path: root/arch/arm/mach-omap2/vp.c
2012-09-12ARM: OMAP: unwrap stringsPaul Walmsley
Find and unwrap wrapped strings in the style: pr_debug("clockdomain: hardware cannot set/clear wake up of " "%s when %s wakes up\n", clkdm1->name, clkdm2->name); Keeping these strings contiguous seems to be the current Linux kernel policy. The offending lines were found with the following command: pcregrep -rnM '"\s*$\s*"' arch/arm/*omap* While here, some messages have been clarified, some pr_warning( ... calls have been converted to pr_warn( ..., and some printk(KERN_* ... have been converted to pr_*. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2012-03-06ARM: OMAP3+: PM: VP: fix integer truncation errorYuan Jiangli
commit 2f34ce81b8c05c900e45bd88595cc154f7bb5957 (OMAP3: PM: Adding voltage driver support.) introduced runtime computation of waittime to handle all potential sys clocks available. In the voltage processor, the SPMSUpdateWait is calculated based on the slew rate and the voltage step (SMPSUpdateWait = slew rate * Voltage Step). After the voltage processor receives the SMPS_Ack signal, the Voltage Controller will wait for SMPSUpdateWait clock cycles for the voltage to settle to the new value. For all practical purposes, the waittime parameter is the OMAP hardware translation of what the slew rate on the PMIC is. As an example, with TPS62361 on OMAP4460, step_size = 10000 slew_rate = 32000 sys_clk_rate = 38400 Our current computation results in the following: = ((step_size / slew_rate) * sys_clk_rate) / 1000 = ((10000 / 32000) * 38400 / 1000 = 0 Fix the same using DIV_ROUND_UP as an extra wait clock cycle is better than lesser clock cycle. For the above example, this translates to: = (10000 * 38400) / (1000 * 32000) = 12 Acked-by: Jon Hunter <jon-hunter@ti.com> [nm@ti.com: slightly better implementation] Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Yuan Jiangli <jlyuan@motorola.com> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-02-09ARM: omap: fix oops in arch/arm/mach-omap2/vp.c when pmic is not foundRussell King
When the PMIC is not found, voltdm->pmic will be NULL. vp.c's initialization function tries to dereferences this, which causes an oops: Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = c0004000 [00000000] *pgd=00000000 Internal error: Oops: 5 [#1] PREEMPT Modules linked in: CPU: 0 Not tainted (3.3.0-rc2+ #204) PC is at omap_vp_init+0x5c/0x15c LR is at omap_vp_init+0x58/0x15c pc : [<c03db880>] lr : [<c03db87c>] psr: 60000013 sp : c181ff30 ip : c181ff68 fp : c181ff64 r10: c0407808 r9 : c040786c r8 : c0407814 r7 : c0026868 r6 : c00264fc r5 : c040ad6c r4 : 00000000 r3 : 00000040 r2 : 000032c8 r1 : 0000fa00 r0 : 000032c8 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387d Table: 80004019 DAC: 00000015 Process swapper (pid: 1, stack limit = 0xc181e2e8) Stack: (0xc181ff30 to 0xc1820000) ff20: c0381d00 c02e9c6d c0383582 c040786c ff40: c040ad6c c00264fc c0026868 c0407814 00000000 c03d9de4 c181ff8c c181ff68 ff60: c03db448 c03db830 c02e982c c03fdfb8 c03fe004 c0039988 00000013 00000000 ff80: c181ff9c c181ff90 c03d9df8 c03db390 c181ffdc c181ffa0 c0008798 c03d9df0 ffa0: c181ffc4 c181ffb0 c0055a44 c0187050 c0039988 c03fdfb8 c03fe004 c0039988 ffc0: 00000013 00000000 00000000 00000000 c181fff4 c181ffe0 c03d1284 c0008708 ffe0: 00000000 c03d1208 00000000 c181fff8 c0039988 c03d1214 1077ce40 01f7ee08 Backtrace: [<c03db824>] (omap_vp_init+0x0/0x15c) from [<c03db448>] (omap_voltage_late_init+0xc4/0xfc) [<c03db384>] (omap_voltage_late_init+0x0/0xfc) from [<c03d9df8>] (omap2_common_pm_late_init+0x14/0x54) r8:00000000 r7:00000013 r6:c0039988 r5:c03fe004 r4:c03fdfb8 [<c03d9de4>] (omap2_common_pm_late_init+0x0/0x54) from [<c0008798>] (do_one_initcall+0x9c/0x164) [<c00086fc>] (do_one_initcall+0x0/0x164) from [<c03d1284>] (kernel_init+0x7c/0x120) [<c03d1208>] (kernel_init+0x0/0x120) from [<c0039988>] (do_exit+0x0/0x2cc) r5:c03d1208 r4:00000000 Code: e5ca300b e5900034 ebf69027 e5994024 (e5941000) ---[ end trace aed617dddaf32c3d ]--- Kernel panic - not syncing: Attempted to kill init! Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-17ARM: 7159/1: OMAP: Introduce local common.h filesTony Lindgren
As suggested by Russell King - ARM Linux <linux@arm.linux.org.uk>, there's no need to keep local prototypes in non-local headers. Add mach-omap1/common.h and mach-omap2/common.h and move the local prototypes there from plat/common.h and mach/omap4-common.h. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-15OMAP3+: VP: combine setting init voltage into common functionKevin Hilman
