[ Upstream commit d1558dfd9f22c99a5b8e1354ad881ee40749da89 ]
A number of the Rockchip-specific drivers (IOMMU, display controllers)
are now assuming that CONFIG_PM is set, and may completely misbehave
if that's not the case.
Since there is hardly any reason for this configuration option not
to be selected anyway, let's require it (in the same way Tegra already
does).
Pull ARM updates from Russell King:
"Low priority fixes and updates for ARM:
- add some missing includes
- efficiency improvements in system call entry code when tracing is
enabled
- ensure ARMv6+ is always built as EABI
- export save_stack_trace_tsk()
- fix fatal signal handling during mm fault
- build translation table base address register from scratch
- appropriately align the .data section to a word boundary where we
rely on that data being word aligned"
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8691/1: Export save_stack_trace_tsk()
ARM: 8692/1: mm: abort uaccess retries upon fatal signal
ARM: 8690/1: lpae: build TTB control register value from scratch in v7_ttb_setup
ARM: align .data section
ARM: always enable AEABI for ARMv6+
ARM: avoid saving and restoring registers unnecessarily
ARM: move PC value into r9
ARM: obtain thread info structure later
ARM: use aliases for registers in entry-common
ARM: 8689/1: scu: add missing errno include
ARM: 8688/1: pm: add missing types include
* next/cleanup:
soc: versatile: remove unnecessary static in realview_soc_probe()
ARM: Convert to using %pOF instead of full_name
ARM: hisi: Fix typo in comment
ARM: OMAP4+: PRM: fix of_irq_get() result checks
ARM: OMAP3+: PRM: fix of_irq_get() result check
ARM: dts: dra72-evm-revc: workaround incorrect DP83867 RX_CTRL pin strap
ARM: dts: dra71-evm: workaround incorrect DP83867 RX_CTRL pin strap
ARM: OMAP2+: omap_device: drop broken RPM status update from suspend_noirq
bus: omap-ocp2scp: Fix error handling in omap_ocp2scp_probe
Now that we have a custom printf format specifier, convert users of
full_name to use %pOF instead. This is preparation to remove storing
of the full path string for each node.
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Javier Martinez Canillas <javier@osg.samsung.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Robert Jarzmik reports that his PXA25x system fails to boot with 4.12,
failing at __flush_whole_cache in arch/arm/mm/proc-xscale.S:215:
0xc0019e20 <+0>: ldr r1, [pc, #788]
0xc0019e24 <+4>: ldr r0, [r1] <== here
with r1 containing 0xc06f82cd, which is the address of "clean_addr".
Examination of the System.map shows:
c06f22c8 D user_pmd_table
c06f22cc d __warned.19178
c06f22cd d clean_addr
indicating that a .data.unlikely section has appeared just before the
.data section from proc-xscale.S. According to objdump -h, it appears
that our assembly files default their .data alignment to 2**0, which
is bad news if the preceding .data section size is not power-of-2
aligned at link time.
Add the appropriate .align directives to all assembly files in arch/arm
that are missing them where we require an appropriate alignment.
Reported-by: Robert Jarzmik <robert.jarzmik@free.fr>
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Rockchip RK3288 has some 64-bit capable DMA and therefore needs
dma_addr_t to be a 64-bit size. One user is the Mali GPU.
Signed-off-by: Tao Huang <huangtao@rock-chips.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Most IP cores on ARM Rockchip platforms can only address 32 bits of
physical memory for DMA. Thus ZONE_DMA should be enabled when LPAE
is activated.
Commit a53e35db70d1 ("reset: Ensure drivers are explicit when requesting
reset lines") started to transition the reset control request API calls
to explicitly state whether the driver needs exclusive or shared reset
control behavior. Convert all drivers requesting exclusive resets to the
explicit API call so the temporary transition helpers can be removed.
No functional changes.
