path: root/arch/arm/mach-pxa
2006-02-01[ARM] 3291/1: PXA27x: Correct get_clk_frequency_khz turbo flag handlingRichard Purdie
Patch from Richard Purdie The turbo flag is in bit 0 of the CLKCFG register, not bit 1. This patch corrects this so get_clk_frequency_khz returns a correct value. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-12[ARM] Convert some arm semaphores to mutexesArjan van de Ven
The arm clock semaphores are strict mutexes, convert them to the new mutex implementation Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-08[PATCH] IRQ type flagsRussell King
Some ARM platforms have the ability to program the interrupt controller to detect various interrupt edges and/or levels. For some platforms, this is critical to setup correctly, particularly those which the setting is dependent on the device. Currently, ARM drivers do (eg) the following: err = request_irq(irq, ...); set_irq_type(irq, IRQT_RISING); However, if the interrupt has previously been programmed to be level sensitive (for whatever reason) then this will cause an interrupt storm. Hence, if we combine set_irq_type() with request_irq(), we can then safely set the type prior to unmasking the interrupt. The unfortunate problem is that in order to support this, these flags need to be visible outside of the ARM architecture - drivers such as smc91x need these flags and they're cross-architecture. Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the property that the device would like. The IRQ controller code should do its best to select the most appropriate supported mode. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-07Merge with Linus' kernel.Russell King
2006-01-07[ARM] 3235/1: SharpSL PM: Fix a gcc4 build errorRichard Purdie
Patch from Richard Purdie Fix a gcc4 build error (incomplete element type) in the pxa SharpSL PM code. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 10 of 11Jean Delvare
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the drivers for arm arch. Signed-off-by: Jean Delvare <khali@linux-fr.org> CC: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Rework client usage count, 2 of 3Jean Delvare
Make I2C_CLIENT_ALLOW_USE the default for all i2c clients. It doesn't hurt if the usage count is actually never used for any given driver, and allows for nice code simplifications in i2c-core. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[ARM] 3206/1: Modifications to the bus arbiter controller for the Intel PXA27xJared Hulbert
Patch from Jared Hulbert The following patch changes the bus arbiter controller settings for the Intel PXA27x Application Processor Family. Up to 5% better video performance. It parks the bus on the core while not in use and sets the arbitration for other bus items. The patch only applies changes to the Intel Mainstone development platform. This patch is not compatible with preproduction Intel PXA27x silicon. This patch is based on the Intel Linux Preview Kit released to the public on 25 Feb. 2005 found at ftp://ftp.arm.linux.org.uk/pub/linux/arm/people/xscale/mainstone/02-25-2005/. Signed-off-by: Justin A Treon <justin_treon@yahoo.com> Signed-off-by: Jared Hulbert <jaredeh@gmail.com> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[ARM] 3230/1: Sharp Scoop: Fix Shared Power Control IssuesRichard Purdie
Patch from Richard Purdie The SL-Cxx00 devices have a power control register in SCOOP that is shared by both CF and MMC/SD card slots. The CF reset code was resetting this register leading to various lockups as the MMC power was suddenly lost. This patch handles the CPR register in a more sensitive manner. It also removes some unneeded collie specific calls as the reset code handles this. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[ARM] 3228/1: SharpSL: Move PM code to arch/arm/commonRichard Purdie
Patch from Richard Purdie This patch moves a large chunk of the sharpsl_pm driver to arch/arm/common so that it can be reused on other devices such as the SL-5500 (collie). It also abstracts some functions from the core into the machine and platform specific parts of the driver to aid reuse. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[ARM] 3227/1: Spitz: Add pxa27x OHCI platform specific codeRichard Purdie
Patch from Richard Purdie Add platform code to enable the ohci device on the pxa27x based Sharp Zaurus Cxx00 devices. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[PATCH] USB: pxa27x OHCI - Separate platform code from main driverRichard Purdie
To allow multiple platforms to use the PXA27x OHCI driver, the platform code needs to be moved into the board specific files in arch/arm/mach-pxa. This patch does this for mainstone and adds preliminary hooks to allow other boards to use the driver. This has been compile tested for mainstone and successfully run on Spitz (Sharp Zaurus SL-C3000) with the addition of an appropriate board support file. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-12[ARM] 3201/1: PXA27x: Prevent hangup during resume due to inadvertedly ↵Lothar Wassmann
