path: root/arch/arm/mach-orion5x/rd88f5182-setup.c
2008-04-29Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (26 commits) [ARM] pxa: fix 1c104e0e4f6ab396960c058e95e18bdedcac945b [ARM] serial: s3c2410: platform_get_irq() may return signed unnoticed [ARM] am79c961a: platform_get_irq() may return signed unnoticed [ARM] Feroceon: Feroceon-specific WA-cache compatible {copy,clear}_user_page() [ARM] Feroceon: fix function alignment in proc-feroceon.S [ARM] Orion: catch a couple more alternative spellings of PCIe [ARM] Orion: fix orion-ehci platform resource end addresses [ARM] Orion: fix ->map_irq() PCIe bus number check [ARM] Orion: fix ioremap() optimization [ARM] feroceon: remove CONFIG_CPU_CACHE_ROUND_ROBIN check [ARM] feroceon: remove CONFIG_CPU_DCACHE_WRITETHROUGH check kprobes/arm: fix decoding of arithmetic immediate instructions kprobes/arm: fix cache flush address for instruction stub [ARM] 5022/1: Race in ARM MMCI PL18x driver, V2 [ARM] 5021/1: at91: buildfix for sam9263 + PM [ARM] 5018/1: RealView: Fix the ARM11MPCore Oprofile compilation [ARM] 5016/1: AT91: typo in mci configuration for at91cap at91sam9263 [ARM] 5017/1: pxa3xx: Report unsupported wakeup sources in pxa3xx_set_wake() [ARM] 5020/1: magician: remove __devinit marker from pasic3_leds_info [ARM] 5014/1: Cleanup reset state before entering suspend or resetting. ...
2008-04-29i2c: Convert most new-style drivers to use module aliasingJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. Update most new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. I've left the video drivers apart (except for SoC camera drivers) as they're a bit more diffcult to deal with, they'll have their own patch later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Jochen Friedrich <jochen@scram.de>
2008-04-28[ARM] Orion: catch a couple more alternative spellings of PCIeLennert Buytenhek
Unify a couple more spellings of "PCIe" ("PCI-E", "PCIE".) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-04-28[ARM] Orion: fix ->map_irq() PCIe bus number checkLennert Buytenhek
The current orion5x board ->map_irq() routines check whether a given bus number lives on the PCIe controller by comparing it with the PCIe controller's primary bus number. This doesn't work in case there are multiple buses in the PCIe domain, i.e. if there exists a PCIe bridge on the primary PCIe bus. This patch adds a helper function (orion5x_pci_map_irq()) that returns the IRQ number for the given PCI device if that device has a hard-wired IRQ, or -1 otherwise, and makes each board's ->map_irq() function use this helper function. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2008-03-27Orion: orion -> orion5x renameLennert Buytenhek
Do a global s/orion/orion5x/ of the Orion 5x-specific bits (i.e. not the plat-orion bits.) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Reviewed-by: Tzachi Perelstein <tzachi@marvell.com> Acked-by: Saeed Bishara <saeed@marvell.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Nicolas Pitre <nico@marvell.com>
