path: root/arch/arm/mach-realview
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-03-21ARM: realview: fix sparsemem buildArnd Bergmann
Commit b713aa0b15 "ARM: fix asm/memory.h build error" broke some configurations on mach-realview with sparsemem enabled, which is missing a definition of PHYS_OFFSET: arch/arm/include/asm/memory.h:268:42: error: 'PHYS_OFFSET' undeclared (first use in this function) #define PHYS_PFN_OFFSET ((unsigned long)(PHYS_OFFSET >> PAGE_SHIFT)) arch/arm/include/asm/dma-mapping.h:104:9: note: in expansion of macro 'PHYS_PFN_OFFSET' return PHYS_PFN_OFFSET + dma_to_pfn(dev, *dev->dma_mask); An easy workaround is for realview to define PHYS_OFFSET itself, in the same way we define it for platforms that don't have a private __virt_to_phys function. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Linus Walleij <linus.walleij@linaro.org>
2013-12-20ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, tooUwe Kleine-König
While <mach/timex.h> isn't used for multi-platform builds since long it still is for "normal" builds. As the previous patches fix all sites to not make use of this per-platform file, it can go now for good also for platforms that are not (yet) converted to multi-platform. While at it there are no users of CLOCK_TICK_RATE any more, so also drop the dummy #define. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-09-06Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This branch contains code cleanups, moves and removals for 3.12. There's a large number of various cleanups, and a nice net removal of 13500 lines of code. Highlights worth mentioning are: - A series of patches from Stephen Boyd removing the ARM local timer API. - Move of Qualcomm MSM IOMMU code to drivers/iommu. - Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM driver and switching over to the drivers/pwm one. - Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM). There's also a move of a header file out of include/linux/i2c/ to platform_data, where it really belongs. It touches mostly ARM platform code for include changes so we took it through our tree" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK gpio: (gpio-pca953x) move header to linux/platform_data/ arm: zynq: hotplug: Remove unreachable code ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*() tegra: simplify use of devm_ioremap_resource ARM: SAMSUNG: Remove plat/regs-timer.h header ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header ARM: SAMSUNG: Remove pwm-clock infrastructure ARM: SAMSUNG: Remove old PWM timer platform devices pwm: Remove superseded pwm-samsung-legacy driver ARM: SAMSUNG: Modify board files to use new PWM platform device ARM: SAMSUNG: Rework private data handling in dev-backlight pwm: Add new pwm-samsung driver ARM: mach-mvebu: remove redundant DT parsing and validation ARM: msm: Only compile io.c on platforms that use it iommu/msm: Move mach includes to iommu directory ARM: msm: Remove devices-iommu.c ARM: msm: Move mach/board.h contents to common.h ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE ARM: msm: Remove TMR and TMR0 static mappings ...
2013-08-25ARM: debug: move PL01X debug include into arch/arm/include/debug/Russell King
Now that the PL01X debug include can mostly stand alone without requiring platforms to provide any macros, move it into the debug directory so it can be directly included. This allows us to get rid of a lot of debug-macros include files. The autodetect case for Versatile Express and the ux500 are left alone; these are more complicated implementations. Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide PL01x debug uart phys/virt address configuration optionsRussell King
Move the definition of the UART register addresses out of the platform specific header files into the Kconfig files. Acked-by: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-07-23Merge tag 'remove-local-timers' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm into next/cleanup From Stephen Boyd: Now that we have a generic arch hook for broadcast we can remove the local timer API entirely. Doing so will reduce code in ARM core, reduce the architecture dependencies of our timer drivers, and simplify the code because we no longer go through an architecture layer that is essentially a hotplug notifier. * tag 'remove-local-timers' of git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm: ARM: smp: Remove local timer API clocksource: time-armada-370-xp: Divorce from local timer API clocksource: time-armada-370-xp: Fix sparse warning ARM: msm: Divorce msm_timer from local timer API ARM: PRIMA2: Divorce timer-marco from local timer API ARM: EXYNOS4: Divorce mct from local timer API ARM: OMAP2+: Divorce from local timer API ARM: smp_twd: Divorce smp_twd from local timer API ARM: smp: Remove duplicate dummy timer implementation Resolved a large number of conflicts due to __cpuinit cleanups, etc. Signed-off-by: Olof Johansson <olof@lixom.net>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-24ARM: smp_twd: Divorce smp_twd from local timer APIStephen Boyd
