path: root/arch/arm/mach-qcom/Kconfig
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-24ARM: qcom: Add support for MDM9615Neil Armstrong
Add support for Qualcomm MDM9615 in Kconfig and in DT match list. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Andy Gross <andy.gross@linaro.org>
2015-12-01ARM: use "depends on" for SoC configs instead of "if" after promptMasahiro Yamada
Many ARM sub-architectures use prompts followed by "if" conditional, but it is wrong. Please notice the difference between config ARCH_FOO bool "Foo SoCs" if ARCH_MULTI_V7 and config ARCH_FOO bool "Foo SoCs" depends on ARCH_MULTI_V7 These two are *not* equivalent! In the former statement, it is not ARCH_FOO, but its prompt that depends on ARCH_MULTI_V7. So, it is completely valid that ARCH_FOO is selected by another, but ARCH_MULTI_V7 is still disabled. As it is not unmet dependency, Kconfig never warns. This is probably not what you want. The former should be used only when you need to do so, and you really understand what you are doing. (In most cases, it should be wrong!) For enabling/disabling sub-architectures, the latter is always correct. As a good side effect, this commit fixes some entries over 80 columns (mach-imx, mach-integrator, mach-mbevu). [Arnd: I note that there is not really a bug here, according to the discussion that followed, but I can see value in being consistent and in making the lines shorter] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Jun Nie <jun.nie@linaro.org> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Krzysztof Halasa <khc@piap.pl> Acked-by: Maxime Coquelin <maxime.coquelin@st.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-03-11firmware: qcom: scm: Move the scm driver to drivers/firmwareKumar Gala
Architectural changes in the ARM Linux kernel tree mandate the eventual removal of the mach-* directories. Move the scm driver to drivers/firmware and the scm header to include/linux to support that removal. Signed-off-by: Kumar Gala <galak@codeaurora.org>
2015-01-23ARM: qcom: Drop unnecessary selects from ARCH_QCOMStephen Boyd
We don't need to force gpiolib on everyone given that it isn't required to actually boot the device and the multiplatform Kconfig already selects ARCH_WANT_OPTIONAL_GPIOLIB. CLKSRC_OF is already selected by CONFIG_ARCH_MULTIPLATFORM too, so we can drop that here. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2015-01-19ARM: qcom: Select ARCH_SUPPORTS_BIG_ENDIANStephen Boyd
We can run qcom platforms in big-endian mode. Select the option. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-06-17ARM: use menuconfig for sub-arch menusRob Herring
The System Type menu is getting quite long with platforms and is inconsistent in handling of sub-arch specific options. Tidy up the menu by making platform options a menuconfig entry containing any platform specific config items. [arnd: change OMAP part according to suggestion from Tony Lindgren <tony@atomide.com>] Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-05-23Merge tag 'qcom-soc-for-3.16' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom into next/soc Merge "Qualcomm ARM Based SoC Updates for v3.16" from Kumar Gala: * Enabling building pinctrl and AMBA bus support * Clean up debug UART selection * tag 'qcom-soc-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom: ARM: qcom: Select PINCTRL by default for ARCH_QCOM ARM: debug: qcom: make UART address selection configuration option ARM: qcom: Enable ARM_AMBA option for Qualcomm SOCs. Conflicts: arch/arm/Kconfig.debug arch/arm/mach-qcom/Kconfig Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-05-22ARM: qcom: Select PINCTRL by default for ARCH_QCOMAndy Gross
Add missing PINCTRL selection. This enables selection of pinctrollers for Qualcomm processors. Signed-off-by: Andy Gross <agross@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-05-22ARM: qcom: Enable ARM_AMBA option for Qualcomm SOCs.Srinivas Kandagatla
As some of the IPs on Qualcomm SOCs are based on ARM PrimeCell IPs. For example SDCC controller is PrimeCell MCI pl180. Adding this option will give flexibility to reuse the existing drivers as it is without major modifications. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-04-22ARM: qcom: clean-up unneeded kconfig selectskconfig-cleanupsRob Herring
Multi-platform support implies all these options are already selected and individual platforms don't need to select them. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Kumar Gala <galak@codeaurora.org> Cc: David Brown <davidb@codeaurora.org> Cc: linux-arm-msm@vger.kernel.org
2014-02-06ARM: qcom: Split Qualcomm support into legacy and multiplatformKumar Gala
Introduce a new mach-qcom that will support SoCs that intend to be multiplatform compatible while keeping mach-msm to legacy SoC/board support that will not transition over to multiplatform. As part of this, we move support for MSM8X60, MSM8960 and MSM8974 over to mach-qcom. Signed-off-by: Kumar Gala <galak@codeaurora.org>
