[ Upstream commit 88af3209aa0881aa5ffd99664b6080a4be5f24e5 ]
WARNING: vmlinux.o(.text+0x19f90): Section mismatch in reference from the function littleton_init_lcd() to the function .init.text:pxa_set_fb_info()
The function littleton_init_lcd() references
the function __init pxa_set_fb_info().
This is often because littleton_init_lcd lacks a __init
annotation or the annotation of pxa_set_fb_info is wrong.
WARNING: vmlinux.o(.text+0xf824): Section mismatch in reference from the function zeus_register_ohci() to the function .init.text:pxa_set_ohci_info()
The function zeus_register_ohci() references
the function __init pxa_set_ohci_info().
This is often because zeus_register_ohci lacks a __init
annotation or the annotation of pxa_set_ohci_info is wrong.
WARNING: vmlinux.o(.text+0xf95c): Section mismatch in reference from the function cm_x300_init_u2d() to the function .init.text:pxa3xx_set_u2d_info()
The function cm_x300_init_u2d() references
the function __init pxa3xx_set_u2d_info().
This is often because cm_x300_init_u2d lacks a __init
annotation or the annotation of pxa3xx_set_u2d_info is wrong.
rtc-v3020.h belongs to include/linux/platform_data/
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Lots of header files are never included outside of a mach-pxa
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Use a PWM lookup table to provide the PWM to the pwm-backlight device.
The driver has a legacy code path that is required only because boards
still use the legacy method of requesting PWMs by global ID. Replacing
these usages allows that legacy fallback to be removed.
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Since dm9000 driver added support for a vcc regulator, platform data
based platforms have their ethernet broken, as the regulator claiming
returns -EPROBE_DEFER and prevents dm9000 loading.
This patch fixes this for all pxa boards using dm9000, by using the
specific regulator_has_full_constraints() function.
This was discovered and tested on the cm-x300 board.
Fixes: 7994fe55a4a2 ("dm9000: Add regulator and reset support to dm9000")
memblock is now fully integrated into the kernel and is the prefered
method for tracking memory. Rather than reinvent the wheel with
meminfo, migrate to using memblock directly instead of meminfo as
an intermediate.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
The GPIO API defines 0 as being a valid GPIO number, so this field needs
to be initialized explicitly.
A special case is the Palm Tungsten|C board. Since it doesn't use any
quirks that would require the existing .init() or .exit() hooks it can
simply use the new enable_gpio field.
Signed-off-by: Thierry Reding <treding@nvidia.com>
This patch moves the pca953x.h header from include/linux/i2c to
include/linux/platform_data and updates existing support accordingly.
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the pxa include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Acked-by: Paul Parsons <lost.distance@yahoo.com>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Acked-By: Stefan Schmidt <stefan@openezx.org>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
Cc: Harald Welte <laforge@openezx.org>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Tomas Cech <sleep_walker@suse.cz>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
Cc: Dan Williams <djbw@fb.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Liam Girdwood <lrg@ti.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: openezx-devel@lists.openezx.org
Tested-by: Paul Parsons <lost.distance@yahoo.com>
Acked-by: Philipp Zabel <philipp.zabel@gmail.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Pull arm-soc fixes from Olof Johansson:
"This is a first pass of some of the merge window fallout for ARM
platforms.
Nothing controversial:
- A system.h fallout fix for OMAP
- PXA fixes for breakage caused by the regulator struct changes
- GPIO fixes for OMAP to properly deal with dynamic IRQ allocation
- A mismerge in our arm-soc tree of an lpc32xx change for networking
- A fix for USB setup on tegra
- An undo of __init annotation of display mux setup on OMAP that's
needed at runtime"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: pxa: fix build issue on stargate2
ARM: pxa: fix build issue on cm-x300
ARM: pxa: fix build failure for regulator consumer in em-x270.c
ARM: LPC32xx: clock.c: Fix lpc-eth clock reference
ARM: OMAP: pm: fix compilation break
ARM: OMAP: Remove OMAP_GPIO_IRQ macro definition
drivers: input: Fix OMAP_GPIO_IRQ with gpio_to_irq() in ams_delta_serio_exit()
ARM: OMAP: boards: Fix OMAP_GPIO_IRQ usage with gpio_to_irq()
ARM: pxa: fix regulator related build fail in magician_defconfig
ARM: tegra: Fix device tree AUXDATA for USB/EHCI
ARM: OMAP2+: Remove __init from DSI mux functions
* 'fixes' of git://github.com/hzhuang1/linux:
arch/arm/mach-pxa/cm-x300.c:716:3: error: unknown field ‘dev’ specified
in initializer
make[1]: *** [arch/arm/mach-pxa/cm-x300.o] Error 1
make: *** [arch/arm/mach-pxa] Error 2
It's caused by 'dev' field removed from struct
regulator_consumer_supply.
Pull more ARM updates from Russell King.
This got a fair number of conflicts with the <asm/system.h> split, but
also with some other sparse-irq and header file include cleanups. They
all looked pretty trivial, though.