Separate the smp_twd timers from the local timer API. This will allow us to remove ARM local timer support in the near future and gets us closer to moving this driver to drivers/clocksource. Tested-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2013-05-03Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "The major items included in here are: - MCPM, multi-cluster power management, part of the infrastructure required for ARMs big.LITTLE support. - A rework of the ARM KVM code to allow re-use by ARM64. - Error handling cleanups of the IS_ERR_OR_NULL() madness and fixes of that stuff for arch/arm - Preparatory patches for Cortex-M3 support from Uwe Kleine-König. There is also a set of three patches in here from Hugh/Catalin to address freeing of inappropriate page tables on LPAE. You already have these from akpm, but they were already part of my tree at the time he sent them, so unfortunately they'll end up with duplicate commits" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (77 commits) ARM: EXYNOS: remove unnecessary use of IS_ERR_VALUE() ARM: IMX: remove unnecessary use of IS_ERR_VALUE() ARM: OMAP: use consistent error checking ARM: cleanup: OMAP hwmod error checking ARM: 7709/1: mcpm: Add explicit AFLAGS to support v6/v7 multiplatform kernels ARM: 7700/2: Make cpu_init() notrace ARM: 7702/1: Set the page table freeing ceiling to TASK_SIZE ARM: 7701/1: mm: Allow arch code to control the user page table ceiling ARM: 7703/1: Disable preemption in broadcast_tlb*_a15_erratum() ARM: mcpm: provide an interface to set the SMP ops at run time ARM: mcpm: generic SMP secondary bringup and hotplug support ARM: mcpm_head.S: vlock-based first man election ARM: mcpm: Add baremetal voting mutexes ARM: mcpm: introduce helpers for platform coherency exit/setup ARM: mcpm: introduce the CPU/cluster power API ARM: multi-cluster PM: secondary kernel entry code ARM: cacheflush: add synchronization helpers for mixed cache state accesses ARM: cpu hotplug: remove majority of cache flushing from platforms ARM: smp: flush L1 cache in cpu_die() ARM: tegra: remove tegra specific cpu_disable() ...
2013-04-18ARM: cpu hotplug: remove majority of cache flushing from platformsRussell King
Remove the majority of cache flushing calls from the individual platform files. This is now handled by the core code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-04-09ARM: Push selects for TWD/SCU into machine entriesStephen Boyd
The TWD and SCU configs are selected by default as long as MSM_SCORPIONMP is false and/or MCT is false. Implementing the logic this way certainly saves lines in the Kconfig but it precludes those machines which select MSM_SCORPIONMP or MCT from participating in the single zImage effort because when those machines are combined with other SMP capable machines the TWD and SCU are no longer selected by default. Push the select out to the machine entries so that we can compile these machines together and still select the appropriate configs. Cc: Barry Song <baohua.song@csr.com> Acked-by: David Brown <davidb@codeaurora.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Linus Walleij <linus.walleij@linaro.org> Acked-by: Pawel Moll <pawel.moll@arm.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Shiraz Hashim <shiraz.hashim@st.com> Acked-by: Simon Horman <horms@verge.net.au> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Viresh Kumar <viresh.linux@gmail.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-02-21Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups from Arnd Bergmann: "A large number of cleanups, all over the platforms. This is dominated largely by the Samsung platforms (s3c, s5p, exynos) and a few of the others moving code out of arch/arm into more appropriate subsystems. The clocksource and irqchip drivers are now abstracted to the point where platforms that are already cleaned up do not need to even specify the driver they use, it can all get configured from the device tree as we do for normal device drivers. The clocksource changes basically touch every single platform in the process. We further clean up the use of platform specific header files here, with the goal of turning more of the platforms over to being "multiplatform" enabled, which implies that they cannot expose their headers to architecture independent code any more. It is expected that no functional changes are part of the cleanup. The overall reduction in total code lines is mostly the result of removing broken and obsolete code." * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits) ARM: mvebu: correct gated clock documentation ARM: kirkwood: add missing include for nsa310 ARM: exynos: move exynos4210-combiner to drivers/irqchip mfd: db8500-prcmu: update resource passing drivers/db8500-cpufreq: delete dangling include ARM: at91: remove NEOCORE 926 board sunxi: Cleanup the reset code and add meaningful registers defines ARM: S3C24XX: header mach/regs-mem.h local ARM: S3C24XX: header mach/regs-power.h local ARM: S3C24XX: header mach/regs-s3c2412-mem.h local ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/ ARM: S3C24XX: transform s3c2443 subirqs into new structure ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs ARM: S3C24XX: move s3c2443 irq code to irq.c ARM: S3C24XX: transform s3c2416 irqs into new structure ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs ARM: S3C24XX: move s3c2416 irq init to common irq code ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property ARM: S3C24XX: Move irq syscore-ops to irq-pm clocksource: always define CLOCKSOURCE_OF_DECLARE ...
