path: root/arch/arm/mach-omap2
2014-04-07Merge tag 'fbdev-omap-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull OMAP fbdev changes from Tomi Valkeinen: "This is based on the already pulled fbdev-main changes, and this also merges .dts branch from Tony Lindgren (which has also been pulled), so that I was able to add the display related .dts changes. This contains OMAP related fbdev changes for 3.15. The bulk of the patches are for adding Device Tree support for OMAP Display Subsystem: - SoCs: OMAP2/3/4 - Boards: OMAP4 Panda, OMAP4 SDP, OMAP3 Beagle, OMAP3 Beagle-xM, OMAP3 IGEP0020, OMAP3 N900 - Devices: TFP410 Encoder, tpd12s015 HDMI companion chip, Sony acx565akm panel, MIPI DSI Command mode panel and HDMI, DVI and Analog TV connectors" * tag 'fbdev-omap-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (45 commits) OMAPDSS: HDMI: fix interlace output OMAPDSS: add missing __init for dss_init_ports ARM: OMAP2+: remove pdata quirks for displays OMAPDSS: remove DT hacks for regulators Doc/DT: Add DT binding documentation for tpd12s015 encoder Doc/DT: Add DT binding documentation for TFP410 encoder Doc/DT: Add DT binding documentation for Sony acx565akm panel Doc/DT: Add DT binding documentation for MIPI DSI CM Panel Doc/DT: Add DT binding documentation for HDMI Connector Doc/DT: Add DT binding documentation for DVI Connector Doc/DT: Add DT binding documentation for Analog TV Connector ARM: omap3-n900.dts: add display information ARM: omap3-igep0020.dts: add display information ARM: omap3-beagle-xm.dts: add display information ARM: omap3-beagle.dts: add display information ARM: omap4-sdp.dts: add display information Doc/DT: Add DT binding documentation for OMAP DSS OMAPDSS: acx565akm: Add DT support OMAPDSS: connector-analog-tv: Add DT support OMAPDSS: hdmi-connector: Add DT support ...
2014-04-07Merge tag 'mfd-for-linus-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - Use of managed resources - omap, twl4030, ti_am335x_tscadc - Advanced error handling - omap - Rework clk management - omap - Device Tree (re-)work - tc3589x, pm8921, da9055, sec - IRC management overhaul and !BROKEN - pm8921 - Convert to regmap - ssbi, pm8921 - Use simple power-management ops - ucb1x00 - Include file clean-up - adp5520, cs5535, janz, lpc_ich, - lpc_sch, max14577, mcp-sa11x0, pcf50633-adc, rc5t583, rdc321x-southbridge, retu, smsc-ece1099, ti-ssp, ti_am335x_tscadc, tps65912, vexpress-config, wm8350, ywm8350 - Various bug fixes across the subsystem - NULL/invalid pointer dereference prevention - Resource leak mitigation, - Variable used initialised - Staticise various containers - Enforce return value checks New drivers/supported devices: - Add support for s2mps14 and s2mpa01 to sec - Add support for da9063 (v5) to da9063 - Add support for atom-c2000 to gpio-ich - Add support for come-{mbt10,cbt6,chl6} to kempld - Add support for da9053 to da9052 - Add support for itco-wdt (v3) and baytrail to lpc_ich - Add new drivers for tps65218, rtsx_usb, bcm590xx (Re-)moved drivers: - twl4030 ==> drivers/iio - ti-ssp ==> /dev/null" * tag 'mfd-for-linus-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (103 commits) mfd: wm5110: Correct default for HEADPHONE_DETECT_1 mfd: arizona: Correct small errors in the DT binding documentation mfd: arizona: Mark DSP clocking register as volatile mfd: devicetree: bindings: Add pm8xxx RTC description mfd: kempld-core: Fix potential hang-up during boot mfd: sec-core: Fix uninitialized 'regmap_rtc' on S2MPA01 mfd: tps65910: Fix regmap_irq_chip_data leak on mfd_add_devices fail mfd: tps65910: Fix possible invalid pointer dereference on regmap_add_irq_chip fail mfd: sec-core: Fix I2C dummy device resource leak on probe failure mfd: sec-core: Add of_compatible strings for clock MFD cells mfd: Remove obsolete ti-ssp driver Documentation: mfd: s2mps11: Describe S5M8767 and S2MPS14 clocks mfd: bcm590xx: Fix type argument for module device table mfd: lpc_ich: Add support for Intel Bay Trail SoC mfd: lpc_ich: Add support for NM10 GPIO mfd: lpc_ich: Change Avoton to iTCO v3 watchdog: iTCO_wdt: Add support for v3 silicon mfd: lpc_ich: Add support for iTCO v3 mfd: lpc_ich: Remove lpc_ich_cfg struct use mfd: lpc_ich: Only configure watchdog or GPIO when present ...