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: linux-rockchip@lists.infradead.org
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Pull ARM SoC platform updates from Arnd Bergmann:
"SoC platform changes (arch/arm/mach-*). This merge window, the bulk is
for a few platforms:
- Andres Färber adds initial support for the Actions Semi S500 (aka
'owl') platform, a close relative of the S900 platform he adds for
arm64.
- in mach-omap2, we remove more legacy code
- Rockchips gains support for the RV1108 SoC designed for camera
applications.
- For Atmel, we gain support for MMU-less SoCs (SAME70/V71/S70/V70)
- Minor updates for other platforms, including davinci, s3c64xx,
prima2, stm32, broadcom nsp, amlogic, pxa, imx and renesas"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (74 commits)
ARM: owl: smp: Drop bogus holding pen
ARM: owl: Drop custom machine
ARM: owl: smp: Implement SPS power-gating for CPU2 and CPU3
soc: actions: owl-sps: Factor out owl_sps_set_pg() for power-gating
soc: actions: Add Owl SPS
dt-bindings: power: Add Owl SPS power domains
MAINTAINERS: Update Actions Semi section with SPS
ARM: owl: Implement CPU enable-method for S500
MAINTAINERS: Add Actions Semi Owl section
ARM: Prepare Actions Semi S500
ARM: socfpga: Increase max number of GPIOs
ARM: stm32: Introduce MACH_STM32F469 flag
ARM: prima2: remove redundant select CPU_V7
ARM: davinci: fix const warnings
ARM: shmobile: pm-rmobile: Use GENPD_FLAG_ALWAYS_ON
ARM: OMAP4: hwmod_data: add SHAM crypto accelerator
ARM: OMAP4: hwmod data: add des
ARM: OMAP4: hwmod data: add aes2
ARM: OMAP4: hwmod data: add aes1
ARM: pxa: Delete an error message for a failed memory allocation in pxa3xx_u2d_probe()
The function name is now renamed to 'timer_probe' for consistency with
the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Add a rockchip,rv1108 compatible.
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
[rk1108->rv1108 rename]
- nommu updates from Afzal Mohammed cleaning up the vectors support
- allow DMA memory "mapping" for nommu Benjamin Gaignard
- fixing a correctness issue with R_ARM_PREL31 relocations in the
module linker
- add strlen() prototype for the decompressor
- support for DEBUG_VIRTUAL from Florian Fainelli
- adjusting memory bounds after memory reservations have been
registered
- unipher cache handling updates from Masahiro Yamada
- initrd and Thumb Kconfig cleanups
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (23 commits)
ARM: mm: round the initrd reservation to page boundaries
ARM: mm: clean up initrd initialisation
ARM: mm: move initrd init code out of arm_memblock_init()
ARM: 8655/1: improve NOMMU definition of pgprot_*()
ARM: 8654/1: decompressor: add strlen prototype
ARM: 8652/1: cache-uniphier: clean up active way setup code
ARM: 8651/1: cache-uniphier: include <linux/errno.h> instead of <linux/types.h>
ARM: 8650/1: module: handle negative R_ARM_PREL31 addends correctly
ARM: 8649/2: nommu: remove Hivecs configuration is asm
ARM: 8648/2: nommu: display vectors base
ARM: 8647/2: nommu: dynamic exception base address setting
ARM: 8646/1: mmu: decouple VECTORS_BASE from Kconfig
ARM: 8644/1: Reduce "CPU: shutdown" message to debug level
ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbol
ARM: 8640/1: Add support for CONFIG_DEBUG_VIRTUAL
ARM: 8639/1: Define KERNEL_START and KERNEL_END
ARM: 8638/1: mtd: lart: Rename partition defines to be prefixed with PART_
ARM: 8637/1: Adjust memory boundaries after reservations
ARM: 8636/1: Cleanup sanity_check_meminfo
ARM: add CPU_THUMB_CAPABLE to indicate possible Thumb support
All low-level PM/SMP code using virt_to_phys() should actually use
__pa_symbol() against kernel symbols. Update code where relevant to move
away from virt_to_phys().