2013-02-08ARM: realview: ensure that we have sufficient IRQs availableRussell King
Realview EB with a rev B MPcore tile results in lots of warnings at boot because it can't allocate enough IRQs. Fix this by increasing the number of available IRQs. WARNING: at /home/rmk/git/linux-rmk/arch/arm/common/gic.c:757 gic_init_bases+0x12c/0x2ec() Cannot allocate irq_descs @ IRQ96, assuming pre-allocated Modules linked in: Backtrace: [<c00185d8>] (dump_backtrace+0x0/0x10c) from [<c03294e8>] (dump_stack+0x18/0x1c) r6:000002f5 r5:c042c62c r4:c044ff40 r3:c045f240 [<c03294d0>] (dump_stack+0x0/0x1c) from [<c00292c8>] (warn_slowpath_common+0x54/0x6c) [<c0029274>] (warn_slowpath_common+0x0/0x6c) from [<c0029384>] (warn_slowpath_fmt+0x38/0x40) [<c002934c>] (warn_slowpath_fmt+0x0/0x40) from [<c042c62c>] (gic_init_bases+0x12c/0x2ec) [<c042c500>] (gic_init_bases+0x0/0x2ec) from [<c042cdc8>] (gic_init_irq+0x8c/0xd8) [<c042cd3c>] (gic_init_irq+0x0/0xd8) from [<c042827c>] (init_IRQ+0x1c/0x24) [<c0428260>] (init_IRQ+0x0/0x24) from [<c04256c8>] (start_kernel+0x1a4/0x300) [<c0425524>] (start_kernel+0x0/0x300) from [<70008070>] (0x70008070) ---[ end trace 1b75b31a2719ed1c ]--- ------------[ cut here ]------------ WARNING: at /home/rmk/git/linux-rmk/kernel/irq/irqdomain.c:234 irq_domain_add_legacy+0x80/0x140() Modules linked in: Backtrace: [<c00185d8>] (dump_backtrace+0x0/0x10c) from [<c03294e8>] (dump_stack+0x18/0x1c) r6:000000ea r5:c0081a38 r4:00000000 r3:c045f240 [<c03294d0>] (dump_stack+0x0/0x1c) from [<c00292c8>] (warn_slowpath_common+0x54/0x6c) [<c0029274>] (warn_slowpath_common+0x0/0x6c) from [<c0029304>] (warn_slowpath_null+0x24/0x2c) [<c00292e0>] (warn_slowpath_null+0x0/0x2c) from [<c0081a38>] (irq_domain_add_legacy+0x80/0x140) [<c00819b8>] (irq_domain_add_legacy+0x0/0x140) from [<c042c64c>] (gic_init_bases+0x14c/0x2ec) [<c042c500>] (gic_init_bases+0x0/0x2ec) from [<c042cdc8>] (gic_init_irq+0x8c/0xd8) [<c042cd3c>] (gic_init_irq+0x0/0xd8) from [<c042827c>] (init_IRQ+0x1c/0x24) [<c0428260>] (init_IRQ+0x0/0x24) from [<c04256c8>] (start_kernel+0x1a4/0x300) [<c0425524>] (start_kernel+0x0/0x300) from [<70008070>] (0x70008070) ---[ end trace 1b75b31a2719ed1d ]--- ------------[ cut here ]------------ WARNING: at /home/rmk/git/linux-rmk/arch/arm/common/gic.c:762 gic_init_bases+0x170/0x2ec() Modules linked in: Backtrace: [<c00185d8>] (dump_backtrace+0x0/0x10c) from [<c03294e8>] (dump_stack+0x18/0x1c) r6:000002fa r5:c042c670 r4:00000000 r3:c045f240 [<c03294d0>] (dump_stack+0x0/0x1c) from [<c00292c8>] (warn_slowpath_common+0x54/0x6c) [<c0029274>] (warn_slowpath_common+0x0/0x6c) from [<c0029304>] (warn_slowpath_null+0x24/0x2c) [<c00292e0>] (warn_slowpath_null+0x0/0x2c) from [<c042c670>] (gic_init_bases+0x170/0x2ec) [<c042c500>] (gic_init_bases+0x0/0x2ec) from [<c042cdc8>] (gic_init_irq+0x8c/0xd8) [<c042cd3c>] (gic_init_irq+0x0/0xd8) from [<c042827c>] (init_IRQ+0x1c/0x24) [<c0428260>] (init_IRQ+0x0/0x24) from [<c04256c8>] (start_kernel+0x1a4/0x300) [<c0425524>] (start_kernel+0x0/0x300) from [<70008070>] (0x70008070) ---[ end trace 1b75b31a2719ed1e ]--- Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-14Merge tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/cleanup From Rob Herring: Initial irqchip init infrastructure and GIC and VIC clean-ups This creates irqchip initialization infrastructure from Thomas Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips and adapted to use the new infrastructure. All DT enabled platforms using GIC and VIC are converted over to use the new irqchip_init. * tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux: irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h ARM: picoxcell: use common irqchip_init function ARM: spear: use common irqchip_init function irqchip: Move ARM VIC to drivers/irqchip ARM: samsung: remove unused tick.h ARM: remove unneeded vic.h includes ARM: remove mach .handle_irq for VIC users ARM: VIC: set handle_arch_irq in VIC initialization ARM: VIC: shrink down vic.h irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h ARM: use common irqchip_init for GIC init irqchip: Move ARM GIC to drivers/irqchip ARM: remove mach .handle_irq for GIC users ARM: GIC: set handle_arch_irq in GIC initialization ARM: GIC: remove direct use of gic_raise_softirq