2014-04-05Merge tag 'iommu-updates-v3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU upates from Joerg Roedel: "This time a few more updates queued up. - Rework VT-d code to support ACPI devices - Improvements for memory and PCI hotplug support in the VT-d driver - Device-tree support for OMAP IOMMU - Convert OMAP IOMMU to use devm_* interfaces - Fixed PASID support for AMD IOMMU - Other random cleanups and fixes for OMAP, ARM-SMMU and SHMOBILE IOMMU Most of the changes are in the VT-d driver because some rework was necessary for better hotplug and ACPI device support" * tag 'iommu-updates-v3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (75 commits) iommu/vt-d: Fix error handling in ANDD processing iommu/vt-d: returning free pointer in get_domain_for_dev() iommu/vt-d: Only call dmar_acpi_dev_scope_init() if DRHD units present iommu/vt-d: Check for NULL pointer in dmar_acpi_dev_scope_init() iommu/amd: Fix logic to determine and checking max PASID iommu/vt-d: Include ACPI devices in iommu=pt iommu/vt-d: Finally enable translation for non-PCI devices iommu/vt-d: Remove to_pci_dev() in intel_map_page() iommu/vt-d: Remove pdev from intel_iommu_attach_device() iommu/vt-d: Remove pdev from iommu_no_mapping() iommu/vt-d: Make domain_add_dev_info() take struct device iommu/vt-d: Make domain_remove_one_dev_info() take struct device iommu/vt-d: Rename 'hwdev' variables to 'dev' now that that's the norm iommu/vt-d: Remove some pointless to_pci_dev() calls iommu/vt-d: Make get_valid_domain_for_dev() take struct device iommu/vt-d: Make iommu_should_identity_map() take struct device iommu/vt-d: Handle RMRRs for non-PCI devices iommu/vt-d: Make get_domain_for_dev() take struct device iommu/vt-d: Make domain_context_mapp{ed,ing}() take struct device iommu/vt-d: Make device_to_iommu() cope with non-PCI devices ...
2014-04-05Merge tag 'drivers-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Arnd Bergmann: "These changes are mostly for ARM specific device drivers that either don't have an upstream maintainer, or that had the maintainer ask us to pick up the changes to avoid conflicts. A large chunk of this are clock drivers (bcm281xx, exynos, versatile, shmobile), aside from that, reset controllers for STi as well as a large rework of the Marvell Orion/EBU watchdog driver are notable" * tag 'drivers-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (99 commits) Revert "dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac." Revert "net: stmmac: Add SOCFPGA glue driver" ARM: shmobile: r8a7791: Fix SCIFA3-5 clocks ARM: STi: Add reset controller support to mach-sti Kconfig drivers: reset: stih416: add softreset controller drivers: reset: stih415: add softreset controller drivers: reset: Reset controller driver for STiH416 drivers: reset: Reset controller driver for STiH415 drivers: reset: STi SoC system configuration reset controller support dts: socfpga: Add sysmgr node so the gmac can use to reference dts: socfpga: Add support for SD/MMC on the SOCFPGA platform reset: Add optional resets and stubs ARM: shmobile: r7s72100: fix bus clock calculation Power: Reset: Generalize qnap-poweroff to work on Synology devices. dts: socfpga: Update clock entry to support multiple parents ARM: socfpga: Update socfpga_defconfig dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac. net: stmmac: Add SOCFPGA glue driver watchdog: orion_wdt: Use %pa to print 'phys_addr_t' drivers: cci: Export CCI PMU revision ...
2014-04-05Merge tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree changes from Arnd Bergmann: "A large part of the arm-soc patches are nowadays DT changes, adding support for new SoCs, boards and devices without changing kernel source. The plan is still to move the devicetree files out of the kernel tree and reduce the amount of churn going on here, but we keep finding reasons to delay doing that. Changes are really all over the place, with little sticking out particularly. We have contributions from a total of 116 people in this branch. Unfortunately, the size of this branch also causes a significant number of conflicts at the moment, typically when subsystem maintainers merge patches that change the driver at the same time as the dts files. In most cases this could be avoided because the dts changes are supposed to be compatible in both ways, and we are asking everyone to send ARM dts changes through our tree only" * tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits) dts: stmmac: Document the clocks property in the stmmac base document dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac. ARM: STi: stih41x: Add support for the FSM Serial Flash Controller ARM: STi: stih416: Add support for the FSM Serial Flash Controller ARM: tegra: fix Dalmore pinctrl configuration ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND ARM: dts: Build all keystone dt blobs ARM: dts: keystone: Fix control register range for clktsip ARM: dts: keystone: Fix domain register range for clkfftc1 ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap ARM: dts: bcm21664: Add device tree files. ARM: DT: bcm21664: Device tree bindings ARM: efm32: properly namespace i2c location property ARM: efm32: fix unit address part in USART2 device nodes' names ARM: mvebu: Enable NAND controller in Armada 385-DB ARM: mvebu: Add support for NAND controller in Armada 38x SoC ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs ...
