path: root/arch/arm/mach-omap2
2009-11-18OMAP: cs should be positive in gpmc_cs_free()Roel Kluin
The index `cs' is signed, test whether it is negative before we release gpmc_cs_mem[cs]. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-11-17omap3: clock: Fixed dpll3_m2x2 rate calculationTero Kristo
Current calculation does not take into account any changes to M2 divisor, and thus when we change VDD2 OPP, dpll3_m2x2 rate does not change. Fixed by re-routing dpll3_m2x2 parent to dpll3_m2. Signed-off-by: Tero Kristo <tero.kristo@nokia.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-17omap3: clock: Fix the DPLL freqsel computationsRajendra Nayak
Fix the freqsel value computation. Use n instead of (n+1) The formula in the TRM uses a zero-based N, hence the (n+1); however at this point in the clock34xx.c code, N is one-based. Hayati Bayrakdar <h-bayrakdar@ti.com> and Nishanth Menon <nm@ti.com> helped track down this bug. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> [paul@pwsan.com: modified commit message] Cc: Hayati Bayrakdar <h-bayrakdar@ti.com> Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-16omap: Fix keymap for zoom2 according to matrix keypad framworkVimal Singh
Interpretation of 'row' and 'col' got reversed in matrix keymap framework. Also last element '0', present in keymap array, is no more needed. Correcting zoom2 keyboard keymap accordingly. Signed-off-by: Vimal Singh <vimalsingh@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-11omap3: beagle: Fix USB host port power controlJarkko Nikula
The host port power is enabled by driving the nEN_USB_PWR low as stated in the comment. This fix is originally from Steve Sakoman <steve@sakoman.com>. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Steve Sakoman <steve@sakoman.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-11omap3: pandora: Fix keypad keymapGrazvydas Ignotas
The original TWL4030 keypad driver from linux-omap used KEY() macro defined as (col, row), but while it was merged upstream it was changed to use matrix keypad infrastructure, which uses (row, col) format. Update the keymap in board file to match layout of mainline driver. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-10omap: Use resource_sizeTobias Klauser
Use the resource_size function instead of manually calculating the resource size. This reduces the chance of introducing off-by-one errors and actually fixes one in mailbox.c. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-22omap4: Fix UART4 platform data on omap4Santosh Shilimkar
This patch removes the unnecessary UART4 platform which is under data is wrong because of this There is a separate platform structure for UART4 Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-By: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-22omap4: Allow omap_serial_early_init() for OMAP4430 boardSantosh Shilimkar
This patch enables omap_serial_early_init() function for OMAP4430 SDP. Without this the bootup would throw oops in omap_serial_init(). Note that the ifndef CONFIG_ARCH_OMAP4 is split into two sections to enable omap_serial_early_init(). This ifndef cannot be removed until omap4 clock framework is implemented. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-By: Tony Lindgren <tony@atomide.com> Reviewed-By: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-22omap3: PM: enable UART3 module wakeupsKevin Hilman
UART3 is in the PER powerdomain. If PER goes idle/inactive independently of CORE, for UART3 to wakeup it must have its wakeup enable bits setup in PM_WKEN_PER. This patch enables these bits. The reason it works when PER and CORE work together is because when CORE goes inactive/retention, the IOPAD wakeups are enabled and trigger UART3 wakeup. Without this patch, when the UART inactivity timer fires for UART3, its clocks are disabled and it's unable to wakeup so will be unusable until PER is awoken by another source. Another way of testing is by keeping CORE on during suspend but allowing PER to hit retention # echo 3 > /debug/pm_debug/core_pwrdm/suspend then enter suspend # echo mem > /sys/power/state Without this patch, UART3 will be unable to wakeup the system. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-22omap2: Fix detection of n8x0Tony Lindgren
Otherwise the machine_is_nokia_n8*() does not work. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-22omap: Fix omap-keypad by restoring old keypad.h without breaking omap2 ↵Janusz Krzysztofik
