Init data marked const should be annotated with __initconst for
correctness and not __initdata. In some cases the array gathering
references to that data has to be marked const as well. This fixes
LTO builds that otherwise fail with section mismatch errors.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Add OMAP4460 OPP definitions for voltage and frequencies based on
OMAP4460 ES1.0 DM Operating Condition Addendum Version 0.1
The following exceptions are present:
* Smartreflex support is still on experimental mode: the gains and min
limits are currently pending characterization data. Currently OMAP4430 values
are used.
* Efuse offset for core OPP100-OV setting is not clear in documentation.
* IVA OPPs beyond OPP100 are disabled due to the delta between max OMAP4460
current requirements and Phoenix Max supply on VCORE2 in the default
configuration - boards which have supply which can support this should
explicitly call opp_enable and enable the same.
* MPU OPPs > OPPTURBO can easily be detected using a efuse burnt - currently
disabled pending clock changes to support DCC feature.
[nm@ti.com: cleanups and updates from Datamanual]
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Vishwanath BS <vishwanath.bs@ti.com>
[t-kristo@ti.com: rebased to linux-3.6-rc5]
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
OMAP4 has two VOLTSETUP registers. One is controlling retention and
sleep voltage setup times, the other one off mode setup times. Both
of these need to be setup for stable behavior of the device.
The code setting up the new register will be added in the next
patch.
These new structs will hold the sleep voltage levels (omap_vc_params)
and voltage processor min / max voltages (omap_vp_params.) Previously
these were part of the PMIC struct, but they do not really belong there,
as they are OMAP chip specific, not PMIC specific parameters. voltdm
code is also changed to use the new structs.
The voltage domain code wants the voltage tables, which are in the
opp*.c files. These files aren't built when PM_OPP is disabled,
causing the following build errors at link time:
twl-common.c:(.init.text+0x2e48): undefined reference to `omap34xx_vddmpu_volt_data'
twl-common.c:(.init.text+0x2e4c): undefined reference to `omap34xx_vddcore_volt_data'
twl-common.c:(.init.text+0x2e5c): undefined reference to `omap36xx_vddmpu_volt_data'
twl-common.c:(.init.text+0x2e60): undefined reference to `omap36xx_vddcore_volt_data'
twl-common.c:(.init.text+0x2830): undefined reference to `omap44xx_vdd_mpu_volt_data'
twl-common.c:(.init.text+0x283c): undefined reference to `omap44xx_vdd_iva_volt_data'
twl-common.c:(.init.text+0x2844): undefined reference to `omap44xx_vdd_core_volt_data'
Acked-by: Kevin Hilman <khilman@ti.com>
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>,
there's no need to keep local prototypes in non-local headers.
Add mach-omap1/common.h and mach-omap2/common.h and move the
local prototypes there from plat/common.h and mach/omap4-common.h.
Remove last remaining member (volt_data) from omap_vdd_info into
struct voltagedomain and removal remaining usage and reference to
omap_vdd_info.
Add sys clock name and rate to struct voltage domain. SoC specific
voltagedomain init code initializes sys clock name. After clock
framework is initialized, voltage late init will then use use the
sys_clk rate to calculate the various timing that depend on that rate.
- move VP instance struct from vdd_info into struct voltage domain
- remove _data suffix from structure name
- rename vp_ prefix from vp_common field: accesses are now vp->common
- move vp_enabled bool from vdd_info into VP instance
- remove remaining references to omap_vdd_info
No functional changes.
- add setup_time field to struct omap_vc_channel (init'd from PMIC data)
- use VC/VP register access helper for read/modify/write
- move VFSM structure from omap_vdd_info into struct voltagedomain
- remove redunant _data suffix from VFSM structures and variables
- remove voltsetup_shift, use ffs() on the mask value to find the shift
Convert VC/VP register access to use PRM VC/VP accessor functions. In
the process, move the read/write function pointers from vdd_info into
struct voltagedomain.
Additional cleanup:
- remove prm_mod field from VC/VP data structures, the PRM register
access functions know which PRM module to use.
Replace the VP tranxdone check/clear with helper functions from the
PRM layer.
