path: root/arch/arm/mach-pxa/gumstix.c
2009-12-01[ARM] pxa: allow platforms to control which uarts are registeredRussell King
For some platforms, it is inappropriate to register all PXA UARTs. In some cases, the UARTs may not be used, and in others we may want to avoid registering the UARTs to allow other drivers (eg, FICP) to make use of the UART. In addition, a while back there was a request to be able to pass platform data to the UART driver. This patch enables all of this by providing functions platforms can call to register each individual UART. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-09-10[ARM] pxa: factor pxamci gpio handlingRobert Jarzmik
Several boards use always the same pattern with pxamci : request gpio, request irq for that gpio to detect MMC card insertion, request gpio for read-only mode detection, etc ... Now that pxamci provides platform_data to describe simple gpio management of the MMC external controls, use it. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: rpurdie@rpsys.net Cc: drwyrm@gmail.com Cc: sakoman@gmail.com Cc: marek.vasut@gmail.com Cc: s.hauer@pengutronix.de Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-03-09[ARM] pxa: introduce pxa{25x,27x,300,320,930}.h for board usageEric Miao
Considering the header mess ATM, it is not always possible to include the correct header files within board code. Let's keep this simple: <mach/pxa25x.h> - for pxa25x based platforms <mach/pxa27x.h> - for pxa27x based platforms <mach/pxa300.h> - for pxa300 based platforms <mach/pxa320.h> - for pxa320 based platforms <mach/pxa930.h> - for pxa930 based platforms NOTE: 1. one header one board file, they are not compatible (i.e. they have conflicting definitions which won't compile if included together). 2. Unless strictly necessary, the following header files are considered to be SoC files use _only_, and is not recommended to be included in board code: <mach/hardware.h> <mach/pxa-regs.h> <mach/pxa2xx-regs.h> <mach/pxa3xx-regs.h> <mach/mfp.h> <mach/mfp-pxa2xx.h> <mach/mfp-pxa25x.h> <mach/mfp-pxa27x.h> <mach/mfp-pxa3xx.h> <mach/mfp-pxa300.h> <mach/mfp-pxa320.h> <mach/mfp-pxa930.h> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-02-10[ARM] 5354/1: mach-pxa: add AM300 platform driver v3Jaya Kumar
This patch adds support for the AM300 platform driver which uses the E-Ink broadsheetfb display driver. Cc: Eric Miao <eric.miao@marvell.com> Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-23Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel Conflicts: arch/arm/mach-pxa/am200epd.c arch/arm/mach-pxa/ezx.c
2008-12-17[ARM] pxa/gumstix: fix incorrect init done by am200Jaya Kumar
Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: Andre Puschmann <andre.puschmann@imms.de> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-13[ARM] 5337/1: gumstix: move am200 specific gpio pins into am200epd.Jaya Kumar
The gpio setup for AM200 specific GPIO pins should be done in the AM200 code rather than in generic gumstix code. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-26[ARM] 5197/1: gumstix: conversion to MFP support and add bluetooth supportJaya Kumar
This patch converts gumstix over to the MFP configuration system and adds bluetooth support. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-21[ARM] 5006/1: Gumstix GPIO header fixup and defconfig fixupJaya Kumar
This patch adds the include of the GPIO header needed to make gumstix build. The defconfig is updated to 2.6.25 and disables PCMCIA since that has not yet been implemented for gumstix. Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4867/1: Adds flash, udc, mci support for gumstix F boardsJaya Kumar
This patch implements support for Gumstix-F flash, udc and mci. Fixes since the last time are: - Steve Sakoman as maintainer - cleanup for udc and mci setup Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
