path: root/arch/arm/mach-orion5x
2011-08-25ARM: mach-orion5x: add missing header file <linux/vga.h>Bryan Wu
This patch fixed following building error: -- arch/arm/mach-orion5x/pci.c: In function 'orion5x_pci_sys_setup': arch/arm/mach-orion5x/pci.c:563:2: error: 'vga_base' undeclared (first use in this function) arch/arm/mach-orion5x/pci.c:563:2: note: each undeclared identifier is reported only once for each function it appears in make[1]: *** [arch/arm/mach-orion5x/pci.o] Error 1 make[1]: *** Waiting for unfinished jobs.... -- Signed-off-by: Bryan Wu <bryan.wu@canonical.com> Acked-by: Rob Herring <rob.herring@calxeda.com>
2011-08-25arm: fix compile failure in orion5x/dns323-setup.cPaul Gortmaker
Upstream commit d5341942d784134f2997b3ff82cd63cf71d1f932 "PCI: Make the struct pci_dev * argument of pci_fixup_irqs const." leaked an extra "const" into an actual call site (vs a proto/decl) which causes this: arch/arm/mach-orion5x/dns323-setup.c: In function 'dns323_pci_map_irq': arch/arm/mach-orion5x/dns323-setup.c:80: error: expected expression before 'const' arch/arm/mach-orion5x/dns323-setup.c:80: error: too few arguments to function 'orion5x_pci_map_irq' make[3]: *** [arch/arm/mach-orion5x/dns323-setup.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Nicolas Pitre <nico@fluxnic.net> Acked-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-18ARM: orion5x: fixup 5181 MPP mask checkImre Kaloz
During the refactoring of the Orion MPP code, the detection for the 5181l as been used to select the 5181 MPP mask, which is wrong. Select the 5181 mask for all 5181 variants. Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-07-12ARM: set vga memory base at run-timeRob Herring
Convert the incorrectly named PCIMEM_BASE to a variable called vga_base. This removes the dependency on mach/hardware.h. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12ARM: convert PCI defines to variablesRob Herring
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow multi-platform builds. This also removes the requirement for a platform to have a mach/hardware.h. The default values for i/o and mem are 0x1000 and 0x01000000, respectively. Per Arnd Bergmann, other values are likely to be incorrect, but this commit does not try to address that issue. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12ARM: pci: make pcibios_assign_all_busses use pci_has_flagRob Herring
Convert pcibios_assign_all_busses from a define to inline so platforms can control this setting. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-05-16ARM: orion5x: Refactor mpp code to use common orion platform mpp.Andrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate setup of the crypto engine.Andrew Lunn
2011-05-16ARM: orion: Consolidate SATA platform setup.Andrew Lunn
2011-05-16ARM: orion: Consolidate USB platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the XOR platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the platform data setup for the watchdog.Andrew Lunn
2011-05-16ARM: orion: Consolidate SPI initialization.Andrew Lunn
This change removes the interrupt resource. The driver does not use it. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate I2C initialization.Andrew Lunn
2011-05-16ARM: orion: Consolidate ethernet platform dataAndrew Lunn
2011-05-16ARM: orion: Consolidate the creation of the uart platform data.Andrew Lunn
2011-05-16ARM: orion: Rename some constants to macros to make code more identicalAndrew Lunn
Changing eg 0xffffffff to DMA_BIT_MASK(32) etc allows easier side by side comparision of identical code which can be consolidated. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits) ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support ARM: 6838/1: etm: fix section mismatch warning ARM: 6837/1: remove unused pci_fixup_prpmc1100 ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC Fix the broken build for Marvell Dove platform. ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency ARM: 6834/1: perf: reset counters on all CPUs during initialisation ARM: 6833/1: perf: add required isbs() to ARMv7 backend ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile arm: mach-mx3: pcm043: add write-protect and card-detect for SD1 eukrea_mbimxsd51: add SD Card detect eukrea_mbimxsd25-baseboard: add SD card detect mx3/eukrea_mbimxsd-baseboard: add SD card detect support mx3/eukrea_mbimxsd-baseboard: fix gpio request ARM: mxs/mx28evk: add mmc device ARM: mxs/mx23evk: add mmc device ARM: mxs: dynamically allocate mmc device ARM: mx51_efika: update platform data for new mfd changes mx2/iomux: Set direction for CSPI2 pins ...