2014-04-05Merge tag 'soc-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC specific changes from Arnd Bergmann: "Lots of changes specific to one of the SoC families. Some that stick out are: - mach-qcom gains new features, most importantly SMP support for the newer chips (Stephen Boyd, Rohit Vaswani) - mvebu gains support for three new SoCs: Armada 375, 380 and 385 (Thomas Petazzoni and Free-electrons team) - SMP support for Rockchips (Heiko Stübner) - Lots of i.MX changes (Shawn Guo) - Added support for BCM5301x SoC (Hauke Mehrtens) - Multiplatform support for Marvell Kirkwood and Dove (Andrew Lunn and Sebastian Hesselbarth doing the final part of a long journey) - Unify davinci platforms and remove obsolete ones (Sekhar Nori, Arnd Bergmann)" * tag 'soc-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (126 commits) ARM: sunxi: Select HAVE_ARM_ARCH_TIMER ARM: cache-tauros2: remove ARMv6 code ARM: mvebu: don't select CONFIG_NEON ARM: davinci: fix DT booting with default defconfig ARM: configs: bcm_defconfig: enable bcm590xx regulator support ARM: davinci: remove tnetv107x support MAINTAINERS: Update ARM STi maintainers ARM: restrict BCM_KONA_UART to ARCH_BCM_MOBILE ARM: bcm21664: Add board support. ARM: sunxi: Add the new watchog compatibles to the reboot code ARM: enable ARM_HAS_SG_CHAIN for multiplatform ARM: davinci: remove da8xx_omapl_defconfig ARM: davinci: da8xx: fix multiple watchdog device registration ARM: davinci: add da8xx specific configs to davinci_all_defconfig ARM: davinci: enable da8xx build concurrently with older devices ARM: BCM5301X: workaround suppress fault ARM: BCM5301X: add early debugging support ARM: BCM5301X: initial support for the BCM5301X/BCM470X SoCs with ARM CPU ARM: mach-bcm: Remove GENERIC_TIME ARM: shmobile: APMU: Fix warnings due to improper printk formats ...
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-04-05Merge tag 'fixes-non-critical-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC non-critical bug fixes from Arnd Bergmann: "Lots of isolated bug fixes that were not found to be important enough to be submitted before the merge window or backported into stable kernels. The vast majority of these came out of Arnd's randconfig testing and just prevents running into build-time bugs in configurations that we do not care about in practice" * tag 'fixes-non-critical-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits) ARM: at91: fix a typo ARM: moxart: fix CPU selection ARM: tegra: fix board DT pinmux setup ARM: nspire: Fix compiler warning IXP4xx: Fix DMA masks. Revert "ARM: ixp4xx: Make dma_set_coherent_mask common, correct implementation" IXP4xx: Fix Goramo Multilink GPIO conversion. Revert "ARM: ixp4xx: fix gpio rework" ARM: tegra: make debug_ll code build for ARMv6 ARM: sunxi: fix build for THUMB2_KERNEL ARM: exynos: add missing include of linux/module.h ARM: exynos: fix l2x0 saved regs handling ARM: samsung: select CRC32 for SAMSUNG_PM_CHECK ARM: samsung: select ATAGS where necessary ARM: samsung: fix SAMSUNG_PM_DEBUG Kconfig logic ARM: samsung: allow serial driver to be disabled ARM: s5pv210: enable IDE support in MACH_TORBRECK ARM: s5p64x0: fix building with only one soc type ARM: s3c64xx: select power domains only when used ARM: s3c64xx: MACH_SMDK6400 needs HSMMC1 ...
2014-04-05Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM changes from Russell King: - Perf updates from Will Deacon: - Support for Qualcomm Krait processors (run perf on your phone!) - Support for Cortex-A12 (run perf stat on your FPGA!) - Support for perf_sample_event_took, allowing us to automatically decrease the sample rate if we can't handle the PMU interrupts quickly enough (run perf record on your FPGA!). - Basic uprobes support from David Long: This patch series adds basic uprobes support to ARM. It is based on patches developed earlier by Rabin Vincent. That approach of adding hooks into the kprobes instruction parsing code was not well received. This approach separates the ARM instruction parsing code in kprobes out into a separate set of functions which can be used by both kprobes and uprobes. Both kprobes and uprobes then provide their own semantic action tables to process the results of the parsing. - ARMv7M (microcontroller) updates from Uwe Kleine-König - OMAP DMA updates (recently added Vinod's Ack even though they've been sitting in linux-next for a few months) to reduce the reliance of omap-dma on the code in arch/arm. - SA11x0 changes from Dmitry Eremin-Solenikov and Alexander Shiyan - Support for Cortex-A12 CPU - Align support for ARMv6 with ARMv7 so they can cooperate better in a single zImage. - Addition of first AT_HWCAP2 feature bits for ARMv8 crypto support. - Removal of IRQ_DISABLED from various ARM files - Improved efficiency of virt_to_page() for single zImage - Patch from Ulf Hansson to permit runtime PM callbacks to be available for AMBA devices for suspend/resume as well. - Finally kill asm/system.h on ARM. * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (89 commits) dmaengine: omap-dma: more consolidation of CCR register setup dmaengine: omap-dma: move IRQ handling to omap-dma dmaengine: omap-dma: move register read/writes into omap-dma.c ARM: omap: dma: get rid of 'p' allocation and clean up ARM: omap: move dma channel allocation into plat-omap code ARM: omap: dma: get rid of errata global ARM: omap: clean up DMA register accesses ARM: omap: remove almost-const variables ARM: omap: remove references to disable_irq_lch dmaengine: omap-dma: cleanup errata 3.3 handling dmaengine: omap-dma: provide register read/write functions dmaengine: omap-dma: use cached CCR value when enabling DMA dmaengine: omap-dma: move barrier to omap_dma_start_desc() dmaengine: omap-dma: move clnk_ctrl setting to preparation functions dmaengine: omap-dma: improve efficiency loading C.SA/C.EI/C.FI registers dmaengine: omap-dma: consolidate clearing channel status register dmaengine: omap-dma: move CCR buffering disable errata out of the fast path dmaengine: omap-dma: provide register definitions dmaengine: omap-dma: consolidate setup of CCR dmaengine: omap-dma: consolidate setup of CSDP ...