ARM: GIC: remove assembly ifdefs from gic.h ARM: mach-ux500: use SGI0 to wake up the other core arm: add set_handle_irq() to register the parent IRQ controller handler function irqchip: add basic infrastructure irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS Fixed up massive merge conflicts with the timer cleanup due to adjacent changes: Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-bcm/board_bcm.c arch/arm/mach-cns3xxx/cns3420vb.c arch/arm/mach-ep93xx/adssphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/simone.c arch/arm/mach-ep93xx/snappercl15.c arch/arm/mach-ep93xx/ts72xx.c arch/arm/mach-ep93xx/vision_ep9307.c arch/arm/mach-highbank/highbank.c arch/arm/mach-imx/mach-imx6q.c arch/arm/mach-msm/board-dt-8960.c arch/arm/mach-netx/nxdb500.c arch/arm/mach-netx/nxdkn.c arch/arm/mach-netx/nxeb500hmi.c arch/arm/mach-nomadik/board-nhk8815.c arch/arm/mach-picoxcell/common.c arch/arm/mach-realview/realview_eb.c arch/arm/mach-realview/realview_pb1176.c arch/arm/mach-realview/realview_pb11mp.c arch/arm/mach-realview/realview_pba8.c arch/arm/mach-realview/realview_pbx.c arch/arm/mach-socfpga/socfpga.c arch/arm/mach-spear13xx/spear1310.c arch/arm/mach-spear13xx/spear1340.c arch/arm/mach-spear13xx/spear13xx.c arch/arm/mach-spear3xx/spear300.c arch/arm/mach-spear3xx/spear310.c arch/arm/mach-spear3xx/spear320.c arch/arm/mach-spear3xx/spear3xx.c arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-tegra/board-dt-tegra20.c arch/arm/mach-tegra/board-dt-tegra30.c arch/arm/mach-u300/core.c arch/arm/mach-ux500/board-mop500.c arch/arm/mach-ux500/cpu-db8500.c arch/arm/mach-versatile/versatile_ab.c arch/arm/mach-versatile/versatile_dt.c arch/arm/mach-versatile/versatile_pb.c arch/arm/mach-vexpress/v2m.c include/asm-generic/vmlinux.lds.h
2013-01-12irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.hRob Herring
Now that we have GIC moved to drivers/irqchip and all GIC DT init for platforms using irqchip_init, move gic.h and update the remaining includes. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Samuel Ortiz <sameo@linux.intel.com>
2013-01-12ARM: remove mach .handle_irq for GIC usersRob Herring
Now that the GIC initialization sets up the handle_arch_irq pointer, we can remove it for all machines and make it static. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Anton Vorontsov <avorontsov@mvista.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2013-01-10ARM: GIC: remove direct use of gic_raise_softirqRob Herring
In preparation of moving gic code to drivers/irqchip, remove the direct platform dependencies on gic_raise_softirq. Move the setup of smp_cross_call into the gic code and use arch_send_wakeup_ipi_mask function to trigger wake-up IPIs. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Shiraz Hashim <shiraz.hashim@st.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Acked-by: Olof Johansson <olof@lixom.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-20ARM: 7607/1: realview: fix private peripheral memory base for EB rev. B boardsWill Deacon
Commit 34ae6c96a6a7 ("ARM: 7298/1: realview: fix mapping of MPCore private memory region") accidentally broke the definition for the base address of the private peripheral region on revision B Realview-EB boards. This patch uses the correct address for REALVIEW_EB11MP_PRIV_MEM_BASE. Cc: <stable@vger.kernel.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Tested-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-12-11ARM: 7594/1: Add .smp entry for REALVIEW_EBSteve Capper
The REALVIEW EB board can host tiles with multiple cores thus needs to be able to initialise SMP. There is, however, no .smp entry in the MACHINE_START struct for REALVIEW_EB. This patch adds the appropriate .smp entry to this struct. Signed-off-by: Steve Capper <steve.capper@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-10-13ARM: config: sort select statements alphanumericallyRussell King
