path: root/arch/arm/mach-pxa
2011-06-16gpio: include linux/gpio.h where neededRandy Dunlap
Some files use GPIOF_ macros but don't include the header file for them. These macros are being moved to <linux/gpio.h>, so add includes for <linux/gpio.h> where needed. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (97 commits) mtd: kill CONFIG_MTD_PARTITIONS mtd: remove add_mtd_partitions, add_mtd_device and friends mtd: convert remaining users to mtd_device_register() mtd: samsung onenand: convert to mtd_device_register() mtd: omap2 onenand: convert to mtd_device_register() mtd: txx9ndfmc: convert to mtd_device_register() mtd: tmio_nand: convert to mtd_device_register() mtd: socrates_nand: convert to mtd_device_register() mtd: sharpsl: convert to mtd_device_register() mtd: s3c2410 nand: convert to mtd_device_register() mtd: ppchameleonevb: convert to mtd_device_register() mtd: orion_nand: convert to mtd_device_register() mtd: omap2: convert to mtd_device_register() mtd: nomadik_nand: convert to mtd_device_register() mtd: ndfc: convert to mtd_device_register() mtd: mxc_nand: convert to mtd_device_register() mtd: mpc5121_nfc: convert to mtd_device_register() mtd: jz4740_nand: convert to mtd_device_register() mtd: h1910: convert to mtd_device_register() mtd: fsmc_nand: convert to mtd_device_register() ... Fixed up trivial conflicts in - drivers/mtd/maps/integrator-flash.c: removed in ARM tree - drivers/mtd/maps/physmap.c: addition of afs partition probe type clashing with removal of CONFIG_MTD_PARTITIONS
2011-05-25mtd: pxa: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Cc: Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-23Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mach-ns9xxx/include/mach/uncompress.h
2011-05-23Merge branches 'consolidate-clksrc', 'consolidate-flash', ↵Russell King
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
2011-05-23clocksource: convert ARM 32-bit up counting clocksourcesRussell King
Convert ixp4xx, lpc32xx, mxc, netx, pxa, sa1100, tcc8k, tegra and u300 to use the generic mmio clocksource recently introduced. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Acked-by: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Olof Johansson <olof@lixom.net> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-20ARM: 6910/1: MTD: physmap: let set_vpp() pass a platform_device instead of a ↵Marc Zyngier
map_info The set_vpp() method provided by physmap passes a map_info back to the platform code, which has little relevance as far as the platform is concerned (this parameter is completely unused). Instead, pass the platform_device, which can be used in the pismo driver to retrieve some important information in a nicer way, instead of the hack that was in place. The empty set_vpp function in board-at572d940hf_ek.c is left untouched, as the board/SoC is scheduled for removal. Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-17Merge branch 'syscore' into for-linusRafael J. Wysocki
* syscore: PM: Remove sysdev suspend, resume and shutdown operations PM / PowerPC: Use struct syscore_ops instead of sysdevs for PM PM / UNICORE32: Use struct syscore_ops instead of sysdevs for PM PM / AVR32: Use struct syscore_ops instead of sysdevs for PM PM / Blackfin: Use struct syscore_ops instead of sysdevs for PM ARM / Samsung: Use struct syscore_ops for "core" power management ARM / PXA: Use struct syscore_ops for "core" power management ARM / SA1100: Use struct syscore_ops for "core" power management ARM / Integrator: Use struct syscore_ops for core PM ARM / OMAP: Use struct syscore_ops for "core" power management ARM: Use struct syscore_ops instead of sysdevs for PM in common code
2011-05-12ARM: use ARM_DMA_ZONE_SIZE to adjust the zone sizesRussell King
