path: root/arch/arm/mach-orion5x
2012-05-21ARM: orion5x: Fix GPIO enable bits for MPP9Ben Hutchings
commit 48d99f47a81a66bdd61a348c7fe8df5a7afdf5f3 upstream. Commit 554cdaefd1cf7bb54b209c4e68c7cec87ce442a9 ('ARM: orion5x: Refactor mpp code to use common orion platform mpp.') seems to have accidentally inverted the GPIO valid bits for MPP9 (only). For the mv2120 platform which uses MPP9 as a GPIO LED device, this results in the error: [ 12.711476] leds-gpio: probe of leds-gpio failed with error -22 Reported-by: Henry von Tresckow <hvontres@gmail.com> References: http://bugs.debian.org/667446 Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Tested-by: Hans Henry von Tresckow <hvontres@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-12ARM: orion: Fix USB phy for orion5x.Andrew Lunn
commit 72053353583230952c4b187e110e9da00dfc3afb upstream. The patch "ARM: orion: Consolidate USB platform setup code.", commit 4fcd3f374a928081d391cd9a570afe3b2c692fdc broke USB on TS-7800 and other orion5x boards, because the wrong type of PHY was being passed to the EHCI driver in the platform data. Orion5x needs EHCI_PHY_ORION and all the others want EHCI_PHY_NA. Allow the mach- code to tell the generic plat-orion code which USB PHY enum to place into the platform data. Version 2: Rebase to v3.3-rc2. Reported-by: Ambroz Bizjak <ambrop7@gmail.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Ambroz Bizjak <ambrop7@gmail.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-05-16ARM: orion5x: Refactor mpp code to use common orion platform mpp.Andrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate setup of the crypto engine.Andrew Lunn
2011-05-16ARM: orion: Consolidate SATA platform setup.Andrew Lunn
2011-05-16ARM: orion: Consolidate USB platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the XOR platform setup code.Andrew Lunn
2011-05-16ARM: orion: Consolidate the platform data setup for the watchdog.Andrew Lunn
2011-05-16ARM: orion: Consolidate SPI initialization.Andrew Lunn
This change removes the interrupt resource. The driver does not use it. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-05-16ARM: orion: Consolidate I2C initialization.Andrew Lunn
2011-05-16ARM: orion: Consolidate ethernet platform dataAndrew Lunn
2011-05-16ARM: orion: Consolidate the creation of the uart platform data.Andrew Lunn
2011-05-16ARM: orion: Rename some constants to macros to make code more identicalAndrew Lunn
Changing eg 0xffffffff to DMA_BIT_MASK(32) etc allows easier side by side comparision of identical code which can be consolidated. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits) ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support ARM: 6838/1: etm: fix section mismatch warning ARM: 6837/1: remove unused pci_fixup_prpmc1100 ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC Fix the broken build for Marvell Dove platform. ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency ARM: 6834/1: perf: reset counters on all CPUs during initialisation ARM: 6833/1: perf: add required isbs() to ARMv7 backend ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile arm: mach-mx3: pcm043: add write-protect and card-detect for SD1 eukrea_mbimxsd51: add SD Card detect eukrea_mbimxsd25-baseboard: add SD card detect mx3/eukrea_mbimxsd-baseboard: add SD card detect support mx3/eukrea_mbimxsd-baseboard: fix gpio request ARM: mxs/mx28evk: add mmc device ARM: mxs/mx23evk: add mmc device ARM: mxs: dynamically allocate mmc device ARM: mx51_efika: update platform data for new mfd changes mx2/iomux: Set direction for CSPI2 pins ...
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/nico/orion into fixesRussell King
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-06ARM: orion5x: replace printk with pr_{err,info,...} in ts78xx-setup.cAlexander Clouter
Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-05ARM: orion5x: fix compiler cast warnings in ts78xx-setup.cAlexander Clouter
Signed-off-by: Alexander Clouter <alex@digriz.org.uk> [np: used min_t() as suggested by Sergei Shtylyov <sshtylyov@mvista.com>] Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-05ARM: orion5x: use safer FPGA ID 'default' for TS-78xxAlexander Clouter
Originally the FPGA ID checking switch statement left disabled all the TS implemented FPGA devices if the ID was unknown to it. Michael Spang created a fix in f9b1184e that changed the default to enable the devices in the event TS silently release more revisions into the wild, this unfortunately breaks custom FPGA bitstreams. This patch amends the switch statement so that the TS devices are only enabled if on the revision number is unknown (whilst the magic matches). Changelog: v2: neater implementation and some cosmetic changes v1: initial release <20110305112937.GA22117@chipmunk> Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-04ARM: Enable TS-78XX features in unknown revisionsMichael Spang
When the manufacturer increases the revision number the platform devices for the RTC, NAND, and RNG disappear. We should assume new revisions have these devices instead of assuming they do not. Signed-off-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion GPIO code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion GPIO code pass in GPIO-related platform info (GPIO controller base address, secondary base IRQ number, etc) explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03ARM: Remove dependency of plat-orion time code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion time code pass in timer and bridge addresses explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] update FPGA revisions for TS-7800Alexander Clouter
New FPGA revisions have been released and seen in the wild on the platform, so it's time to update the list. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-03-03[ARM] orion5x: accelerate NAND on the TS-78xxAlexander Clouter
