path: root/arch/arm/mach-pxa/spitz.c
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-08[PATCH] IRQ type flagsRussell King
Some ARM platforms have the ability to program the interrupt controller to detect various interrupt edges and/or levels. For some platforms, this is critical to setup correctly, particularly those which the setting is dependent on the device. Currently, ARM drivers do (eg) the following: err = request_irq(irq, ...); set_irq_type(irq, IRQT_RISING); However, if the interrupt has previously been programmed to be level sensitive (for whatever reason) then this will cause an interrupt storm. Hence, if we combine set_irq_type() with request_irq(), we can then safely set the type prior to unmasking the interrupt. The unfortunate problem is that in order to support this, these flags need to be visible outside of the ARM architecture - drivers such as smc91x need these flags and they're cross-architecture. Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the property that the device would like. The IRQ controller code should do its best to select the most appropriate supported mode. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-05[ARM] 3230/1: Sharp Scoop: Fix Shared Power Control IssuesRichard Purdie
Patch from Richard Purdie The SL-Cxx00 devices have a power control register in SCOOP that is shared by both CF and MMC/SD card slots. The CF reset code was resetting this register leading to various lockups as the MMC power was suddenly lost. This patch handles the CPR register in a more sensitive manner. It also removes some unneeded collie specific calls as the reset code handles this. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[ARM] 3227/1: Spitz: Add pxa27x OHCI platform specific codeRichard Purdie
Patch from Richard Purdie Add platform code to enable the ohci device on the pxa27x based Sharp Zaurus Cxx00 devices. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-12[ARM] 3149/1: SharpSL: Add Akita (SL-C1000) machine supportRichard Purdie
Patch from Richard Purdie Add the core machine support for the Sharp SL-C1000 (Akita) and enable the Kconfig selection for it. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-08[ARM] 3093/1: SharpSL PCMCIA Updates for Cxx00 modelsRichard Purdie
Patch from Richard Purdie The Sharp SL-Cxx00 models have a combined power control for the SD and CF slot 0. This patch adds hooks to the scoop driver to allow machines to provide a custom control function for this and such a function is added for spitz/akita/borzoi. It also moves the gpio init code into the machine files as this is machine dependent and differs between some models. A couple of warnings when compiling for collie are also fixed. Signed-off-by: Richard Purdie Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[ARM] 3069/1: Add spitz irda platform supportRichard Purdie
Patch from Richard Purdie Add spitz irda platform support Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-14[ARM] 3013/1: Spitz: Fix compile errorsRichard Purdie
Patch from Richard Purdie Remove a couple of lines of accidently added code causing compile errors. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-14[ARM] 3011/1: pxafb: Add ability to set device parent + fix spitz compile errorRichard Purdie
Patch from Richard Purdie Add a function to allow machines to set the parent of the pxa framebuffer device. This means the power up/down sequence can be controlled where required by the machine. Update spitz to use the new function, fixing a compile error. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-13[PATCH] SharpSL: Add new ARM PXA machines Spitz and Borzoi with partial ↵Richard Purdie
Akita Support Add the platform support code for two new Sharp Zaurus Models, Spitz (SL-C3000) and Borzoi (SL-C3100). This patch also adds most of the foundations for Akita (SL-C1000) Support. The missing link for Akita is the driver for its I2C io expander. Once this has been finished, the missing Kconfig option and machine declaration can easily be added to this code. Signed-Off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Vojtech Pavlik <vojtech@suse.cz> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