Rather than each platform providing its own function to adjust the zone sizes, use the new ARM_DMA_ZONE_SIZE definition to perform this adjustment. This ensures that the actual DMA zone size and the ISA_DMA_THRESHOLD/MAX_DMA_ADDRESS definitions are consistent with each other, and moves this complexity out of the platform code. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: Replace platform definition of ISA_DMA_THRESHOLD/MAX_DMA_ADDRESSRussell King
The values of ISA_DMA_THRESHOLD and MAX_DMA_ADDRESS are related; one is the physical/bus address, the other is the virtual address. Both need to be kept in step, so rather than having platforms define both, allow them to define a single macro which sets both of these macros appropraitely. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-07Merge branch 'zImage_fixes' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-05-07ARM: zImage: remove the static qualifier from global data variablesNicolas Pitre
To be able to relocate the .bss section at run time independently from the rest of the code, we must make sure that no GOTOFF relocations are used with .bss symbols. This usually means that no global variables can be marked static unless they're also const. Let's remove the static qualifier from current offenders, or turn them into const variables when possible. Next commit will ensure the build fails if one of those is reintroduced due to otherwise enforced coding standards for the kernel. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com>
2011-04-25ARM: pxa/magician: bq24022 regulator needs to be enabledPhilipp Zabel
Add REGULATOR_CHANGE_STATUS flag to magician bq24022 regulator to enable charging. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-04-25ARM: pxa/hx4700: bq24022 regulator needs to be enabledPaul Parsons
Add REGULATOR_CHANGE_STATUS flag to hx4700 bq24022 regulator. Without this flag the bq24022 cannot be enabled and the battery will not charge. Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Tested-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-04-24ARM / PXA: Use struct syscore_ops for "core" power managementRafael J. Wysocki
Replace sysdev classes and struct sys_device objects used for "core" power management by the PXA platform code with struct syscore_ops objects that are simpler. This reduces the code size and the kernel memory footprint. It also is necessary for removing sysdevs entirely from the kernel in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-13ARM: pxa: convert incorrect IRQ_TO_IRQ() to irq_to_gpio()Eric Miao
This fixes the failure to register the IRQ_RTCAlrm alarm as a wakeup event. It is misinterpreted as a gpio irq not a PWER bitmask. Fixed this by converting the incorrect IRQ_TO_IRQ() to a correct version of irq_to_gpio(). Reported-by: Nick Bane <nickbane1@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-04-12ARM: pxa: align NR_BUILTIN_GPIO with GPIO interrupt numberHaojian Zhuang
Avoid to mismatch between NR_BUILTIN_GPIO and GPIO interrupt number Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (65 commits) ARM: 6826/1: Merge v6 and v7 DEBUG_LL DCC support ARM: 6838/1: etm: fix section mismatch warning ARM: 6837/1: remove unused pci_fixup_prpmc1100 ARM: 6836/1: kprobes/fix emulation of LDR/STR instruction when Rn == PC Fix the broken build for Marvell Dove platform. ARM: 6835/1: perf: ensure overflows aren't missed due to IRQ latency ARM: 6834/1: perf: reset counters on all CPUs during initialisation ARM: 6833/1: perf: add required isbs() to ARMv7 backend ARM: 6825/1: kernel/sleep.S: fix Thumb2 compilation issues ARM: 6807/1: realview: Fix secondary GIC initialisation for EB with MPCore tile arm: mach-mx3: pcm043: add write-protect and card-detect for SD1 eukrea_mbimxsd51: add SD Card detect eukrea_mbimxsd25-baseboard: add SD card detect mx3/eukrea_mbimxsd-baseboard: add SD card detect support mx3/eukrea_mbimxsd-baseboard: fix gpio request ARM: mxs/mx28evk: add mmc device ARM: mxs/mx23evk: add mmc device ARM: mxs: dynamically allocate mmc device ARM: mx51_efika: update platform data for new mfd changes mx2/iomux: Set direction for CSPI2 pins ...
