path: root/arch/arm/mach-pxa/cpufreq-pxa2xx.c
2009-11-20[ARM] pxa/cpufreq: fix index assignments for end markerDaniel Mack
I stumbled over two small things regarding the .index field assignment in the dynamically created cpu frequency tables for pxa2xx and pxa3xx. Even though that doesn't currently cause any problem, it should still be fixed in case the logic in the CPUFREQ core changes. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-10-12[ARM] pxa: workaround errata #37 by not using half turbo switchingDennis O'Brien
PXA27x Errata #37 implies system will hang when switching into or out of half turbo (HT bit in CLKCFG) mode, workaround this by not using it. Signed-off-by: Dennis O'Brien <dennis.obrien@eqware.net> Cc: stable-2.6.31 <stable@kernel.org> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-06-05[ARM] pxa: add vcc_core regulation for cpufreq on pxa2xxRobert Jarzmik
Add voltage regulation capability to pxa2xx cpufreq driver. The cpufreq will ask for a "vcc_core" regulator to the regulator framework. If a regulator is found at probe time, it will be used with values specified in PXA270 Electrical, Mechanical, and Thermal Specifications. If not, it will be assumed for now that frequency change will work without voltage control. This assumes that the IPL/SPL installs sane values to an existing voltage regulator (ie. voltage high enough to support the full range). Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: introduce pxa{25x,27x,300,320,930}.h for board usageEric Miao
Considering the header mess ATM, it is not always possible to include the correct header files within board code. Let's keep this simple: <mach/pxa25x.h> - for pxa25x based platforms <mach/pxa27x.h> - for pxa27x based platforms <mach/pxa300.h> - for pxa300 based platforms <mach/pxa320.h> - for pxa320 based platforms <mach/pxa930.h> - for pxa930 based platforms NOTE: 1. one header one board file, they are not compatible (i.e. they have conflicting definitions which won't compile if included together). 2. Unless strictly necessary, the following header files are considered to be SoC files use _only_, and is not recommended to be included in board code: <mach/hardware.h> <mach/pxa-regs.h> <mach/pxa2xx-regs.h> <mach/pxa3xx-regs.h> <mach/mfp.h> <mach/mfp-pxa2xx.h> <mach/mfp-pxa25x.h> <mach/mfp-pxa27x.h> <mach/mfp-pxa3xx.h> <mach/mfp-pxa300.h> <mach/mfp-pxa320.h> <mach/mfp-pxa930.h> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-02[ARM] pxa: cpufreq-pxa2xx: sdram_rows detection supportPhilipp Zabel
This patch implements Eric Miao's idea to detect the correct value of sdram_rows by inspecting the MDCNFG register settings. It is only tested on two pxa27x devices with 64MB RAM (magician and hx4700) so far. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-02[ARM] pxa: cpufreq-pxa2xx: allow frequency table selectionMarc Zyngier
Following the removal of the "->policy" usage for PXA255 in patch 459fc208abd1b365fa013c17d433dfb5b4bc1e3a (cpufreq: remove policy->governor setting in drivers initialization), this patch introduces an option (called "pxa255_turbo_table") to select either the "run" or "turbo" frequency table. It also cures the runtime warning that was printed each time the frequency was changed. Got rid of all references to CPUFREQ_POLICY_* for pxa255, and sticked with the run/turbo thing. Tested on an Arcom/Eurotech Viper. Signed-off-by: Marc Zyngier <maz@misterjones.org> Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-10-15cpufreq: remove policy->governor setting in drivers initializationDominik Brodowski
As policy->governor is already set to CPUFREQ_DEFAULT_GOVERNOR in the (always built-in) cpufreq core, we do not need to set it in the drivers. This fixes the sparc64 allmodconfig build failure. Also, remove a totally useles setting of ->policy in cpufreq-pxa3xx.c. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-07[ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.cEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