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
We moved that functionality to a more generic place where it can also
be used for other socs, so drop it from architecture code.
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Shawn Lin <shawn.lin@rock-chips.com>
Pull ARM SoC cleanups from Olof Johansson:
"The cleanup branch keeps going down in size as we've completed a lot
of the major legacy platform removals and conversions.
A handful of changes this time around, some of the themes or larger
sets are:
- A bunch of i.MX cleanups around platform detection, init call cleanups
- Misc fixes of missing/implicit includes
- Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
ARM: mps2: fix typo
ARM: s3c64xx: avoid warning about 'struct device_node'
bus: mvebu-mbus: make mvebu_mbus_syscore_ops static
bus: mvebu-mbus: fix __iomem on register pointers
ARM: tegra: Remove board_init_funcs array
ARM: iop: Fix indentation
ARM: imx: remove cpu_is_mx*()
ARM: imx: remove last call to cpu_is_mx5*
ARM: imx: rework mx27_pm_init() call
ARM: imx: deconstruct mx3_idle
ARM: imx: deconstruct mxc_rnga initialization
ARM: imx: remove cpu_is_mx1 check
ARM: i.MX: Do not explicitly call l2x0_of_init()
ARM: i.MX: system.c: Tweak prefetch settings for performance
ARM: i.MX: system.c: Replace magic numbers
ARM: i.MX: system.c: Remove redundant errata 752271 code
ARM: i.MX: system.c: Convert goto to if statement
ARM: Kirkwood: fix kirkwood_pm_init() declaration/type
ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static
ARM: orion5x: make orion5x_legacy_handle_irq static
After patch "of/platform: Add common method to populate default bus",
it is possible for arch code to remove unnecessary callers of
of_platform_populate with default match table.
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Lee Jones <lee@kernel.org>
Cc: Krzysztof Halasa <khalasa@piap.pl>
Cc: Rob Herring <robh@kernel.org>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Santosh Shilimkar <ssantosh@kernel.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Viresh Kumar <vireshk@kernel.org>
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
Cc: Tony Prisk <linux@prisktech.co.nz>
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
This replaces:
- "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can
now be selected directly.
- "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB
is now selectable by everyone, so we need not declare our
intent to select it.
When ordering the symbols the following rationale was used:
if the selects were in alphabetical order, I moved select GPIOLIB
to be in alphabetical order, but if the selects were not
maintained in alphabetical order, I just replaced
"select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB".
Cc: Michael Büsch <m@bues.ch>
Cc: arm@kernel.org
Pull ARM SoC cleanups and fixes from Arnd Bergmann:
"Traditionally we've had two separate branches for cleanups and
non-critical bug fixes, but both of these got smaller with each
release and the differences are rather unclear now, so it seems more
appropriate to have a combined branch.
The most notable change is for OMAP, which gets a small rework to
simplify handling of the AUXDATA mechanism used on machines that are
not completely DT based yet, along with other work that is used as
preparation for dropping the legacy board files"
* tag 'armsoc-cleanups-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: dts: exynos: Add interrupt line to MAX8997 PMIC on exynos4210-trats
ARM: dts: exynos: Fix regulator name to avoid forbidden character on exynos4210-trats
ARM: dts: exynos: Add MFC memory banks for Peach boards
ARM: OMAP2+: n900 needs MMC slot names for legacy user space
ARM: OMAP2+: Add more functions to pwm pdata for ir-rx51
ARM: debug: remove extraneous DEBUG_HI3716_UART option
ARM: OMAP2+: Simplify auxdata by using the generic match
of/platform: Allow secondary compatible match in of_dev_lookup
ARM: davinci: use IRQCHIP_DECLARE for cp_intc
ARM: davinci: remove unused DA8XX_NUM_UARTS
ARM: davinci: simplify call to of populate
ARM: DaVinci USB: removed deprecated properties from MUSB config
ARM: rockchip: Fix use of plain integer as NULL pointer
ARM: realview: hide unused 'pmu_device' object
soc: versatile: dynamically detect RealView HBI numbers
This patch add rockchip's compatible string to the compat list and
remove similar code from platform code for supporting generic platdev
driver.
