Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
arch/arm/mach-pxa/tosa.c
This patch moves the platform data definition from
arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so
it can be accessed from x86 the same way as on ARM.
This change should make no functional change to the PXA code. The move
is verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig
pxa910_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
set_pxa_fb_info() has been a long-standing wart in the naming scheme
of the pxa_set_xxx_info() functions. This renames the function, and
combines set_pxa_fb_parent() with set_pxa_fb_info().
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish
between PXA25x/PXA27x and PXA3xx memory mapping.
Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io()
and pxa3xx_map_io() is included.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (505 commits)
[media] af9015: Fix max I2C message size when used with tda18271
[media] IR: initialize ir_raw_event in few more drivers
[media] Guard a divide in v4l1 compat layer
[media] imon: fix nomouse modprobe option
[media] imon: remove redundant change_protocol call
[media] imon: fix my egregious brown paper bag w/rdev/idev split
[media] cafe_ccic: Configure ov7670 correctly
[media] ov7670: allow configuration of image size, clock speed, and I/O method
[media] af9015: support for DigitalNow TinyTwin v3 [1f4d:9016]
[media] af9015: map DigitalNow TinyTwin v2 remote
[media] DigitalNow TinyTwin remote controller
[media] af9015: RC fixes and improvements
videodev2.h.xml: Update to reflect the latest changes at videodev2.h
[media] v4l: document new Bayer and monochrome pixel formats
[media] DocBook/v4l: Add missing formats used on gspca cpia1 and sn9c2028
[media] firedtv: add parameter to fake ca_system_ids in CA_INFO
[media] tm6000: fix a macro coding style issue
tm6000: Remove some ugly debug code
[media] Nova-S-Plus audio line input
[media] [RFC,1/1] V4L2: Use new CAP bits in existing RDS capable drivers
With the v4l2_i2c_new_subdev* functions now supporting loading modules
based on modaliases, remove the module names hardcoded in platform data
and pass a NULL module name to those functions.
All corresponding I2C modules have been checked, and all of them include
a module aliases table with names corresponding to what the soc_camera
platform data uses.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
mach-mmp utilizes pxa27x_keypad code so we need to move header to
platform pxa directory.
Signed-off-by: Mark F. Brown <mark.brown314@gmail.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Acked-by: Antonio Ospite <ospite@studenti.unina.it>
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Signed-off-by: Bart Visscher <bartv@thisnet.nl>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
For some platforms, it is inappropriate to register all PXA UARTs.
In some cases, the UARTs may not be used, and in others we may want
to avoid registering the UARTs to allow other drivers (eg, FICP) to
make use of the UART.
In addition, a while back there was a request to be able to pass
platform data to the UART driver.
This patch enables all of this by providing functions platforms can
call to register each individual UART.
Acked-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Setup gpio-keys for EzX phones
Acked-by: Daniel Ribeiro <drwyrm@gmail.com>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Signed-off-by: Paul Shen <paul.shen@marvell.com>
Fix LPM configuration on ezx.c
Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com>
Considering the header mess ATM, it is not always possible to include
the correct header files within board code. Let's keep this simple:
<mach/pxa25x.h> - for pxa25x based platforms
<mach/pxa27x.h> - for pxa27x based platforms
<mach/pxa300.h> - for pxa300 based platforms
<mach/pxa320.h> - for pxa320 based platforms
<mach/pxa930.h> - for pxa930 based platforms
NOTE:
1. one header one board file, they are not compatible (i.e. they have
conflicting definitions which won't compile if included together).
2. Unless strictly necessary, the following header files are considered
to be SoC files use _only_, and is not recommended to be included in
board code:
<mach/hardware.h>
<mach/pxa-regs.h>
<mach/pxa2xx-regs.h>
<mach/pxa3xx-regs.h>
<mach/mfp.h>
<mach/mfp-pxa2xx.h>
<mach/mfp-pxa25x.h>
<mach/mfp-pxa27x.h>
<mach/mfp-pxa3xx.h>
<mach/mfp-pxa300.h>
<mach/mfp-pxa320.h>
<mach/mfp-pxa930.h>
arch/arm/mach-pxa/am200epd.c
arch/arm/mach-pxa/ezx.c
I2C platform data setups.
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
Matrix and single key setups for all phones.
Pin configs for different generations and phones.
Our bootloader now supports ATAGS_MEM
arch/arm/mach-pxa/pxa25x.c
Avoid unnecessarily pollution of the kernel's namespace by avoiding
mach/hardware.h. Include this header file where necessary.
This just leaves include/asm-arm/plat-* to deal with.
Common code for the different EZX GSM phones. Functions to control framebuffer,
backlight power, OHCI and UART init.
Acked-by: Eric Miao <eric.miao@marvell.com>
