mach-mmp utilizes pxa27x_keypad code so we need to move header to
platform pxa directory.
Signed-off-by: Mark F. Brown <mark.brown314@gmail.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
delay_detect in HZ is confusing, convert it to be millisecond based. And
thus remove those unnecessary call to msecs_to_jiffies() at runtime for
this field. Other constants are converted assuming HZ == 100, which are
basically true for those platforms.
The assignment in csb726.c was incorrect, and is fixed in this patch as
a result.
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
pxa_camera init() is ambiguous, it's better to statically configure the sensor.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
For some platforms, it is inappropriate to register all PXA UARTs.
In some cases, the UARTs may not be used, and in others we may want
to avoid registering the UARTs to allow other drivers (eg, FICP) to
make use of the UART.
In addition, a while back there was a request to be able to pass
platform data to the UART driver.
This patch enables all of this by providing functions platforms can
call to register each individual UART.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Several boards use always the same pattern with pxamci :
request gpio, request irq for that gpio to detect MMC card
insertion, request gpio for read-only mode detection, etc
Now that pxamci provides platform_data to describe simple
gpio management of the MMC external controls, use it.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Philipp Zabel <philipp.zabel@gmail.com>
Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: rpurdie@rpsys.net
Cc: drwyrm@gmail.com
Cc: sakoman@gmail.com
Cc: marek.vasut@gmail.com
Cc: s.hauer@pengutronix.de
If CONFIG_APM_EMULATION=n em-x270 build fails with linker error:
arch/arm/mach-pxa/built-in.o: In function `em_x270_battery_critical': em-x270.c:(.text+0x12c0): undefined reference to `apm_queue_event'
arch/arm/mach-pxa/built-in.o: In function `em_x270_battery_low': em-x270.c:(.text+0x12c8): undefined reference to `apm_queue_event'
make: *** [.tmp_vmlinux1] Error 1
Fix it.
After commit 6b849bcff0004aa5dd216b4d3eb56f51c9df8a72 (ASoC: Convert PXA
AC97 driver to probe with the platform device) AC97 controller device
should be registered explicitly for both ASoC and generic AC97 drivers
Register userspace-consumer devices to allow userspace control of
voltage regulators supplying GPS and GPRS modules
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Signed-off-by: Paul Shen <paul.shen@marvell.com>
Remove duplicated #include in arch/arm/mach-pxa/em-x270.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
After commit a7bb3909b3293d503211d7f6af8ed62c1644b686 ("spi: pxa2xx_spi:
introduce chipselect GPIO to simplify the common cases") the .gpio_cs
field in pxa2xx_spi_chip has to be set explicitly.
Considering the header mess ATM, it is not always possible to include
the correct header files within board code. Let's keep this simple:
<mach/pxa25x.h> - for pxa25x based platforms
<mach/pxa27x.h> - for pxa27x based platforms
<mach/pxa300.h> - for pxa300 based platforms
<mach/pxa320.h> - for pxa320 based platforms
<mach/pxa930.h> - for pxa930 based platforms
NOTE:
1. one header one board file, they are not compatible (i.e. they have
conflicting definitions which won't compile if included together).
2. Unless strictly necessary, the following header files are considered
to be SoC files use _only_, and is not recommended to be included in
board code:
<mach/hardware.h>
<mach/pxa-regs.h>
<mach/pxa2xx-regs.h>
<mach/pxa3xx-regs.h>
<mach/mfp.h>
<mach/mfp-pxa2xx.h>
<mach/mfp-pxa25x.h>
<mach/mfp-pxa27x.h>
<mach/mfp-pxa3xx.h>
<mach/mfp-pxa300.h>
<mach/mfp-pxa320.h>
<mach/mfp-pxa930.h>
Change several GPIO assignment from static to run-time
Split MFP table to common and EM-X270 specific parts
Introduce em_x270_module_init
The patch includes the following updates to EM-X270:
- Added DA9030 support
- Added NOR flash support
- Added QCI with mt9m112 sensor support
- Updated LCD support
Direct access to USB host controller registers is considered to be not
portable, and is usually a bad sign for poorly abstracted interface.
Introduce .flags and .power_on_delay to "struct pxaohci_platform_data"
so that most platforms don't bother to write their own .init/.exit()
sequences.
This just leaves include/asm-arm/plat-* to deal with.
Convert EM-X270 pin configuration to use MFP tables and gpio library
Make device initialization dependent on respective driver CONFIG_ value (like
in zylonite)
Add keypad and gpio_key devices
As well as moving all the device declarations to a single one in devices.c
this causes all platforms to register the I/O and interrupt resources for
the AC97 controller.
Cc: eric miao <eric.miao@marvell.com>
Cc: Mike Rapoport <mike@compulab.co.il>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Jürgen Schindele <linux@schindele.name>
Cc: Juergen Beisert <jbe@pengutronix.de>
The PXA25x and PXA27x USB device controller register definitions are
different. Currently, they live side by side in pxa-regs.h, but only
one set is available depending on the setting of PXA25x or PXA27x.
This means that if we build to support both PXA25x and PXA27x, the
PXA27x definitions are unavailable, even to PXA27x specific code.
Remove these definitions from pxa-regs.h, and place them in separate
files. Include these files where appropriate.
Note: according to the dependencies in drivers/usb/gadget/Kconfig,
we do not support the UDC on PXA27x nor PXA3xx CPUs, so remove the
platform devices from pxa27x.c and pxa3xx.c.
two reasons:
1. GPIO namings and their mode definitions are conceptually not part
of the PXA register definitions
2. this is actually a temporary move in the transition of PXA2xx to
use MFP-alike APIs (as what PXA3xx is now doing), so that legacy
code will still work and new code can be added in step by step
Signed-off-by: eric miao <eric.miao@marvell.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