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits)
ARM: fix Kconfig warning for HAVE_BPF_JIT
ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds
ARM: 7349/1: integrator: convert to sparse irqs
ARM: 7259/3: net: JIT compiler for packet filters
ARM: 7334/1: add jump label support
ARM: 7333/2: jump label: detect %c support for ARM
ARM: 7338/1: add support for early console output via semihosting
ARM: use set_current_blocked() and block_sigmask()
ARM: exec: remove redundant set_fs(USER_DS)
ARM: 7332/1: extract out code patch function from kprobes
ARM: 7331/1: extract out insn generation code from ftrace
ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format
ARM: 7351/1: ftrace: remove useless memory checks
ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path
ARM: Versatile Express: add NO_IOPORT
ARM: get rid of asm/irq.h in asm/prom.h
ARM: 7319/1: Print debug info for SIGBUS in user faults
ARM: 7318/1: gic: refactor irq_start assignment
ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop
ARM: 7315/1: perf: add support for the Cortex-A7 PMU
Disintegrate asm/system.h for ARM.
cc: Russell King <linux@arm.linux.org.uk>
cc: linux-arm-kernel@lists.infradead.org
Remove NR_IRQS and add a per machine .nr_irqs setting.
arch/arm/mach-mxs/include/mach/common.h
Pull in previous samsung conflict merges and do a trivial
merge of an mxs double-add conflict.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Avoid potential naming confliction since multiple architecture will be built
in a single kernel.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
* git://git.infradead.org/mtd-2.6: (226 commits)
mtd: tests: annotate as DANGEROUS in Kconfig
mtd: tests: don't use mtd0 as a default
mtd: clean up usage of MTD_DOCPROBE_ADDRESS
jffs2: add compr=lzo and compr=zlib options
jffs2: implement mount option parsing and compression overriding
mtd: nand: initialize ops.mode
mtd: provide an alias for the redboot module name
mtd: m25p80: don't probe device which has status of 'disabled'
mtd: nand_h1900 never worked
mtd: Add DiskOnChip G3 support
mtd: m25p80: add EON flash EN25Q32B into spi flash id table
mtd: mark block device queue as non-rotational
mtd: r852: make r852_pm_ops static
mtd: m25p80: add support for at25df321a spi data flash
mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks
mtd: nand: switch `check_pattern()' to standard `memcmp()'
mtd: nand: invalidate cache on unaligned reads
mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set
mtd: nand: wait to set BBT version
mtd: nand: scrub BBT on ECC errors
Fix up trivial conflicts:
- arch/arm/mach-at91/board-usb-a9260.c
Merged into board-usb-a926x.c
- drivers/mtd/maps/lantiq-flash.c
add_mtd_partitions -> mtd_device_register vs changed to use
mtd_device_parse_register.
* 'next/fixes' of git://git.linaro.org/people/arnd/arm-soc: (28 commits)
ARM: pxa/cm-x300: properly set bt_reset pin
ARM: mmp: rename SHEEVAD to GPLUGD
ARM: imx: Fix typo 'MACH_MX31_3DS_MXC_NAND_USE_BBT'
ARM: i.MX28: shift frac value in _CLK_SET_RATE
plat-mxc: iomux-v3.h: implicitly enable pull-up/down when that's desired
ARM: mx5: fix clock usage for suspend
ARM: pxa: use correct __iomem annotations
ARM: pxa: sharpsl pm needs SPI
ARM: pxa: centro and treo680 need palm27x
ARM: pxa: make pxafb_smart_*() empty when not enabled
ARM: pxa: select POWER_SUPPLY on raumfeld
ARM: pxa: pxa95x is incompatible with earlier pxa
ARM: pxa: CPU_FREQ_TABLE is needed for CPU_FREQ
ARM: pxa: pxa95x/saarb depends on pxa3xx code
ARM: pxa: allow selecting just one of TREO680/CENTRO
ARM: pxa: export symbols from pxa3xx-ulpi
ARM: pxa: make zylonite_pxa*_init declaration match code
ARM: pxa/z2: fix building error of pxa27x_cpu_suspend() no longer available
ARM: at91: add defconfig for at91sam9g45 family
ARM: at91: remove dependency for Atmel PWM driver selector in Kconfig
Fix up all conflicts between the memory.h cleanup and bug fixes.
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
Fix below build warning and properly set bt_reset pin.
CC arch/arm/mach-pxa/cm-x300.o
arch/arm/mach-pxa/cm-x300.c: In function 'cm_x300_init_wi2wi':
arch/arm/mach-pxa/cm-x300.c:779: warning: unused variable 'wlan_en'
arch/arm/mach-pxa/cm-x300.c:795: warning: 'bt_reset' may be used uninitialized in this function
Cc: <stable@kernel.org>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Get rid of the mdesc pointer in the fixup function call. No one uses
the mdesc pointer, it shouldn't be modified anyway, and we can't wrap
it, so let's remove it.