combine VPCONFIG init voltage setup into common function and use from both vp_enable and from vp_forceupdate_scale(). NOTE: this patch changes the sequence of when the initVDD bit is cleared. The bit is now cleared immediately after it was written. Since only the rising edge of this bit has any affect according to the TRM, the exact timing of clearing of this bit should not have any effect. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: VP: remove unused omap_vp_get_curr_volt()Kevin Hilman
2011-09-15OMAP3+: VP: update_errorgain(): return error if VPKevin Hilman
Add check for valid VP in omap_vp_update_errorgain() Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP: VP: Explicitly mask VPVOLTAGE fieldTodd Poynor
Reading the VPVOLTAGE field of PRM_VP_*_VOLTAGE registers currently relies on a u32 -> u8 conversion to mask off the FORCEUPDATEWAIT field in the upper bits. Make this explicit using the mask symbol already defined, added as a new field in struct omap_vp_common. Signed-off-by: Todd Poynor <toddpoynor@google.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: VP: remove omap_vp_runtime_dataKevin Hilman
Remove the "runtime" VP data in favor of direct programming of VP registers. The VP is in the PRM, which is in the wakeup powerdomain, so there is no need to keep the state dynamically. Fixes to original version from Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: VP: create VP helper function for updating error gainKevin Hilman
Create new helper function in VP layer for updating VP error gain. Currently used during pre-scale for VP force update and VC bypass. TODO: determine if this can be removed from the pre-scale path and moved to VP enable path. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: VP: move timing calculation/config into VP initKevin Hilman
Move VP timing calcluation (based on sys clock) and register programming into VP init. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: VP: struct omap_vp_common: replace shift with __ffs(mask)Kevin Hilman
In struct omap_vp_common, the shift value can be derived from the mask value by using __ffs(), so remove the shift value for the various VPCONFIG bitfields, and use __ffs() in the code for the shift value. While here, rename field names in kerneldoc comment to match actual field names in structure. Also, cleanup indendentaion for other VP register accesses in omap_vp_init(). No functional changes. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: voltage: remove unneeded debugfs interfaceKevin Hilman
Remove read-only debugfs interface to VP values. Most of the values are init-time only and never change. Current voltage value should be retreived from the (eventual) regulator framework interface to the voltage domain. Fixes to original version provided by Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: VP: cleanup: move VP instance into voltdm, misc. renamesKevin Hilman
- move VP instance struct from vdd_info into struct voltage domain - remove _data suffix from structure name - rename vp_ prefix from vp_common field: accesses are now vp->common - move vp_enabled bool from vdd_info into VP instance - remove remaining references to omap_vdd_info No functional changes. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: voltage domain: move PMIC struct from vdd_info into struct voltagedomainKevin Hilman
Move structure containing PMIC configurable settings into struct voltagedomain. In the process, rename from omap_volt_pmic_info to omap_voltdm_pmic (_info suffix is not helpful.) No functional changes. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+: voltage: convert to PRM register access functionsKevin Hilman
Convert VC/VP register access to use PRM VC/VP accessor functions. In the process, move the read/write function pointers from vdd_info into struct voltagedomain. No functional changes. Additional cleanup: - remove prm_mod field from VC/VP data structures, the PRM register access functions know which PRM module to use. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP3+ VP: replace transaction done check/clear with VP opsKevin Hilman
Replace the VP tranxdone check/clear with helper functions from the PRM layer. In the process, remove prm_irqst_* voltage structure fields for IRQ status checking which are no longer needed. Since these reads/writes of the IRQ status bits were the only PRM accesses that were not to VC/VP registers, this allows the rest of the register accesses in the VC/VP code to use VC/VP specific register access functions (done in the following patch.) Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-09-15OMAP2+: voltage: split out voltage processor (VP) code into new layerKevin Hilman
This patch is primarily a move of VP specific code from voltage.c into its own code in vp.c and adds prototypes to vp.h No functional changes, except debugfs... VP debugfs moved to 'vp' subdir of <debugfs>/voltage/ and 'vp_' prefixes removed from all debugfs filenames. Signed-off-by: Kevin Hilman <khilman@ti.com>
