path: root/arch/arm/mach-pxa/corgi_lcd.c
2008-01-28[ARM] 4737/1: Refactor corgi_lcd to improve readability + bugfixRichard Purdie
This patch refactors the code in corgi_lcd.c moving it to the board specific corgi and spitz files where appropriate instead of the existing ifdef mess which hinders readability. Fix spitz_get_hsync_len() to call get_hsync_invperiod so pxafb can be compiled as a module. The confusing variables which represent the inverse horizintal sync period are renamed to "invperiod" consistently. An incorrect comment in corgi_ts.c is also corrected. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-02[ARM] 3848/1: pxafb: Add option of fixing video modes and spitz QVGA mode ↵Richard Purdie
support Add the ability to have pxafb use only certain fixed video modes (selected on a per platform basis). This is useful on production hardware such as the Zaurus cxx00 models where the valid modes are known in advance and any other modes could result in hardware damage. Following this, add support for the cxx00 QVGA mode. Mode information is passed to the lcd_power call to allowing the panel drivers to configure the display hardware accordingly (corgi_lcd already contains the functionality for the cxx00 panel). This mirrors the setup already used by w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-16[ARM] Include asm/hardware.h instead of asm/arch/hardware.hRussell King
Rationalise hardware.h include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-24[ARM] fix sharp zaurus c-3000 compile failure without CONFIG_FB_PXAPavel Machek
This fixes compile problem when CONFIG_FB_PXA is not set. LD .tmp_vmlinux1 arch/arm/mach-pxa/built-in.o(.text+0x1d74): In function `spitz_get_hsync_len': : undefined reference to `pxafb_get_hsync_time' make: *** [.tmp_vmlinux1] Error 1 3.46user 0.46system 5.10 (0m5.106s) elapsed 77.01%CPU Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-14[ARM] 3012/1: Corgi/Spitz LCD: Use bus_find_device to locate pxafb - fix ↵Richard Purdie
compile error Patch from Richard Purdie Update corgi_lcd to use bus_find_device to locate the pxafb device hence fixing a compile error. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-29[ARM] Don't include mach-types.h unnecessarilyRussell King
It's pointless to include mach-types.h if you're not going to use anything from it. These references were removed as a result of: grep -lr 'asm/mach-types\.h' . | xargs grep -L 'machine_is_\|MACH_TYPE_\|MACHINE_START\|machine_type' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-13[PATCH] SharpSL: Abstract model specifics from Corgi Backlight driverRichard Purdie
Separate out the Sharp Zaurus c7x0 series specific code from the Corgi backlight driver. Abstract model/machine specific functions to corgi_lcd.c via sharpsl.h This enables the driver to be used by the Zaurus cxx00 series. Signed-Off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Vojtech Pavlik <vojtech@suse.cz> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] SharpSL: Add cxx00 support to the Corgi LCD driverRichard Purdie
The same LCD is present on both the Sharp Zaurus c7x0 series and the cxx00 but with different framebuffer drivers (w100fb vs. pxafb). This patch adds support for the cxx00 series to the LCD driver. It also adds some LCD to touchscreen interface logic needed by the touchscreen driver to prevent interference problems, the idea being to keep all the ugly code in one place leaving the drivers themselves clean. sharpsl.h is used to provide the abstraction. Signed-Off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Vojtech Pavlik <vojtech@suse.cz> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] w100fb: Update corgi platform code to match new driverRichard Purdie
This patch moves the platform specific Sharp SL-C7x0 LCD code from the w100fb driver into a more appropriate place and updates the Corgi code to match the new w100fb driver. It also updates the corgi touchscreen code to match the new simplified interface available from w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
