path: root/arch/arm/mach-pnx4008
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-25Merge branches 'clks' and 'pnx' into develRussell King
2010-02-12ARM: PNX4008: move i2c_adapter structure inside the drivers private dataRussell King
2010-02-12ARM: PNX4008: kzalloc i2c drivers internal dataRussell King
2010-02-12ARM: PNX4008: remove platform definitions from mach/timex.hRussell King
mach/timex.h is only supposed to contain a definition for CLOCK_TICK_RATE. Remove additional includes, and move private definitions to a private header file. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: PNX4008: get i2c clock rate from clk APIRussell King
Acked-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: PNX4008: convert i2c-pnx to use clk API enable/disable callsRussell King
clk_set_rate() is not supposed to be used to turn clocks on and off. That's what clk_enable/clk_disable is for. Acked-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: PNX4008: move i2c clock start/stop into driverRussell King
2010-02-12ARM: PNX4008: move i2c suspend/resume callbacks into driverRussell King
2010-02-12ARM: PNX4008: convert i2c clocks to match by device onlyRussell King
2010-02-12ARM: PNX4008: convert watchdog to use clk API enable/disable callsRussell King
clk_set_rate() is not supposed to be used to turn clocks on and off. That's what clk_enable/clk_disable is for. Acked-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: PNX4008: convert watchdog clocks to match by device onlyRussell King
2010-02-12ARM: PNX4008: provide clock enable/disable methods and initializationRussell King
2010-02-12ARM: PNX4008: simplify clk enable/disable pathsRussell King
2010-02-12ARM: PNX4008: convert to clkdevRussell King
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-08[ARM] fix pnx4008Russell King
arch/arm/mach-pnx4008/include/mach/gpio.h:214: error: implicit declaration of function 'IO_ADDRESS' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-30[ARM] Add a common typesafe __io implementationRussell King
As Al did for Versatile in 2ad4f86b60b649fd7428265c08d73a3bd360c81b, add a typesafe __io implementation for platforms to use. Convert platforms to use this new simple typesafe implementation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-30[ARM] pnx4008: fix definition of PHYS_OFFSETRussell King
PHYS_OFFSET constants should be defined using UL(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] move MAX_DMA_ADDRESS to mach/memory.hRussell King
Move the definition of MAX_DMA_ADDRESS from mach/dma.h to mach/memory.h, thereby placing it along side its relative, ISA_DMA_THRESHOLD. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-08[ARM] fix pnx4008 build errorsRussell King
include/linux/i2c-pnx.h was missed when moving the include files. Fix it now; it doesn't really need to include mach/i2c.h at all. Successfully build tested with pnx4008_defconfig, which had failed in linux-next. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Eliminate useless includes of asm/mach-types.hRussell King
There are 43 includes of asm/mach-types.h by files that don't reference anything from that file. Remove these unnecessary includes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-18arch: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] Fix timer damage from d3d74453c34f8fd87674a8cf5b8a327c68f22e99Russell King
Move the xtime write mode seqlock into timer_tick(), so it only surrounds the call to do_timer(). This avoids a deadlock in update_process_times() ... hrtimer_get_softirq_time() which tries to get a read mode seqlock on xtime, thereby preventing booting. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-18PM: Rename struct pm_ops and related thingsRafael J. Wysocki
The name of 'struct pm_ops' suggests that it is related to the power management in general, but in fact it is only related to suspend.  Moreover, its name should indicate what this structure is used for, so it seems reasonable to change it to 'struct platform_suspend_ops'.  In that case, the name of the global variable of this type used by the PM core and the names of related functions should be changed accordingly. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18PM: Move definition of struct pm_ops to suspend.hRafael J. Wysocki
Move the definition of 'struct pm_ops' and related functions from <linux/pm.h> to <linux/suspend.h> . There are, at least, the following reasons to do that: * 'struct pm_ops' is specifically related to suspend and not to the power management in general. * As long as 'struct pm_ops' is defined in <linux/pm.h>, any modification of it causes the entire kernel to be recompiled, which is unnecessary and annoying. * Some suspend-related features are already defined in <linux/suspend.h>, so it is logical to move the definition of 'struct pm_ops' into there. * 'struct hibernation_ops', being the hibernation-related counterpart of 'struct pm_ops', is defined in <linux/suspend.h> . Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[ARM] Spinlock initializer cleanupThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30power management: implement pm_ops.valid for everybodyJohannes Berg
Almost all users of pm_ops only support mem sleep, don't check in .valid and don't reject any others in .prepare so users can be confused if they check /sys/power/state, especially when new states are added (these would then result in s-t-r although they're supposed to be something different). This patch implements a generic pm_valid_only_mem function that is then exported for users and puts it to use in almost all existing pm_ops. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: linux-pm@lists.linux-foundation.org Cc: Len Brown <lenb@kernel.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10i2c: New Philips PNX bus driverVitaly Wool
New I2C bus driver for Philips ARM boards (Philips IP3204 I2C IP block). This I2C controller can be found on (at least) PNX010x, PNX52xx and PNX4008 Philips boards. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-09[ARM] 3857/2: pnx4008: add devices' registrationVitaly Wool
This patch adds platform devices' registration for the devices which drivers either have been added to the mainline or on the way to. arch/arm/mach-pnx4008/core.c | 69 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 69 insertions(+) Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-10-02[WATCHDOG] pnx4008: add watchdog supportVitaly Wool
Add watchdog support for Philips PNX4008 ARM board inlined. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-07-05[ARM] 3709/1: pnx4008: convert to generic irq subsystemVitaly Wool
Patch from Vitaly Wool Convert pnx4008 chip support to use generic irq subsystem Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ARM] 3623/1: pnx4008: move GPIO-related defines to gpio.hVitaly Wool
Patch from Vitaly Wool This patch moves GPIO-related defines and static inline funcs from include/asm-arm/arch-pnx4008/pm.h to include/asm-arm/arch-pnx4008/gpio.h. Also, some more GPIO-related defines are added to include/asm-arm/arch-pnx4008/gpio.h as they are needed for the USB host driver (coming soon...) Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] 3622/1: pnx4008: remove clk_use/clk_unuseVitaly Wool
Patch from Vitaly Wool clk_use/clk_unuse functions are no longer needed, so removing those from arch/arm/mach-pnx4008/clock.c. Also, the order of functions is rearranged a bit, to avoid forward declarations. Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-20[ARM] Include asm/hardware.h not asm/arch/hardware.hRussell King
2006-06-18[ARM] 3466/1: [2/3] Support for Philips PNX4008 platform: chip supportVitaly Wool
Patch from Vitaly Wool This patch adds basic chip support for PNX4008 ARM platform. It's basically the same as the previous one, but with the rmk's comments taken into account. Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Signed-off-by: Dmitry Pervushin <dpervushin@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
