path: root/arch/arm/mach-pxa/pxa300.c
2010-02-12ARM: Consolidate clks_register() and similarRussell King
Most machine classes want some way to register a block of clk_lookup structures, and most do it by implementing a clks_register() type function which walks an array, or by open-coding a loop. Consolidate all this into clkdev_add_table(). Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-10[ARM] pxa: add clock definition for graphics controllerDaniel Mack
Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-03-23[ARM] pxa: move common MFP handling code into plat-pxaEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-09[ARM] pxa: introduce pxa{25x,27x,300,320,930}.h for board usageEric Miao
Considering the header mess ATM, it is not always possible to include the correct header files within board code. Let's keep this simple: <mach/pxa25x.h> - for pxa25x based platforms <mach/pxa27x.h> - for pxa27x based platforms <mach/pxa300.h> - for pxa300 based platforms <mach/pxa320.h> - for pxa320 based platforms <mach/pxa930.h> - for pxa930 based platforms NOTE: 1. one header one board file, they are not compatible (i.e. they have conflicting definitions which won't compile if included together). 2. Unless strictly necessary, the following header files are considered to be SoC files use _only_, and is not recommended to be included in board code: <mach/hardware.h> <mach/pxa-regs.h> <mach/pxa2xx-regs.h> <mach/pxa3xx-regs.h> <mach/mfp.h> <mach/mfp-pxa2xx.h> <mach/mfp-pxa25x.h> <mach/mfp-pxa27x.h> <mach/mfp-pxa3xx.h> <mach/mfp-pxa300.h> <mach/mfp-pxa320.h> <mach/mfp-pxa930.h> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-01-19[ARM] pxa: fix NAND and MMC clock initialization for pxa3xxMike Rapoport
After commit 8c3abc7d903df492a7394b0adae4349d9a381aaf ("[ARM] pxa: convert to clkdev and match clocks by struct device where possible") get_clk in pxa3xx_nand fails with -ENOENT. Apparently, clk_get in pxamci will also fail for MCI2 on PXA310. The 'clk_find' and therefore 'clk_get' require driver to supply both 'dev_id' and 'con_id' if they are not NULL in the 'strcut clk_lookup', but neither pxa3xx_nand nor pxamci supply 'con_id'. This patch sets 'con_id' to NULL in NAND clock and MCI2 clock registration. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-11-27[ARM] pxa: convert to clkdev and match clocks by struct device where possibleRussell King
2008-08-20[ARM] 5212/1: pxa: fix build error when CPU_PXA310 is not definedMike Rapoport
Fix arch/arm/mach-pxa/pxa300.c:94: error: 'CKEN_MMC3' undeclared here (not in a function) when building for PXA300. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] pxa: add pxa3xx NAND device and clock sourcesEric Miao
A pxa3xx_set_nand_info() is also introduced to set the PXA3xx NAND driver specific platform_data structure pointer. Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Sergey Podstavin <spodstavin@ru.mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-09[ARM] pxa: move pxa310 specific MMC3 clk out of generic pxa3xx.cEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-31[ARM] 4635/1: pxa: Change Eric Miao's email address to eric.miao@marvell.comeric miao
Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-20[ARM] 4613/1: pxa300: MFP typo fixAleksey Makarov
This fixes a typo in MFP address map. Signed-off-by: Aleksey Makarov <amakarov@ru.mvista.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] pxa: PXA3xx base supporteric miao
Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
