path: root/arch/arm/mach-pxa/poodle.c
2008-05-08[ARM] pxa: Fix RCSR handlingRussell King
Related to d3930614e68bdf83a120d904c039a64e9f75dba1. RCSR is only present on PXA2xx CPUs, not on PXA3xx CPUs. Therefore, we should not be unconditionally writing to RCSR from generic code. Since we now clear the RCSR status from the SoC specific PXA PM code and before reset in the arch_reset() function, the duplication in the corgi, poodle, spitz and tosa code can be removed. Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4803/1: pxa: fix building issue of poodle.c caused by patch 4737/1eric miao
The is caused by the patch below: [ARM] 4737/1: Refactor corgi_lcd to improve readability + bugfix It renamed the confusing get_hsync_len() to get_hsync_invperiod(), which unfortunately leaves poodle.c un-modified. Signed-off-by: eric miao <eric.miao@marvell.com> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] pxa: fix mci_init functions returning -1Russell King
Fix all those PXA mci_init functions which return -1 rather than propagating the error code to the higher levels. Remove the silly set_irq_type() calls as well - use the flags for request_irq() instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] pxa: move platform devices to separate header fileRussell King
2007-07-12[ARM] 4450/1: pxa: add pxa25x_init_irq() and pxa27x_init_irq()Eric Miao
/* should be ok this time, I aligned this patch to your arm:pxa2.mbox */ 1. move pxa25x specific IRQ initialization code to pxa25x_init_irq() and pxa27x code to pxa27x_init_irq(), remove pxa_init_irq() 2. replace all pxa_init_irq() with their PXA25x or PXA27x specific functions Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[ARM] 3848/1: pxafb: Add option of fixing video modes and spitz QVGA mode ↵Richard Purdie
support Add the ability to have pxafb use only certain fixed video modes (selected on a per platform basis). This is useful on production hardware such as the Zaurus cxx00 models where the valid modes are known in advance and any other modes could result in hardware damage. Following this, add support for the cxx00 QVGA mode. Mode information is passed to the lcd_power call to allowing the panel drivers to configure the display hardware accordingly (corgi_lcd already contains the functionality for the cxx00 panel). This mirrors the setup already used by w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[ARM] 3594/1: Poodle: Add touchscreen support + other updatesRichard Purdie
Patch from Richard Purdie Poodle Updates: * Update corgi_ssp to make the GPIO chip selects optional * Enable corgi_ssp for use by poodle * Add corgi touchscreen platform device for poodle * Export locomo platform device. * Set framebuffer device parent correctly Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3561/1: Poodle: Correct the MMC/SD power controlRichard Purdie
Patch from Richard Purdie Correct the Poodle power control for the MMC/SD port. Also add write protection switch support. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3593/1: Add reboot and shutdown handlers for Zaurus handheldsRichard Purdie
Patch from Richard Purdie Add functionality to allow machine specific reboot handlers on ARM. Add machine specific reboot and poweroff handlers for all PXA Zaurus models. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-02[ARM] 3453/1: Poodle: Correctly set the memory sizeRichard Purdie
Patch from Richard Purdie Force the Sharp Zaurus Poodle memory size to 32MB. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Remove asm/arch/irq.hRussell King
asm/arch/irq.h used to be included from asm/irq.h, but was removed from the ARM kernel a long time ago. Consequently, the contents of asm/arch/irq.h (which mostly contain a definition for fixup_irq()) have not been used. Hence, remove asm/arch/irq.h. Some machine support files incorrectly included this file, making little or no use of the contents. Move the contents to a local include file, and remove those include statements as well. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-08[PATCH] IRQ type flagsRussell King
Some ARM platforms have the ability to program the interrupt controller to detect various interrupt edges and/or levels. For some platforms, this is critical to setup correctly, particularly those which the setting is dependent on the device. Currently, ARM drivers do (eg) the following: err = request_irq(irq, ...); set_irq_type(irq, IRQT_RISING); However, if the interrupt has previously been programmed to be level sensitive (for whatever reason) then this will cause an interrupt storm. Hence, if we combine set_irq_type() with request_irq(), we can then safely set the type prior to unmasking the interrupt. The unfortunate problem is that in order to support this, these flags need to be visible outside of the ARM architecture - drivers such as smc91x need these flags and they're cross-architecture. Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the property that the device would like. The IRQ controller code should do its best to select the most appropriate supported mode. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[ARM] 3093/1: SharpSL PCMCIA Updates for Cxx00 modelsRichard Purdie
Patch from Richard Purdie The Sharp SL-Cxx00 models have a combined power control for the SD and CF slot 0. This patch adds hooks to the scoop driver to allow machines to provide a custom control function for this and such a function is added for spitz/akita/borzoi. It also moves the gpio init code into the machine files as this is machine dependent and differs between some models. A couple of warnings when compiling for collie are also fixed. Signed-off-by: Richard Purdie Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[ARM] 3067/1: Add poodle irda platform supportRichard Purdie
Patch from Richard Purdie Add poodle irda platform support Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-15[ARM] 2914/1: PXA Poodle: Add MMC and UDC supportRichard Purdie
Patch from Richard Purdie This patch adds MMC and UDC support to the PXA Poodle platform. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-15[ARM] 2913/1: PXA Poodle: Cleanup some unneeded codeRichard Purdie
Patch from Richard Purdie This patch cleans up the PXA Poodle platform code removing an unneeded static iomap. It also corrects errors in the platform header file and adds a missing GPIO define. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-05[ARM] 2882/1: pxa2xx_sharpsl: Update PCMCIA driver to support variety of new ↵Richard Purdie
hardware Patch from Richard Purdie This patch updates the PCMCIA pxa2xx_sharpsl driver to support multiple scoop devices by adding a scoop to pcmcia slot mapping structure. It adds platform support for poodle, is known to work on spitz (which is dual slot) and should also support collie with a minor amount of further work. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-04[PATCH] ARM: Fix non-standard PXA io_pg_offst initialisersRussell King
These didn't match my sed expression correctly, fix them up manually. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
