path: root/arch/arm/mach-pxa/generic.h
2011-07-12ARM: pxa: move declarations from generic.h to <soc>.hEric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-04-24ARM / PXA: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by the PXA platform code with struct syscore_ops objects that are simpler. This reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13ARM: PXA SoCs: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
2010-12-18ARM: pxa: support pxa95xHaojian Zhuang
The core of PXA955 is PJ4. Add new PJ4 support. And add new macro CONFIG_PXA95x. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: remove get_memclk_frequency_10khz()Eric Miao
Introduce 'struct clk' for memory and remove get_memclk_frequency_10khz(). Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: pxa: Introduce pxa{25x,27x,3xx}_map_io()Marek Vasut
This patch introduces pxa2xx_map_io() and pxa3xx_map_io() to distinguish between PXA25x/PXA27x and PXA3xx memory mapping. Also, fixup for platforms broken after introducing pxa{25x,27x}_map_io() and pxa3xx_map_io() is included. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-10-09ARM: pxa: reduce the scope of get_memclk_frequency_10khz()Haojian Zhuang
Up to now, only pxa2xx pcmcia driver is using the API. No other device driver is using this API in PXA3xx or any other PXA silicons. Restrict the scope only on pxa2xx and remove the implementation of pxa3xx. So we can avoid oo much checking on cpuid after more pxa chips supported. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-07-16ARM: Remove DISCONTIGMEM supportRussell King
Everything should now be using sparsemem rather than discontigmem, so remove the code supporting discontigmem from ARM. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-01[ARM] pxa: allow platforms to control which uarts are registeredRussell King
For some platforms, it is inappropriate to register all PXA UARTs. In some cases, the UARTs may not be used, and in others we may want to avoid registering the UARTs to allow other drivers (eg, FICP) to make use of the UART. In addition, a while back there was a request to be able to pass platform data to the UART driver. This patch enables all of this by providing functions platforms can call to register each individual UART. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-04-13[ARM] pxa: add missing declaration of pxa26x_init_irq()Marek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: move declaration of 'pxa_last_gpio' into <mach/gpio.h>Eric Miao
2009-03-09[ARM] pxa: move IRQ handling of GPIO 0 and 1 outside of gpio.cEric Miao
This is part of the work making gpio.c generic enough, the changes include: 1. move IRQ handling of GPIO 0 and 1 outside (and back into irq.c) 2. pxa_init_gpio() accepts a range for muxed GPIO IRQs, and an IRQ number for the muxed GPIOs 3. __gpio_is_occupied() and __gpio_is_inverted() are made inline, and are moved into <mach/gpio.h> instead of generic gpio.c Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-09-26[ARM] pxa: better MFP low power state support for pxa25x/pxa27xEric Miao
When configured as a specific low power state: MFP_LPM_DRIVE_LOW, MFP_LPM_DRIVE_HIGH, the corresponding GPDR register bit during low power mode shall be re-configured as output (if they are not configured so), thus the PGSRx bits can output. Create an additional low power values GPDR registers, and properly save/restore the GAFR + GPDR registers when doing suspend/resume. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-05[ARM] pxa: introduce reset_status and clear_reset_status for driver's usageEric Miao
Due to the problem of reset status bits being handled by different registers between pxa2xx and pxa3xx, introduce a global reset_status variable, initialized by SoC-specific code and later being used by other drivers. And also introduce clear_reset_status(), which is used to clear the corresponding status bits. Pass RESET_STATUS_ALL to clear all bits. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-04-19[ARM] pxa: move ARRAY_AND_SIZE definition to generic.heric miao
for use by other platforms Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: move mfp sysdev registeration out for suspend/resume ordereric miao
MFP configurations after resume should be done before the GPIO registers are restored. Move the mfp sysdev registeration to the same place where GPIO and IRQ sysdev(s) are registered to better control the order. Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: merge assignment of set_wake into pxa_init_{irq,gpio}()eric miao
To further clean up the GPIO and IRQ structure: 1. pxa_init_irq_gpio() and pxa_init_gpio() combines into a single function pxa_init_gpio() 2. assignment of set_wake merged into pxa_init_{irq,gpio}() as an argument Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: integrate low IRQ chip (ICIP) and high IRQ chip (ICIP2) into oneeric miao
This makes the code better organized and simplified a bit. The change will lose a bit of performance when performing IRQ ack/mask/unmask,but that's not too much after checking the result binary. This patch also removes the ugly #ifdef CONFIG_PXA27x .. #endif by carefully not to access those pxa{27x,3xx} specific registers, this is done by keeping an internal IRQ number variable. The pxa-regs.h is also modified so registers for IRQ > PXA_IRQ(31) are made public even if CONFIG_PXA{27x,3xx} isn't defined (for pxa25x's sake) The incorrect assumption in the original code that internal irq starts from 0 is also corrected by comparing with PXA_IRQ(0). "struct sys_device" for the IRQ are reduced into one single device on pxa{27x,3xx}. Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: move GPIO IRQ specific code out of irq.c into gpio.ceric miao
2008-02-05gpiolib support for the PXA architecturePhilipp Zabel
This adds gpiolib support for the PXA architecture: - move all GPIO API functions from generic.c into gpio.c - convert the gpio_get/set_value macros into inline functions This makes it easier to hook up GPIOs provided by external chips like ASICs and CPLDs. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Jean Delvare <khali@linux-fr.org> Cc: Eric Miao <eric.miao@marvell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Minor ARM fixup from David Brownell folded into this ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04[ARM] pxa: introduce sysdev for GPIO register saving/restoringeric miao
2008-02-04[ARM] pxa: introduce sysdev for IRQ register saving/restoringeric miao
2007-10-15[ARM] pxa: PXA3xx base supporteric miao
Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4560/1: pxa: move processor specific set_wake logic out of irq.ceric miao
a function pxa_init_irq_set_wake() was introduced, so that processor specific code could install their own version code setting PFER and PRER registers within pxa_gpio_irq_type are removed, and the edge configuration is postponed to the (*set_wake) and copies the GRER and GFER register, which will always be set up correctly by pxa_gpio_irq_type() Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4559/1: pxa: make PXA_LAST_GPIO a run-time variableeric miao
This definition produces processor specific code in generic function pxa_gpio_mode(), thus creating inconsistencies for support of pxa25x and pxa27x in a single zImage. As David Brownell suggests, make it a run-time variable and initialize at run-time according to the number of GPIOs on the processor. For now the initialization happens in pxa_init_irq_gpio(), since there is already a parameter for that, besides, this is and MUST be earlier than any subsequent calls to pxa_gpio_mode(). Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: remove get_lcdclk_frequency_10khz()Russell King
get_lcdclk_frequency_10khz() is now redundant, remove it. Hide pxa27x_get_lcdclk_frequency_10khz() from public view. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: fix naming of memory/lcd/core clock functionsRussell King
Rename pxa25x and pxa27x memory/lcd/core clock functions, and select the correct version at run time. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] pxa: move platform devices to separate header fileRussell King
2007-07-12[ARM] pxa: move device registration into CPU-specific fileRussell King
This allows individual CPU support to determine which platform devices should be registered. Also fix a copy-n-paste bug in the I2C power platform device entry. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] 4450/1: pxa: add pxa25x_init_irq() and pxa27x_init_irq()Eric Miao
/* should be ok this time, I aligned this patch to your arm:pxa2.mbox */ 1. move pxa25x specific IRQ initialization code to pxa25x_init_irq() and pxa27x code to pxa27x_init_irq(), remove pxa_init_irq() 2. replace all pxa_init_irq() with their PXA25x or PXA27x specific functions Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