Signed-off-by: Finley Xiao <finley.xiao@rock-chips.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
This fixes the following sparse build warning:
mach-rockchip/platsmp.c:68:43: Using plain integer as NULL pointer
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Merge in cleanup to avoid internal conflicts with newly added code.
* treewide/cleanup:
ARM: use "depends on" for SoC configs instead of "if" after prompt
ARM/clocksource: use automatic DT probing for ux500 PRCMU
ARM: use const and __initconst for smp_operations
ARM: hisi: do not export smp_operations structures
Add a rockchip,rk3228 compatible.
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
The newly added rk3036 smp operations missed the wholesale fixup from
Masahiro Yamada. So fix that now.
Reported-by: Mark Brown <broonie@kernel.org>
Many ARM sub-architectures use prompts followed by "if" conditional,
but it is wrong.
Please notice the difference between
config ARCH_FOO
bool "Foo SoCs" if ARCH_MULTI_V7
and
config ARCH_FOO
bool "Foo SoCs"
depends on ARCH_MULTI_V7
These two are *not* equivalent!
In the former statement, it is not ARCH_FOO, but its prompt that
depends on ARCH_MULTI_V7. So, it is completely valid that ARCH_FOO
is selected by another, but ARCH_MULTI_V7 is still disabled. As it is
not unmet dependency, Kconfig never warns. This is probably not what
you want.
The former should be used only when you need to do so, and you really
understand what you are doing. (In most cases, it should be wrong!)
For enabling/disabling sub-architectures, the latter is always correct.
As a good side effect, this commit fixes some entries over 80 columns
(mach-imx, mach-integrator, mach-mbevu).
[Arnd: I note that there is not really a bug here, according to
the discussion that followed, but I can see value in being consistent
and in making the lines shorter]
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Jun Nie <jun.nie@linaro.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Krzysztof Halasa <khc@piap.pl>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
The dual-core Cortex A7 rk3036 is a bit special in that it does not allow
to control the actual powerdomain of the cpu cores, while the rest of the
smp-bringup like reset control and entry address handling stays the same.
Its bigger sibling, the quad-core rk3128 again allows powerdomain control.
So allow that case by introducing a separate smp-enable-method, that simply
disables powerdomain handling in the common code.
Tested-by: Xing Zheng <zhengxing@rock-chips.com>
Acked-by: Rob Herring <robh@kernel.org>
Seeing the 'of' characters in a symbol that is being called from
ACPI seems to freak out people. So let's do a bit of pointless
renaming so that these folks do feel at home.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Hanjun Guo <hanjun.guo@linaro.org>
PTR_ERR should access the value just tested by IS_ERR.
The semantic patch that makes this change is available
in scripts/coccinelle/tests/odd_ptr_err.cocci.
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
PMU_GPIOINT_WAKEUP_EN seems needed when entering the shallow suspend
(with logic staying on) but does not seem to be needed for the deep
suspend for unknown reasons.
Testing revealed that this setting really is necessary to reliably
resume the veyron devices from suspend.
Reported-by: Chris Zhong <zyw@rock-chips.com>
Reviewed-by: Chris Zhong <zyw@rock-chips.com>
Tested-by: Chris Zhong <zyw@rock-chips.com>
Currently the stabilization thresholds for the oscillator and external pmu
are statically set to 30ms based on a 32kHz clock rate. This leaves out the
case when we don't switch to the 32kHz clock when only entering the shallow
suspend mode where the logic keeps running.
So, set the correct threshold after we have determined if we switch to the
32kHz clock or stay with the 24MHz one. Also set the oscillator-
stabilization to 0 if it is kept running during suspend, as it of course
does not need to stabilize then.
The variable name is misleading, as the deep suspend mode always switches
the main supplying clock to the 32kHz source. Additionally the main
oscillator remains running in some cases, which this var indicates.