boards that use matrix_keypad Only mach-omap2 boards are currently using matrix_keypad. Allow mach-omap1 boards to use the old style keypad.h without breaking. Created against linux-2.6.32-rc5. Compile tested with omap_3430sdp_defconfig and rx51_defconfig. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-14Merge branch '2_6_32rc4_fixes' of git://git.pwsan.com/linux-2.6 into ↵Tony Lindgren
omap-fixes-for-linus
2009-10-14OMAP2xxx clock: set up clockdomain pointer in struct clkPaul Walmsley
clock24xx.c is missing a omap2_init_clk_clkdm() in its omap2_clk_init() function. Among other bad effects, this causes the OMAP hwmod layer to oops on boot. Thanks to Carlos Aguiar <carlos.aguiar@indt.org.br> and Stefano Panella <Stefano.Panella@csr.com> for reporting this bug. Thanks to Tony Lindgren <tony@atomide.com> for N800 booting advice. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Carlos Aguiar <carlos.aguiar@indt.org.br> Cc: Stefano Panella <Stefano.Panella@csr.com> Cc: Tony Lindgren <tony@atomide.com>
2009-10-14OMAP: Fix race condition with autodepsKalle Jokiniemi
There is a possible race condition in clockdomain code handling hw supported idle transitions. When multiple autodeps dependencies are being added or removed, a transition of still remaining dependent powerdomain can result in false readings of the state counter. This is especially fatal for off mode state counter, as it could result in a driver not noticing a context loss. Fixed by disabling hw supported state transitions when autodeps are being changed. Signed-off-by: Kalle Jokiniemi <kalle.jokiniemi@digia.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-10-14omap: Initialization of SDRC params on Zoom2Teerth Reddy
This patch initializes the correct SDRC settings required for DVFS on Zoom2. Signed-off-by: Teerth Reddy <teerth@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-14omap: RX-51: Drop I2C-1 speed to 2200Aaro Koskinen
The I2C-1 bus frequency on RX-51 should be 2.2 MHz. The speed is limited by TWL5030/GAIA; a higher speed could lead to errors on the interface. The maximum speed depends on the system clock for GAIA: 2.2 MHz (if 19.2 MHz), 2.4 MHz (26 MHz) or 2.9 MHz (38.4 MHz). Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - print debug data when testing AUX IRQ delivery Input: libps2 - fix dependancy on i8042 Input: fix rx51 board keymap Input: ad7879 - pass up error codes from probe functions Input: xpad - add BigBen Interactive XBOX 360 Controller Input: rotary_encoder - fix relative axis support Input: sparkspkr - move remove() functions to .devexit.text Input: wistron_btns - add DMI entry for Medion WIM2030 laptop
2009-10-06Merge branch 'pm-fixes-32' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into omap-fixes-for-linus
2009-10-05Input: fix rx51 board keymapAmit Kucheria
The original driver was written with the KEY() macro defined as (col, row) instead of (row, col) as defined by the matrix keypad infrastructure. So the keymap was defined accordingly. Since the driver that was merged upstream uses the matrix keypad infrastructure, modify the keymap accordingly. While we are at it, fix the comments in twl4030.h and define PERSISTENT_KEY as (r,c) instead of (c, r) Tested on a RX51 (N900) device. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-05omap: Lock DPLL5 at bootRajendra Nayak
Lock DPLL5 at 120MHz at boot. The USBHOST 120MHz f-clock and USBTLL f-clock are the only users of this DPLL, and 120MHz is is the only recommended rate for these clocks. With this patch, the 60 MHz ULPI clock is generated correctly. Tested on an OMAP3430 SDP. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-05OMAP3: PM: introduce a new powerdomain walk helperArtem Bityutskiy
The 'pwrdm_for_each()' function walks powerdomains with a spinlock locked, so the the callbacks cannot do anything which may sleep. This patch introduces a 'pwrdm_for_each_nolock()' helper which does the same, but without the spinlock locked. This fixes the following lockdep warning: [ 0.000000] WARNING: at kernel/lockdep.c:2460 lockdep_trace_alloc+0xac/0xec() [ 0.000000] Modules linked in: (unwind_backtrace+0x0/0xdc) from [<c0045464>] (warn_slowpath_common+0x48/0x60) (warn_slowpath_common+0x48/0x60) from [<c0067dd4>] (lockdep_trace_alloc+0xac/0xec) (lockdep_trace_alloc+0xac/0xec) from [<c009da14>] (kmem_cache_alloc+0x1c/0xd0) (kmem_cache_alloc+0x1c/0xd0) from [<c00b21d8>] (d_alloc+0x1c/0x1a4) (d_alloc+0x1c/0x1a4) from [<c00a887c>] (__lookup_hash+0xd8/0x118) (__lookup_hash+0xd8/0x118) from [<c00a9f20>] (lookup_one_len+0x84/0x94) (lookup_one_len+0x84/0x94) from [<c010d12c>] (debugfs_create_file+0x8c/0x20c) (debugfs_create_file+0x8c/0x20c) from [<c010d320>] (debugfs_create_dir+0x1c/0x20) (debugfs_create_dir+0x1c/0x20) from [<c000e8cc>] (pwrdms_setup+0x60/0x90) (pwrdms_setup+0x60/0x90) from [<c002e010>] (pwrdm_for_each+0x30/0x80) (pwrdm_for_each+0x30/0x80) from [<c000e79c>] (pm_dbg_init+0x7c/0x14c) (pm_dbg_init+0x7c/0x14c) from [<c00232b4>] (do_one_initcall+0x5c/0x1b8) (do_one_initcall+0x5c/0x1b8) from [<c00083f8>] (kernel_init+0x90/0x10c) (kernel_init+0x90/0x10c) from [<c00242c4>] (kernel_thread_exit+0x0/0x8) Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-10-05OMAP3: PM: Enable GPIO module-level wakeupsKevin Hilman
Currently, only GPIOs in the wakeup domain (GPIOs in bank 0) are enabled as wakups. This patch also enables GPIOs in the PER powerdomain (banks 2-6) to be used as possible wakeup sources. In addition, this patch ensures that all GPIO wakeups can wakeup the MPU using the PM_MPUGRPSEL_<pwrdm> registers. NOTE: this doesn't enable the individual GPIOs as wakeups, this simply enables the per-bank wakeups at the powerdomain level. This problem was discovered by Mike Chan when preventing the CORE powerdomain from going into retention/off. When CORE was allowed to hit retention, GPIO wakeups via IO pad were working fine, but when CORE remained on, GPIO module-level wakeups were not working properly. To test, prevent CORE from going inactive/retention/off, thus preventing the IO chain from being armed: # echo 3 > /debug/pm_debug/core_pwrdm/suspend This ensures that GPIO wakeups happen via module-level wakeups and not via IO pad. Tested on 3430SDP using the touchscreen GPIO (gpio 2, in WKUP) Tested on Zoom2 using the QUART interrup GPIO (gpio 102, in PER) Also, c.f. OMAP PM wiki for troubleshooting GPIO wakeup issues: http://elinux.org/OMAP_Power_Management Reported-by: Mike Chan <mikechan@google.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-10-05OMAP3: PM: USBHOST: clear wakeup events on both hostsVikram Pandita
USBHOST module has 2 fclocks (for HOST1 and HOST2), only one iclock and only a single bit in the WKST register to indicate a wakeup event. Because of the single WKST bit, we cannot know whether a wakeup event was on HOST1 or HOST2, so enable both fclocks before clearing the wakeup event to ensure both hosts can properly clear the event. Signed-off-by: Vikram Pandita <vikram.pandita@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-10-05OMAP3: PM: PRCM interrupt: only handle selected PRCM interruptsPaul Walmsley
Clearing wakeup sources is now only done when the PRM indicates a wakeup source interrupt. Since we don't handle any other types of PRCM interrupts right now, warn if we get any other type of PRCM interrupt. Either code needs to be added to the PRCM interrupt handler to react to these, or these other interrupts should be masked off at init. Updated after Jon Hunter's PRCM IRQ rework by Kevin Hilman. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-10-05OMAP3: PM: PRCM interrupt: check MPUGRPSEL registerPaul Walmsley
PM_WKST register contents should be ANDed with the contents of the MPUGRPSEL registers. Otherwise the MPU PRCM interrupt handler could wind up clearing wakeup events meant for the IVA PRCM interrupt handler. A future revision to this code should be to read a cached version of MPUGRPSEL from the powerdomain code, since PRM reads are relatively slow. Updated after Jon Hunter's PRCM IRQ change by Kevin Hilman Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-10-05OMAP3: PM: Prevent hang in prcm_interrupt_handlerJon Hunter
There are two scenarios where a race condition could result in a hang in the prcm_interrupt handler. These are: 1). Waiting for PRM_IRQSTATUS_MPU register to clear. Bit 0 of the PRM_IRQSTATUS_MPU register indicates that a wake-up event is pending for the MPU. This bit can only be cleared if the all the wake-up events latched in the various PM_WKST_x registers have been cleared. If a wake-up event occurred during the processing of the prcm interrupt handler, after the corresponding PM_WKST_x register was checked but before the PRM_IRQSTATUS_MPU was cleared, then the CPU would be stuck forever waiting for bit 0 in PRM_IRQSTATUS_MPU to be cleared. 