2014-04-04Merge tag 'fbdev-main-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev changes from Tomi Valkeinen: "Various fbdev fixes and improvements, but nothing big" * tag 'fbdev-main-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (38 commits) fbdev: Make the switch from generic to native driver less alarming Video: atmel: avoid the id of fix screen info is overwritten video: imxfb: Add DT default contrast control register property. video: atmel_lcdfb: ensure the hardware is initialized with the correct mode fbdev: vesafb: add dev->remove() callback fbdev: efifb: add dev->remove() callback video: pxa3xx-gcu: switch to devres functions video: pxa3xx-gcu: provide an empty .open call video: pxa3xx-gcu: pass around struct device * video: pxa3xx-gcu: rename some symbols sisfb: fix 1280x720 resolution support video: fbdev: uvesafb: Remove impossible code path in uvesafb_init_info video: fbdev: uvesafb: Remove redundant NULL check in uvesafb_remove fbdev: FB_OPENCORES should depend on HAS_DMA OMAPDSS: convert pixel clock to common videomode style OMAPDSS: Remove unused get_context_loss_count support OMAPDSS: use DISPC register to detect context loss video: da8xx-fb: Use "SIMPLE_DEV_PM_OPS" macro video: imxfb: Convert to SIMPLE_DEV_PM_OPS video: imxfb: Resolve mismatch between backlight/contrast ...
2014-04-04Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "The main set of series of patches for media subsystem, including: - document RC sysfs class - added an API to setup scancode to allow waking up systems using the Remote Controller - add API for SDR devices. Drivers are still on staging - some API improvements for getting EDID data from media inputs/outputs - new DVB frontend driver for drx-j (ATSC) - one driver (it913x/it9137) got removed, in favor of an improvement on another driver (af9035) - added a skeleton V4L2 PCI driver at documentation - added a dual flash driver (lm3646) - added a new IR driver (img-ir) - added an IR scancode decoder for the Sharp protocol - some improvements at the usbtv driver, to allow its core to be reused. - added a new SDR driver (rtl2832u_sdr) - added a new tuner driver (msi001) - several improvements at em28xx driver to fix PM support, device removal and to split the V4L2 specific bits into a separate sub-driver - one driver got converted to videobuf2 (s2255drv) - the e4000 tuner driver now follows an improved binding model - some fixes at V4L2 compat32 code - several fixes and enhancements at videobuf2 code - some cleanups at V4L2 API documentation - usual driver enhancements, new board additions and misc fixups" [ NOTE! This merge effective drops commit 4329b93b283c ("of: Reduce indentation in of_graph_get_next_endpoint"). The of_graph_get_next_endpoint() function was moved and renamed by commit fd9fdb78a9bf ("[media] of: move graph helpers from drivers/media/v4l2-core to drivers/of"). It was originally called v4l2_of_get_next_endpoint() and lived in the file drivers/media/v4l2-core/v4l2-of.c. In that original location, it was then fixed to support empty port nodes by commit b9db140c1e46 ("[media] v4l: of: Support empty port nodes"), and that commit clashes badly with the dropped "Reduce intendation" commit. I had to choose one or the other, and decided that the "Support empty port nodes" commit was more important ] * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (426 commits) [media] em28xx-dvb: fix PCTV 461e tuner I2C binding Revert "[media] em28xx-dvb: fix PCTV 461e tuner I2C binding" [media] em28xx: fix PCTV 290e LNA oops [media] em28xx-dvb: fix PCTV 461e tuner I2C binding [media] m88ds3103: fix bug on .set_tone() [media] saa7134: fix WARN_ON during resume [media] v4l2-dv-timings: add module name, description, license [media] videodev2.h: add parenthesis around macro arguments [media] saa6752hs: depends on CRC32 [media] si4713: fix Kconfig dependencies [media] Sensoray 2255 uses videobuf2 [media] adv7180: free an interrupt on failure paths in init_device() [media] e4000: make VIDEO_V4L2 dependency optional [media] af9033: Don't export functions for the hardware filter [media] af9035: use af9033 PID filters [media] af9033: implement PID filter [media] rtl2832_sdr: do not use dynamic stack allocation [media] e4000: fix 32-bit build error [media] em28xx-audio: make sure audio is unmuted on open() [media] DocBook media: v4l2_format_sdr was renamed to v4l2_sdr_format ...