As suggested by Andrew Morton: This is a pet peeve of mine. Any time there's a long list of items (header file inclusions, kconfig entries, array initalisers, etc) and someone wants to add a new item, they *always* go and stick it at the end of the list. Guys, don't do this. Either put the new item into a randomly-chosen position or, probably better, alphanumerically sort the list. lets sort all our select statements alphanumerically. This commit was created by the following perl: while (<>) { while (/\\\s*$/) { $_ .= <>; } undef %selects if /^\s*config\s+/; if (/^\s+select\s+(\w+).*/) { if (defined($selects{$1})) { if ($selects{$1} eq $_) { print STDERR "Warning: removing duplicated $1 entry\n"; } else { print STDERR "Error: $1 differently selected\n". "\tOld: $selects{$1}\n". "\tNew: $_\n"; exit 1; } } $selects{$1} = $_; next; } if (%selects and (/^\s*$/ or /^\s+help/ or /^\s+---help---/ or /^endif/ or /^endchoice/)) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } undef %selects; } print; } if (%selects) { foreach $k (sort (keys %selects)) { print "$selects{$k}"; } } It found two duplicates: Warning: removing duplicated S5P_SETUP_MIPIPHY entry Warning: removing duplicated HARDIRQS_SW_RESEND entry and they are identical duplicates, hence the shrinkage in the diffstat of two lines. We have four testers reporting success of this change (Tony, Stephen, Linus and Sekhar.) Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-10-01Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM soc multiplatform enablement from Olof Johansson: "This is a pretty significant branch. It's the introduction of the first multiplatform support on ARM, and with this (and the later branch) merged, it is now possible to build one kernel that contains support for highbank, vexpress, mvebu, socfpga, and picoxcell. More platforms will be convered over in the next few releases. Two critical last things had to be done for this to be practical and possible: * Today each platform has its own include directory under mach-<mach>/include/mach/*, and traditionally that is where a lot of driver/platform shared definitions have gone, such as platform data structures. They now need to move out to a common location instead, and this branch moves a large number of those out to include/linux/platform_data. * Each platform used to list the device trees to compile for its boards in mach-<mach>/Makefile.boot. Both of the above changes will mean that there are some merge conflicts to come (and some to resolve here). It's a one-time move and once it settles in, we should be good for quite a while. Sorry for the overhead." Fix conflicts as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits) ARM: add v7 multi-platform defconfig ARM: msm: Move core.h contents into common.h ARM: highbank: call highbank_pm_init from .init_machine ARM: dtb: move all dtb targets to common Makefile ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ...
2012-10-01Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc driver specific changes from Olof Johansson: - A long-coming conversion of various platforms to a common LED infrastructure - AT91 is moved over to use the newer MCI driver for MMC - Pincontrol conversions for samsung platforms - DT bindings for gscaler on samsung - i2c driver fixes for tegra, acked by i2c maintainer Fix up conflicts as per Olof. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) drivers: bus: omap_l3: use resources instead of hardcoded irqs pinctrl: exynos: Fix wakeup IRQ domain registration check pinctrl: samsung: Uninline samsung_pinctrl_get_soc_data pinctrl: exynos: Correct the detection of wakeup-eint node pinctrl: exynos: Mark exynos_irq_demux_eint as inline pinctrl: exynos: Handle only unmasked wakeup interrupts pinctrl: exynos: Fix typos in gpio/wkup _irq_mask pinctrl: exynos: Set pin function to EINT in irq_set_type of GPIO EINTa drivers: bus: Move the OMAP interconnect driver to drivers/bus/ i2c: tegra: dynamically control fast clk i2c: tegra: I2_M_NOSTART functionality not supported in Tegra20 ARM: tegra: clock: remove unused clock entry for i2c ARM: tegra: clock: add connection name in i2c clock entry i2c: tegra: pass proper name for getting clock ARM: tegra: clock: add i2c fast clock entry in clock table ARM: EXYNOS: Adds G-Scaler device from Device Tree ARM: EXYNOS: Add clock support for G-Scaler ARM: EXYNOS: Enable pinctrl driver support for EXYNOS4 device tree enabled platform ARM: dts: Add pinctrl node entries for SAMSUNG EXYNOS4210 SoC ARM: EXYNOS: skip wakeup interrupt setup if pinctrl driver is used ...