In the process, remove prm_irqst_* voltage structure fields for IRQ
status checking which are no longer needed.
Since these reads/writes of the IRQ status bits were the only PRM
accesses that were not to VC/VP registers, this allows the rest of the
register accesses in the VC/VP code to use VC/VP specific register
access functions (done in the following patch.)
Move the VC instance struct from omap_vdd_info into struct voltagedomain.
While moving, perform some misc. renames for readability.
Summary of renames:
- rename omap_vc_instance to omap_vc_channel, since there is only
one instance of the VC IP and this actually represents channels
using TRM terminology.
- rename 'vc_common' field of VC channel which led to:
s/vc->vc_common/vc->common/
- remove redundant '_data' suffix
- OMAP3: vc1 --> vc_mpu, vc2 --> vc_core
- omap_vc_bypass_scale_voltage() -> omap_vc_bypass_scale()
merge
Add voltage domain name to indicate which voltagedomain each
powerdomain is in.
The fixed voltage domain like ldo_wakeup for emu and wkup power
domain is added too.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
[khilman@ti.com]: renamed wakeup domain: s/ldo_wakeup/wakeup/
Add a 'bool scalable' flag to the struct powerdomain and set it for
the scalable domains on OMAP3 and OMAP4.
Start cleaning up the voltage layer to have a voltage domain layer
that resembles the structure of the existing clock and power domain
layers. To that end:
- move the 'struct voltagedomain' out of 'struct omap_vdd_info' to
become the primary data structure.
- convert any functions taking a pointer to struct omap_vdd_info into
functions taking a struct voltagedomain pointer.
- convert the register & initialize of voltage domains to look like
that of powerdomains
- convert omap_voltage_domain_lookup() to voltdm_lookup(), modeled
after the current powerdomain and clockdomain lookup functions.
- omap_voltage_late_init(): only configure VDD info when
the vdd_info struct is non-NULL
The prm_irqst_reg is not part of the VP. Move it up into the common
voltage domain struct.
Eliminate need for global variables for the various PRM module offsets by
making them part of the VP/VC common structures
Eventually, these will likely be moved again, or more likely removed
when VP/VC code is isolated, but for now just getting rid of them as
global variabes so that the voltage domain initialization can be
cleaned up.
This is a first pass at reorganizing mach-omap2/voltage.c:
- Separate almost all of the data from the code of mach-omap2/voltage.c.
The code remains in mach-omap2/voltage.c. The data goes into one
of several places, depending on what type of data it is:
- Silicon process/validation data: mach-omap2/opp*_data.c
- VC (Voltage Controller) data: mach-omap2/vc*_data.c
- VP (Voltage Processor) data: mach-omap2/vp*_data.c
- Voltage domain data: mach-omap2/voltagedomains*_data.c
The ultimate goal is for all this data to be autogenerated, the same
way we autogenerate the rest of our data.
- Separate VC and VP common data from VDD-specific VC and VP data.
- Separate common voltage.c code from SoC-specific code; reuse common code.
- Reorganize structures to avoid unnecessary memory loss due to unpacked
fields.
There is much left to be done. VC code and VP code should be separated out
into vc*.c and vp*.c files. Many fields in the existing structures are
superfluous, and should be removed. Some code in voltage.c seems to be
duplicated; that code should be moved into functions of its own. Proper
voltage domain code should be created, as was done with the powerdomain
and clockdomains, and powerdomains should reference voltagedomains.
Thanks to Shweta Gulati <shweta.gulati@ti.com> for comments. Thanks
to Rajendra Nayak <rnayak@ti.com> for finding and fixing some bugs
that prevented OMAP4 from booting:
https://patchwork.kernel.org/patch/587311/
His patch has been folded into this one to avoid breaking OMAP4
between patches. Thanks also to Kevin Hilman <khilman@ti.com> for
finding and fixing a compile problem when !CONFIG_PM:
http://www.spinics.net/lists/arm-kernel/msg118067.html
His patch has also been folded into this one to avoid breaking
!CONFIG_PM builds.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Shweta Gulati <shweta.gulati@ti.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