2014-04-04ARM: OMAP2+: remove pdata quirks for displaysTomi Valkeinen
Remove pdata quirks for the displays on boards that are now supported properly with DT. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2014-04-04Merge branch 'devel-stable' into for-nextRussell King
2014-04-04Merge branches 'amba', 'fixes', 'misc', 'mmci', 'unstable/omap-dma' and ↵Russell King
'unstable/sa11x0' into for-next
2014-04-04dmaengine: omap-dma: move register read/writes into omap-dma.cRussell King
Export the DMA register information from the SoC specific data, such that we can access the registers directly in omap-dma.c, mapping the register region ourselves as well. Rather than calculating the DMA channel register in its entirety for each access, we pre-calculate an offset base address for the allocated DMA channel and then just use the appropriate register offset. Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-04ARM: omap: dma: get rid of 'p' allocation and clean upRussell King
The omap_system_dma_plat_info structure is only seven words, it's not worth the expense of kmalloc()'ing backing store for this only to release it later. Note that platform_device_add_data() copies the data anyway. Clean up the initialisation of this structure - we don't even need code to initialise most of this structure. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-04ARM: omap: move dma channel allocation into plat-omap codeRussell King
This really needs to be there, because otherwise the plat-omap code can kfree() this data structure, and then re-use the pointer later. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-04ARM: omap: dma: get rid of errata globalRussell King
There's no need for this to be a global variable; move it into the errata configuration function instead. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-04ARM: omap: clean up DMA register accessesRussell King
We can do much better with this by using a structure to describe each register, rather than code. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-04ARM: omap: remove almost-const variablesRussell King
dma_stride and dma_common_ch_start are only ever initialised to one known value at initialisation, and are private to each of these files. There's no point these being variables at all. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-04ARM: omap: remove references to disable_irq_lchRussell King
The disable_irq_lch method is never actually used, so there's not much point it existing; remove it. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Here is my initial pull request for the networking subsystem during this merge window: 1) Support for ESN in AH (RFC 4302) from Fan Du. 2) Add full kernel doc for ethtool command structures, from Ben Hutchings. 3) Add BCM7xxx PHY driver, from Florian Fainelli. 4) Export computed TCP rate information in netlink socket dumps, from Eric Dumazet. 5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas Dichtel. 6) Convert many drivers to pci_enable_msix_range(), from Alexander Gordeev. 7) Record SKB timestamps more efficiently, from Eric Dumazet. 8) Switch to microsecond resolution for TCP round trip times, also from Eric Dumazet. 9) Clean up and fix 6lowpan fragmentation handling by making use of the existing inet_frag api for it's implementation. 10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss. 11) Auto size SKB lengths when composing netlink messages based upon past message sizes used, from Eric Dumazet. 12) qdisc dumps can take a long time, add a cond_resched(), From Eric Dumazet. 13) Sanitize netpoll core and drivers wrt. SKB handling semantics. Get rid of never-used-in-tree netpoll RX handling. From Eric W Biederman. 14) Support inter-address-family and namespace changing in VTI tunnel driver(s). From Steffen Klassert. 15) Add Altera TSE driver, from Vince Bridgers. 16) Optimizing csum_replace2() so that it doesn't adjust the checksum by checksumming the entire header, from Eric Dumazet. 17) Expand BPF internal implementation for faster interpreting, more direct translations into JIT'd code, and much cleaner uses of BPF filtering in non-socket ocntexts. From Daniel Borkmann and Alexei Starovoitov" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits) netpoll: Use skb_irq_freeable to make zap_completion_queue safe. net: Add a test to see if a skb is freeable in irq context qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port' net: ptp: move PTP classifier in its own file net: sxgbe: make "core_ops" static net: sxgbe: fix logical vs bitwise operation net: sxgbe: sxgbe_mdio_register() frees the bus Call efx_set_channels() before efx->type->dimension_resources() xen-netback: disable rogue vif in kthread context net/mlx4: Set proper build dependancy with vxlan be2net: fix build dependency on VxLAN mac802154: make csma/cca parameters per-wpan mac802154: allow only one WPAN to be up at any given time net: filter: minor: fix kdoc in __sk_run_filter netlink: don't compare the nul-termination in nla_strcmp can: c_can: Avoid led toggling for every packet. can: c_can: Simplify TX interrupt cleanup can: c_can: Store dlc private can: c_can: Reduce register access can: c_can: Make the code readable ...