enabling MBREQ (replaces: 3198/1) Patch from Lothar Wassmann The patch makes sure, that the ouptut functions of pins are restored before restoring the Alternat Function settings, preventing pins from being intermediately configured for undefined or unwanted alternate functions. Here is the original comment: I've got a PXA270 system that uses GPIO80 as nCS4. This system did hang on resume. Digging into the problem I found that the processor stalled immediately when restoring the GAFR2_U register which restored the alternate function for GPIO80. Since the GPDR registers were restored after the GAFR registers, the offending GPIO was configured as input at this point. Thus the alternate function that was in effect after restoring the GAFR was in fact the input function "MBREQ" instead of the output function "nCS4". The "PXA27x Processor Family Developer's Manual" (Footnote in Table 6-1 on page 6-3) states that: "The MBREQ alternate function must not be enabled until the PSSR[RDH] bit field is cleared. For more details, see Table 3-15, "PSSR Bit Definitions" on page 3-71." There is another note in the Developer's Manual (chapter 24.4.2 "GPIO operation as Alternate Function" on page 24-4) stating that: "Configuring a GPIO for an alternate function that is not defined for it causes unpredictable results." Since some GPIOs have no input function defined, and to prevent inadvertedly programming the MBREQ function on some pin, the GAFR registers should be restored after the GPDR registers have been restored. Additional provisions have to be made when the MBREQ function is actually required. The corresponding GAFR bits should not be restored with the regular GAFR restore, but must be set only after the PSSR bits have been cleared. Signed-off-by: Lothar Wassmann <LW@KARO-electronics.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-01[ARM] 3188/1: Add missing i2c dependency for AkitaRichard Purdie
Patch from Richard Purdie Akita requires inbuilt kernel i2c support for its GPIOs. Add this requirement to Kconfig and update the defconfig to match. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-28[ARM] 3179/1: Update/correct Zaurus Kconfig entriesRichard Purdie
Patch from Richard Purdie Add iWMMX Extentions for the pxa27x based Zaurus models and fix a couple of minor mistakes in the PXA Kconfig file. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-21[ARM] 3170/1: Sharp SL-6000x: platform device conversion fixupDirk Opfer
Patch from Dirk Opfer Fix an error in tosa.c after the platform device conversion. Signed-off-by: Dirk Opfer <Dirk@Opfer-Online.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-16[ARM] Include asm/hardware.h instead of asm/arch/hardware.hRussell King
Rationalise hardware.h include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-13[ARM] 3160/1: SharpSL: Add driver for Akita specific GPIOsRichard Purdie
Patch from Richard Purdie Add a driver for the extra GPIOs found on the Sharp SL-C1000 (Akita). These GPIOs are found on a Maxim MAX7310 I2C i/o expander chip. A generic GPIO driver for the MAX7310 was attempted but this mini driver is a much simpler and much more effective solution avoiding several issues and complexity the generic driver had (as discussed on LKML). The platform device is required so the device parent can be set correctly which ensures the device is one of the last to suspend and first to resume. Whilst the i2c suspend/resume calls can be influenced, nothing guarantees this is easlier/later than the subsystems the gpios are used on which are all independent of i2c (sound, irda, video/backlight etc.). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-13[ARM] 3159/1: SharpSL: Add PM device driver for the SL-Cx00 machines.Richard Purdie
Patch from Richard Purdie Add a SharpSL PM device driver for the SL-Cxx00 machines. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-13[ARM] 3158/1: SharpSL: Add PM device driver for the SL-C7x0 machines.Richard Purdie
Patch from Richard Purdie Add a SharpSL PM device driver for the SL-C7x0 machines. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-12[ARM] 3154/1: SharpSL PM Driver updatesRichard Purdie
Patch from Richard Purdie Updates to the SharpSL PM driver including cleanups from both Pavel Machek and myself and updates after the platform device changes to make it compile again. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-12[ARM] 3149/1: SharpSL: Add Akita (SL-C1000) machine supportRichard Purdie
Patch from Richard Purdie Add the core machine support for the Sharp SL-C1000 (Akita) and enable the Kconfig selection for it. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-11Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
2005-11-10[ARM] 3098/1: pxa2xx disable ssp irqLiam Girdwood
Patch from Liam Girdwood This patch allows users of the pxa SSP driver to register their own irq handlers instead of using the default SSP handler. It also cleans up the CKEN clock and irq detection as the values are now stored in a table. This patch replaces 2845/1 Changes:- o Added flags parameter to ssp_init() o Added SSP_NO_IRQ flag to disable registering of ssp irq handler (for drivers that want to register their own handler) o Cleaned up clock and irq detection, values are now stored in table. o Added build changes to allow other drivers (e.g audio) to select the ssp driver. o corgi_ssp.c changed to use new interface. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3096/1: Add SharpSL Zaurus power and battery management core driverRichard Purdie