2). Waiting for the PM_WKST_x register to clear. Some power domains have more than one wake-up source. The PM_WKST_x registers indicate the source of a wake-up event and need to be cleared after a wake-up event occurs. When the PM_WKST_x registers are read and before they are cleared, it is possible that another wake-up event could occur causing another bit to be set in one of the PM_WKST_x registers. If this did occur after reading a PM_WKST_x register then the CPU would miss this event and get stuck forever in a loop waiting for that PM_WKST_x register to clear. This patch address the above race conditions that would result in a hang. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Reviewed-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-09-28omap: Fix wrong condition check in while loop for mailbox and iommu2Hiroshi DOYU
It's worked fine so far since reset is done for the first time. Reported-by: Juha Leppanen <juha_motorsportcom@luukku.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Juha Leppanen <juha_motorsportcom@luukku.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: Fix MMC gpio_wp for BeagleBoard C2 and aboveJarkko Nikula
Earlier BeagleBoards were using pad AH8 muxed to GPIO29 for MMC write-protect. However, this signal has been changed to pad AG9 in board revision C2. Fix this by adding mux configuration for pad AG9, runtime check for board revisions and set the gpio number and pad muxing accordingly. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: Fix matrix_keymap_data usageTony Lindgren
Otherwise we'll get compile errors like: arch/arm/plat-omap/include/mach/keypad.h:38:1: warning: "KEY" redefined arch/arm/plat-omap/include/mach/keypad.h:39:1: warning: "PERSISTENT_KEY" redefined ... Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: mailbox: Flush posted write when acking mailbox irqHiroshi DOYU
The only way to flush posted write to L4 bus is to do a read back of the same register right after the write. This seems to be mostly needed in interrupt handlers to avoid causing spurious interrupts. The earlier fix has been to mark the L4 bus as strongly ordered memory, which solves the problem, but causes performance penalties. Similar to the fix, 03803a71041e3bc3c077f4e7b92f6ceaa9426df3 Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: mailbox: Execute softreset at startupHiroshi DOYU
The softreset at startup is introduced as TRM describes and also some register bit definitions are added instead of magic number. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: Add missing mux pin for EHCI phy reset lineAjay Kumar Gupta
GPIO135 is used as EHCI (port2) phy reset pin on Multi Media Daughter card connected to OMAP3EVM. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: Fix 44xx compileTony Lindgren
Looks like these patches were not tested that well.. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: Fix mcspi compile for 2420Tony Lindgren
Commit 7869c0b9ed44404bbc675ef76f8ccb3be5496f39 added support for additional McSPI ports. Unfortunately that broke compile for 2420. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-24omap: Fix compile for arch/arm/mach-omap2Tony Lindgren
Patch 941132606c7611246d2034cb7b01f9270c2d1ede split IO_ADDRESS into OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS except for the omap4 code to avoid merge conflicts with the omap4 code that was queued earlier. Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-23Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (58 commits) mtd: jedec_probe: add PSD4256G6V id mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board) mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board) m25p80: Add Spansion S25FL129P serial flashes jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabs mtd: sh_flctl: register sh_flctl using platform_driver_probe() mtd: nand: txx9ndfmc: transfer 512 byte at a time if possible mtd: nand: fix tmio_nand ecc correction mtd: nand: add __nand_correct_data helper function mtd: cfi_cmdset_0002: add 0xFF intolerance for M29W128G mtd: inftl: fix fold chain block number mtd: jedec: fix compilation problem with I28F640C3B definition mtd: nand: fix ECC Correction bug for SMC ordering for NDFC driver mtd: ofpart: Check availability of reg property instead of name property driver/Makefile: Initialize "mtd" and "spi" before "net" mtd: omap: adding DMA mode support in nand prefetch/post-write mtd: omap: add support for nand prefetch-read and post-write mtd: add nand support for w90p910 (v2) mtd: maps: add mtd-ram support to physmap_of mtd: pxa3xx_nand: add single-bit error corrections reporting ...