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Reorder irq_set_ function callsThomas Gleixner
Reorder irq_set_chip() irq_set_chip_data() irq_set_handler() to irq_set_chip() irq_set_handler() irq_set_chip_data() so the next patch can combine irq_set_chip() and irq_set_handler() to irq_set_chip_and_handler(). Automated conversion with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-26Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable Conflicts: arch/arm/mach-pxa/tosa.c
2011-03-21ARM: pxa2xx: reorganize I2C filesSebastian Andrzej Siewior
This patch moves the platform data definition from arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so it can be accessed from x86 the same way as on ARM. This change should make no functional change to the PXA code. The move is verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig pxa910_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-17ARM: pxa/am300epd: fix leak in am300_init_gpio_regs error pathAxel Lin
If gpio_request fails when i > 0, gpios[0] is not freed in current implementation. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-17ARM: pxa/am200epd: fix leak in am200_init_gpio_regs error pathAxel Lin
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-03-16Merge branches 'at91', 'ep93xx', 'errata', 'footbridge', 'fncpy', 'gemini', ↵Russell King
'irqdata', 'pm', 'sh', 'smp', 'spear', 'ux500' and 'via' into devel
2011-03-16ARM: PXA: Z2: Use switch event for lidVasily Khoruzhick
Otherwise userspace might be confused. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-03-16ARM: PXA: Z2: Add default triggers for LEDsVasily Khoruzhick
So user can see if there's any mmc activity and if device's charging. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-03-16ARM: PXA: Z2: Keep kbd backlight disabled by defaultVasily Khoruzhick
It eats too much power, and anyway it's not usefull during boot process. Userspace can enable it later. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-03-16ARM: PXA: Z2: Fix libertas init/tear down sequencesVasily Khoruzhick
GPIO15 seems to be not related to WiFi, so don't touch it. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-03-16ARM: PXA: Z2: Fix battery pdataVasily Khoruzhick
Fix coefficients to get actual voltage, and make voltage_max/voltage_min looks like values for LiIon battery. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-03-16ARM: PXA: Z2: Use only power button as wake sourceVasily Khoruzhick
It's very easy to press some keypad key when Z2 is closed, so to prevent unexpected wakeups, use only 'Power' key to wake Z2 from sleep. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-03-16ARM: pxa: drop gpio_vbus field from pxa2xx_udc_mach_infoDmitry Eremin-Solenikov
Neither pxa25x_udc, nor pxa27x_udc use gpio_vbus/gpio_vbus_inverted anymore. Drop those two fields from udc info completely. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-16ARM: pxa/tosa: switch to using gpio-vbus transceiverDmitry Eremin-Solenikov
Switch from handling gpio-vbus in pxa25x_udc to using standard gpio-vbus tranceiver. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-16ARM: pxa/gumstix: switch to using gpio-vbus transceiverDmitry Eremin-Solenikov
Switch from handling gpio-vbus in pxa25x_udc to using standard gpio-vbus tranceiver. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-16ARM: pxa/eseries: switch to using gpio-vbus transceiverDmitry Eremin-Solenikov
Switch from handling gpio-vbus in pxa25x_udc to using standard gpio-vbus tranceiver. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-16ARM: pxa: auto compute shift and mult of timerHaojian Zhuang
Use auto-computed shift and mult of timer with new API clocksource_calc_mult_shift()/clockevents_calc_mult_shift(). Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-16ARM: pxa: clean up set_pxa_fb_infoRussell King - ARM Linux
set_pxa_fb_info() has been a long-standing wart in the naming scheme of the pxa_set_xxx_info() functions. This renames the function, and combines set_pxa_fb_parent() with set_pxa_fb_info(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-03-16ARM: pxa: PalmZ72: Add OV9640 camera supportMarek Vasut
Rework of patch from 2009: PalmZ72: Add support for OV9640 camera sensor Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-03-16ARM: pxa: Update copyright notices for Palm devicesMarek Vasut
2011-03-16ARM: pxa: PalmTE2: Use gpio arrays in backlight initMarek Vasut
Use gpio_request_array() / gpio_free_array() in backlight init and exit functions. This makes the code cleaner and less error prone. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-02-27ARM: pxa/tosa: register wm9712 codec deviceDmitry Eremin-Solenikov
Since f0fba2ad1b it's required to register platform devices even for AC'97 codecs. Register one on tosa (wm9712-codec). Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-02-27ARM: pxa: enable pxa-pcm-audio on pxa210/pxa25x platformDmitry Eremin-Solenikov
pxa25x platforms were left out of major ASoC Update patch. Since f0fba2ad1b a registration of pxa-pcm-audio device is required for ASoC to function on pxa platforms. Register one also for pxa210/pxa25x. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-02-27ARM: pxa/tosa: drop setting LED trigger name, as it's unsupported nowDmitry Eremin-Solenikov
Since 2e48928d8a0f38c1b5c81eb3f1294de8a6382c68 it's no longer possible to set the name of the LED trigger for RFKILL events. Drop respective code from tosa-bt.c Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: John W. Linville <linville@tuxdriver.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-02-22ARM: pm: convert PXA to generic suspend/resume supportRussell King
2011-02-17ARM: P2V: avoid initializers and assembly using PHYS_OFFSETRussell King
As PHYS_OFFSET will be becoming a variable, we can't have it used in initializers nor assembly code. Replace those in generic code with a run-time initialization. Replace those in platform code using the individual platform specific PLAT_PHYS_OFFSET. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-09ARM: pxa: Properly configure PWM period for palm27xMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