2012-10-01Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM soc general cleanups from Olof Johansson: "This is a large branch that contains a handful of different cleanups: - Fixing up the I/O space remapping on PCI on ARM. This is a series from Rob Herring that restructures how all pci devices allocate I/O space, and it's part of the work to allow multiplatform kernels. - A number of cleanup series for OMAP, moving and removing some headers, sparse irq rework and in general preparation for multiplatform. - Final removal of all non-DT boards for Tegra, it is now device-tree-only! - Removal of a stale platform, nxp4008. It's an old mobile chipset that is no longer in use, and was very likely never really used with a mainline kernel. We have not been able to find anyone interested in keeping it around in the kernel. - Removal of the legacy dmaengine driver on tegra + A handful of other things that I haven't described above." Fix up some conflicts with the staging tree (and because nxp4008 was removed) * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (184 commits) ARM: OMAP2+: serial: Change MAX_HSUART_PORTS to 6 ARM: OMAP4: twl-common: Support for additional devices on i2c1 bus ARM: mmp: using for_each_set_bit to simplify the code ARM: tegra: harmony: fix ldo7 regulator-name ARM: OMAP2+: Make omap4-keypad.h local ARM: OMAP2+: Make l4_3xxx.h local ARM: OMAP2+: Make l4_2xxx.h local ARM: OMAP2+: Make l3_3xxx.h local ARM: OMAP2+: Make l3_2xxx.h local ARM: OMAP1: Move irda.h from plat to mach ARM: OMAP2+: Make hdq1w.h local ARM: OMAP2+: Make gpmc-smsc911x.h local ARM: OMAP2+: Make gpmc-smc91x.h local ARM: OMAP1: Move flash.h from plat to mach ARM: OMAP2+: Make debug-devices.h local ARM: OMAP1: Move board-voiceblue.h from plat to mach ARM: OMAP1: Move board-sx1.h from plat to mach ARM: OMAP2+: Make omap-wakeupgen.h local ARM: OMAP2+: Make omap-secure.h local ARM: OMAP2+: Make ctrl_module_wkup_44xx.h local ...
2012-09-22Merge branch 'multiplatform/smp_ops' into next/multiplatformOlof Johansson
* multiplatform/smp_ops: ARM: consolidate pen_release instead of having per platform definitions ARM: smp: Make SMP operations mandatory ARM: SoC: convert spear13xx to SMP operations ARM: SoC: convert imx6q to SMP operations ARM: SoC: convert highbank to SMP operations ARM: SoC: convert shmobile SMP to SMP operations ARM: SoC: convert ux500 to SMP operations ARM: SoC: convert MSM to SMP operations ARM: SoC: convert Exynos4 to SMP operations ARM: SoC: convert Tegra to SMP operations ARM: SoC: convert OMAP4 to SMP operations ARM: SoC: convert VExpress/RealView to SMP operations ARM: SoC: add per-platform SMP operations Conflicts due to file moves or removals in: arch/arm/mach-msm/board-msm8960.c arch/arm/mach-msm/board-msm8x60.c arch/arm/mach-tegra/board-harmony.c arch/arm/mach-tegra/board-trimslice.c Conflicts due to board file cleanup: arch/arm/mach-tegra/board-paz00.c Conflicts due to cpu hotplug addition: arch/arm/mach-tegra/hotplug.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-20Merge tag 'multi-platform-for-3.7' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/multiplatform Enable initial ARM multi-platform support for highbank, mvebu, socfpga, picoxcell, and vexpress. Multi-platform support is dependent on mach/gpio.h removal and restructuring of DEBUG_LL and dtb build rules included in this branch. This has been built for all defconfigs, and booted on highbank with all 5 platforms enabled. By Rob Herring (18) and Arnd Bergmann (1) via Rob Herring * tag 'multi-platform-for-3.7' of git://sources.calxeda.com/kernel/linux: ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ARM: orion: move custom gpio functions to orion-gpio.h ARM: shmobile: move custom gpio functions to sh-gpio.h ARM: pxa: use gpio_to_irq for sharppm_sl net: pxaficp_ir: add irq resources usb: pxa27x_udc: remove IRQ_USB define staging: ste_rmi4: remove gpio.h include Conflicts due to addition of bcm2835 and removal of pnx4008 in: arch/arm/Kconfig arch/arm/Makefile Conflicts due to new dtb targets, moved to arch/arm/boot/dts/Makefile in: arch/arm/mach-imx/Makefile.boot arch/arm/mach-mxs/Makefile.boot arch/arm/mach-tegra/Makefile.boot Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-20Merge branch 'next/dt' into next/multiplatformOlof Johansson
* next/dt: (182 commits) ARM: tegra: Add Avionic Design Tamonten Evaluation Carrier support ARM: tegra: Add Avionic Design Medcom-Wide support ARM: tegra: Add Avionic Design Plutux support ARM: tegra: Add Avionic Design Tamonten support ARM: tegra: dts: Add pwm label ARM: dt: tegra: whistler: configure power off ARM: mxs: m28evk: Disable OCOTP OUI loading ARM: imx6q: use pll2_pfd2_396m as the enfc_sel's parent ARM: dts: imx6q-sabrelite: add usbotg pinctrl support ARM: dts: imx23-olinuxino: Add USB host support ARM: dts: imx6q-sabrelite: add usbmisc device ARM: dts: mx23: Add USB resources ARM: dts: mxs: Add ethernetX to macX aliases ARM: msm: Remove non-DT targets from 8960 ARM: msm: Add DT support for 8960 ARM: msm: Move io mapping prototypes to common.h ARM: msm: Rename board-msm8x60 to signify its DT only status ARM: msm: Make 8660 a DT only target ARM: msm: Move 8660 to DT timer ARM: msm: Add DT support to msm_timer ...