So rename it to osc_disable to clarity.
The following was seen in branch[0] build.
arch/arm/mach-rockchip/platsmp.c:154:23: error:
'rockchip_secondary_startup' undeclared (first use in this function)
branch[0]:
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip.git
v4.3-armsoc/soc
The broken build is caused by the commit fe4407c0dc58
("ARM: rockchip: fix the CPU soft reset").
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
The breakage was a result of it being wrongly merged in my branch with
the cache invalidation rework from Russell 02b4e2756e01c
("ARM: v7 setup function should invalidate L1 cache").
These are actually not used in the pm code, as we moved suspend handling
to the clock driver, remove them here.
Signed-off-by: Chris Zhong <zyw@rock-chips.com>
If we want to wake up system via usb, the 24Mhz osc could not be
disabled during suspend, read the usb phy SIDDQ bit to decide whether
to switch to 32khz clock-in.
Tested-by: Douglas Anderson <dianders@chromium.org>
Use the below scripts to check:
scripts/checkpatch.pl -f --subject arch/arm/mach-rockchip/platsmp.c
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
The patch can ensure that v7_exit_coherency_flush() in rockchip_cpu_die()
executed in time.
The mdelay(1) has enough time to fix the problem of CPU offlining.
That's a workaround way in rockchip hotplug code,
At least, we haven't a better way to solve it. Who know,
that maybe fixed by chip (hardware) in the future.
We need different orderings when turning a core on and turning a core
off. In one case we need to assert reset before turning power off.
In ther other case we need to turn power on and the deassert reset.
In general, the correct flow is:
CPU off:
reset_control_assert
regmap_update_bits(pmu, PMU_PWRDN_CON, BIT(pd), BIT(pd))
wait_for_power_domain_to_turn_off
CPU on:
regmap_update_bits(pmu, PMU_PWRDN_CON, BIT(pd), 0)
wait_for_power_domain_to_turn_on
reset_control_deassert
This is needed for stressing CPU up/down, as per:
cd /sys/devices/system/cpu/
for i in $(seq 10000); do
echo "================= $i ============"
for j in $(seq 100); do
while [[ "$(cat cpu1/online)$(cat cpu2/online)$(cat cpu3/online)" != "000"" ]]
echo 0 > cpu1/online
echo 0 > cpu2/online
echo 0 > cpu3/online
done
while [[ "$(cat cpu1/online)$(cat cpu2/online)$(cat cpu3/online)" != "111" ]]; do
echo 1 > cpu1/online
echo 1 > cpu2/online
echo 1 > cpu3/online
done
done
done
The following is reproducable log:
[34466.186812] PM: noirq suspend of devices complete after 0.669 msecs
[34466.186824] Disabling non-boot CPUs ...
[34466.187509] CPU1: shutdown
[34466.188672] CPU2: shutdown
[34473.736627] Kernel panic - not syncing:Watchdog detected hard LOCKUP on cpu 0
or others similar log:
[ 4072.454453] CPU1: shutdown
[ 4072.504436] CPU2: shutdown
[ 4072.554426] CPU3: shutdown
[ 4072.577827] CPU1: Booted secondary processor
[ 4072.582611] CPU2: Booted secondary processor
<hang>
Tested by cpu up/down scripts, the results told us need delay more time
before write the sram. The wait time is affected by many aspects
(e.g: cpu frequency, bootrom frequency, sram frequency, bus speed, ...).
Although the cpus other than cpu0 will write the sram, the speedy is
no the same as cpu0, if the cpu0 early wake up, perhaps the other cpus
can't startup. As we know, the cpu0 can wake up when the cpu1/2/3 write
the 'sram+4/8' and send the sev.
Anyway.....
At the moment, 1ms delay will be happy work for cpu up/down scripts test.
