path: root/arch/arm/mach-pxa/ssp.c
2009-12-01[ARM] pxa: use platform_device_id table for SSP driverEric Miao
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-03-09[ARM] pxa: remove unnecessary #include of pxa-regs.h and hardware.hEric Miao
pxa-regs.h and hardware.h are not intended for use directly in driver code, remove those unnecessary references. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-11-27[ARM] pxa: don't pass a consumer clock name for devices with unique clocksRussell King
Where devices only have one consumer, passing a consumer clock ID has no real benefit. Remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-12Merge branch 'pxa-devel' into pxaRussell King
2008-07-10[ARM] 5112/1: PXA SSP: Strip in-code changelogMark Brown
It's not been updated in quite some time and we now have git for history. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-10[ARM] 5110/1: PXA SSP: Remember the platform device on probe()Mark Brown
pdev is used later on by dev_printk() so must be set. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-10[ARM] 5108/2: PXA SSP: Don't unconditionally free interruptMark Brown
Callers may stop the SSP core requesting the interrupt so it can't be freed unconditionally. Also use NO_IRQ like we should. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-11[ARM] 5077/1: spi: fix list scan success verification in PXA ssp driverGuennadi Liakhovetski
The list search success check in arch/arm/mach-pxa/ssp.c is wrong: for example, it didn't recognise failure for me when I requested port 0. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28Merge branch 'pxa-plat' into develRussell King
* pxa-plat: (53 commits) [ARM] 4762/1: Basic support for Toradex Colibri module [ARM] pxa: fix mci_init functions returning -1 [ARM] 4737/1: Refactor corgi_lcd to improve readability + bugfix [ARM] 4747/1: pcm027: support for pcm990 baseboard for phyCORE-PXA270 [ARM] 4746/1: pcm027: network support for phyCORE-PXA270 [ARM] 4745/1: pcm027: default configuration [ARM] 4744/1: pcm027: add support for phyCORE-PXA270 CPU module [NET] smc91x: Make smc91x use IRQ resource trigger flags [ARM] pxa: add default config for littleton [ARM] pxa: add basic support for Littleton (PXA3xx Form Factor Platform) [ARM] 4664/1: Add basic support for HTC Magician PDA phones [ARM] 4649/1: Base support for pxa-based Toshiba e-series PDAs. [ARM] pxa: skip registers saving/restoring if entering standby mode [ARM] pxa: fix PXA27x resume [ARM] pxa: Avoid fiddling with CKEN register on suspend [ARM] pxa: Add PXA3 standby code hooked into the IRQ wake scheme [ARM] pxa: Add zylonite MFP wakeup configurations [ARM] pxa: program MFPs for low power mode when suspending [ARM] pxa: make MFP configuration processor independent [ARM] pxa: remove un-used pxa3xx_mfp_set_xxx() functions ... Conflicts: arch/arm/mach-pxa/ssp.c Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: ensure SSP TX FIFO is empty instead of not full for pxa3xxeric miao
Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: initialise SSP earlierRussell King
Initialise the SSP driver at arch_initcall() time, so it's available for other drivers to use it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: use __raw_writel()/__raw_readl() for ssp_xxxx()eric miao
1. change SSP register definitions from absolute virtual addresses to offsets 2. use __raw_writel()/__raw_readl() for functions of ssp_xxxx() Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] pxa: move SSP register definitions from pxa-regs.h to regs-ssp.heric miao
2008-01-26[ARM] pxa: define "struct ssp_device" and add ssp_request()/ssp_free()eric miao
1. define "struct ssp_device" for SSP information, which is requested and released by function ssp_request()/ssp_free() 2. modify the ssp_init() and ssp_exit() to use the interface Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-26[ARM] Remove pointless casts from void pointers,Jeff Garzik
mostly in and around irq handlers. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-26[ARM] PXA ssp: unlock when ssp tries to close an invalid portRoel Kluin
Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4304/1: removes the unnecessary bit number from CKENnn_XXXXEric Miao
This patch removes the unnecessary bit number from CKENnn_XXXX definitions for PXA, so that CKEN0_PWM0 --> CKEN_PWM0 CKEN1_PWM1 --> CKEN_PWM1 ... CKEN24_CAMERA --> CKEN_CAMERA The reasons for the change of these defitions are: 1. they do not scale - they are currently valid for pxa2xx, but definitely not valid for pxa3xx, e.g., pxa3xx has bit 3 for camera instead of bit 24 2. they are unnecessary - the peripheral name within the definition has already announced its usage, we don't need those bit numbers to know which peripheral we are going to enable/disable clock for 3. they are inconvenient - think about this: a driver programmer for pxa has to remember which bit in the CKEN register to turn on/off Another change in the patch is to make the definitions equal to its clock bit index, so that #define CKEN_CAMERA (24) instead of #define CKEN_CAMERA (1 << 24) this change, however, will add a run-time bit shift operation in pxa_set_cken(), but the benefit of this change is that it scales when bit index exceeds 32, e.g., pxa3xx has two registers CKENA and CKENB, totally 64 bit for this, suppose CAMERA clock enabling bit is CKENB:10, one can simply define CKEN_CAMERA to be (32 + 10) and so that pxa_set_cken() need minimum change to adapt to that. Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[ARM] 3760/1: This patch adds timeouts while working with SSP registers. ↵Paul Sokolovsky
Such timeouts were en Patch from Paul Sokolovsky This patch adds timeouts while working with SSP registers. Such timeouts were envisioned by docstrings in ssp.c, but were not implemented. There were actual lockups while accessing touchscreen for iPaqs h1910, h4000 due to lack of the timeouts. This is updated version of previously submitted patch: 3738/1. Signed-off-by: Paul Sokolovsky <pmiscml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-12[ARM] Convert some arm semaphores to mutexesArjan van de Ven
The arm clock semaphores are strict mutexes, convert them to the new mutex implementation Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3098/1: pxa2xx disable ssp irqLiam Girdwood
Patch from Liam Girdwood This patch allows users of the pxa SSP driver to register their own irq handlers instead of using the default SSP handler. It also cleans up the CKEN clock and irq detection as the values are now stored in a table. This patch replaces 2845/1 Changes:- o Added flags parameter to ssp_init() o Added SSP_NO_IRQ flag to disable registering of ssp irq handler (for drivers that want to register their own handler) o Cleaned up clock and irq detection, values are now stored in table. o Added build changes to allow other drivers (e.g audio) to select the ssp driver. o corgi_ssp.c changed to use new interface. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