Patch from Richard Purdie This patch adds a power and battery management core driver which with the addition of the right device files, supports the c7x0 and cxx00 series of Sharp Zaurus handhelds. The driver is complex for several reasons. Battery charging is manually monitored and controlled. When suspended, the device needs to periodically partially resume, check the charging status and then re-suspend. It does without bothering the higher linux layers as a full resume and re-suspend is unnecessary. The code is carefully written to avoid interrupts or calling code outside the module under these circumstances. It also vets the various wake up sources and monitors the device's power situation. Hooks to limit the backlight intensity and to notify the battery monitoring code of backlight events are connected/added as the backlight is one of the biggest users of power on the device. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-08[ARM] 3135/1: harden SA11x0 and PXA2xx timer init codeNicolas Pitre
Patch from Nicolas Pitre Make it completely deterministic and leave nothing to chance (even if it had at worst 0.001% probability of failing). Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-08[ARM] 3124/1: Sharp SL-6000x: SharpSL PCMCIA UpdatesDirk Opfer
Patch from Dirk Opfer This patch updates the tosa machine to use the new SharpSL PCMCIA layer introduced with Patch #3093/1 Depends on #3093/1 Signed-off-by: Dirk Opfer <Dirk@Opfer-Online.de> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-08[ARM] 3093/1: SharpSL PCMCIA Updates for Cxx00 modelsRichard Purdie
Patch from Richard Purdie The Sharp SL-Cxx00 models have a combined power control for the SD and CF slot 0. This patch adds hooks to the scoop driver to allow machines to provide a custom control function for this and such a function is added for spitz/akita/borzoi. It also moves the gpio init code into the machine files as this is machine dependent and differs between some models. A couple of warnings when compiling for collie are also fixed. Signed-off-by: Richard Purdie Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-08[ARM] 3123/1: Sharp SL-6000x: Add IRDA, MMC, UDC and keyboard deviceDirk Opfer
Patch from Dirk Opfer This patch adds MMC, IRDA and UDC support to the Sharp SL-6000x device. Also it adds a platform device for the keyboard driver. Signed-off-by: Dirk Opfer Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-06[ARM] 3113/1: PXA: Allow machines to override (and also reuse) pxa pm functionsRichard Purdie
Patch from Richard Purdie Update the PXA pm.c file to allow machines (such as the Sharp Zaurus) to override the standard pm functions but reuse/wrap them where needed. The init call is made slightly earlier to give machine code an init level to override them in removing any race. Signed-off-by: Richard Purdie Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-06[ARM] 3088/1: PXA: Add machine support for the Sharp SL-6000x series of PDAsDirk Opfer
Patch from Dirk Opfer This patch adds basic machine support for the Sharp SL-6000x (Tosa) PDAs. Signed-off-by: Dirk Opfer Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-04[ARM] 3087/1: PXA2xx flash platform device conversionTodd Poynor
Patch from Todd Poynor Add platform devices for flash to Lubbock and Mainstone board files. Once in place, the two existing mtd map drivers for the boards will be converted to use a single pxa2xx map driver in the linux-mtd tree. Take 4: flash_platform_data .map_name vs. .name cleaned up, resync with merged irda patch context. Signed-off-by: Todd Poynor <tpoynor@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-01Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-11-01[ARM] 3078/1: lubbock platform updates, mostly mmc detectionDavid Brownell
Patch from David Brownell Lubbock updates: * Provide an address for the SMC91x chip that doesn't generate a boot-time warning (matching the EEPROM). * Update MMC support to (a) detect card insert/remove, and (b) report the readonly switch setting for SD cards. Previously, MMC/SD cards had to be present at boot time else they couldn't be detected. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[ARM] 3069/1: Add spitz irda platform supportRichard Purdie
Patch from Richard Purdie Add spitz irda platform support Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-30[ARM] 3068/1: Add corgi irda platform supportRichard Purdie
Patch from Richard Purdie Add corgi irda platform support Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-30[ARM] 3067/1: Add poodle irda platform supportRichard Purdie
Patch from Richard Purdie Add poodle irda platform support Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[ARM] 2897/2: PXA2xx IRDA supportNicolas Pitre
Patch from Nicolas Pitre This is the PXA2xx common IRDA driver, plus platform support for Lubbock and Mainstone. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 3029/1: Add HWUART support for PXA 255/26xMatt Reimer
Patch from Matt Reimer Adds support for HWUART on PXA 255 / 26x. This patch originally came from http://svn.rungie.com/svn/gumstix-buildroot/trunk/sources/kernel-patches/000-gumstix-hwuart.patch and has been tweaked by me. Signed-off-by: Matt Reimer <mreimer@vpop.net> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