2014-04-02Merge tag 'dt-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull devicetree changes from Grant Likely: "Updates to devicetree core code. This branch contains the following notable changes: - add reserved memory binding - make struct device_node a kobject and remove legacy /proc/device-tree - ePAPR conformance fixes - update in-kernel DTC copy to version v1.4.0 - preparatory changes for dynamic device tree overlays - minor bug fixes and documentation changes The most significant change in this branch is the conversion of struct device_node to be a kobject that is exposed via sysfs and removal of the old /proc/device-tree code. This simplifies the device tree handling code and tightens up the lifecycle on device tree nodes. [updated: added fix for dangling select PROC_DEVICETREE]" * tag 'dt-for-linus' of git://git.secretlab.ca/git/linux: (29 commits) dt: Remove dangling "select PROC_DEVICETREE" of: Add support for ePAPR "stdout-path" property of: device_node kobject lifecycle fixes of: only scan for reserved mem when fdt present powerpc: add support for reserved memory defined by device tree arm64: add support for reserved memory defined by device tree of: add missing major vendors of: add vendor prefix for SMSC of: remove /proc/device-tree of/selftest: Add self tests for manipulation of properties of: Make device nodes kobjects so they show up in sysfs arm: add support for reserved memory defined by device tree drivers: of: add support for custom reserved memory drivers drivers: of: add initialization code for dynamic reserved memory drivers: of: add initialization code for static reserved memory of: document bindings for reserved-memory nodes Revert "of: fix of_update_property()" kbuild: dtbs_install: new make target ARM: mvebu: Allows to get the SoC ID even without PCI enabled of: Allows to use the PCI translator without the PCI core ...
2014-04-02Merge branches 'iommu/fixes', 'arm/smmu', 'x86/amd', 'arm/omap', ↵Joerg Roedel
'arm/shmobile' and 'x86/vt-d' into next
2014-04-01dt: Remove dangling "select PROC_DEVICETREE"Grant Likely
CONFIG_PROC_DEVICETREE has been removed from the tree. This commit removes a dangling select of the config symbol. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Paul Bolle <pebolle@tiscali.nl> Cc: Rob Herring <rob.herring@linaro.org>
2014-03-20Merge branch '3.15/dss-dt-dts' into 3.15/fbdevTomi Valkeinen
OMAP DSS related .dts changes
2014-03-20Merge branch '3.15/dss-dt' into 3.15/fbdevTomi Valkeinen
Merge OMAP DSS DT support
2014-03-19ARM: OMAP2+: DT 'compatible' tweak for displaysTomi Valkeinen
As there is no common panel framework in the kernel, we have OMAP specific panel drivers. However, the DT data should be generic. This brings the issue that some other platform could use the same panels, and would need to create a driver with the same 'compatible' string as the OMAP driver. In the long run, we have to get a common panel framework. For the time being, this patch solves the issue: At early boot time, we go through the DT nodes looking for the panels the kernel supports for OMAP. For each found node, the 'compatible' string is prepended with "omapdss,", i.e. "sony,acx565akm" becomes "omapdss,sony,acx565akm". The OMAP display drivers all have "omapdss," at the beginning of their compatible field. This allows us to have generic DT data, but OMAP specific display drivers. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Archit Taneja <archit@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2014-03-19ARM: OMAP2+: add omapdss_init_of()Tomi Valkeinen
The OMAP display architecture requires a bunch of platform devices which are not created via .dts (for now). We also need to pass a few function pointers and the DSS hardware version from the arch code to omapdss driver. This patch adds omapdss_init_of() function, called from board-generic at init time, which handles those tasks. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Archit Taneja <archit@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2014-03-18Merge branch 'cleanup/kconfig' into next/driversArnd Bergmann
