path: root/arch/arm/mach-pxa/cm-x2xx-pci.h
2008-10-07[ARM] 5280/1: pxa: prepare cm-x2xx.c and cm-x2xx-pci.[ch] for addition of ↵Mike Rapoport
CM-X255 - Change CM-X255 and CM-X270 common function prefix from cmx270 to cmx2xx - Split cmx2xx_init to common and CM-X270-specific parts - Use dynamic assignement for DM9000 resources and led GPIOs. Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] 5286/2: pxa: rename cm-x270* to cm-x2xx* to allow addition of cm-x255 ↵Mike Rapoport
support Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