2012-09-14ARM: make mach/gpio.h headers optionalRob Herring
Most platforms don't need mach/gpio.h and it prevents multi-platform kernel images. Add CONFIG_NEED_MACH_GPIO_H and make platforns select it if they need gpio.h. This is platforms that define __GPIOLIB_COMPLEX or have lots of implicit includes pulled in by mach/gpio.h. at91 and omap have gpio clean-up pending and can drop CONFIG_NEED_MACH_GPIO_H once that is in. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-14ARM: consolidate pen_release instead of having per platform definitionsMarc Zyngier
Almost each SMP platform defines pen_release to manage booting secondary CPUs. This of course clashes with the single zImage effort. Add the pen_release definition to the ARM SMP code, and remove all others. This should only be used by platforms which lack any kind of CPU power management... Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-09-13ARM: SoC: convert VExpress/RealView to SMP operationsMarc Zyngier
Convert both Realview and VExpress to use struct smp_operations to provide their SMP and CPU hotplug operation. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-08-24clk: convert ARM RealView to common clkLinus Walleij
This converts the ARM RealView machine over to using the common clock. The approach is similar to the one used for the Integrator, and we're reusing the ICST wrapper code. We have to put the clock intialization in the timer init function for the clocks to be available when initializing the timer, keeping them in early_init() is too early for the common clk. Since we now have to go down and compile drivers/clk/versatile a CONFIG_COMMON_CLK_VERSATILE symbol has been added so the proper code gets compiled into the kernel for either machine. A leftover CLK_VERSATILE in the Integrator Kconfig was fixed up to use the new symbol as well. Tested on ARM RealView PB1176. Cc: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-08-23ARM: pmu: remove arm_pmu_type enumerationSudeep KarkadaNagesha
The arm_pmu_type enumeration was initially introduced to identify different PMU types in the system, the usual one being that on the CPU (ARM_PMU_DEVICE_CPU). With the removal of the PMU reservation code and the introduction of devicetree bindings for the CPU PMU, the enumeration is no longer required. This patch removes the enumeration and updates the various CPU PMU platform devices so that they no longer pass an .id field referring to identify the PMU type. Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Olof Johansson <olof@lixom.net> Cc: Pawel Moll <pawel.moll@arm.com> Acked-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Sudeep KarkadaNagesha <Sudeep.KarkadaNagesha@arm.com> [will: cosmetic edits and actual removal of the enum type] Signed-off-by: Will Deacon <will.deacon@arm.com>
2012-08-01ARM: mach-realview and mach-versatile: retire custom LED codeBryan Wu
This replaces the custom LED trigger code in mach-realview with some overarching platform code for the plat-versatile family that will lock down LEDs 2 thru 5 for CPU activity indication. The day we have 8 core ARM systems the plat-versatile code will have to become more elaborate. Tested on RealView PB11MPCore by invoking four different CPU hogs (yes > /dev/null&) and see the LEDs go on one at a time. They all go off as the hogs are killed. Tested on the PB1176 as well - just one activity led (led 2) goes on and off with CPU activity. (bryan.wu@canonical.com: use ledtrig-cpu instead of ledtrig-arm-cpu) Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Bryan Wu <bryan.wu@canonical.com> Acked-by: Pawel Moll <pawel.moll@arm.com>
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-03-28ARM: move CP15 definitions to separate header fileRussell King