This resolves a conflict between the new sti reset controller driver and the Kconfig cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-03-17Merge tag 'omap-for-v3.15/dt-overo-signed' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt Updates to the .dts files to support more Gumstix boards. These are sent separately from the rest of the .dts changes as these depend on the fixes merged into v3.14-rc4, and needed a bit more time to get updated on the fixes. * tag 'omap-for-v3.15/dt-overo-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: dts: Add support for the Overo Summit ARM: dts: Add support for the Overo Chestnut43 ARM: dts: Add support for the Overo Alto35 ARM: dts: Add support for the Overo Gallop43 ARM: dts: Add support for the Overo Palo43 ARM: dts: overo: Add LIS33DE accelerometer ARM: dts: overo: Create a file for common Gumstix peripherals ARM: dts: overo: Push uart3 pinmux down to expansion board ARM: dts: omap3-tobi: Add AT24C01 EEPROM ARM: dts: omap3-tobi: Use include file omap-gpmc-smsc9221 ARM: dts: omap: Add common file for SMSC9221 ARM: dts: omap3-overo: Add HSUSB PHY ARM: dts: omap3-overo: Enable WiFi/BT combo ARM: dts: omap3-overo: Add missing pinctrl ARM: dts: omap3-tobi: Add missing pinctrl ARM: dts: overo: reorganize include files Signed-off-by: Arnd Bergmann <arnd@arndb.de> Conflicts: arch/arm/boot/dts/omap3-overo.dtsi
2014-03-17Merge tag 'omap-for-v3.15/dt-part3' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt Pull "omap device tree changes for v3.15, part 3" from Tony Lindgren: Device tree related changes to the omap iommu driver as that is finally getting updated. Also few trivial board related .dts updates to add more devices. * tag 'omap-for-v3.15/dt-part3' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: dts: Add MMC2/SDIO/WLAN support for cm-t3530 ARM: dts: am335x-evmsk: enable DMA controller for USB ARM: dts: OMAP5: Add IOMMU nodes ARM: dts: OMAP4: Add IOMMU nodes ARM: dts: OMAP3: Add IVA IOMMU node ARM: dts: OMAP3: Update ISP IOMMU node ARM: OMAP2+: extend iommu pdata-quirks to OMAP5 ARM: OMAP5: hwmod data: add mmu data for ipu & dsp ARM: OMAP2+: use pdata quirks for iommu reset lines ARM: OMAP2+: change the ISP device archdata MMU name for DT ARM: OMAP3: fix iva mmu programming issues ARM: OMAP3: remove deprecated CONFIG_OMAP_IOMMU_IVA2 Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-03-17Merge branch 'efm32/cleanup' into next/dtArnd Bergmann
Dependency for efm32/dt branch. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-03-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c drivers/net/xen-netback/netback.c Both the r8152 and netback conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-13mfd: omap-usb-host: Use proper clock name instead of aliasRoger Quadros
Use the proper clock name 'usbhost_120m_fck' instead of the alias 'ehci_logic_fck' Get rid of the 'ehci_logic_fck' alias from the OMAP3 hwmod data as well. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-13mfd: omap-usb-host: Get clocks based on hardware revisionRoger Quadros
Not all revisions have all the clocks so get the necessary clocks based on hardware revision. This should avoid un-necessary clk_get failure messages that were observed earlier. Also remove the dummy USB host clocks from the OMAP3 clock data. These are no longer expected by the driver. Acked-by: Mike Turquette <mturquette@linaro.org> [OMAP3 CLK data] Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-13ARM: OMAP4: hwmod data: correct the idlemodes for spinlockSuman Anna
The spinlock module's SYSCONFIG register does not support smart wakeup, so remove this flag from the idle modes in the spinlock hwmod definition. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Benoit Cousson <bcousson@baylibre.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-13ARM: OMAP4: Fix definition of IS_PM44XX_ERRATUMNishanth Menon
Just like IS_PM34XX_ERRATUM, IS_PM44XX_ERRATUM is valid only if CONFIG_PM is enabled, else, disabling CONFIG_PM results in build failure complaining about the following: arch/arm/mach-omap2/built-in.o: In function `omap4_boot_secondary': :(.text+0x8a70): undefined reference to `pm44xx_errata' Fixes: c962184 (ARM: OMAP4: PM: add errata support) Reported-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.ocm> Acked-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-13ARM: OMAP2+: INTC: Acknowledge stuck active interruptsStefan Sørensen
When an interrupt has become active on the INTC it will stay active until it is acked, even if masked or de-asserted. The INTC_PENDING_IRQn registers are however updated and since these are used by omap_intc_handle_irq to determine which interrupt to handle, it will never see the active interrupt. This will result in a storm of useless interrupts that is only stopped when another higher priority interrupt is asserted. Fix by sending the INTC an acknowledge if we find no interrupts to handle. Cc: stable@vger.kernel.org Signed-off-by: Stefan Sørensen <stefan.sorensen@spectralink.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-13Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/ath/ath9k/recv.c
2014-03-12Merge 3.14-rc6 into usb-nextGreg Kroah-Hartman
We want the USB fixes in here as well.
