* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits)
ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support
ARM: 6838/1: etm: fix section mismatch warning
ARM: 6837/1: remove unused pci_fixup_prpmc1100
ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC
Fix the broken build for Marvell Dove platform.
ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency
ARM: 6834/1: perf: reset counters on all CPUs during initialisation
ARM: 6833/1: perf: add required isbs() to ARMv7 backend
ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues
ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile
arm: mach-mx3: pcm043: add write-protect and card-detect for SD1
eukrea_mbimxsd51: add SD Card detect
eukrea_mbimxsd25-baseboard: add SD card detect
mx3/eukrea_mbimxsd-baseboard: add SD card detect support
mx3/eukrea_mbimxsd-baseboard: fix gpio request
ARM: mxs/mx28evk: add mmc device
ARM: mxs/mx23evk: add mmc device
ARM: mxs: dynamically allocate mmc device
ARM: mx51_efika: update platform data for new mfd changes
mx2/iomux: Set direction for CSPI2 pins
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Convert to the new function names. Automated with coccinelle.
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
arch/arm/mach-pxa/tosa.c
This patch moves the platform data definition from
arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so
it can be accessed from x86 the same way as on ARM.
This change should make no functional change to the PXA code. The move
is verified by building the following defconfigs:
cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig
imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig
raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig
pxa910_defconfig
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
set_pxa_fb_info() has been a long-standing wart in the naming scheme
of the pxa_set_xxx_info() functions. This renames the function, and
combines set_pxa_fb_parent() with set_pxa_fb_info().
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
With the v4l2_i2c_new_subdev* functions now supporting loading modules
based on modaliases, remove the module names hardcoded in platform data
and pass a NULL module name to those functions.
All corresponding I2C modules have been checked, and all of them include
a module aliases table with names corresponding to what the soc_camera
platform data uses.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
delay_detect in HZ is confusing, convert it to be millisecond based. And
thus remove those unnecessary call to msecs_to_jiffies() at runtime for
this field. Other constants are converted assuming HZ == 100, which are
basically true for those platforms.
The assignment in csb726.c was incorrect, and is fixed in this patch as
a result.
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Daniel Mack <daniel@caiaq.de>
Missing AC97 pin configurations are added where pxa_set_ac97_info() are
called for all pxa25x/pxa27x platforms. Where no exact configuration is
provided, use the default as in sound/arm/pxa2xx-ac97-lib.c
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
pxa_camera init() is ambiguous, it's better to configure PXA CIF pins
statically in machine init function.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Several boards use always the same pattern with pxamci :
request gpio, request irq for that gpio to detect MMC card
insertion, request gpio for read-only mode detection, etc
Now that pxamci provides platform_data to describe simple
gpio management of the MMC external controls, use it.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Philipp Zabel <philipp.zabel@gmail.com>
Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: rpurdie@rpsys.net
Cc: drwyrm@gmail.com
Cc: sakoman@gmail.com
Cc: marek.vasut@gmail.com
Cc: s.hauer@pengutronix.de
Currently pcm990 camera bus-width management functions request a GPIO and never
free it again. With this approach the GPIO extender driver cannot be unloaded
once camera drivers have been loaded, also unloading theb i2c-pxa bus driver
produces errors, because the GPIO extender driver cannot unregister properly.
Another problem is, that if camera drivers are once loaded before the GPIO
extender driver, the platform code marks the GPIO unavailable and only a reboot
helps to recover. Adding an explicit free_bus method and using it in mt9m001
and mt9v022 drivers fixes these problems.
Acked-by: Eric Miao <eric.miao@marvell.com>
Signed-off-by: Paul Shen <paul.shen@marvell.com>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
As a result of an off-by-1 error pcm990 leaves one unused GPIO number between
built-in GPIOs and the pca9536 extender. Fix it.
soc_camera_link
Some Phytec cameras have a I2C GPIO expander which allows it to
switch between different sensor bus widths. This was previously
handled in the camera driver. Since handling of this switch
varies on several boards the cameras are used on, the board
support seems a better place to handle the switch
Considering the header mess ATM, it is not always possible to include
the correct header files within board code. Let's keep this simple:
<mach/pxa25x.h> - for pxa25x based platforms
<mach/pxa27x.h> - for pxa27x based platforms
<mach/pxa300.h> - for pxa300 based platforms
<mach/pxa320.h> - for pxa320 based platforms
<mach/pxa930.h> - for pxa930 based platforms
NOTE:
1. one header one board file, they are not compatible (i.e. they have
conflicting definitions which won't compile if included together).