2009-09-23spi: McSPI support for OMAP4Syed Rafiuddin
tAdd adds McSPI support for OMAP4430 SDP platform. All the base addresses are changed between OMAP1/2/3 and OMAP4. The fields of the resource structures are filled at runtime to have McSPI support on OMAP4. Signed-off-by: Syed Rafiuddin <rafiuddin.syed@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23omap4: mmc driver support on OMAP4kishore kadiyala
Add basic support for all 5 MMC controllers on OMAP4. This patch doesn't include mmc-regulator support Signed-off-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Acked-by: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Cc: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23ARM: OMAP: RX51: set MMC capabilities and power-saving flagAdrian Hunter
Specify MMC capabilities and set the power-saving flag for RX51. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23ARM: OMAP: mmc-twl4030: add regulator sleep / wake functionAdrian Hunter
Add the ability for the driver to put the card power regulators to sleep and wake them up again. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23omap_hsmmc: support for deeper power saving statesDenis Karpov
Support for multi-level dynamic power saving states in omap_hsmmc (ENABLED->DISABLED->OFF). In the "deepest" state (OFF) we switch off the voltage regulators. Signed-off-by: Denis Karpov <ext-denis.2.karpov@nokia.com> Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23omap_hsmmc: make use of new MMC_CAP_NONREMOVABLE host capabilityAdrian Hunter
Let the board specify that a card is nonremovable e.g. eMMC Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23ARM: OMAP: mmc-twl4030: add context loss counter supportDenis Karpov
PM dynamic OFF state results in context loss. That is, the host controller has been powered off at some point, which means the registers have been reset. The driver must detect when this happens, and restore the context. This patch adds the means to detect context loss. Note, the PM side is not yet implemented. Signed-off-by: Denis Karpov <ext-denis.2.karpov@nokia.com> Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Ian Molton <ian@mnementh.co.uk> Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Philip Langdale <philipl@overt.org> Cc: "Madhusudhan" <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-20Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/mtdcore.c Merged in order that I can apply the Nomadik nand/onenand support patches.
2009-09-19mtd: omap: add support for nand prefetch-read and post-writevimal singh
This patch adds prefetch support to access nand flash in mpu mode. This patch also adds 8-bit nand support (omap_read/write_buf8). Prefetch can be used for both 8- and 16-bit devices. Signed-off-by: Vimal Singh <vimalsingh@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-19mtd: onenand: make onenand/generic.c more genericMagnus Damm
Remove the ARM dependency from the generic "onenand" platform device driver. This change makes the driver useful for other architectures as well. Needed for the SuperH kfr2r09 board. Apart from the obvious Kconfig bits, the most important change is the move away from ARM specific includes and platform data. Together with this change the only in-tree board code gets an update, and the driver name is also changed gracefully break potential out of tree drivers. The driver is also updated to allow NULL as platform data together with a few changes to make use of resource_size() and dev_name(). Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-18Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (55 commits) regulator: Voltage count for AB3100 mfd: Convert WM8350 to use request_threaded_irq() mfd: Update MAINTAINERS patterns for WM831x mfd: Fix twl4030-power warnings regulator: AB3100 support rtc: AB3100 RTC support mfd: Fix ab3100-otp build failure mfd: OMAP: Board-specifc twl4030 DPS scripts for RX51 board mfd: Print warning for twl4030 out-of-order script loading mfd: Add support for TWL4030/5030 dynamic power switching mfd: AB3100 OTP readout regulator: Add Freescale MC13783 driver mfd: Add Freescale MC13783 driver mfd: AB3100 disable irq nosync mfd: AB3100 alter default setting mfd: AB3100 propagate error mfd: AB3100 accessor function cleanups rtc: Add support for RTCs on Wolfson WM831x devices regulator: get pcap data from the parent device input: PCAP2 misc input driver ...
2009-09-18Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (47 commits) OMAP clock: use debugfs_remove_recursive() for rewinding OMAP2/3/4 core: create omap_device layer OMAP: omap_hwmod: call omap_hwmod init at boot; create interconnects OMAP2/3/4: create omap_hwmod layer OMAP2/3 board-*.c files: read bootloader configuration earlier OMAP2/3/4 PRCM: add module IDLEST wait code OMAP2/3 PM: create the OMAP PM interface and add a default OMAP PM no-op layer OMAP3 clock: remove superfluous calls to omap2_init_clk_clkdm OMAP clock: associate MPU clocks with the mpu_clkdm OMAP3 clock: Fixed processing of bootarg 'mpurate' OMAP: SDRC: Add several new register definitions OMAP: powerdomain: Fix overflow when doing powerdomain deps lookups. OMAP: PM: Added suspend target state control to debugfs for OMAP3 OMAP: PM debug: Add PRCM register dump support OMAP: PM debug: make powerdomains use PM-debug counters OMAP: PM: Add pm-debug counters OMAP: PM: Add closures to clkdm_for_each and pwrdm_for_each. OMAP: PM: Hook into PM counters OMAP: PM counter infrastructure. OMAP3: PM: fix lockdep warning caused by omap3_pm_init ...
2009-09-17mfd: OMAP: Board-specifc twl4030 DPS scripts for RX51 boardAmit Kucheria
Add support for Dynamic Power Switching (DPS) for the RX51 board. These scripts are still a work-in-progress. I'll keep sending patches to update the scripts as they are optimised. Signed-off-by: Amit Kucheria <amit.kucheria@verdurent.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