2014-03-12ARM: OMAP2+: extend iommu pdata-quirks to OMAP5Suman Anna
OMAP5 has the same iommus as OMAP4, so extend the OMAP4 iommu pdata quirks for OMAP5 as well. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-12ARM: OMAP5: hwmod data: add mmu data for ipu & dspSuman Anna
A new MMU hwmod class and data structures are created to represent the MMUs within the IPU and DSP processor subsystems in OMAP5. The MMUs in OMAP5 are identical to those in OMAP4. Cc: Benoit Cousson <bcousson@baylibre.com> Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-12ARM: OMAP2+: use pdata quirks for iommu reset linesSuman Anna
The OMAP iommu driver performs the reset management for the iommu instances in processor sub-systems using the omap_device API which are currently supplied as platform data ops. Use pdata quirks to maintain the functionality as the OMAP iommu driver gets converted to use DT nodes, until the reset portions are decoupled from omap_hwmod/omap_device into a separate reset driver. This patch adds the pdata quirks for the reset management of iommus within the DSP (OMAP3 & OMAP4) and IPU subsystems (OMAP4). Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-12ARM: OMAP2+: change the ISP device archdata MMU name for DTSuman Anna
The IOMMU DT adaptation support uses the device name instead of an iommu object name. Fixup the ISP device archdata MMU name at runtime if using DT-boot. This allows the OMAP3 camera to be functional in both legacy and DT boots. The iommu object names should eventually vanish when all the IOMMU users have been converted to DT nodes. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-12ARM: OMAP3: fix iva mmu programming issuesSuman Anna
The IVA MMU is not functional when used through the hwmod and omap_device layers. Add fixes to clockdomain and hwmod data to have it functional. The hwmod changes are needed to enable the clock, and the SWSUP change is needed to wakeup the domain because the power domain is programmed to be in RET, and there is no automatic power domain switching to ON. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-12ARM: OMAP3: remove deprecated CONFIG_OMAP_IOMMU_IVA2Florian Vaussard
CONFIG_OMAP_IOMMU_IVA2 was defined originally to avoid conflicting usage by tidspbridge and other iommu users. The same can be achieved by marking the DT node disabled, so remove this obsolete flag and the corresponding hwmod data can be enabled. Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> [s-anna@ti.com: revise commit log] Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-11Merge tag 'v3.14-rc5' into patchworkMauro Carvalho Chehab
Linux 3.14-rc5 * tag 'v3.14-rc5': (1117 commits) Linux 3.14-rc5 drm/vmwgfx: avoid null pointer dereference at failure paths drm/vmwgfx: Make sure backing mobs are cleared when allocated. Update driver date. drm/vmwgfx: Remove some unused surface formats MAINTAINERS: add maintainer entry for Armada DRM driver arm64: Fix !CONFIG_SMP kernel build arm64: mm: Add double logical invert to pte accessors dm cache: fix truncation bug when mapping I/O to >2TB fast device perf tools: Fix strict alias issue for find_first_bit powerpc/powernv: Fix indirect XSCOM unmangling powerpc/powernv: Fix opal_xscom_{read,write} prototype powerpc/powernv: Refactor PHB diag-data dump powerpc/powernv: Dump PHB diag-data immediately powerpc: Increase stack redzone for 64-bit userspace to 512 bytes powerpc/ftrace: bugfix for test_24bit_addr powerpc/crashdump : Fix page frame number check in copy_oldmem_page powerpc/le: Ensure that the 'stop-self' RTAS token is handled correctly kvm, vmx: Really fix lazy FPU on nested guest perf tools: fix BFD detection on opensuse drm/radeon: enable speaker allocation setup on dce3.2 ...
2014-03-09Merge tag 'imx-soc-3.15' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Olof Johansson
into next/soc i.MX SoC changes for 3.15 from Shawn Guo: - Support suspend from ocram (DDR IO floating) for imx6 platforms - Add cpuidle support for imx6sl - Sparse warning fixes for imx6sl and vf610 clock code - Remove PWM platform code - Support ptp and rmii clock from pad - Support WEIM CS GPR configuration - Random cleanups and defconfig updates * tag 'imx-soc-3.15' of git://git.linaro.org/people/shawnguo/linux-2.6: (373 commits) ARM: imx6: drop .text.head section annotation from headsmp.S ARM: imx6: build suspend-imx6.o with CONFIG_SOC_IMX6 ARM: imx6: rename pm-imx6q.c to pm-imx6.c ARM: imx6: introduce CONFIG_SOC_IMX6 for i.MX6 common stuff ARM: imx6: do not call imx6q_suspend_init() with !CONFIG_SUSPEND ARM: imx6: call suspend_set_ops() from suspend routine ARM: imx6: build headsmp.o only on CONFIG_SMP ARM: imx6: move v7_cpu_resume() into suspend-imx6.S ARM i.MX6q: Mark VPU and IPU AXI transfers as cacheable, increase IPU priority ARM: imx6q: Add GPR6 and GPR7 register definitions for iomuxc gpr bus: imx-weim: support CS GPR configuration ARM: mach-imx: Kconfig: Remove IMX_HAVE_PLATFORM_IMX2_WDT from SOC_IMX53 ARM: imx_v6_v7_defconfig: Select CONFIG_DEBUG_FS ARM: mach-imx: Select CONFIG_SRAM at ARCH_MXC level ARM: imx: add speed grading check for i.mx6 soc ARM: imx: avoid calling clk APIs in idle thread which may cause schedule ARM: imx6q: support ptp and rmii clock from pad ARM: imx6q: remove unneeded clk lookups ARM: imx_v6_v7_defconfig: Select CONFIG_MMC_UNSAFE_RESUME ARM: imx_v4_v5_defconfig: Select CONFIG_MMC_UNSAFE_RESUME ...
2014-03-08Merge tag 'omap-for-v3.15/crossbar-signed' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/drivers Merge OMAP crossbar support from Tony Lindgren: Add support for GIC crossbar that routes interrupts on newer omaps. Looks like people wanted these merged via the omap tree as it's the only user for the GIC crossbar. * tag 'omap-for-v3.15/crossbar-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: DRA: Enable Crossbar IP support for DRA7XX ARM: OMAP4+: Correct Wakeup-gen code to use physical irq number DRIVERS: IRQCHIP: CROSSBAR: Add support for Crossbar IP DRIVERS: IRQCHIP: IRQ-GIC: Add support for routable irqs Signed-off-by: Olof Johansson <olof@lixom.net>