Reviewed-by: Doug Anderson <dianders@chromium.org>
Fixes: 3ee851e212d0 ("ARM: rockchip: add basic smp support for rk3288")
Cc: stable@vger.kernel.org
In the commit (0ea001d ARM: rockchip: disable dapswjdp during suspend)
we made the assumption that we didn't need to restore dapswjdp after
suspend because "the MASKROM will enable it back".
It turns out that's not a safe assumption. In some cases (pending
interrupts) it's possible that the WFI might act as a no-op and the
MaskROM will never run. Since we're changing the bit, we should
restore it ourselves.
Signed-off-by: Doug Anderson <dianders@chromium.org>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull __cpuinit removal from Paul Gortmaker:
"Remove __cpuinit macros and users.
We removed the __cpuinit stuff in 3.11-rc1 with commit 22f0a2736774
("init.h: remove __cpuinit sections from the kernel") but we left some
no-op stubs as a courtesy to unmerged code.
Here we get rid of the stubs as well, since (as can be seen in these
changes) they are enabling use cases to sneak back in, primarily from
older BSP code that has been living out of tree for some time prior to
getting mainlined. So we get rid of these "new" users 1st and then
get rid of the stubs.
Obviously, getting rid of the stubs can't happen until all the users
are gone, so I had to keep this together as a series, even though some
of these commits since got picked up into maintainers trees as well.
The nature of this change is such that it should have zero impact on
the generated runtime.
This is one of several independent cleanup branches aimed at enabling
better organization in the init.h and module.h code. They have been
getting coverage in the linux-next tree for the last month, in
addition to my local testing, which also covers approximately a half
dozen or more architectures"
* tag 'cpuinit-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
init: delete the __cpuinit related stubs
kernel/cpu.c: remove new instance of __cpuinit that crept back in
sched/core: remove __cpuinit section tag that crept back in.
mips/mm/tlbex: remove new instance of __cpuinit that crept back in
mips/c-r4k: remove legacy __cpuinit section that crept in
mips/bcm77xx: remove legacy __cpuinit sections that crept in
mips/ath25: remove legacy __cpuinit section that crept in
arm/mach-hisi: remove legacy __CPUINIT section that crept in
arm/mach-rockchip: remove legacy __cpuinit section that crept in
arm/mach-mvebu: remove legacy __cpuinit sections that crept in
arm/mach-keystone: remove legacy __cpuinit sections that crept in
Pull ARM SoC cleanups from Kevin Hilman:
"A relatively small setup of cleanups this time around, and similar to
last time the bulk of it is removal of legacy board support:
- OMAP: removal of legacy (non-DT) booting for several platforms
- i.MX: remove some legacy board files"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (36 commits)
ARM: fix EFM32 build breakage caused by cpu_resume_arm
ARM: 8389/1: Add cpu_resume_arm() for firmwares that resume in ARM state
mach-omap2: Remove use of deprecated marco, PTR_RET in devices.c
ARM: OMAP2+: Remove calls to deprecacted marco,PTR_RET in the files,fb.c and pmu.c
ARM: OMAP2+: Constify irq_domain_ops
ARM: OMAP2+: use symbolic defines for console loglevels instead of numbers
ARM: at91: remove useless Makefile.boot
ARM: at91: remove at91rm9200_sdramc.h
ARM: at91: remove mach/at91_ramc.h and mach/at91rm9200_mc.h
ARM: at91/pm: use the atmel-mc syscon defines
pcmcia: at91_cf: Use syscon to configure the MC/smc
ARM: at91: declare the at91rm9200 memory controller as a syscon
mfd: syscon: Add Atmel MC (Memory Controller) registers definition
ARM: at91: drop sam9_smc.c
ata: at91: use syscon to configure the smc
ARM: ux500: delete static resource defines
ARM: ux500: rename ux500_map_io
ARM: ux500: look up PRCMU resource from DT
ARM: ux500: kill off L2CC static map
We removed __cpuinit support (leaving no-op stubs) quite some time ago.
However this one crept back in as of commit a7a2b3118b410fb3cd3a8363b1
("ARM: rockchip: add smp bringup code").