Platform files found by:
$ regexp=$(git grep -h '\.fixup.*=' arch/arm |
sed 's!.*= *\([^,]*\),* *!\1!' | sort -u |
tr '\n' '|' | sed 's,|$,,;s,|,\\|,g')
$ git grep $regexp arch/arm
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Current pxa3xx_nand controller has two chip select which
both be workable. This patch enable this feature.
Update platform driver to support this feature.
Another notice should be taken that:
When you want to use this feature, you should not enable the
keep configuration feature, for two chip select could be
attached with different nand chip. The different page size
and timing requirement make the keep configuration impossible.
Signed-off-by: Lei Wen <leiwen@marvell.com>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits)
ARM: S5P64X0: External Interrupt Support
ARM: EXYNOS4: Enable MFC on Samsung NURI
ARM: EXYNOS4: Enable MFC on universal_c210
ARM: S5PV210: Enable MFC on Goni
ARM: S5P: Add support for MFC device
ARM: EXYNOS4: Add support FIMD on SMDKC210
ARM: EXYNOS4: Add platform device and helper functions for FIMD
ARM: EXYNOS4: Add resource definition for FIMD
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: SAMSUNG: Add IRQ_I2S0 definition
ARM: SAMSUNG: Add platform device for idma
ARM: EXYNOS4: Add more registers to be saved and restored for PM
ARM: EXYNOS4: Add more register addresses of CMU
ARM: EXYNOS4: Add platform device for dwmci driver
ARM: EXYNOS4: configure rtc-s3c on NURI
ARM: EXYNOS4: configure MAX8903 secondary charger on NURI
ARM: EXYNOS4: configure ADC on NURI
ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI
ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI
ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs
Fix up tons of silly conflicts:
- arch/arm/mach-davinci/include/mach/psc.h
- arch/arm/mach-exynos4/Kconfig
- arch/arm/mach-exynos4/mach-smdkc210.c
- arch/arm/mach-exynos4/pm.c
- arch/arm/mach-imx/mm-imx1.c
- arch/arm/mach-imx/mm-imx21.c
- arch/arm/mach-imx/mm-imx25.c
- arch/arm/mach-imx/mm-imx27.c
- arch/arm/mach-imx/mm-imx31.c
- arch/arm/mach-imx/mm-imx35.c
- arch/arm/mach-mx5/mm.c
- arch/arm/mach-s5pv210/mach-goni.c
- arch/arm/mm/Kconfig
introduce pr_fmt, so the pr_* calls will be cleaner
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
use gpio_request_<one|array>() instead of multiple gpiolib calls
While in sleep mode the CS# and other V3020 RTC GPIOs must be driven
high, otherwise V3020 RTC fails to keep the right time in sleep mode.
Cc: stable@kernel.org
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits)
ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support
ARM: 6838/1: etm: fix section mismatch warning
ARM: 6837/1: remove unused pci_fixup_prpmc1100
ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC
Fix the broken build for Marvell Dove platform.
ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency
ARM: 6834/1: perf: reset counters on all CPUs during initialisation
ARM: 6833/1: perf: add required isbs() to ARMv7 backend
ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues
ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile
arm: mach-mx3: pcm043: add write-protect and card-detect for SD1
eukrea_mbimxsd51: add SD Card detect
eukrea_mbimxsd25-baseboard: add SD card detect
mx3/eukrea_mbimxsd-baseboard: add SD card detect support
mx3/eukrea_mbimxsd-baseboard: fix gpio request
ARM: mxs/mx28evk: add mmc device
ARM: mxs/mx23evk: add mmc device
ARM: mxs: dynamically allocate mmc device
ARM: mx51_efika: update platform data for new mfd changes
mx2/iomux: Set direction for CSPI2 pins
Convert to the new function names. Automated with coccinelle.
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
arch/arm/mach-pxa/tosa.c
This patch moves the platform data definition from
arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so
it can be accessed from x86 the same way as on ARM.
This change should make no functional change to the PXA code. The move
is verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig
pxa910_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
set_pxa_fb_info() has been a long-standing wart in the naming scheme
of the pxa_set_xxx_info() functions. This renames the function, and
combines set_pxa_fb_parent() with set_pxa_fb_info().
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish
between PXA25x/PXA27x and PXA3xx memory mapping.
Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io()
and pxa3xx_map_io() is included.
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
ffuart is available on cm-x300 only with pxa300.
Cc: stable <stable@kernel.org>
delay_detect in HZ is confusing, convert it to be millisecond based. And
thus remove those unnecessary call to msecs_to_jiffies() at runtime for
this field. Other constants are converted assuming HZ == 100, which are
basically true for those platforms.
The assignment in csb726.c was incorrect, and is fixed in this patch as
a result.
Acked-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Daniel Mack <daniel@caiaq.de>
CM-X300 bootloader passes DRAM configuration information in ATAGS,
however, the first memory bank is reported at actual physical address 0x8000000.
Use the configuration information supplied by the bootloader and
cope with the necessity to have PHYS_ADDR=0xa0000000.
