path: root/arch/arm/mach-pxa/Makefile
2008-05-09[ARM] 5033/1: Unbreak corgi_ssp by registering ssp drivers earlier.Dmitry Baryshkov
A lot of stuff in spitz/akita/etc. depends on corgi_ssp to be initialised early. However corgi_ssp initialisation fails, because at that time pxa*-ssp devices don't have drivers. Move ssp earlier in the makefile so they are registered before corgi-ssp. Also move sleep/suspend and cpu-freq to more logical places Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-29[ARM] pxa: fix 1c104e0e4f6ab396960c058e95e18bdedcac945bRussell King
The referenced commit changed the order such that the CPU code was initialised before MFP, resulting in unregistered MFP sysfs objects being referenced. Reverse the link order of these so MFP is initialised before the CPU code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4867/1: Adds flash, udc, mci support for gumstix F boardsJaya Kumar
This patch implements support for Gumstix-F flash, udc and mci. Fixes since the last time are: - Steve Sakoman as maintainer - cleanup for udc and mci setup Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: add MFP-alike pin configuration support for pxa{25x, 27x}eric miao
Pin configuration on pxa{25x,27x} has now separated from generic GPIO into dedicated mfp-pxa2xx.c by this patch. The name "mfp" is borrowed from pxa3xx and is used here to alert the difference between the two concepts: pin configuration and generic GPIOs. A GPIO can be called a "GPIO" _only_ when the corresponding pin is configured so. A pin configuration on pxa{25x,27x} is composed of: - alternate function selection (or pin mux as commonly called) - low power state or sleep state - wakeup enabling from low power mode The following MFP_xxx bit definitions in mfp.h are re-used: - MFP_PIN(x) - MFP_AFx - MFP_LPM_DRIVE_{LOW, HIGH} - MFP_LPM_EDGE_* Selecting alternate function on pxa{25x, 27x} involves configuration of GPIO direction register GPDRx, so a new bit and MFP_DIR_{IN, OUT} are introduced. And pin configurations are defined by the following two macros: - MFP_CFG_IN : for input alternate functions - MFP_CFG_OUT : for output alternate functions Every configuration should provide a low power state if it configured as output using MFP_CFG_OUT(). As a general guideline, the low power state should be decided to minimize the overall power dissipation. As an example, it is better to drive the pin as high level in low power mode if the GPIO is configured as an active low chip select. Pins configured as GPIO are defined by MFP_CFG_IN(). This is to avoid side effects when it is firstly configured as output. The actual direction of the GPIO is configured by gpio_direction_{input, output} Wakeup enabling on pxa{25x, 27x} is actually GPIO based wakeup, thus the device based enable_irq_wake() mechanism is not applicable here. E.g. invoking enable_irq_wake() with a GPIO IRQ as in the following code to enable OTG wakeup is by no means portable and intuitive, and it is valid _only_ when GPIO35 is configured as USB_P2_1: enable_irq_wake( gpio_to_irq(35) ); To make things worse, not every GPIO is able to wakeup the system. Only a small number of them can, on either rising or falling edge, or when level is high (for keypad GPIOs). Thus, another new bit is introduced to indicate that the GPIO will wakeup the system: - MFP_LPM_WAKEUP_ENABLE The following macros can be used in platform code, and be OR'ed to the GPIO configuration to enable its wakeup: - WAKEUP_ON_EDGE_{RISE, FALL, BOTH} - WAKEUP_ON_LEVEL_HIGH The WAKEUP_ON_LEVEL_HIGH is used for keypad GPIOs _only_, there is no edge settings for those GPIOs. These WAKEUP_ON_* flags OR'ed on wrong GPIOs will be ignored in case that platform code author is careless enough. The tradeoff here is that the wakeup source is fully determined by the platform configuration, instead of enable_irq_wake(). Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: rename mfp.c to mfp-pxa3xx.c to indicate it's pxa3xx specificeric miao
2008-02-05gpiolib support for the PXA architecturePhilipp Zabel
This adds gpiolib support for the PXA architecture: - move all GPIO API functions from generic.c into gpio.c - convert the gpio_get/set_value macros into inline functions This makes it easier to hook up GPIOs provided by external chips like ASICs and CPLDs. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Jean Delvare <khali@linux-fr.org> Cc: Eric Miao <eric.miao@marvell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Minor ARM fixup from David Brownell folded into this ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04[ARM] pxa: introduce sysdev for pxa3xx static memory controllereric miao
Introduce a sysdev for pxa3xx static memory controller, mainly for register saving/restoring in PM Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] 4762/1: Basic support for Toradex Colibri moduleDaniel Mack
This patch adds support for Toradex' PXA27x based Colibri module. It's kept as simple as possible to only provide basic functionality. A default config is also included. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] 4747/1: pcm027: support for pcm990 baseboard for phyCORE-PXA270Robert Schwebel
This patch adds baseboard support for the phyCORE-PXA270 development kit (aka PCM-990). This example shows how to use some phyCORE-PXA270 CPU module features on a baseboard in a standard manner. It could be used as a starting point for custom baseboard development. V2: After comments by Eric Miao: - IRQ chained handler fixed - video/graphic support moved to separate patch - ifdef/endif hell reduced ;-) V3: After comments by Russell King - initialise the mmci platform data statically V4: After comments by Russell King - wrong return value in pcm990_mci_init() fixed Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] 4744/1: pcm027: add support for phyCORE-PXA270 CPU moduleRobert Schwebel
This patch adds main support for the generic phyCORE-PXA270 CPU module (aka PCM-027). Its as generic as possible to support any kind of baseboard. Note: Neither the CPU module nor the pcm027.c implementation can work without a baseboard support. Baseboard support can be added by the PCM-990 or any custom variant. V2: After comments by Eric Miao: - Currently unsupported devices moved into separate patch - direct call of baseboard initialisation V3: After comments by Russell King - sort include files - setting RTC bit for power control removed - style problems fixed (discovered by checkpatch.pl) Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] pxa: add basic support for Littleton (PXA3xx Form Factor Platform)eric miao