2. Unless strictly necessary, the following header files are considered
to be SoC files use _only_, and is not recommended to be included in
board code:
<mach/hardware.h>
<mach/pxa-regs.h>
<mach/pxa2xx-regs.h>
<mach/pxa3xx-regs.h>
<mach/mfp.h>
<mach/mfp-pxa2xx.h>
<mach/mfp-pxa25x.h>
<mach/mfp-pxa27x.h>
<mach/mfp-pxa3xx.h>
<mach/mfp-pxa300.h>
<mach/mfp-pxa320.h>
<mach/mfp-pxa930.h>
arch/arm/mach-pxa/am200epd.c
arch/arm/mach-pxa/ezx.c
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Ian Molton <spyro@f2s.com>
Cc: pHilipp Zabel <philipp.zabel@gmail.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Juergen Schindele <linux@schindele.name>
Acked-by: Stefan Schmidt <stefan@datenfreihafen.org>
Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com>
0 is a valid GPIO number, use a negative number to specify, that this camera
doesn't have a GPIO for bus-width switching.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
desc_handle_irq() was declared as obsolete since long ago.
Replace it with generic_handle_irq()
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Direct access to USB host controller registers is considered to be not
portable, and is usually a bad sign for poorly abstracted interface.
Introduce .flags and .power_on_delay to "struct pxaohci_platform_data"
so that most platforms don't bother to write their own .init/.exit()
sequences.
This just leaves include/asm-arm/plat-* to deal with.
Compiling pcm990 produces an error:
In file included from arch/arm/mach-pxa/pcm990-baseboard.c:25:
include/linux/ide.h:645: error: 'CONFIG_IDE_MAX_HWIFS' undeclared here (not in a function)
Fix it by removing unneeded header include.
pxa_gpio_mode() is deprecated, use the new pxa2xx_mfp_config() function to
configure GPIOs in pcm990 platform code. Convert "array, ARRAY_SIZE(array)"
to "ARRAY_AND_SIZE(array)" while at it.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de>
As well as moving all the device declarations to a single one in devices.c
this causes all platforms to register the I/O and interrupt resources for
the AC97 controller.
Cc: eric miao <eric.miao@marvell.com>
Cc: Mike Rapoport <mike@compulab.co.il>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Jürgen Schindele <linux@schindele.name>
Cc: Juergen Beisert <jbe@pengutronix.de>
PCM990 boards can be assembled with either a Sharp STN or a NEC TFT LCD. This
patch adds support for these displays and for the backlight, using the pwm_bl
driver.
Based on earlier work by Jon Smirl and Jochen Friedrich.
Update most new-style i2c drivers to use standard module aliasing
instead of the old driver_name/type driver matching scheme. I've
left the video drivers apart (except for SoC camera drivers) as
they're a bit more diffcult to deal with, they'll have their own
patch later.
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Jochen Friedrich <jochen@scram.de>
Platform-specific code for Phytec's phyCORE-PXA270 platform
two reasons:
1. GPIO namings and their mode definitions are conceptually not part
of the PXA register definitions
2. this is actually a temporary move in the transition of PXA2xx to
use MFP-alike APIs (as what PXA3xx is now doing), so that legacy
code will still work and new code can be added in step by step
Signed-off-by: eric miao <eric.miao@marvell.com>
This patch adds baseboard support for the phyCORE-PXA270 development
kit (aka PCM-990).
This example shows how to use some phyCORE-PXA270 CPU module features
on a baseboard in a standard manner. It could be used as a starting
point for custom baseboard development.
V2:
After comments by Eric Miao:
- IRQ chained handler fixed
- video/graphic support moved to separate patch
- ifdef/endif hell reduced ;-)
V3:
After comments by Russell King
- initialise the mmci platform data statically
V4:
- wrong return value in pcm990_mci_init() fixed
Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de>