Since we want to clobber the stubs soon, get this removed now.
http://ftp.arm.linux.org.uk/pub/armlinux/kernel/git-cur/linux-2.6-arm into next/cleanup
* 'for-arm-soc' of http://ftp.arm.linux.org.uk/pub/armlinux/kernel/git-cur/linux-2.6-arm:
All ARMv5 and older CPUs invalidate their caches in the early assembly
setup function, prior to enabling the MMU. This is because the L1
cache should not contain any data relevant to the execution of the
kernel at this point; all data should have been flushed out to memory.
This requirement should also be true for ARMv6 and ARMv7 CPUs - indeed,
these typically do not search their caches when caching is disabled (as
it needs to be when the MMU is disabled) so this change should be safe.
ARMv7 allows there to be CPUs which search their caches while caching is
disabled, and it's permitted that the cache is uninitialised at boot;
for these, the architecture reference manual requires that an
implementation specific code sequence is used immediately after reset
to ensure that the cache is placed into a sane state. Such
functionality is definitely outside the remit of the Linux kernel, and
must be done by the SoC's firmware before _any_ CPU gets to the Linux
kernel.
Changing the data cache clean+invalidate to a mere invalidate allows us
to get rid of a lot of platform specific hacks around this issue for
their secondary CPU bringup paths - some of which were buggy.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Thierry Reding <treding@nvidia.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Tested-by: Michal Simek <michal.simek@xilinx.com>
Tested-by: Wei Xu <xuwei5@hisilicon.com>
This reverts commit b403125d3bbf8046c1186e1a49cb17bb5551db14.
As reported by Chris, both commits
b403125 "ARM: rockchip: fix undefined instruction of reset_ctrl_regs"
0ea001d "ARM: rockchip: disable dapswjdp during suspend"
actually fix the same issue and b403125 is the older one, which got
superseded by 0ea001d. Therefore revert the obsolete one again.
timer7 supplies the architected timer and thus as has to run when
the system clocksource and clockevents drivers are registered.
While it should be the responsibility of the bootloader to do this,
and there exists a fix in a community u-boot, all u-boot based systems
that actually shipped have the mentioned issue.
Therefore to not require every developer to update their u-boot, add a
snippet for this, enabling the timer early in the kernel.
Sometimes the debug module may not work well after resume, since it has
not been correctly reset when wakeup from suspend. That cause system
crash during reusme, and a 'undefined instruction' is displayed on the
console. Set the GRF_FORCE_JTAG bit of RK3288_GRF_SOC_CON0 can ensure
that debug modul is reset. And we can change the value of
RK3288_GRF_SOC_CON0 back when system resume.
Tested-by: Caesar Wang <wxt@rock-chips.com>
According to discussions, there does not seem a better solution available.
Please also see the potential security implication described in the
comment inline in the code.
Reset dapswjdp is controlled by JTAG_TRSTN, if the iomux of this pin is
not "jtag_trstn". the AP would think this pin is always high, so it can
not reset before resume. When system resume, but the dapswjdp is not in
a default state, it may Access some illegal address, it cause system
crash during resume.
Let's disable this jtag function by clear the dapdeviceen bit, it
prohibit the dapswjdp to access memory and registers. This bit would
be enable in MASKROM, so we need clear it in suspend everytime.
The watchdog clock should be disable in dw_wdt_suspend, but we set a
dummy clock to watchdog for rk3288. So the watchdog will continue to
work during suspend. And we switch the system clock to 32khz from 24Mhz,
during suspend, so the watchdog timer over count will increase to
755 times, about 12.5 hours, the original value is 60 seconds. So
watchdog will reset the system over a night, but voltage are all
incorrect, then it hang on reset.
Signed-off-by: Daniel Kurtz <djkurtz@google.com>
Tested-by: Doug Anderson <dianders@chromium.org>
The register-default delay time for wait the 24MHz OSC stabilization as well
as PMU stabilization is 750ms, let's decrease them to a still safe 30ms.
