: Thara Gopinath <thara@ti.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
This patch adds support for device registration of various
smartreflex module present in the system. This patch introduces
the platform data for smartreflex devices which include
the efused n-target vaules, a parameter to indicate
whether smartreflex autocompensation needs to be
enabled on init or not. An API
omap_enable_smartreflex_on_init is provided for the
board files to enable smartreflex autocompensation during
system boot up.