The NAND supports 32bit reads and writes so lets stop shunting 8bit chunks across the bus. Doing a dumb 'dd' benchmark, this increases performance roughly like so: * read: 1.3MB/s to 3.4MB/s * write: 614kB/s to 882kB/s Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-06Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/mach-pxa/clock.c arch/arm/mach-pxa/clock.h
2010-12-08ARM: io: make iounmap() a simple macroRussell King
Defining iounmap() with arguments prevents it from being used as a function pointer, causing platforms to work around this. Instead, define it to be a simple macro. Do the same for __arch_io(re|un)map too. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-07[ARM] Orion: added Buffalo LS-CHL supportAsh Hughes
Adds support for Buffalo Linkstation Live v3 (LS-CHL) NAS drives. Signed-off-by: Ash Hughes <ashley.hughes@blueyonder.co.uk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-11-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/nico/orionRussell King
2010-11-05ARM: orion5x/kirkwood/mv78xx0: fix MPP configuration corner casesMike Rapoport
Wrong MPP configuration would cause <cpu>_mpp_conf loop infinitely because the mpp list iterator would not be incremented. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-11-05[ARM] TS-78xxx NAND resource type should be IORESOURCE_MEMMichael Spang
The type was IORESOURCE_IO which is not what is expected by plat_nand_probe(). This device has not worked since 2d098a72 ("mtd: plat_nand: request memory resource before doing ioremap"). Signed-off-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-08-12ARM: Fix gen_nand probe structures contentsMarek Vasut
These three platforms didn't properly fill nr_chips in gen_nand registration and therefore depended on gen_nand bug fixed by commit 81cbb0b17796d81cbd92defe113cf2a7c7a21fbb ("mtd: gen_nand: fix support for multiple chips") Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-07-16[ARM] Orion: DNS-323 C1 requires phylibMartin Michlmayr
The code to support the DNS-323 rev C1 added a call to phy_register_fixup_for_uid() and therefore phylib has to be built in. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] orion5x: Fix soft-reset for some platformsBenjamin Herrenschmidt
Some platforms, such as the DNS-323 rev C requires the soft reset line to be toggled on and back off for the reset to work. Note: The choice of 200ms delay comes from the 2.6.12 based vendor kernel. It seems to be a -lot- though and I had my device working fine with much smaller delays but better safe... Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] orion5x: Base support for DNS-323 rev C1Benjamin Herrenschmidt
This patch adds the base support for this new HW revision to the existing dns323-setup.c file. The SoC seems to be the same as rev B1, the GPIOs are all wired differently though and the fan control isn't i2c based anymore. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] orion5x: Set links to solid on D-Link DNS-323Martin Michlmayr
Among other changes, commit b2a731aa ("D-link DNS-323 revision A1 power LED") changed the default behaviour of the power LED from solid to blinking. This was done to match the original DNS-323 firmware which blinks during the boot process and sets the LED to solid when booting has completed. However, the downside of this behaviour is that it requires userland code to change the LED, even for those who don't care about the behaviour of the original firmware. Therefore, change it to solid again and let those who care about the original behaviour change the behaviour from userland. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-05-26leds: leds-gpio: Change blink_set callback to be able to turn off blinkingBenjamin Herrenschmidt
The leds-gpio blink_set() callback follows the same prototype as the main leds subsystem blink_set() one. The problem is that to stop blink, normally, a leds driver does it in the brightness_set() callback when asked to set a new fixed value. However, with leds-gpio, the platform has no hook to do so, as this later callback results in a standard GPIO manipulation. This changes the leds-gpio specific callback to take a new argument that indicates whether the LED should be blinking or not and in what state it should be set if not. We also update the dns323 platform which seems to be the only user of this so far. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-05-03[ARM] dns323-setup.c: fix WARN() when bootingArnaud Patard
Since commit b2a731aa5cbca7e0252da75e16de7ae5feb1313a, dns323_init() is setting the power led gpio direction with gpio_direction_output() but doesn't request the gpio before (which is not permitted by the gpio layer afaik). This behaviour is triggering a WARN() at boot time. Tested-by: Christian Samsel <csamsel@gmxpro.de> Cc: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Nicolas Pitre <nico@marvell.com> [ Part 2: "Attached Text" ]
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-23[ARM] Orion5x: replace KEY_WLAN with KEY_WPS_BUTTONChristian Lamparter
"Input: add KEY_WPS_BUTTON definition" introduced a generic keycode for WPS input events. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2010-03-08Merge branch 'origin' into devel-stableRussell King
Conflicts: arch/arm/mach-mx2/devices.c arch/arm/mach-mx2/devices.h sound/soc/pxa/pxa-ssp.c
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-10[ARM] orion5x: D-link DNS-323 revision A1 power LEDLaurie Bradshaw
This patch fixes the power LED on DNS-323 revision A1, and adds timer support for (hopefully) both A1 and B1 revisions. Power LED on revision A1 is active low and also requires GPIO 4 to be low to work. Tested on my DNS-323 revision A1. I have set the default trigger to timer as that replicates the behaviour of the original firmware, userspace can change the trigger at the end of the boot process providing a useful indication that booting has completed. Signed-off-by: Nicolas Pitre <nico@marvell.com>