2008-01-28[ARM] 4664/1: Add basic support for HTC Magician PDA phonesPhilipp Zabel
This includes irda, gpio keys, pxafb, backlight, ohci and flash (read-only). Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] 4649/1: Base support for pxa-based Toshiba e-series PDAs.Ian Molton
This patch contains the base code to boot the Toshiba e330, e740, e750, e400, and e800 PDAs. Signed-off-by: Ian Molton <spyro@f2s.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: omit PXA25x or PXA27x standby/sleep code as appropriateRussell King
There's no point building standby/sleep code for processors which aren't configured. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: create arch/arm/mach-pxa/device.c for all on-chip deviceseric miao
Considering that generic.c is getting more and more bloated by device information, moving that part out side will be much cleaner. Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: add cpufreq supportRussell King
There have been patches hanging around for ages to add support for cpufreq to PXA255 processors. It's about time we applied one. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] 4576/1: CM-X270 machine supportMike Rapoport
This patch provides core support for CM-X270 platform. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] pxa: PXA3xx base supporteric miao
Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] pxa: tidy up arch/arm/mach-pxa/MakefileRussell King
2007-07-20[ARM] 4475/2: EM-x270 board supportMike Rapoport
2006-06-29[ARM] 3666/1: TRIZEPS4 [1/5] coreJürgen Schindele
Patch from Jürgen Schindele This patch adds support for Trizeps4 SoM and ConXS-evalboard from "Keith und Koep" This DIMM-module is based on PXA270. Signed-off-by: Jürgen Schindele <linux@schindele.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3594/1: Poodle: Add touchscreen support + other updatesRichard Purdie
Patch from Richard Purdie Poodle Updates: * Update corgi_ssp to make the GPIO chip selects optional * Enable corgi_ssp for use by poodle * Add corgi touchscreen platform device for poodle * Export locomo platform device. * Set framebuffer device parent correctly Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-28[ARM] 3417/1: add support for logicpd pxa270 card engineLennert Buytenhek
Patch from Lennert Buytenhek Add support for the LogicPD PXA270 Card Engine. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Convert SA1111 to use clock architectureRussell King
2005-11-13[ARM] 3160/1: SharpSL: Add driver for Akita specific GPIOsRichard Purdie
Patch from Richard Purdie Add a driver for the extra GPIOs found on the Sharp SL-C1000 (Akita). These GPIOs are found on a Maxim MAX7310 I2C i/o expander chip. A generic GPIO driver for the MAX7310 was attempted but this mini driver is a much simpler and much more effective solution avoiding several issues and complexity the generic driver had (as discussed on LKML). The platform device is required so the device parent can be set correctly which ensures the device is one of the last to suspend and first to resume. Whilst the i2c suspend/resume calls can be influenced, nothing guarantees this is easlier/later than the subsystems the gpios are used on which are all independent of i2c (sound, irda, video/backlight etc.). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-13[ARM] 3159/1: SharpSL: Add PM device driver for the SL-Cx00 machines.Richard Purdie
Patch from Richard Purdie Add a SharpSL PM device driver for the SL-Cxx00 machines. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-13[ARM] 3158/1: SharpSL: Add PM device driver for the SL-C7x0 machines.Richard Purdie
Patch from Richard Purdie Add a SharpSL PM device driver for the SL-C7x0 machines. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3098/1: pxa2xx disable ssp irqLiam Girdwood
Patch from Liam Girdwood This patch allows users of the pxa SSP driver to register their own irq handlers instead of using the default SSP handler. It also cleans up the CKEN clock and irq detection as the values are now stored in a table. This patch replaces 2845/1 Changes:- o Added flags parameter to ssp_init() o Added SSP_NO_IRQ flag to disable registering of ssp irq handler (for drivers that want to register their own handler) o Cleaned up clock and irq detection, values are now stored in table. o Added build changes to allow other drivers (e.g audio) to select the ssp driver. o corgi_ssp.c changed to use new interface. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-06[ARM] 3088/1: PXA: Add machine support for the Sharp SL-6000x series of PDAsDirk Opfer
Patch from Dirk Opfer This patch adds basic machine support for the Sharp SL-6000x (Tosa) PDAs. Signed-off-by: Dirk Opfer Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-13[PATCH] SharpSL: Add new ARM PXA machines Spitz and Borzoi with partial ā†µRichard Purdie
Akita Support Add the platform support code for two new Sharp Zaurus Models, Spitz (SL-C3000) and Borzoi (SL-C3100). This patch also adds most of the foundations for Akita (SL-C1000) Support. The missing link for Akita is the driver for its I2C io expander. Once this has been finished, the missing Kconfig option and machine declaration can easily be added to this code. Signed-Off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Vojtech Pavlik <vojtech@suse.cz> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] w100fb: Update corgi platform code to match new driverRichard Purdie
This patch moves the platform specific Sharp SL-C7x0 LCD code from the w100fb driver into a more appropriate place and updates the Corgi code to match the new w100fb driver. It also updates the corgi touchscreen code to match the new simplified interface available from w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-01[PATCH] ARM: 2781/2: PXA27x Standby mode take 2Todd Poynor
Patch from Todd Poynor Add support for PXA27x Standby mode, a low-power mode that retains CPU and some peripheral state (the existing "sleep" mode is a power-power mode that retains less state). Activated via: echo -n standby > /sys/power/state From: David Burrage and Todd Poynor Signed-off-by: Todd Poynor <tpoynor@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