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/nico/orion into fixesRussell King
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-06ARM: orion5x: replace printk with pr_{err,info,...} in ts78xx-setup.cAlexander Clouter
Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-05ARM: orion5x: fix compiler cast warnings in ts78xx-setup.cAlexander Clouter
Signed-off-by: Alexander Clouter <alex@digriz.org.uk> [np: used min_t() as suggested by Sergei Shtylyov <sshtylyov@mvista.com>] Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-05ARM: orion5x: use safer FPGA ID 'default' for TS-78xxAlexander Clouter
Originally the FPGA ID checking switch statement left disabled all the TS implemented FPGA devices if the ID was unknown to it. Michael Spang created a fix in f9b1184e that changed the default to enable the devices in the event TS silently release more revisions into the wild, this unfortunately breaks custom FPGA bitstreams. This patch amends the switch statement so that the TS devices are only enabled if on the revision number is unknown (whilst the magic matches). Changelog: v2: neater implementation and some cosmetic changes v1: initial release <20110305112937.GA22117@chipmunk> Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-04ARM: Enable TS-78XX features in unknown revisionsMichael Spang
When the manufacturer increases the revision number the platform devices for the RTC, NAND, and RNG disappear. We should assume new revisions have these devices instead of assuming they do not. Signed-off-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion GPIO code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion GPIO code pass in GPIO-related platform info (GPIO controller base address, secondary base IRQ number, etc) explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion time code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion time code pass in timer and bridge addresses explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] update FPGA revisions for TS-7800Alexander Clouter
New FPGA revisions have been released and seen in the wild on the platform, so it's time to update the list. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] orion5x: accelerate NAND on the TS-78xxAlexander Clouter
The NAND supports 32bit reads and writes so lets stop shunting 8bit chunks across the bus. Doing a dumb 'dd' benchmark, this increases performance roughly like so: * read: 1.3MB/s to 3.4MB/s * write: 614kB/s to 882kB/s Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-06Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/mach-pxa/clock.c arch/arm/mach-pxa/clock.h
2010-12-08ARM: io: make iounmap() a simple macroRussell King
Defining iounmap() with arguments prevents it from being used as a function pointer, causing platforms to work around this. Instead, define it to be a simple macro. Do the same for __arch_io(re|un)map too. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-07[ARM] Orion: added Buffalo LS-CHL supportAsh Hughes
Adds support for Buffalo Linkstation Live v3 (LS-CHL) NAS drives. Signed-off-by: Ash Hughes <ashley.hughes@blueyonder.co.uk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-11-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/nico/orionRussell King
2010-11-05ARM: orion5x/kirkwood/mv78xx0: fix MPP configuration corner casesMike Rapoport
Wrong MPP configuration would cause <cpu>_mpp_conf loop infinitely because the mpp list iterator would not be incremented. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-11-05[ARM] TS-78xxx NAND resource type should be IORESOURCE_MEMMichael Spang
The type was IORESOURCE_IO which is not what is expected by plat_nand_probe(). This device has not worked since 2d098a72 ("mtd: plat_nand: request memory resource before doing ioremap"). Signed-off-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-08-12ARM: Fix gen_nand probe structures contentsMarek Vasut
These three platforms didn't properly fill nr_chips in gen_nand registration and therefore depended on gen_nand bug fixed by commit 81cbb0b17796d81cbd92defe113cf2a7c7a21fbb ("mtd: gen_nand: fix support for multiple chips") Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-07-16[ARM] Orion: DNS-323 C1 requires phylibMartin Michlmayr
The code to support the DNS-323 rev C1 added a call to phy_register_fixup_for_uid() and therefore phylib has to be built in. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] orion5x: Fix soft-reset for some platformsBenjamin Herrenschmidt
Some platforms, such as the DNS-323 rev C requires the soft reset line to be toggled on and back off for the reset to work. Note: The choice of 200ms delay comes from the 2.6.12 based vendor kernel. It seems to be a -lot- though and I had my device working fine with much smaller delays but better safe... Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] orion5x: Base support for DNS-323 rev C1Benjamin Herrenschmidt
This patch adds the base support for this new HW revision to the existing dns323-setup.c file. The SoC seems to be the same as rev B1, the GPIOs are all wired differently though and the fan control isn't i2c based anymore. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] orion5x: Set links to solid on D-Link DNS-323Martin Michlmayr
Among other changes, commit b2a731aa ("D-link DNS-323 revision A1 power LED") changed the default behaviour of the power LED from solid to blinking. This was done to match the original DNS-323 firmware which blinks during the boot process and sets the LED to solid when booting has completed. However, the downside of this behaviour is that it requires userland code to change the LED, even for those who don't care about the behaviour of the original firmware. Therefore, change it to solid again and let those who care about the original behaviour change the behaviour from userland. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-05-26leds: leds-gpio: Change blink_set callback to be able to turn off blinkingBenjamin Herrenschmidt
The leds-gpio blink_set() callback follows the same prototype as the main leds subsystem blink_set() one. The problem is that to stop blink, normally, a leds driver does it in the brightness_set() callback when asked to set a new fixed value. However, with leds-gpio, the platform has no hook to do so, as this later callback results in a standard GPIO manipulation. This changes the leds-gpio specific callback to take a new argument that indicates whether the LED should be blinking or not and in what state it should be set if not. We also update the dns323 platform which seems to be the only user of this so far. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-05-03[ARM] dns323-setup.c: fix WARN() when bootingArnaud Patard
Since commit b2a731aa5cbca7e0252da75e16de7ae5feb1313a, dns323_init() is setting the power led gpio direction with gpio_direction_output() but doesn't request the gpio before (which is not permitted by the gpio layer afaik). This behaviour is triggering a WARN() at boot time. Tested-by: Christian Samsel <csamsel@gmxpro.de> Cc: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Nicolas Pitre <nico@marvell.com> [ Part 2: "Attached Text" ]
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