Avoid namespace conflicts with drivers over the CP15 definitions by moving CP15 related prototypes and definitions to a private header file. Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> [Tegra] Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> [EP93xx] Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-27Merge tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: timer cleanup work" from Arnd Bergmann: "These are split out from the generic soc and driver updates because there was a lot of conflicting work by multiple people. Marc Zyngier worked on simplifying the "localtimer" interfaces, and some of the platforms are touching the same code as they move to device tree based booting. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" * tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (61 commits) ARM: tegra: select USB_ULPI if USB is selected arm/tegra: pcie: fix return value of function ARM: ux500: fix compilation after local timer rework ARM: shmobile: remove additional __io() macro use ARM: local timers: make the runtime registration interface mandatory ARM: local timers: convert MSM to runtime registration interface ARM: local timers: convert exynos to runtime registration interface ARM: smp_twd: remove old local timer interface ARM: imx6q: convert to twd_local_timer_register() interface ARM: highbank: convert to twd_local_timer_register() interface ARM: ux500: convert to twd_local_timer_register() interface ARM: shmobile: convert to twd_local_timer_register() interface ARM: tegra: convert to twd_local_timer_register() interface ARM: plat-versatile: convert to twd_local_timer_register() interface ARM: OMAP4: convert to twd_local_timer_register() interface ARM: smp_twd: add device tree support ARM: smp_twd: add runtime registration support ARM: local timers: introduce a new registration interface ARM: smp_twd: make local_timer_stop a symbol instead of a #define ARM: mach-shmobile: default to no earlytimer ...
2012-03-23Merge branch 'amba' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #2 ARM updates from Russell King: "Further ARM AMBA primecell updates which aren't included directly in the previous commit. I wanted to keep these separate as they're touching stuff outside arch/arm/." * 'amba' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7362/1: AMBA: Add module_amba_driver() helper macro for amba_driver ARM: 7335/1: mach-u300: do away with MMC config files ARM: 7280/1: mmc: mmci: Cache MMCICLOCK and MMCIPOWER register ARM: 7309/1: realview: fix unconnected interrupts on EB11MP ARM: 7230/1: mmc: mmci: Fix PIO read for small SDIO packets ARM: 7227/1: mmc: mmci: Prepare for SDIO before setting up DMA job ARM: 7223/1: mmc: mmci: Fixup use of runtime PM and use autosuspend ARM: 7221/1: mmc: mmci: Change from using legacy suspend ARM: 7219/1: mmc: mmci: Change vdd_handler to a generic ios_handler ARM: 7218/1: mmc: mmci: Provide option to configure bus signal direction ARM: 7217/1: mmc: mmci: Put power register deviations in variant data ARM: 7216/1: mmc: mmci: Do not release spinlock in request_end ARM: 7215/1: mmc: mmci: Increase max_segs from 16 to 128
2012-03-21Merge branch 'tegra/cleanups' into next/timerArnd Bergmann
Conflicts: arch/arm/mach-tegra/Makefile arch/arm/mach-vexpress/core.h The tegra Makefile was changed in four different branches in the same line. This merge should reduce the amount of churn. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-13ARM: __io abuse cleanupRob Herring
Several platforms incorrectly use __io() for casting to 'void __iomem *'. This converts all of those uses to use the common IOMEM macro. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: linux-sh@vger.kernel.org Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-03-13ARM: plat-versatile: convert to twd_local_timer_register() interfaceMarc Zyngier
Add support for the new smp_twd runtime registration interface to the RealView/VE platforms, and remove the old compile-time support. Tested on EB11MP. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2012-03-06ARM: remove bunch of now unused mach/io.h filesRob Herring
Now that many platforms don't need mach/io.h, remove the unused ones. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-02-07Merge tag 'v3.3-rc2' into depends/rmk/for-armsocOlof Johansson
There were conflicts between fixes going in after 3.3-rc1 and Russell's stable arm-soc base branch. Resolving it in the dependency branch so that each topic branch shares the same resolution. Conflicts: arch/arm/mach-at91/at91cap9.c arch/arm/mach-at91/at91sam9g45.c
2012-02-02ARM: 7309/1: realview: fix unconnected interrupts on EB11MPMarc Zyngier
Since commit 2eac58d (ARM: amba: make use of -1 IRQs warn), we're able to detect the use of value -1 to indicate the lack of interrupt line. The RealView EB, when used with the 11MPCore tile, has a number of devices without interrupts, and uses the value -1 to indicate this. Change that value to 0 to conform to the new behaviour. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
